#91 | |
Postovi: 10,185
https://plus.google.com/+BensonLeung/posts/AxHVKXrdCD7 It has come to our attention that some units of the Anker PowerLine USB-C A8185011 may present technical issues, which could prevent the cable from performing at its full capacity or even cause damage to devices when used. Therefore, to ensure that all of our customers are getting only the best quality products from Anker, we are recalling all units of our Anker PowerLine USB-C A8185011 immediately. We'll be issuing a full refund and customers will be provided with a free cable once the problem has been resolved. In total, less than 150 customers have purchased this product and our support team have reached out to each of them individually via email.
#92 |
Postovi: 7,691
Pohvalno ![]() @edit Da li preko Amazona uključen shipping za Hrvatsku ( mislim direktno preko Aukey i Anker) Naime, mislio sam naručiti punjač Aukey 3-portni, a ono štanga "not shipping"
__________________ |
#93 |
Postovi: 10,185
Gledaj amazon.de gdje ces dobiti i obicni eu plug (sada postoji i sa sluzbenim engleskim jezikom) ili co.uk i .fr. Shipping inace nije u cijeni, a ako se logiras na amazon pisat ce ti pored itema dostavljaju li kod nas.
#95 |
Postovi: 3,507
Choetech?
Ima netko iskustava s kabelima marke Choetech? Na neku foru na aliexpressu mi search za USB-C s 56k otporom daje samo njihove kablove ![]() Naručen ovaj, uskoro treba doći, valjda se nisam zeznuo? https://www.aliexpress.com/item/USB-...738677522.html Kako stoji stvar s kablovima duljim od 1m, npr 1.5m, kakva su im svojstva? Treba mi prvenstveno za data sync na PC, a kad povučem odostraga na stol malo mi na knap. |
#96 | |
Postovi: 2,438
![]() Nisu na onoj zloglasnoj listi loših kablova... Kakva svojstva? Radit će... |
#97 |
Postovi: 10,185
Koristim iste od 1 do 3m modele (pisao u temi). Rade kako treba, koristim ih za punjenje, isporucuju urednih 2,8-3 ampera. Oni su ti na safe listi tako da...
#99 |
The mighty pirate
Lokacija: London
Postovi: 9,123
Uzeo sam nedavno Aukey, paket od 3 komada: https://www.amazon.de/gp/product/B01...?ie=UTF8&psc=1 Vrhunsko metalno kućište konektora, kabel je čvrst i fino umotan u bužir. Preporuka.
#100 |
freak
Postovi: 2,688
Uzeo preko Ebaya ovaj: http://www.ebay.com/itm/3m-Braided-U...item2375f8f1d9 1.5m, za LG G5. Već 6 mj s njim punim mob i prebacujem podatke. Sve u redu, puni kao i original kabal te prebacuje podatke istom brzinom. Također je kvalitetne izrade.
#101 | |
Postovi: 2,438
https://plus.google.com/102612254593917101378 +AUKEY Official (non-eMarked/3A) USB2.0 2m Type-C Charging Cable [Model CB-C19]. tl;dr: BAD cable. Shield intermittent/missing due to questionable manufacturing. Poor performance. +Anker PowerPort Speed PD 30w wall charger [Model A2014111]. tl;dr: Noncompliant charger. Printed and advertised levels do not match actual capabilities. Inconsistent overload protection. It may not work on certain laptops and high-power devices. +Anker PowerLine+ USB 2.0 C-to-C cord. [Model A8187091] tl;dr: Safe but middling quality at best. Packaging has nice fit and finish. But IR drop (.31v) is absolutely excessive. +AUKEY "24W" USB-PD Dual Port 12v car charger [Model CC-Y7]. tl;dr: Bad -- provable on two points, "spidey sense" on another (due to lack of test equipment). Mismatch in safety markings (24w) vs claimed capacity (36w), goes outside USB-PD voltage thresholds. CC line errors, dubious overload behavior. Ali, ne govorim o svim proizvodima ![]() Zadnje izmijenjeno od: gin.tonic. 21.12.2016. u 00:44. |
#102 | |
Postovi: 7,691
Sent from my Nexus 6P
#103 |
Lokacija: Cirkus
Postovi: 642
Uzet cu i ja ovaj Choetech, ali prvi put narucujem sa Aliexpress, i vidim nema opcije paypal za plaćanje, sto mi je jako čudno. Pa sam naručio kabal i platio Visa karticom, medjutim u medjuvremenu sam malo gledao po profilu prodavača i ugledao jos nesto od istog prodavača i da ne kupujem ponovo taj drugi predmet i placam na njega postarinu posebno trebao sam to fino sve u chart staviti i naručiti. U medjuvremenu sam 15min nakon plaćanja isao na cancel order. Vidim s kartice mi je vec skinilo taj iznos koji sam platio, koliko cu čekati refund da legne novac na kraticu, i dali treba ista osim samo cancel order uraditi, valjda se refound podrazumijeva. Navikao sam na ebay i paypal pa mi je ovo novo sve, ali mislim da cu ubuduce cesce kupovati preko Aliexpress, izbor je puno bolji, i aplikacija je miljama ispred ebay i sama stranica takodjer. Sent from my ONEPLUS A3003 using Tapatalk |
#104 |
Lika u mom srcu
Lokacija: Canada, Toronto
Postovi: 9,887
gdje je ta lista o dobrim kablovima? ja trebam naruciti par dugackih, ovi od 90cm su smijeh, pa ne mogu nista s tim, trebam 2 metra duzine, nesto USB C, a nesto obicnih Micro USB za tablete, te mi treba i lightning za iphone za punjenje u krevet, isto bar 2 metra. (10feet) |
#105 |
Lokacija: Cirkus
Postovi: 642
#106 |
Postovi: 3,507
Dobro da sam spomenuo choetech, jutros ga poštar donio, 14 dana je putovao. Kabel izgleda ok, nije naročito dobeo, dosta je čvrst, krut, fino opleten izvana, ne petlja se. Djeluje kvalitetno, konektori su čvrsti, nisu glomazni, USB-C seamless. Nije mi spalio komp kod data transfera niti mob kod uštekavanja na punjač, za dalje ćemo vidjeti ![]() |
#107 |
Postovi: 10,185
A sta poceli su raditi seamless metalni dio konektora? Ajde pohvalno, mene je jedino to brinulo po pitanju dugotrajnosti iako zasad izgledaju kao prvog dana. Volio bih da nisu tako zilavi ![]()
#108 |
Postovi: 3,507
Da. Sorry, ova druga slika malo ispala van fokusa ![]() Nego jel netko uzimao nešto od ove marke Ugreen na aliju? Imaju mi par zanimljivih stvari, a ne znam kakvi su. Usput, kod pretraživanja na Aliju dobra fora da nakon searcha posloži na vrh linkove po brandovima. |
#110 |
Postovi: 3,507
Ovaj je opleten izvana nekom sintetikom, pitam se koliko će to trajati. Samo pazi ako gledaš na slici na linku sa alija, bešavni je samo USB C strana. Slika im je kriva, druga strana ima šav, ali to ne me smeta, i drugi kablovi to imaju pa se nikad ništa nije potrgalo. |
#111 | |
Datum registracije: Dec 2015
Postovi: 1,044
Ja ga imam vec par miseci Kupio zajedno sa ovim punjacem http://m.geekbuying.com/item/Tronsma...ug-363290.html |
#112 |
jedan i jedini :D
Lokacija: novi zagreb
Postovi: 5,280
Ja kupio ovaj, komada 2 Look at this on eBay http://www.ebay.com/itm/282231430191 Jebat cu mu kevu ne bude li radio kako treba. |
#113 | |
Postovi: 2,438
A ne znam čemu toliko novaca dati za taj kabel i na testovima nije baš bio bajan ![]() |
#117 |
Postovi: 10,185
A gle, objavim oglas, prodajem fejk anker kablove, stavim 10 anker slika ali nijednu live, stavim cijenu malo vecu ali taman nizu da se ekipa zakaci, profit dok netko ne skuzi i pocbe pisati kako su fejk ![]() Ako mu je netko preporucio tog sellera i item, ili seller ima super feedback za taj item, nema dvojbe da je kabel ok!
#118 | |
Postovi: 2,438
#119 |
Postovi: 10,185
Aliexpress je smetje, tamo svaka fejk sd kartica ima odlican rejting Na ebayu feedback barem ima vise smisla (on je postao link sa ebaya gore).
