Povratak   PC Ekspert Forum > Raèunala > Kriptovalute > Mining
Ureðivanje
Staro 12.11.2016., 08:05   #361
mladen_87
mladen_87's Avatar
Postovi: 120
Bas sa frendom komentiram, da uzmemo skupa 3 ili 6 rx480. Pa ako i ne bude najbolje islo ostanu grafe koje se mogu prodat. A razliku koju cemo izgubit na grafama valjda ce izmajnat.
Gledao sam na nekom wattage calculatoru da bi moje napajanje od 650w moglo gurati 3 rx480, sad kako je u praksi?
mladen_87 je offline   Reply With Quote
Staro 12.11.2016., 11:29   #362
dadoremix
dadoremix's Avatar
Postovi: 4,694
Autor dakky Pregled postova
Ionako smo na konfama... i ionako ces minirat s tim... pa specifikacija moze i tu, mada nije neka svemirska znanost slozit je...
MBO - bilo koja do 500kn
CPU - recimo i3-6100 (1000kn) ili i5-6400 (1500kn)
RAM - 1 keks od 8 GB DDR3 ili DDR4 - 350 kn
Znaèi to nam je okvirno 2350 kn sa i5....
GPU - RX 470 - 1650kn
i tu smo na 4000kn, ostane ti još 1000 za napajanje novo i/ili jaèu grafièku... i praktièki imaš cijelu konfu novu...
a rx 480 vs 470 nema neke razlike?
vidim cijena je 400-500 u razliki, a u rudarenju?
Staro 12.11.2016., 12:06   #363
orbital_station
orbital_station's Avatar
Datum registracije: Oct 2012
Postovi: 289
Code:
setx GPU_FORCE_64BIT_PTR 0
setx GPU_MAX_HEAP_SIZE 100
setx GPU_USE_SYNC_OBJECTS 1
setx GPU_MAX_ALLOC_PERCENT 100
setx GPU_SINGLE_ALLOC_PERCENT 100
ZecMiner64.exe
pause
config.txt:
Code:
-zpool stratum.zcash.nicehash.com:3357
-zwal t1KHHP9xjGpwTDWcWfwfdRk8wTFguZ7vvmY
-zpsw x
-allpools 1
-dbg 1
log.txt:
Code:
12:02:01:275	348	ÉÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍ»
12:02:01:283	348	º            Claymore's ZCash AMD GPU Miner v4.0 Beta            º
12:02:01:289	348	ÈÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍÍͼ
12:02:01:295	348
12:02:01:502	348	ZEC: 1 pool is specified
12:02:01:521	348	Main ZCash pool is stratum.zcash.nicehash.com:3357
12:02:01:613	348	OpenCL platform: AMD Accelerated Parallel Processing
12:02:01:619	348	OpenCL platform: AMD Accelerated Parallel Processing
12:02:01:630	348	OpenCL initializing...
12:02:01:636	348	AMD Cards available: 1
12:02:01:641	348	GPU #0: Bonaire, 2048 MB available, 14 compute units
12:02:01:647	348	POOL version
12:02:01:651	348	b161
12:02:01:655	348	Platform: Windows
Ako netko ima volje pomoæi zahvaljujem.
Prije nekog veæeg ulaganja pokušavam pokrenuti zcash mining na trenutnoj konfi da dobijem malo iskustva s tim, ali mi ne ide.
Stalno mi izbacuje "ZecMiner64.exe not working", isto i sa Genoil minerom.
Imam R7 260x 2Gb, sa 15.12 driverima kako je preporuèeno.
start.bat:
Code:
ZecMiner64.exe
pause
config.txt:
Code:
-zpsw x
-allpools 1
-dbg 1
log.txt:
Code:
12:02:01:295	348
orbital_station je offline   Reply With Quote
Staro 12.11.2016., 15:14   #364
dakky
Uptime freak
dakky's Avatar
Lokacija: Ri, Cro
Postovi: 2,944
orbital... editiraj epools.txt i tamo dodaj nicehash pool, a u start.bat dodaj -allpools 1
par stranica u nazad ovdje sam objasnio kako ga pokrenuti, imas detaljno tamo...
Staro 12.11.2016., 18:17   #365
orbital_station
Postovi: 289
Znaèi nakon pokušavanja svega i èitanja 50+ stranica sa bitcointalk, odluèio sam još jednom reinstall drivera, mada sam ih veæ 2 put reinstaliravao. To je riješilo problem
Hvala
U cmd-u piše 21.475 H/s za R7 260 X. Oèekivao sam manje. Koliko je to Sol/s?
EDIT: Aha, našao piše avg 20 Sol/s na onoj nanopool statistici.
Gdje je najbolje mijenjati ZEC za usd/eur?
Zadnje izmijenjeno od: orbital_station. 13.11.2016. u 10:28.
Staro 13.11.2016., 10:26   #366
orbital_station
Postovi: 289
EDIT: dupli post
Staro 15.11.2016., 08:47   #367
dadoremix
dadoremix's Avatar
Postovi: 4,694
Ima ko coinbase za wallet?
Kako pare povuc na visa karticu?
Preko ios app ima deposit i withdraw ali ne reagira kad pritisnem
Na webstranici nit tu opciju ne mogu nac. Mamicu im, sve samo da su pare kod njih
Staro 15.11.2016., 08:49   #368
Shamanix
Shamanix's Avatar
Postovi: 870
Coinbase nisam nikad koristio, ali ako je ta viza kunski tekuci onda preko bitkonana, a ako je devizni tekuc onda preko bitstampa
Shamanix je offline   Reply With Quote
Staro 15.11.2016., 08:53   #369
dadoremix
dadoremix's Avatar
Postovi: 4,694
Rigovi za mining
Je, ja sam btca pretvoril u eure
Sad je u euro wallet i nema dalje
Tj pise da moram prvo neke eure gore stavit da potvrde karticu, ali nejde
Budem pisao mail supportu pa da cujem, di je problem
Nije neka lova 12,8€ ali prvo zelim isprobat da ta lova naðe put do mojih prsti.
Tamo na walletu mi nema koristi ne?
Kartica je pbz visa i nije problem
Vezana je i na paypal i alibaba i ovako radi.
Staro 15.11.2016., 08:56   #370
Shamanix
Shamanix's Avatar
Postovi: 870
mozes kupit ponovo bitcoine na coinbase i prebacit ih dalje..
Trebao bi moci i preko coinbase povuc lovu al prvo moras linkat racun od banke gore.. kazem nisam nikad to radio niti koristio coinbase tak da..
Ak je kartica pbz onda je devizni, onda preko bitstampa pouvec eure na karticu samo prvo moras verificirat account na bitstampu
Staro 15.11.2016., 08:58   #371
dadoremix
dadoremix's Avatar
Postovi: 4,694
Ma izgleda da bude tako, kupio opet btc pa vozi dalje. Sitna lova pa budu provizije prije sve pojele.
Kartica je upisana i pise da je ok.
Idem pisat supportu pa budem vidio šta oni vele.
I onda u potragu za drugi wallet
Staro 15.11.2016., 12:21   #372
dadoremix
dadoremix's Avatar
Postovi: 4,694
poludel bom..
ajde hint koji wallet izabrat a da mogu na viza karticu vuè pare..
ovi javili kasika FAQ nek èitam.. valjda na kraju izgleda da se nemože vuè pare na karticu
nego kupi prodaj btc
edit
mogu samo prek credit kartice kupiti, ne i poslati na nju.. a ide.
mogu samo preko iban raèuna uplatit njima.. pa oni meni vrate.. ali samo u euro.. a moj je tekuèi raèun, dakle imam kune.. pih
Dakle.. ili da naðem neki wallet koji mogu normalno vuè pare.. ili se neko javi.. pa mu pošaljem pare i bok.. da ima za pivo 12,80 € zaglavilo na netu
@dakky kako ti imas slozeno?
Zadnje izmijenjeno od: dadoremix. 15.11.2016. u 12:50.
Staro 15.11.2016., 19:36   #373
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Èistilište
Postovi: 3,553
Shamanix, jel odustaješ od rudarenja? Vidim sve 1070 na prodaji.
Uzimaš 470-tke?
Staro 15.11.2016., 19:48   #374
Shamanix
Shamanix's Avatar
Postovi: 870
Nisu sve na prodaji, dvije cu si ostavit..
Sad jos ne znam dal da idem na 470 ili 480
Staro 16.11.2016., 17:23   #375
orbital_station
Postovi: 289
Ja sam s coinbase povuko pare, stigle za 2 dana na devizni.
Ali prvo trebaš uplatit neki iznos (ja sam jedan euro) prema njima da ti potvrde da je to tvoj raèun.
To sam napravio preko internet bankarstva, banka pbz. Ne ideš direktno na naloge, nego na neku opciju doznaka. Tamo upišeš one podatke koje ti daju na coinbase i isto kroz dan dva ti sjedne u eur wallet.
Staro 16.11.2016., 17:27   #376
dadoremix
dadoremix's Avatar
Postovi: 4,694
jes, devizni.. ja imam tekuæi .. i ne mislim sad otvarat devizni da veselim banku
dosta je i ovo
trenutno sam sve prebacio na bitkonan
tamo popunio podatke o ibanu i ostalo.
Èudi me što ne traže osobnu nit druge kerefeke..
I bas pred 5 min eure prebacio tamo.
pa da vidim dal se može od tamo povuè lova na iban acc od pbz-a
btw .. šta vi mislite.. nvidia 1070 ili amd rx 480 ?
gledam sad neku recenziju i piše da nvidia skoro pa duplo bolja od ati-a .. moguèe ?
http://cryptomining-blog.com/tag/rx-480-vs-gtx-1070/
Staro 16.11.2016., 18:45   #377
kopija
DIY DILETANT
kopija's Avatar
Postovi: 3,553
pa jebaga patak, Shamanix prodaje zelene i kupuje crvene, a ti se pitaš šta kupiti?
najbolje zlato ili bitcoin, to ti je moj savjet, nemreš fulat.
Staro 16.11.2016., 18:56   #378
dakky
Uptime freak
dakky's Avatar
Lokacija: Ri, Cro
Postovi: 2,944
dadoremix kao sto sam rekao do sad... ja isto imam pbz tekuci u kunama... nemam devizni... na the rock tradingu sa Malte imam deposit address... posaljem BTC na tu adresu... prodam BTC za EUR ... napravim SEPA withdrawal na svoj tekuci... unutar 48h sjedne u kunama. Banka popapa malo na konverziji iz EUR u KN, ali stvar radi.
Staro 16.11.2016., 19:59   #379
rock00
Datum registracije: Feb 2011
Postovi: 324
Sepa se jako.isplati..uf
Najjednostavnije je direkt na bitkonan slat(da ti je to wallet)i kasnije bacat na tekuce
rock00 je offline   Reply With Quote
Staro 16.11.2016., 20:26   #380
dadoremix
dadoremix's Avatar
Postovi: 4,694
A pitam.
Zato sam i link stavio da se vidi što sam to gledao
Btw kakvo je sad kod vas stanje? Koji rudarite na nicehash??
Meni sa onih lijepih 3$/day palo na 0.19$
Pa je sad stanka
Staro 17.11.2016., 08:34   #381
orbital_station
Postovi: 289
Ima li gdje u hrvatskoj za kupiti PCIE risera?
Da ne èekam 30-60 dana iz kine...
Staro 17.11.2016., 10:13   #382
nino
nino's Avatar
Postovi: 12,613
Di si bio prosli tjedan kad ih je bilo +100 kom na lageru dobavljaca, nesto i kod nas. Sve rasprodano zacas. Mozda se pojave krajem slijedeceg tjedna, tako barem pise kod svabe.
https://www.nabava.net/search.php?q=BTC+PRO+KIT
Staro 17.11.2016., 10:24   #383
siloman
siloman's Avatar
Lokacija: Otok Krk
Postovi: 330
Kako da sa coinbase posaljem novac na bitkonan i onda na tekuci?
Coinbase me trazi email ili bitcoin adresu a ne vidim ju na bitkonanu..
Gdje se jede jedem,gdje se pije pijem,gdje se radi ne smetam!
siloman je offline   Reply With Quote
Staro 17.11.2016., 10:26   #384
Shamanix
Shamanix's Avatar
Postovi: 870
Ti asrockovi riseri su i kvaltetniji.. ovi jeftini od kineza pola ne radi i znaju zezati neki.. al 33kn komad, kupim 4 za cijenu ovog jednog..
Ja sam narucivao od kinza, al ak neki budu zezali uzmem ove asrockove u uziju..
Autor siloman Pregled postova
Gore odes na deposit pa odaberes lijevo u meniju bitcoin
Staro 17.11.2016., 10:37   #385
siloman
siloman's Avatar
Lokacija: Otok Krk
Postovi: 330
Hvala!
znaci li to da mogu bitkonan kao wallet koristit?
Staro 17.11.2016., 10:43   #386
Shamanix
Shamanix's Avatar
Postovi: 870
Mozes, ali nije preporucljivo drzat lovu na mjenjacnici zbog sigurnosti.. ako mislis odmah prodavat i povlacit lovu onda mozes da..
Staro 17.11.2016., 16:38   #387
dakky
Uptime freak
dakky's Avatar
Lokacija: Ri, Cro
Postovi: 2,944
Nego, jel se meni cini ili Zcash lagano propada... evo ga ispod 100 dolara... a istovremeno BTC raste... lici mi na namjestaljku, navlakušu da ekipa koja ima zCash proda dok se jos koliko toliko isplati.
No u svakom slucaju, negdje sam citao da je DAG na Ethereumu postao prilicno velik i da uskoro ni kartice sa 3 GB nece moci rudariti. Kad je PoS prema sadasnjem hashrateu?
Staro 18.11.2016., 08:06   #388
orbital_station
Postovi: 289
http://cryptomine.weebly.com/cryptom...ovember-1-2017
Prema ovom još cca godinu dana.
Tako da tko sad planira uæi u mining ethereuma dobit æe roi nazad, ako ima jeftinu struju, vjerojatno. Još je pitanje fluktuacije cijena kako se pos približava.
A zcash je u velikom problemu, ne znam zašto i kako, al ja ga izbjegavam. Prerizièno mi je sad ulagat.
A što se tièe gpu minanja opæenito, mislim da æe se ljudi prebaciti na što god je isplativije. Jedan coin padne drugi se digne.
Ima li coinova koji se minaju samo sa cpu?
Staro 18.11.2016., 11:45   #389
Nick7
Lokacija: Velika Gorica
Postovi: 1,520
Veliki hype....
A da ne govorim o '20% founders tax' dijelu... neki su jaaaaako lijepo zaradili
.. i jos ce zaraditi
Staro 18.11.2016., 17:55   #390
dakky
Uptime freak
dakky's Avatar
Lokacija: Ri, Cro
Postovi: 2,944
Autor orbital_station Pregled postova
ono nesto sto sam citao na bitcointalku je da Z adrese ne rade, odnosno da se ne moze trejdat sa dark Zcachom ako sam dobro shvatio... ono po cemu je ovaj coin trebao biti prepoznatljiv... navodno da je developer odustao od coina... zato mu pada cijena... ako developer napravi da adrese rade, opet ce mu cijena narasti... valjda.
Ureðivanje
Vi ne možete ureðivati svoje poruke
BB code je Ukljuèeno
Smajliæi su Ukljuèeno
[IMG] kod je Ukljuèeno
HTML je Ukljuèeno
