Sandy!!!
Postovi: 1,691
Random restarti
The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly. The computer has rebooted from a bugcheck. The bugcheck was: 0x00000101 (0x0000000000000018, 0x0000000000000000, 0xffffd201472a3180, 0x0000000000000006). A dump was saved in: C:\WINDOWS\MEMORY.DMP. Report Id: 86032d19-c1ee-4795-868a-9f59e1369331. Audit events have been dropped by the transport. 0 Svaka pomoć je dobrodošla ![]() Imam problem sa random restartima svako X dana. Nekad nebude po tjedan-dva nekad restarta 2 put u 2 dana.
Komp je pod moj komp, OS je Win 10 x64 Upaljen je 24/7 ,i uvik radi nešto, ram je popunjen 90% uglavnom, 2 virtualne mašine itd. Do hardvera nije, bar ja mislim. Počelo se događat ima mnogo miseci tako da neznam točno što sam instalira prije nego se počelo događat al je pomalo krenilo ić na živce sve pokretat ispočetka, mašine i to Evo Event Viewer posto ja nekužin ništa iz toga: The previous system shutdown at 8:46:12 AM on 11/22/2016 was unexpected. The system has rebooted without cleanly shutting down first. This error could be caused if the system stopped responding, crashed, or lost power unexpectedly. The computer has rebooted from a bugcheck. The bugcheck was: 0x00000101 (0x0000000000000018, 0x0000000000000000, 0xffffd201472a3180, 0x0000000000000006). A dump was saved in: C:\WINDOWS\MEMORY.DMP. Report Id: 86032d19-c1ee-4795-868a-9f59e1369331. Audit events have been dropped by the transport. 0 Svaka pomoć je dobrodošla ![]() |
Postovi: 16,706
Dobivaš BSOD ili se samo ugasi komp i ponovo upali? Ide tipičan restart/shutdown windows screen, ili kao da si ga iz struje ugasio, odmah se ugasi? Provjerio temperature i stanje harda? |
#3 | |
Sandy!!!
Postovi: 1,691
Jednom sam ubra BSOD ,slucajno doša u sobu. Jednom se desilo da zamrzne sve i mora sam ga sam restartat. nekako virjen da je BSOD i/ili da se zamrzne i srusi...Bez "normalnog" restarta Ali ostalih bar 10-20 puta me nije bilo tu. Temp odlicne, SSD novi,testiran, sve normalno. Edit: Jel imaju neki logovi ili programi koji vade logove pa da neko ko se razumi pogleda? Edit1: C:\WINDOWS\system32>sfc /scannow Beginning system scan. This process will take some time. Beginning verification phase of system scan. Verification 100% complete. Windows Resource Protection did not find any integrity violations. Zadnje izmijenjeno od: webstartm. 22.11.2016. u 20:43. |
Postovi: 16,706
Ja mislim da je do hardware-a ipak. Nisam siguran. |
Sandy!!!
Postovi: 1,691
Mozda fali soka CPU? OC je na 4.2, vcore 1.256V i tako radi otkad ga imam. I s time je prosa prime 24 sata, WoT, WoWs, GTA 5 Dignit cu mu malo napon iduci put kad se crasha,pa cmo vidit. nemogu odma dignit jer mi se neda sve gasit pa palit opet ![]() |
