Staro 14.12.2016., 21:50   #2461
Tihomir111
ZeNgE_Tiho_Cro
Tihomir111's Avatar
Lokacija: Virovitica
Postovi: 466
Koliko sam shvatio, za to moram unlockat Voltage control i još one dvije postavke jel?
Ma jok. I ovo je više nego dosta
Ma jok, sam dodaj jos +125 na core i pusti heavens
Tihomir111 je offline   Reply With Quote
Staro 14.12.2016., 21:57   #2462
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
Autor Tihomir111 Pregled postova
Tako je! Bez 2150+ nisi nisa napravio
Bez potpisa.
Staro 15.12.2016., 18:28   #2463
Kaj dobijem sa 150 MHz više od 2000MHz na 1080p ?
Staro 15.12.2016., 19:48   #2464
dean225
DD9512
dean225's Avatar
Postovi: 1,869
Nist. 2 fpsa..
Čemu natezanje tako vrhunske grafe?
dean225 je offline   Reply With Quote
Staro 15.12.2016., 21:29   #2465
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
Autor dean225 Pregled postova
Nist. 2 fpsa..
Ali GRATIS!
Bez potpisa.
Staro 15.12.2016., 21:34   #2466
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
A niš. Veseli čovjeka vidjet 2160 Mhz na overlayu, ja sam prvi put kad sam taj broj vidio dobio geekgasm 😁
Pogotovo nakon 290X i clockova oko 1ghz
Staro 16.12.2016., 00:36   #2467
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
Ahahahaaha, budale
Bez potpisa.
Staro 16.12.2016., 01:45   #2468
Dottore
Dottore's Avatar
Postovi: 7,696
Može preporuka GTX 1060 6Gb? Nisam ih pratio u zadnje vrijeme.
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 16.12.2016., 02:07   #2469
Getriba94
Getriba94's Avatar
Datum registracije: Jun 2016
Postovi: 1,052
Autor Dottore Pregled postova
Dosta subjektivno
Ja sam odvagno na stranu MSI gaming x , nemam primjedbi , tiha jako...
Staro 16.12.2016., 08:00   #2470
Postovi: 10,218
Osobno isao na zotac amp, nakon pogledanih recenzija i pohvala na racun coolera. Zasad je solidna, ne razumijem se u te mhz boostove, nema whinea, i pristojne su joj temp. Bitnija mi je pasiva u idleu jer tad mi nijedan vent od kucista ne radi, grafa bude uvijek oko 40C +/-2C
Staro 16.12.2016., 11:22   #2471
Dottore
Dottore's Avatar
Postovi: 7,696
Autor Getriba94 Pregled postova
Dosta subjektivno
Može link modela? Asus, čini mi se lagano podbacio zbog nižeg takts i visoke cijene.
Autor xlr Pregled postova
Zotac? Ako se ne varam bili su problematični na 5xx ili 6xx seriji zbog ventilatora. To si uzeo preko uzi shopa? Dual fan?
Sent from my Nexus 6P
HP 845 G9
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 16.12.2016., 11:25   #2472
Getriba94
Getriba94's Avatar
Postovi: 1,052
https://www.centro.hr/msi-gf-gtx-106...ddr5-dx12.aspx
Vjerujem da je asus strix super grafa , ali samo zbog cijene ju nisam gledo.
Sent from my Xperia Z3
Staro 16.12.2016., 11:30   #2473
Tihomir111
ZeNgE_Tiho_Cro
Tihomir111's Avatar
Postovi: 466
Nist ne dobijes al dobijes overklok a ne onaj boost gore navedeni
Staro 16.12.2016., 13:05   #2474
Postovi: 10,218
Sve "da", osim problematicnosti. Nisam nis pratio od 2009. godine pa mogu reci "ne znam". Nisam citao da ovaj amp model ima nekih problema...
Prvi izbor mi je bila evga sc gaming model (dual fan). Dobavljivost je malo teza i ceka se, a kad mi je napokon stigla javili su mi da je ostecena u transportu. Nije mi se dalo vise cekati pa isao na drugi izbor
Staro 16.12.2016., 14:47   #2475
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,585
Getriba94 neraspoloživo. Prvo gdje ih vidim dostupne na nabavi je kod mađara za preko 2800kn, a u hr shopu preko 3200kn. Totalno neisplativo
Meni se best buy u ovom trenutku čine gigabajtice wf2 i g1, ima ih čak ispod 2500kn
I inno ichill isto oko 2500kn. Ima i jeftinijih naravno (oko 2200kn) ali su singe fan i/ili 2 god. garancije
Staro 16.12.2016., 15:15   #2476
Getriba94
Getriba94's Avatar
Postovi: 1,052
Sto se dogodilo , ja platio 2600
P.s. G1 ima 4god gare
Staro 16.12.2016., 15:29   #2477
Manuel Calavera
Postovi: 14,585
Gdje?
Staro 16.12.2016., 15:34   #2478
ODO
Datum registracije: Feb 2015
Postovi: 596
Nema G1, već Extreme.
ODO je offline   Reply With Quote
Staro 16.12.2016., 15:36   #2479
Getriba94
Getriba94's Avatar
Postovi: 1,052
Nisam skuzio sta sam napiso , mislim na "xtreme gaming"
uz registraciju +1god
http://www.futura-it.hr/katalog/komp...060xtreme-6gd/
p.s. Extreme ne postoji :P
Staro 16.12.2016., 15:49   #2480
Manuel Calavera
Postovi: 14,585
Svejedno mi je dati preko 2700kn za gtx 1060 6gb suludo. U suprotnom taboru ima nitro 480 8gb ispod 2200kn
Staro 16.12.2016., 15:58   #2481
Getriba94
Getriba94's Avatar
Postovi: 1,052
Je , al recimo ichill 300kn razlika , vec za razmislit (mislim da bu se prije prodala zbog fanboy-eva zelenaša )
Staro 16.12.2016., 16:13   #2482
Manuel Calavera
Postovi: 14,585
Mooožda radi garancije, inače su već su i G1 i ichill badass cooleri za takav čip
Inače nikad nije bilo isplativo ići na top swagg verzije na mainstream gpu
Staro 16.12.2016., 17:33   #2483
ODO
Postovi: 596
Kao što ne postoji G1, već G1 Gaming
Staro 16.12.2016., 18:41   #2484
Omerta
Omerta's Avatar
Lokacija: Grobnik - Rijeka
Postovi: 3,254
Na tržnici vam je 1070 za 2500kn
Staro 16.12.2016., 19:40   #2485
Bez garancije
Za 500 više se ima sa 36 mjeseci u HR. Osobno nebi dao, ali ko voli nek izvoli.
Doduše, može se i Gigabyte kontaktirat i pitat jel moguće ostvarenje jamstva po serijskom broju negdje u EU. Ako da, onda je to jako dobra ponuda. Ako ne, nisam siguran baš. Ok, možda ne rikne ali kaj ak rikne
Staro 16.12.2016., 19:45   #2486
Omerta
Omerta's Avatar
Postovi: 3,254
Slažem se..
Ja ću ju uzeti u Uzi Shopu samo da riješim neke stvari.
Ali mislim da grafe ne crkavaju baš nešto.
Barem meni nikad nije crkla grafa..
Staro 16.12.2016., 19:47   #2487
Vidi, to je vječna rasprava. Nekome je garancija bitna, nekome nije. Nekome vredi 500kn, nekome ne. Meni osobno je gara bitna što god da kupujem zato i kupujem uglavnom nove stvari iz trgovine ili zapakirane sa oglasa. Polovne stvari ne skuplje od 200-500 kaj se tiče mobitela i PC komponenti.
Staro 16.12.2016., 19:49   #2488
Manuel Calavera
Postovi: 14,585
Autor Omerta Pregled postova
Ma oće to krepat, biti falično ili čak out of the box mrtvo... Zato se bolje ne zajebavati sa skupim gpu bez garancije. Procesori su pak već druga priča, šanse da ti krepa su ti tu negdje kao i dobiti na lotu
Staro 16.12.2016., 19:56   #2489
Meni su se grafičke nakrepavale, doduše, prastare nVidijine pekare 6600GT i 6800GT. Novije nisu, ali svejedno.
Dovoljno je da jedan SMD popizdi i bok.
Ali velim, vidite sa prodavačem, kontaktirajte Gigabyte. Meni su izašli u susret sa nekim stvarima. RMA im je OK za razliku od kvalitete ploča kad sam ih pitao za eventualni RMA za grafu kupljenu u USA, rekli su da mora biti vraćena u USA.
Za EU je vjerojatno isto. Ako je komp kupljen u EU, možda bi i grafu po serialu priznali u EU. A slanje grafe bilo kamo u eu je 50tak kuna. Slao sam svašta u Austriju, Njemacku, Nizozemsku, Irsku... i nema zejebancije kao sa našim vrlim uvoznicima i RMA officialima
Staro 16.12.2016., 20:46   #2490
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
Pričaj u svoje ime
Bez potpisa.
