#9241 |
Datum registracije: Mar 2011
Postovi: 2,707
SSD AD 120GB ASP580 2,5" MEM DDR4 8GB 2133MHz Value RAM KIN MSI Main Board Desktop H110 (S1151, DDR4, USB3.1, USB2.0, SATA III, DVI, VGA, Audio, LAN) mATX Retail (H110M_PRO-VD_PLUS) Corsair Carbide Series 100R Mid Tower Case CGenius SP j120 1800, 4W ,zvučnici Acer V246HQLAbd 23.6 LED Monitor IPS UM.UV6EE.A01 Toshiba DT01ACA100 1TB 3.5" Corsair Builder Series CX450M, Modular Power Supply, EU Version, 5yrs Procesor Intel Core i3 6100 Sapphire RX 470 Nitro, 4GB GDDR5,DVI,2xHDMI,2XDP 6.051,09kn Malo preko, ali se morala ugurati RX 470 IMO. |
#9242 |
Datum registracije: Mar 2008
Lokacija: Đakovo
Postovi: 13
Pozdrav trebao bih preporuku za konfu od 3000 kn (+500kn) Procesor, matična, ram, grafa, hdd, napajanje, kučište. Služio bi za "gaming", surfanje itd. Naručio bi preko Future-it. Hvala!
GOD Hates Us ALL!! |
#9243 |
Postovi: 2,707
#1 1 x Sapphire Radeon RX460 2GB, 128bit GDDR5 1 x Kućište MS Mercury 2, 1x12cm+1x9cm vent. 1 x Fortron Hexa+ 400W, 80+ 1 x HDD Toshiba P300 1TB, 64MB, 7200rpm, High-Performance 1 x Intel CPU Desktop Core i3-6098P (3.6GHz, 3MB, LGA1151) box 1 x MSI H110M PRO-VD (S1151, DDR4, USB3.1, SATA III, DVI, VGA, Audio, LAN) mATX 1 x Kingston 8GB 2133MHz DDR4 Non-ECC CL15 DIMM 1Rx8 Ukupno: 3494,00 kn #2 - slabiji procesor, nemogućnost nadogradnje 1 x Sapphire Radeon RX460 2GB, 128bit GDDR5 1 x Kućište MS Mercury 2, 1x12cm+1x9cm vent. 1 x Fortron Hexa+ 400W, 80+ 1 x HDD Toshiba P300 1TB, 64MB, 7200rpm, High-Performance 1 x Gigabyte GA-F2A68HM-DS2 (SFM2+,DDR3,DVI/VGA,USB3.0,SATA III) mATX 1 x Memorija PC DDR3 8GB, 1600MHz PNY, bulk 1 x Procesor AMD Athlon II X4 845 Ukupno: 3016,00 kn |
#9244 |
weliki pwner...
Lokacija: čakovec
Postovi: 131
bok ekipica bio bih vam vrlo zahvalan ako mi netko moze preporuciti konfu za fax - potrebe arhitekture (CAD, Photoshop, sketchup, renderiranje) znaci trebam dobar GPU i dobar CPU i htel bi SSD barem 128 gb i jos bi onda stavil nutra HDD koji imam doma rang cijene je tam do max 5500 kn hvala vam, puno, puno! Lp, Dorian
Rijeci su isto kao i gomile ljudi, nije nuzno znati za sve... J. B. Štulić |
#9245 |
Datum registracije: Jul 2016
Lokacija: Đakovo
Postovi: 9
pozdrav molio bih ocjenu slijedeće kofiguracije koja bi se koristila za igranje,filmove i internet: 1 x Asrock H110M-DGS (s1151,DDR4,USB 3.0,SATA III,LAN,DVI) mATX 1 x Procesor Intel Core i5 6402P 1 x Kingston 8GB 2133MHz DDR4 CL15 1 x HDD SEAGATE Barracuda (3.5",1TB,64MB,SATA III) 1 x SSD Scan Disc Z400s 128GB, 1x LITE ON DVDRW 24x SATA, black, bulk 1 x Gigabyte GeForce GTX 960, 2GB 128 bit DDR5 1 x Zalman T3 Mini-Tower ATX kućište, bez napajanja, crno 1 x Fortron Hexa+ 400W, 80+ 1.da li je što potrebno ili moguće (zbog uštede) mijenjat? 2.gdje bi bila najpovoljnija kupnja? hvala |
#9247 |
Lokacija: Đakovo
Postovi: 9
,pozdravZadnje izmijenjeno od: coconut. 15.09.2016. u 13:37. |
#9249 |
Lokacija: Đakovo
Postovi: 9
ok,kako spojiti monitor sa 15 pinskim konektorom na recimo 470? |
#9250 |
Postovi: 34,075
#9251 | |
Lokacija: Đakovo
Postovi: 9
,samo sad su mi u jednoj trgovini rekli da to ne ide |
#9252 |
Postovi: 12,613
Samo pomocu trikova coconut Sent from my D5803 using Tapatalk
#9253 |
Postovi: 34,075
Obično ga dobiješ s grafom. Tebi treba DVI (M)->VGA (Ž) https://www.links.hr/hr/adapter-delo...-5-m-200300284
#9254 | |
Lokacija: Đakovo
Postovi: 9
#9255 |
Postovi: 12,613
Cocunut, nemoze dvi-d spajat tako Treba nu aktivni adapter pretvarac, a i onda je pitanje hoce li delat. Ima raznih sranja tu.
#9256 |
Postovi: 14,589
Da, jer nove gpu mogu samo digitalni signal, adapter je funkcionirao sa dvi-i (koji podržava i analogni), a za dvi-d im treba konverter. Moja neka računica je da se više isplati promjeniti monitor. Konverter je cca 200kn, nek postojeći monitor vrijedi bar par sto kn, a za cca 100 eura ima poštenih monitora (čan i VA panel). Za polovne sa dvi da ne govorim |
#9257 |
Postovi: 34,075
Ispričavam se na svojoj neupućenosti. Slažem se s kolegom Manuelom da bi mu bilo bolje promijeniti monitor.
#9258 |
Datum registracije: Sep 2016
Postovi: 2
Pozdrav, Trebao bi konfiguraciju za kompjuter nije mi bitno AMD/Intel bitno je da radi što bolje. Bez HDD, optičkog pogona, monitora i periferije za 4000kn i htio bi da je SSD unutra od 120Gb. Koristim kompjuter za faks autocad i takvi programi, a tu i tamo volim neku igricu upalit i dosta patim na sliku kod filmova. Uzeo bi to sve iz protisa kolko vidim tamo je najpovoljnije jedino ako imate neku drugu preporuku dobro bi došla ![]() |
#9259 |
Postovi: 430
1 x Intel Skylake Core i5-6400 (2.7GHz, 6MB,LGA1151) box 1 x PNY DDR4 8GB, 2133MHz 1 x MSI H110M PRO-VD (S1151, DDR4, USB3.1, SATA III, DVI, VGA, Audio, LAN) mATX 1 x SSD SanDisk Z400s 128GB, 2.5” 7mm, SATA 6 Gbit/s - 60mj 1 x Zalman T1 PLUS, mATX, USB3.0 black 1 x Fortron Hexa+ 400W, 80+ 1 x Sapphire Radeon RX460 2GB, 128bit GDDR5 Ukupno: 4064,00 kn slaganje i dostava u cijeni |
#9260 |
Postovi: 2
Hvala puno. S koje stranice si našao te komponente i cijene? |
#9261 |
Lokacija: Požega
Postovi: 1
5000-5500 kn
molio bih pomoc,treba mi konfiguracija od 5000 do 5500 kn. racunalo bi se koristilo za autocad,photoshop i ostale programe,te bi se ovisno o vremenu zaigralo nesto novije.ssd nije potreban. znaci racunalo za sve namjene. unaprijed hvala. |
#9262 | |
Postovi: 4,069
Pozdrav, Trebam preporuku sličnog računala za frenda. Uglavnom traži se konfiguracija do 3500-4000, za igranje, ali bez kućišta i sa SSD-om umjesto HDD-a. Dvojba je oko procesora i grafičke. Isplati li se uzimati i5 za 500-tinjak HRK više uz ovu RX460 (to ispadne oko 3800 onda)? Ili je možda bolje staviti i3 i staviti neku malo jaču grafičku (ako postoji uopće nešto takvo)? Hvala unaprijed Citiraj:
#9263 |
Postovi: 2,707
@tutix Procesor Intel Core i3 6100 Matična ploča MSI H110M_PRO-VD (S1151, DDR4, USB3.1, USB2.0, SATA III, DVI, VGA, Audio, LAN) SSD AD 120GB ASP580 2,5" bulk Kingmax 1x8GB DDR4 2133 GLJG, KIN-8GB DDR4 2133 SAPPHIRE Video Card AMD Radeon RX 470 NITRO+ GDDR5 4GB/256bit, 1260MHz/1750MHz, PCI-E 3.0 x16 XFX PSU TS 430W, XFX-P1-430S-XXB9 4.017,61kn |
#9266 |
Slažem se. Zadnje izmijenjeno od: coconut. 20.09.2016. u 07:11. |
#9267 | |
Lokacija: Popovača
Postovi: 98
#9268 |
Postovi: 430
1 x Intel Skylake Core i5-6400 (2.7GHz, 6MB,LGA1151) box 1 x PNY DDR4 8GB, 2133MHz 1 x MSI H110M PRO-VD (S1151, DDR4, USB3.1, SATA III, DVI, VGA, Audio, LAN) mATX 1 x Sapphire RX480 Nitro+, 4GB, 256bit GDDR5 1 x HDD Toshiba P300 1TB, 64MB, 7200rpm, High-Performance 1 x Fortron Hyper 500W, 80+ - 60mj. 1 x Kućište MS Mercury 2, 1x12cm+1x9cm vent. Ukupno: 5089,00 kn slaganje i dostava u cijeni. |
#9270 |
![]() Fali li nesto ovoj konfi i jel sve ok? |
