Staro 12.09.2016., 22:46   #9241
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
SSD AD 120GB ASP580 2,5"
MEM DDR4 8GB 2133MHz Value RAM KIN
MSI Main Board Desktop H110 (S1151, DDR4, USB3.1, USB2.0, SATA III, DVI, VGA, Audio, LAN) mATX Retail (H110M_PRO-VD_PLUS)
Corsair Carbide Series 100R Mid Tower Case
CGenius SP j120 1800, 4W ,zvučnici
Acer V246HQLAbd 23.6 LED Monitor IPS UM.UV6EE.A01
Toshiba DT01ACA100 1TB 3.5"
Corsair Builder Series CX450M, Modular Power Supply, EU Version, 5yrs
Procesor Intel Core i3 6100
Sapphire RX 470 Nitro, 4GB GDDR5,DVI,2xHDMI,2XDP
6.051,09kn
Malo preko, ali se morala ugurati RX 470 IMO.
Staro 13.09.2016., 17:17   #9242
RidDLe
RidDLe's Avatar
Datum registracije: Mar 2008
Lokacija: Đakovo
Postovi: 13
Pozdrav trebao bih preporuku za konfu od 3000 kn (+500kn)
Procesor, matična, ram, grafa, hdd, napajanje, kučište.
Služio bi za "gaming", surfanje itd.
Naručio bi preko Future-it.
Hvala!
GOD Hates Us ALL!!
RidDLe je offline   Reply With Quote
Staro 13.09.2016., 17:30   #9243
Smartic
Smartic's Avatar
Postovi: 2,707
#1
1 x Sapphire Radeon RX460 2GB, 128bit GDDR5
1 x Kućište MS Mercury 2, 1x12cm+1x9cm vent.
1 x Fortron Hexa+ 400W, 80+
1 x HDD Toshiba P300 1TB, 64MB, 7200rpm, High-Performance
1 x Intel CPU Desktop Core i3-6098P (3.6GHz, 3MB, LGA1151) box
1 x MSI H110M PRO-VD (S1151, DDR4, USB3.1, SATA III, DVI, VGA, Audio, LAN) mATX
1 x Kingston 8GB 2133MHz DDR4 Non-ECC CL15 DIMM 1Rx8
Ukupno: 3494,00 kn
#2 - slabiji procesor, nemogućnost nadogradnje
1 x Gigabyte GA-F2A68HM-DS2 (SFM2+,DDR3,DVI/VGA,USB3.0,SATA III) mATX
1 x Memorija PC DDR3 8GB, 1600MHz PNY, bulk
1 x Procesor AMD Athlon II X4 845
Ukupno: 3016,00 kn
Staro 14.09.2016., 16:58   #9244
doorman
weliki pwner...
doorman's Avatar
Lokacija: čakovec
Postovi: 131
bok ekipica
bio bih vam vrlo zahvalan ako mi netko moze preporuciti konfu za fax - potrebe arhitekture (CAD, Photoshop, sketchup, renderiranje) znaci trebam dobar GPU i dobar CPU i htel bi SSD barem 128 gb i jos bi onda stavil nutra HDD koji imam doma
rang cijene je tam do max 5500 kn
hvala vam, puno, puno!
Lp,
Dorian
CPU: Intel Core 2 Duo E6300
MBO: Gigabyte 945P-S3
RAM: 2X1GB KingMAX i GoodRAM
GPU: ATi Radeon X1600
HDD: Hitachi HDP725025GLA380 (250 gb) & Hitachi HDT722516DLA380 (160 bg)
OPT: nec dvd r/rw
PSU: chieftech 440w
OS: Windows XPSP2 & Vista
Rijeci su isto kao i gomile ljudi, nije nuzno znati za sve...
J. B. Štulić
doorman je offline   Reply With Quote
Staro 15.09.2016., 10:26   #9245
besh
Datum registracije: Jul 2016
Lokacija: Đakovo
Postovi: 9
pozdrav
molio bih ocjenu slijedeće kofiguracije koja bi se koristila za igranje,filmove i internet:
1 x Asrock H110M-DGS (s1151,DDR4,USB 3.0,SATA III,LAN,DVI) mATX
1 x Procesor Intel Core i5 6402P
1 x Kingston 8GB 2133MHz DDR4 CL15
1 x HDD SEAGATE Barracuda (3.5",1TB,64MB,SATA III)
1 x SSD Scan Disc Z400s 128GB,
1x LITE ON DVDRW 24x SATA, black, bulk
1 x Gigabyte GeForce GTX 960, 2GB 128 bit DDR5
1 x Zalman T3 Mini-Tower ATX kućište, bez napajanja, crno
1.da li je što potrebno ili moguće (zbog uštede) mijenjat?
2.gdje bi bila najpovoljnija kupnja?
hvala
besh je offline   Reply With Quote
Staro 15.09.2016., 10:44   #9246
Doc
Postovi: 430
Dobro složeno. Nemaš baš ništa pametno na čemu bi mogao uštedjeti, sve je najjeftinije u svojoj klasi. Najpovoljnije je otići na nabavu i odabrati trgovinu.
Doc je offline   Reply With Quote
Staro 15.09.2016., 12:26   #9247
besh
Lokacija: Đakovo
Postovi: 9
,pozdrav
Zadnje izmijenjeno od: coconut. 15.09.2016. u 12:37.
Staro 15.09.2016., 13:18   #9248
Smartic
Smartic's Avatar
Postovi: 2,707
Kakva GTX 960
RX 470 Nitro 4GB(skoro ista cijena)/GTX 1060 3GB/RX 480 Nitro 4GB(200tinjak kuna skuplje). Najpovoljniji su uglavnom Protis, Centro i Supernet.
Staro 15.09.2016., 16:37   #9249
besh
Lokacija: Đakovo
Postovi: 9
ok,kako spojiti monitor sa 15 pinskim konektorom na recimo 470?
Staro 15.09.2016., 16:39   #9250
Postovi: 33,990
Staro 15.09.2016., 16:42   #9251
besh
Lokacija: Đakovo
Postovi: 9
Autor coconut Pregled postova
,samo sad su mi u jednoj trgovini rekli da to ne ide
Staro 15.09.2016., 16:44   #9252
nino
nino's Avatar
Postovi: 12,613
Samo pomocu trikova coconut
Sent from my D5803 using Tapatalk
Staro 15.09.2016., 16:44   #9253
Postovi: 33,990
Obično ga dobiješ s grafom. Tebi treba DVI (M)->VGA (Ž)
https://www.links.hr/hr/adapter-delo...-5-m-200300284
Staro 15.09.2016., 16:48   #9254
besh
Lokacija: Đakovo
Postovi: 9
da,to sam uzeo za GTX960 i radi,međutim iz trgovine mi je rečeno da se RX 470 ne može tako spojiti
Staro 15.09.2016., 16:51   #9255
nino
nino's Avatar
Postovi: 12,613
Cocunut, nemoze dvi-d spajat tako
Treba nu aktivni adapter pretvarac, a i onda je pitanje hoce li delat. Ima raznih sranja tu.
Staro 15.09.2016., 17:19   #9256
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Da, jer nove gpu mogu samo digitalni signal, adapter je funkcionirao sa dvi-i (koji podržava i analogni), a za dvi-d im treba konverter.
Moja neka računica je da se više isplati promjeniti monitor. Konverter je cca 200kn, nek postojeći monitor vrijedi bar par sto kn, a za cca 100 eura ima poštenih monitora (čan i VA panel). Za polovne sa dvi da ne govorim
Staro 15.09.2016., 18:13   #9257
Postovi: 33,990
Ispričavam se na svojoj neupućenosti.
Slažem se s kolegom Manuelom da bi mu bilo bolje promijeniti monitor.
Staro 16.09.2016., 03:01   #9258
PC_MasterRace
Datum registracije: Sep 2016
Postovi: 2
Pozdrav,
Trebao bi konfiguraciju za kompjuter nije mi bitno AMD/Intel bitno je da radi što bolje. Bez HDD, optičkog pogona, monitora i periferije za 4000kn i htio bi da je SSD unutra od 120Gb. Koristim kompjuter za faks autocad i takvi programi, a tu i tamo volim neku igricu upalit i dosta patim na sliku kod filmova. Uzeo bi to sve iz protisa kolko vidim tamo je najpovoljnije jedino ako imate neku drugu preporuku dobro bi došla
PC_MasterRace je offline   Reply With Quote
Staro 16.09.2016., 08:47   #9259
Doc
Postovi: 430
1 x Intel Skylake Core i5-6400 (2.7GHz, 6MB,LGA1151) box
1 x PNY DDR4 8GB, 2133MHz
1 x SSD SanDisk Z400s 128GB, 2.5” 7mm, SATA 6 Gbit/s - 60mj
1 x Zalman T1 PLUS, mATX, USB3.0 black
Ukupno: 4064,00 kn slaganje i dostava u cijeni
Staro 16.09.2016., 16:09   #9260
PC_MasterRace
Postovi: 2
Hvala puno. S koje stranice si našao te komponente i cijene?
Staro 16.09.2016., 23:04   #9261
Shinari
Lokacija: Požega
Postovi: 1
5000-5500 kn
molio bih pomoc,treba mi konfiguracija od 5000 do 5500 kn.
racunalo bi se koristilo za autocad,photoshop i ostale programe,te bi se ovisno o vremenu zaigralo nesto novije.ssd nije potreban.
znaci racunalo za sve namjene.
unaprijed hvala.
Shinari je offline   Reply With Quote
Staro 18.09.2016., 18:49   #9262
tutix
tutix's Avatar
Postovi: 4,069
Pozdrav,
Trebam preporuku sličnog računala za frenda. Uglavnom traži se konfiguracija do 3500-4000, za igranje, ali bez kućišta i sa SSD-om umjesto HDD-a.
Dvojba je oko procesora i grafičke. Isplati li se uzimati i5 za 500-tinjak HRK više uz ovu RX460 (to ispadne oko 3800 onda)? Ili je možda bolje staviti i3 i staviti neku malo jaču grafičku (ako postoji uopće nešto takvo)?
Hvala unaprijed
Autor Smartic Pregled postova
#1
Ukupno: 3494,00 kn
Staro 18.09.2016., 19:25   #9263
Smartic
Smartic's Avatar
Postovi: 2,707
@tutix
Matična ploča MSI H110M_PRO-VD (S1151, DDR4, USB3.1, USB2.0, SATA III, DVI, VGA, Audio, LAN)
SSD AD 120GB ASP580 2,5" bulk
Kingmax 1x8GB DDR4 2133 GLJG, KIN-8GB DDR4 2133
SAPPHIRE Video Card AMD Radeon RX 470 NITRO+ GDDR5 4GB/256bit, 1260MHz/1750MHz, PCI-E 3.0 x16
XFX PSU TS 430W, XFX-P1-430S-XXB9
4.017,61kn
Staro 19.09.2016., 19:36   #9264
tutix
tutix's Avatar
Postovi: 4,069
Hvala smartic
Samo pitanje, neće tu procesor biti usko grlo za RX 470? Planira se igrati na 1080p.
Staro 19.09.2016., 21:43   #9265
Smartic
Smartic's Avatar
Postovi: 2,707
Rekao bih da je baš na granici bottlenecka. Jasno da bi i5 bio malo bolji, ali je grafička poprilično bitnija. Uglavnom, s i3+RX 470 se mogu pošteno nafrljiti detalji
Staro 19.09.2016., 22:19   #9266
Bariarnil
Aiden Fierce
Bariarnil's Avatar
Datum registracije: Jan 2016
Postovi: 1,171
Slažem se.
the Bariarnil
Zadnje izmijenjeno od: coconut. 20.09.2016. u 06:11.
Bariarnil je offline   Reply With Quote
Staro 20.09.2016., 12:23   #9267
Tihomiy
Tihomiy's Avatar
Lokacija: Popovača
Postovi: 98
Autor tutix Pregled postova
Pozdrav,
Hvala unaprijed
Popeo se limit na 5000 kn al sve komplet bez monitora..treba i kuciste ..rjesio sam stari komp..
Tihomiy je offline   Reply With Quote
Staro 20.09.2016., 12:30   #9268
Doc
Postovi: 430
1 x Sapphire RX480 Nitro+, 4GB, 256bit GDDR5
1 x Fortron Hyper 500W, 80+ - 60mj.
Ukupno: 5089,00 kn slaganje i dostava u cijeni.
Staro 20.09.2016., 13:05   #9269
Tihomiy
Tihomiy's Avatar
Lokacija: Popovača
Postovi: 98
a kad bi se ubacio SSD? i gdje to koja trgovina?
Staro 20.09.2016., 13:35   #9270
yaya
Fali li nesto ovoj konfi i jel sve ok?
