#1802 |
420
Lokacija: Le Molve
Postovi: 1,577
#1803 |
Lokacija: Čakovec / AT
Postovi: 1,782
znaci ako nude "do 20 mbita" , trebalo bi bit moguce barem 14 (70%), right? ako uzmemo u obzir da je to 3 i nesto puta brze od trenutnog kaj imam a samo duplo skuplje... uzeo bi ODMAH! a da ne spominjemo stavku "bez ugovorne obveze" ![]()
slow is smooth, smooth is fast... |
#1804 |
Pitao upravo mogu li se prebaciti na SOLO paket uz postojeću UO do kraja. Odgovor je NE. Ugovor do kraja a onda se mogu prebacit na taj SOLO. Tako da nekom potencijalno uštedim trud zvanja. |
#1805 |
Postovi: 1,782
jel mi moze neko objasnit preko cega (?!) ide VDSL? isto preko bakrene zice ili? jer adsl mi kaze da mogu dobit 10 mbita (149 kn, bez ugovorne obveze) a vdsl 40 mbita (isto 149 kn bez ugovorne obveze) uzeo sam VDSL , sad cekat da stigne oprema... ukljucenje je za 2-3 tjedna. edit: nasao "VDSL operates over the copper wires in your phone line in much the same way that ADSL does, but there are a couple of distinctions. VDSL can achieve incredible speeds, as high as 52 Mbps downstream (to your home) and 16 Mbps upstream (from your home). That is much faster than ADSL, which provides up to 8 Mbps downstream and 800 Kbps (kilobits per second) upstream. But VDSL's amazing performance comes at a price: It can only operate over the copper line for a short distance, about 4,000 feet (1,200 m)."
slow is smooth, smooth is fast... Zadnje izmijenjeno od: santos. 12.10.2016. u 11:03. |
#1806 | |
Lokacija: Vukovar
Postovi: 203
Sent from my MI MAX using Tapatalk |
#1807 |
Lokacija: Vukovar
Postovi: 203
Evo danas mi pustili koliko može.... ![]() Code:
Link Status Connected Rate (Up/Down) 950/18995 kbps Noise Margin (Up/Down) 12.5/8 dB Modulation Type ADSL_2plus Line Attenuation (Up/Down) 12.6/19.2 dB Output Power (Up/Down) 12.4/19.4 dBm Data Path (Up/Down) Interleaved/Interleaved Max Rate(Up/Down) 1052/20648 kbps Interleave depth 8 Annex Type AnnexA CRC errors 1 |
#1808 |
Lokacija: doma
Postovi: 2,895
Tu nema ni traga VDSL2 nego puste po ADSL2+ koliko ide. Neznam, mozda sam ja onako malo pomaknut pa paranoican ali ja kada gledam ovu njihovu sliku i objasnjenje i sam postupak... jel se to meni cini ili kao da citam bajku vuk i crvenkapica ili neku slicnu... Imamo Iskon sa svojim "razredima" gdje pitaj boga ili vuka kojom tehnikom se tko stavlja u koji a H1 prica neke basne. ![]() Na kraju sve smrdi jednako tj. istim intezitetom... uzmes 20-50 kod Iskona i cekas upis u skolicu da vidis koji ces razred ili odes u H1 i onda 14 dana slusas basnu dok "oni mjere" ![]() Zbilja je sve manje ili uopce vise nema normalnih operatera.... Sto dalje to sve vise nesto upakiravaju, zamaskiravaju itd. Definitino se moze cekati upis u skolicu/razred ili slusati basne ako nije ugovorena obveza ali po ovakvim uvjetima ugovoriti nesto na 2g je kao dici kredit kod lokalnog lihvara sa stupa. |
#1809 |
Datum registracije: Oct 2016
Postovi: 2
Poštovani, Molim vas za pomoć tj.informaciju Korisnik sam H1 Telekoma već 9 mj i koristim uslugu tel+net 4 plus a sada sam podnio zahtjev za tv-om (tv+tel+net 4 plus) koji još nije realiziran do kraja. Internet za sada radi onako kako sam očekivao veza je sve vrijeme oko 4mb no zanima me kako će to nadalje raditi uz tv. U prilogu dostavljam podatke sa modema. Link Status Connected Rate (Up/Down) 895/5160 kbps Noise Margin (Up/Down) 7.7/9.6 dB Modulation Type ADSL_2plus Line Attenuation (Up/Down) 27.6/37.4 dB Output Power (Up/Down) 12.4/16.2 dBm Data Path (Up/Down) Fast/Fast Max Rate(Up/Down) 951/7408 kbps Interleave depth 0 Annex Type AnnexB CRC errors 9895 Hvala i lijep pozdrav
Stjepan :-) |
#1810 |
RESPECT MY AUTHORITAH
Postovi: 7,485
Ne možeš imati TV, udaljen si preko 2km od centrale, margina ti je već sada 9db, maksimum je ono što sada imaš tj oko 5-6 mbps. Očito živiš u nekoj selendri udaljen od centrale jer ništa drugo ne opravdava ovo katastrofalno stanje. Ne znam bi li ti stabilno radilo no eventualno oko 2Mbps za DL i ostatak bi išao na tv
#1811 |
Postovi: 2
Hvala vam na odgovoru. Ako ćemo realno udaljen sam 1km od same centrale. Može biti oko parice tj. HT infrastrukture jer je sve to u mome mjestu rađeno pa prije više od desetak godina i nikada nakon toga ništa. Stvarno ne razumijem se toliko u navedeno. Vidim da su mi već na moj H-1 uvrstili navedeni paket samo što oprema nije stigla. Nego prije cca. 2 godine sam bio na HT-u te sam tamo imao Max tv, internet 4mbs i telefon sve normalno radilo tokom cijele ugovorne obveze a isto tako na iskonu nije ništa radilo niti tv niti internet. Stalna pucanja veze i sl. tako da evo odlučio sam tu pitati one koji ipak znaju više od mene samoga.
Stjepan :-) |
#1812 |
Datum registracije: Apr 2016
Postovi: 126
Jel bi trebalo biti nekih promjena nakon što Optima (a ustvari HT) preuzme H1 Telekom nakon 1.1.2017.? |
#1814 | |
Datum registracije: Apr 2015
Postovi: 1,703
#1815 | |
Postovi: 1,782
evo ja upravo imam taj problem.... znaci telefonski potpisao za 40 mbita, jer je tolko covjek reko da ide kroz liniju.... jucer bio tehnicar iz t-coma, zastekao se na liniju, otiso dolje do razvodne kutije na stupu (u susjednom dvoristu), isprobali i.... nista... iako imam tel liniju, ista nikad nije bila ukljucena... tako da po njemu... nista od neta... prije pola sata mi postar donio potvrdu o sklapanju ugovora s h1... sad sam ih zvao al mi se ne da 20 min cekat da mi se neko javi pa sam im poslao mejl... cekam odgovor... ![]()
#1817 |
Postovi: 888
evo ako nekog zanima, kroz 2 tjedna od zahtjeva spojili mi H1 net, bez ugovorne obveze, 150kn mjesečno, i nakon par dana digli brzinu "najviše koliko parica propušta stabilno" na 10/1 mbit ![]() ne mogu reći o dugoročnoj stabilnosti ali zasad sam zadovoljan, nigdje ne šteka, torent ide, youtube ide, stranice otvara bez nekih problema i zastajkivanja, lap i 2 moba bežično na onom fritzu ![]() PS, zna netko jel ih se da najebat da još malo dignu? ![]() |
#1819 |
Postovi: 12,613
Hmm, bas i frendu tcom odbio prelazak na h1, ugovor istekao. Sent from my D5803 using Tapatalk
#1820 |
Datum registracije: Dec 2012
Lokacija: Usa
Postovi: 253
Sad su za H1 počeli radit vanjski kao i za vip pred godinu dana, tako da će se poboljšat vrijeme odaziva tehničara na kvar ili ukopčanje. Možda je vanjskih bilo i prije ali vjerojatno ful malo jer h1 nije bio redovan platiša, nema kome nisu ostali dužni. Sada je to valjda riješeno, nadam se preko banaka. |
#1823 |
Postovi: 144
#1824 |
Postovi: 888
ipak nije tako savršen, ima malo prekida nekad maknuo sam neke adrese i to ![]() Code:
07.11.16 14:33:32 Internet connection established successfully. IP address: , DNS server: and , Gateway: , Broadband PoP: 07. :29 DSL is available (DSL synchronization exists with 11993/1092 kbit/s). 07. :00 Timeout during PPP negotiation. 07. :00 Internet connection cleared. 07. :56 DSL not responding (no DSL synchronization). 07.11.16 03:53:20 Internet connection established successfully. IP address: , DNS server: and , Gateway: , Broadband PoP: 07.11.16 03:53:20 Internet connection cleared. 07.11.16 03:53:16 Clearing Internet connection briefly to prevent the Internet service provider from disconnecting you in the immediate future. 06.11.16 04:37:21 Internet connection established successfully. IP address: , DNS server: and , Gateway: , Broadband PoP: 06.11.16 04:29:30 Log in with Internet service provider failed. Terminated LCP 06.11.16 04:15:38 Log in with Internet service provider failed. Terminated LCP 06.11.16 04:01:20 Log in with Internet service provider failed. Terminated LCP 06.11.16 03:53:46 Log in with Internet service provider failed. Terminated LCP 06.11.16 03:52:46 Log in with Internet service provider failed. Terminated LCP 06.11.16 03:51:46 Log in with Internet service provider failed. Terminated LCP 06.11.16 03:50:46 Log in with Internet service provider failed. Terminated LCP 06.11.16 03:49:46 Log in with Internet service provider failed. Terminated LCP 06.11.16 03:49:46 Internet connection cleared. 06.11.16 03:49:42 Clearing Internet connection briefly to prevent the Internet service provider from disconnecting you in the immediate future. 05.11.16 04:33:47 Internet connection established successfully. IP address: , DNS server: and , Gateway: , Broadband PoP: 05.11.16 04:27:11 Log in with Internet service provider failed. Terminated LCP 05.11.16 04:15:30 Log in with Internet service provider failed. Terminated LCP 05.11.16 04:10:11 Log in with Internet service provider failed. Terminated LCP 05.11.16 04:01:27 Log in with Internet service provider failed. Terminated LCP 05.11.16 03:47:11 Log in with Internet service provider failed. Terminated LCP 05.11.16 03:40:56 Log in with Internet service provider failed. Terminated LCP 05.11.16 03:31:15 Log in with Internet service provider failed. Terminated LCP 05.11.16 03:21:14 Log in with Internet service provider failed. Terminated LCP 05.11.16 03:20:14 Log in with Internet service provider failed. Terminated LCP 05.11.16 03:19:14 Log in with Internet service provider failed. Terminated LCP 05.11.16 03:18:14 Log in with Internet service provider failed. Terminated LCP 05.11.16 03:17:14 Log in with Internet service provider failed. Terminated LCP 05.11.16 03:17:14 Internet connection cleared. 05.11.16 03:17:12 Clearing Internet connection briefly to prevent the Internet service provider from disconnecting you in the immediate future. 04.11.16 04:01:17 Internet connection established successfully. IP address: , DNS server: and , Gateway: , Broadband PoP: 04.11.16 03:51:21 Log in with Internet service provider failed. Terminated LCP 04.11.16 03:45:51 Log in with Internet service provider failed. Terminated LCP 04.11.16 03:44:51 Log in with Internet service provider failed. Terminated LCP 04.11.16 03:43:51 Log in with Internet service provider failed. Terminated LCP 04.11.16 03:42:51 Log in with Internet service provider failed. Terminated LCP 04.11.16 03:41:51 Log in with Internet service provider failed. Terminated LCP 04.11.16 03:41:51 Internet connection cleared. 04.11.16 03:41:47 Clearing Internet connection briefly to prevent the Internet service provider from disconnecting you in the immediate future. 03.11.16 03:42:56 Internet connection established successfully. IP address: , DNS server: and , Gateway: , Broadband PoP: 03.11.16 03:41:55 Log in with Internet service provider failed. Terminated LCP 03.11.16 03:40:55 Log in with Internet service provider failed. Terminated LCP 03.11.16 03:39:55 Log in with Internet service provider failed. Terminated LCP 03.11.16 03:39:55 Internet connection cleared. 03.11.16 03:39:51 Clearing Internet connection briefly to prevent the Internet service provider from disconnecting you in the immediate future. 02.11.16 03:41:13 Internet connection established successfully. IP address: , DNS server: and , Gateway: , Broadband PoP: 02.11.16 03:28:13 Log in with Internet service provider failed. Terminated LCP 02.11.16 03:27:13 Log in with Internet service provider failed. Terminated LCP 02.11.16 03:26:13 Log in with Internet service provider failed. Terminated LCP 02.11.16 03:25:13 Log in with Internet service provider failed. Terminated LCP 02.11.16 03:24:13 Log in with Internet service provider failed. Terminated LCP 02.11.16 03:24:13 Internet connection cleared. 02.11.16 03:24:09 Clearing Internet connection briefly to prevent the Internet service provider from disconnecting you in the immediate future. 01.11.16 05:08:14 Internet connection established successfully. IP address: , DNS server: and , Gateway: , Broadband PoP: 01.11.16 05:02:22 Log in with Internet service provider failed. Terminated LCP 01.11.16 04:48:57 Log in with Internet service provider failed. Terminated LCP 01.11.16 04:37:07 Log in with Internet service provider failed. Terminated LCP 01.11.16 04:25:13 Log in with Internet service provider failed. Terminated LCP 01.11.16 04:14:07 Log in with Internet service provider failed. Preauth 01.11.16 04:03:25 Log in with Internet service provider failed. Preauth 01.11.16 03:52:35 Log in with Internet service provider failed. Terminated LCP 01.11.16 03:39:22 Log in with Internet service provider failed. Terminated LCP 01.11.16 03:28:47 Log in with Internet service provider failed. Terminated LCP 01.11.16 03:25:22 PPP negotiation failed. 01.11.16 03:25:22 PPP negotiation failed. 01.11.16 03:25:12 PPP negotiation failed. 01.11.16 03:19:54 Log in with Internet service provider failed. Terminated LCP 01.11.16 03:18:54 Log in with Internet service provider failed. Terminated LCP 01.11.16 03:17:54 Log in with Internet service provider failed. Terminated LCP 01.11.16 03:16:54 Log in with Internet service provider failed. Terminated LCP 01.11.16 03:15:54 Log in with Internet service provider failed. Terminated LCP 01.11.16 03:15:54 Internet connection cleared. 01.11.16 03:15:50 Clearing Internet connection briefly to prevent the Internet service provider from disconnecting you in the immediate future. :59:55 Internet connection established successfully. IP address: , DNS server: and , Gateway: , Broadband PoP: :58:54 Log in with Internet service provider failed. Preauth :58:31 DSL is available (DSL synchronization exists with kbit/s). :57:58 DSL not responding (no DSL synchronization). :57:54 Log in with Internet service provider failed. Terminated LCP :57:54 Internet connection cleared. 31.10.16 03:32:56 Internet connection established successfully. IP address: , DNS server: and , Gateway: , Broadband PoP: 31.10.16 03:31:56 Log in with Internet service provider failed. Terminated LCP 31.10.16 03:31:56 Internet connection cleared. 31.10.16 03:31:52 Clearing Internet connection briefly to prevent the Internet service provider from disconnecting you in the immediate future. 30.10.16 05:15:57 Internet connection established successfully. IP address: , DNS server: and , Gateway: , Broadband PoP: 30.10.16 05:05:05 Log in with Internet service provider failed. Terminated LCP 30.10.16 04:58:00 Log in with Internet service provider failed. Terminated LCP 30.10.16 04:46:13 Log in with Internet service provider failed. Preauth 30.10.16 04:37:25 Log in with Internet service provider failed. Preauth 30.10.16 04:28:56 Log in with Internet service provider failed. Terminated LCP 30.10.16 04:21:27 Log in with Internet service provider failed. Terminated LCP 30.10.16 04:11:45 Log in with Internet service provider failed. Terminated LCP 30.10.16 04:00:24 Log in with Internet service provider failed. Terminated LCP 30.10.16 03:46:25 Log in with Internet service provider failed. Terminated LCP 30.10.16 03:40:41 Log in with Internet service provider failed. Terminated LCP 30.10.16 03:31:46 Log in with Internet service provider failed. Terminated LCP 30.10.16 03:21:36 Log in with Internet service provider failed. Terminated LCP 30.10.16 03:20:36 Log in with Internet service provider failed. Terminated LCP 30.10.16 03:19:36 Log in with Internet service provider failed. Terminated LCP 30.10.16 03:18:36 Log in with Internet service provider failed. Terminated LCP 30.10.16 03:17:36 Log in with Internet service provider failed. Terminated LCP 30.10.16 03:17:36 Internet connection cleared. 30.10.16 03:17:32 Clearing Internet connection briefly to prevent the Internet service provider from disconnecting you in the immediate future. 29.10.16 06:01:37 Internet connection established successfully. IP address: , DNS server: and , Gateway: , Broadband PoP: 29.10.16 05:50:23 Log in with Internet service provider failed. Terminated LCP 29.10.16 05:40:58 Log in with Internet service provider failed. Terminated LCP 29.10.16 05:31:02 Log in with Internet service provider failed. Terminated LCP 29.10.16 05:18:08 Log in with Internet service provider failed. Terminated LCP 29.10.16 05:07:51 Log in with Internet service provider failed. Terminated LCP 29.10.16 04:57:00 Log in with Internet service provider failed. Terminated LCP 29.10.16 04:49:02 Log in with Internet service provider failed. Terminated LCP 29.10.16 04:34:32 Log in with Internet service provider failed. Terminated LCP 29.10.16 04:29:00 Log in with Internet service provider failed. Terminated LCP 29.10.16 04:15:19 Log in with Internet service provider failed. Terminated LCP 29.10.16 04:14:19 Log in with Internet service provider failed. Terminated LCP 29.10.16 04:13:19 Log in with Internet service provider failed. Terminated LCP 29.10.16 04:12:19 Log in with Internet service provider failed. Terminated LCP 29.10.16 04:11:19 Log in with Internet service provider failed. Terminated LCP 29.10.16 04:11:19 Internet connection cleared. 29.10.16 04:11:15 Clearing Internet connection briefly to prevent the Internet service provider from disconnecting you in the immediate future. 29.10.16 03:55:20 Internet connection established successfully. IP address: , DNS server: and , Gateway: , Broadband PoP: 29.10.16 03:55:20 Internet connection cleared. 29.10.16 03:55:16 Clearing Internet connection briefly to prevent the Internet service provider from disconnecting you in the immediate future. :39:21 Internet connection established successfully. IP address: , DNS server: and , Gateway: , Broadband PoP: :39:17 DSL is available (DSL synchronization exists with kbit/s). |
#1825 | |
Postovi: 993
#1826 |
Postovi: 144
Ne brinite, to je normalno. To se i meni dešavalo kad sam imao fritz box. Vidite da se dešava samo kroz 3-4 ujutro. To je onaj 24h reset 99% sam siguran... |
#1827 |
Datum registracije: Jul 2009
Postovi: 338
Razumljivo je da se radi o refreshu, ali da to traje tako dugo ne znam baš. Mislim neki mi je dan ponovna uspostava trajala 2.5h. Nazvao sam ih i pitao o tome, kaže da su dobijali prijave da neki korisnici na UbaciImeServera (zaboravio sam) imaju poteškoća, da će zabilježiti pa da će vidjeti šta i kako. |
#1828 |
Postovi: 144
Hmm, nezz, ja se s tim uopće nisam zamarao dok sam imao fritz box, jer skoro nikad u to vrijeme nisam koristio net. Ne znam da li se isto dešava na ZTE bijelom routeru. Za par dana ću preći na VDSL kod njih pa prepostavljam da će mi dati ponovo fritz ili onaj novi inboox router, javim rezultate. |
#1830 | ||
Postovi: 993
Očigledno toliko pojavljivanje nije normalno, možda i ja prijavim smetnju ( ali ne želim ništa dirati jer imam otključan fritz pa da mi ne prigovaraju ) |
