Staro 01.11.2005., 14:38   #1
marko_1
marko_1's Avatar
Postovi: 750
OPET! Restartanje kompa
opet ista stvar, slusam mp3-ce, surfam netom dopisujem se i restarta se. Super PI mi radi na 8m i ne restarta se, kao da je poludio, igram igre i ne restarta se, upalim komp, uđem u windowse i restarta se!!!
Očistio sam utore za ram, premjestio ram na drugi utor, neznam više šta da radim!!! Je*o mu bog ma*er i kompjuteru!!!11 Nikako na zelenu granu, pomoć ljudi bilo kakav savjet je dobrodosao!
marko_1 je offline   Reply With Quote
Staro 01.11.2005., 15:45   #2
marko_1
marko_1's Avatar
Postovi: 750
Pokrenuo sam dobri stari Scan Disk i evo izvješča:
Checking file system on C:
The type of the file system is NTFS.
A disk check has been scheduled.
Windows will now check the disk.
Cleaning up minor inconsistencies on the drive.
Cleaning up 53 unused index entries from index $SII of file 0x9.
Cleaning up 53 unused index entries from index $SDH of file 0x9.
Cleaning up 53 unused security descriptors.
CHKDSK discovered free space marked as allocated in the
master file table (MFT) bitmap.
Windows has made corrections to the file system.
5245190 KB total disk space.
1911072 KB in 15693 files.
4512 KB in 1196 indexes.
0 KB in bad sectors.
45970 KB in use by the system.
28288 KB occupied by the log file.
3283636 KB available on disk.
4096 bytes in each allocation unit.
1311297 total allocation units on disk.
820909 allocation units available on disk.
Staro 01.11.2005., 15:59   #3
SniperWolf
SniperWolf's Avatar
Postovi: 4,193
Pa jeli sad bolje?
Pošteni Trgovci: 1,2
Staro 01.11.2005., 16:28   #4
marko_1
marko_1's Avatar
Postovi: 750
Je, sad bi rekao kako opet se on restarta mater mu.
Baciti cu ga u pi*ku materinu i to sranje dao bog da bill gates sutra umre i da se vratimo u srednji vijek, tamo barem nije bilo ovakbih sranja, idem sada viditi da se negdje žica ne dotiče sa ukletim kučištem, smeče jedno smetlarsko
Neznam ni kakvi su ovo glupi procesi u taskbaru sve sranje do sranja, i kakve su to gluposti da antivirus ima 5 proces, glupi avast, smeče nedorađeno bugovito.
Staro 02.11.2005., 12:34   #5
SniperWolf
SniperWolf's Avatar
Postovi: 4,193
Nemoj ništa silovati...
Ako stvarno neide rastavi komp i ispočetka ga sastavi...
a možda je do clocka, možda napajanje odahnulo...
Staro 02.11.2005., 12:49   #6
Vjeko
V.I.P. član
Vjeko's Avatar
Lokacija: Hennef, DE
Postovi: 796
Potpisujem!
Nemoj se bezveze živcirati.
Jel se pregrijava?
Pusti memtest, prime, blablabla...
nemoguče da nemožeš otkriti šta mu je.
Vjeko je offline   Reply With Quote
Staro 02.11.2005., 14:01   #7
marko_1
marko_1's Avatar
Postovi: 750
E kako ce napajanje na tome riknuti ??? kupio sam ga u 9 mjesecu! u kučištu imam grafu sa coolerom, proc sa coolerom, 1 HDD, 1 DVD-RW i 1 FLOPPY, ajde mi reci kako napajanje to nemože goniti??? Od jučer mi se nije restartao, viditi cu sta bude ubuduce...
Staro 02.11.2005., 16:50   #8
Dudek
Dudek's Avatar
Datum registracije: May 2005
Postovi: 369
Tek tolko da znas napajanje moze jednostavno prestati raditi ili biti u polu-radi modu
Dudek je offline   Reply With Quote
Staro 02.11.2005., 18:39   #9
Broken Arrow
The Man
Broken Arrow's Avatar
Lokacija: Novi Zagreb
Postovi: 1,252
Imao isti problem ,pizdio jako ,te nakon kojeg petog format c: sve proradilo po duhu svetome
Nije mi jasno samo znam da su problemi počeli kada sam bio uveo adsl ,i znam još ljudi kojima je počelo sa uvođenjem dsl-a ,znam da nema nikakve logike (povezanost dsl-a i restartanja) ali čista statistika
"Everybody's at war with different things...I'm at war with my own heart sometimes"
Broken Arrow je offline   Reply With Quote
Staro 02.11.2005., 18:45   #10
Mr. Nice
Mr. Nice's Avatar
Datum registracije: Sep 2004
Postovi: 357
Prije nekoliko mjeseci sam imao sličan problem. Komp se na da ugasit, nego se odmah upali i kod pokretanja bilo kakve vizualizacije u WMP, a da ne govorim o 3D Marku -> plavi ekren !
Donesem napajanje iz podruma -> sve radi OK. Kupio drugo napajanje i do danas sve radi bez problema.
I sam kažeš da reset BIOS-a i friški windowsi ne pomažu, dakle hardware.
Kreni sistemom eliminacije, a moja preporuka - od napajanja.
Mr. Nice je offline   Reply With Quote
Staro 02.11.2005., 21:40   #11
E.T.
E.T.'s Avatar
Postovi: 2,458
Istina svaki 3 nakon uvedenog ADSL ima slicni problem...Neznam da li svi ti navale na iste ilegalne stranice pa poberu nesto ili sto no to je cinjenica...Meni je bilo: Upalim komp i on se restarta ude ponovno u win i radi i nekoliko dana bez gasenja i bez ikakvog restarta...ugasim ga ponovno upalim i radi 10 min pa se restarta...
Sad vec nekoliko dana nema restarta...Napomena: antivirus, ad-aware i sl. nista nisu nasli... Cini se da cu i ja probati format C kad uhvatim vremena.
www.rabbits-clan.com
E.T. je offline   Reply With Quote
Staro 02.11.2005., 22:04   #12
MRKONJA
M.U.P.
MRKONJA's Avatar
Postovi: 2,277
Meni se zblokira kad pokrenem neki video bilo sa hard ili dvda ako clockovi nisu da defaultu
Ponekad se hard sam od sebe ugasi i dok se resetira radi normalno.
Prime,super pi ,s&m,3dčmarkovi, igre sve radi bez problema samo nekad pukne sam od sebe:confused:
Abit AX8 VIA k8t890//Venice 3000@2250//1x1gb PQI//POV 7600gs silent//Seagate 7200.10 250gb(16mb//sata)//Hitachi 7k160 120gb@mobile kučište//Seagate 7200.7 200gb
//Samsung SH-w163A//Seasonic S-12 380w//Sharkoon silvation
MRKONJA je offline   Reply With Quote
Staro 02.11.2005., 23:47   #13
marko_1
marko_1's Avatar
Postovi: 750
Jel postoji neki tester napjanja, imam tu doma jos jedino CODEGEN 300 w (moš' misliti) a sumnjam da bi to pogonilo komp.
Staro 02.11.2005., 23:52   #14
Darth Vader
Dark side Moderator
Darth Vader's Avatar
Postovi: 1,633
ja nisam imao bas takvih bedova al sam pizdio sa demom od call of duty 2. skino sam 5 komda s razlicitih strainca kad trebam pocet igrat restart. instaliram na laptop radi. wtf??? sad igram cod2 sve bez beda ni vau. ko ce ga znat neto se s necim kolje a ti sad skontaj sta, meni za cod2 demo nije ni reinstal pomogo. :confused:
Jak ko rakija!
Darth Vader je offline   Reply With Quote
Staro 03.11.2005., 00:14   #15
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
grebeš demo bitno da je igra izašla!
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 03.11.2005., 19:13   #16
boky222
boky222's Avatar
Lokacija: krk
Postovi: 160
restart
da nisi pokupio virus,ja sam imao jedan koji ti nakon minute restarta komp.
boky222 je offline   Reply With Quote
Staro 03.11.2005., 19:20   #17
Broken Arrow
The Man
Postovi: 1,252
Re: restart
Meni se restartal uvijek kada sam ušo u dreamweawer ili paint shop pro 9 i to baš kada već nešto napravim
,ali sada je fala bogu dobro
rijetko tko ga nije imao (ja sam jedan od njih i zaboravio sam mu ime) ali je on čista prošlost
Staro 03.11.2005., 21:51   #18
gospar
Faraon
gospar's Avatar
Datum registracije: Oct 2002
Lokacija: Cork
Postovi: 948
windowsi xp imaju ukljuceno da nepokazuje blue screen of death nego u slucaju njega da se automatski restartaju tako moze se u par slucaja ovdje bas dogodi greska u windowsima zbog kojega se onda sami restartaju. a greska sama od sebe se moze dogoditi radi lose memorije ili napajanja. kad se tako nesto desi treba sve testirati. meni se auto samo od sebe gasi evo treci elektricar nezna sto mu je. svaki kaze da bi mogao promijeniti par dijelova po 300kn ali da to nejamci rjesenje problema i sta da im radim....
e da isto tako moze se restartati radi usb uredaja. par puta su se kompjuteri restartirali i radi miseva i adslova isto tako bio je jednom i slucaj ako se nabije kartica u agp slot preduboko... .sta da ti kazem prozivljavas nocnu moru svakog od nas
gospar je offline   Reply With Quote
Staro 03.11.2005., 22:27   #19
domy_os
domy_os's Avatar
Postovi: 18,868
Nije istina, i Windowsi XP i 2000 imaju BSOD, samo u ponešto drugačijem obliku nego Windowsi 9x.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 03.11.2005., 22:28   #20
Broken Arrow
The Man
Postovi: 1,252
Imaju ako ugasiš autorestart...
Staro 03.11.2005., 22:56   #21
domy_os
domy_os's Avatar
Postovi: 18,868
Pa znam, al, uglavnom, imaju BSOD.
Staro 03.11.2005., 23:15   #22
Maynard
Maynard's Avatar
Postovi: 124
Dečki evo malo statistike: nije sad da pljujem po amdu al svi do reda ga imate i svi nekakav problem sa blokiranjem aplikacija i resetiranjem.
Maynard je offline   Reply With Quote
Staro 03.11.2005., 23:19   #23
Drvomlat
Postovi: 25
De se odi sam obisi da te nebi triba neko drugi
Takve gluposti nisam ćua godinama
a ako bi imali svi intela windowsi bi radili kako triba
Adio
Drvomlat je offline   Reply With Quote
Staro 03.11.2005., 23:23   #24
Broken Arrow
The Man
Postovi: 1,252
@ autor
Ako ti se još restarta odi ovako:
Control Panel => System => Advanced => Pad startap and recovery klikni setings i isključi automatically restart
tada ti se nebi trebao retsartati ,nego ako je velika greška izbaci bsod
I kada ti se sruši pogledaj u events logu što je uzrok greške
Staro 03.11.2005., 23:26   #25
Broken Arrow
The Man
Postovi: 1,252
Nemojte mi pljuvati po amd-u pljujte po win-u
Staro 03.11.2005., 23:31   #26
gospar
Faraon
gospar's Avatar
Lokacija: Cork
Postovi: 948
pa e ja sam rekao da imaju ukljuceno da ga nepokazuju to je jedan lijep nacin da u reklami pokazu koliko je stabilniji od prethodnih verzija. jednostavno se restartira kompjuter pa ti dokazi da se srusio windows
Staro 03.11.2005., 23:35   #27
MRKONJA
M.U.P.
MRKONJA's Avatar
Postovi: 2,277
Samo jedno pitanje jel koristite možda nlite verziju windoza?
Staro 04.11.2005., 00:02   #28
domy_os
domy_os's Avatar
Postovi: 18,868
Ne baljezgaj...
Staro 04.11.2005., 01:14   #29
Maynard
Maynard's Avatar
Postovi: 124
Ma dok sam imao amd-a isto tak me nešt jeb*lo samo sta se gad resetirao dva-tri puta i onda zablokirao, več sam ga htio bacit kroz balkon od muke i onda me puklo da ga prodam po komponentama. Nije se nitko žalio ni za jednu stvar a sve sam prodao osim šugavog napajanja. Najvjerojatnije je napajanje i kod vas
Staro 04.11.2005., 14:44   #30
MRKONJA
M.U.P.
MRKONJA's Avatar
Postovi: 2,277
Nevidim da neko ima šit napajanje
