Staro 14.01.2003., 17:04   #1
sc00pe
Postovi: 14
konfa 2.put
-- Cini mi se najisplativije kupiti kod INFO GAMAdi ali vi me odgovorite ...
hard disk 60,0 GB MAXTOR DiamondMax Plus 9 (6Y060L0), FDB motor, 7200 okr/min, 2Mb cache (U-ATA 133) 856,60
mbo ASUS A7N8X, nVidia nForce2 chipset, AGP 8x, ATX, Sound Realtek ALC650 5.1 + LAN 10/100Mbit o/b, U-ATA133, FSB333MHz, 3x184pin DDR400, USB 2.0 NOVO !!! 1.234,25
cpu CPU AMD Athlon XP 2400+, 1930 MHz, L1 128kB, L2 cache 256kB, socket 462 (socket A), BUS 266MHz NOVO !!! 1.796,11
cooler CPU Cooler Thermaltake Volcano 9 za AMD Duron, Thunderbird i Athlon XP (socket A), Smart & Silent , 1300- 4800okr/min, Variable Fan Speed Control NOVO !!! 184,22
memory DIMM 256 MB, DDR RAM, PC2700 (PC333), 184pin, brand name - INFINEON 663,18
kuciste Kućište MACOM MIDI Tower BMW Design BLACK, DLC-M76, 300W, ATX (4x5,25" + 1x3,5" vanjski utori + 2x3,5" unutarnji utori), AMD Approved, P4 Ready Best Buy !!! 303,96
vga VGA 128 MB DDR RAM Gainward, PowerPack Ultra/650 XP GeForce 4 Ti4200 chip, AGP 4x, 350MHz RAMDAC, Core Clock: 250MHz, Memory Clock: 444MHz, DVI/TV out 1685,58
fdd FDD 1.44 MB Alps 73,69
dvd DVD/CD-ROM TOSHIBA SD-M1712, DVD 16x/CD 48x/DVD-RAM 2x, 512Kb buffer, ATAPI IDE, tray, bulk 478,96
zvucnici WAVEMASTER 2.1 zvučnici 480W PMPO, M-2042, 80Hz-20kHz, 2 x satellites + subwoofer, Slim - Hi End Design, power on/off, volume control & tone control button 202,64
mis Miš LOGITECH Wheel Mouse Optical (Black Label M-BD69), wheel mouse, PS/2 ili USB, (optički, 3 tipke & scroll wheel), BLACK (crni), up to 800-dpi, OEM 147,37
tipkovnica Tipkovnica FUJITSU SIEMENS (Samsung) Multimedija SEM-M2A, Built-in external hot buttons (Internet, Mute, Vol. Up-Down, Stop, Play, Record...), HR, soft, PS/2 101,32
monitor 19" FUJITSU SIEMENS C994, Invar Shadow Mask, TCO99 (max1600x1200), 96kHz, digital, OSD, 0.24mm, 1280x1024@85Hz, WHITE BOX 1.611,89
UKUPNO 9339,76
16% popust na donsenje kupona iz bug-a 7845,40
Preko e-mail a sam saznao da mi mogu napraviti sve sa garancijom i ako ja njima donesem maticnu plocu pa cu vjerojatno umjesto one asusuove dovuci EPOX 8RDA+ po 1043 k iz VE-MIL-a.
sc00pe je offline   Reply With Quote
Staro 14.01.2003., 17:24   #2
Elven
Elven's Avatar
Datum registracije: Sep 2002
Postovi: 2,721
Re: konfa 2.put
1. Samo kod nekih komponenti si pisao NOVO!!, znaci li to da su ti oni dali potvrdu da ne prodaju nove komponente?
1.1. Salim se, to si copy-paste iz cjenika, a ovo su nove na ponudi, ne morate me odmah napast (ako ste mislili)
2. Mislim da se Fujitsu-Siemense tastature ne mogu kupiti posebno tj. odvojeno od cijele konfiguracije, koja naravno mora biti Fujitsu-Siemens, a tvoja to nije, zato ukoliko je moja tvrdnja istinita (provjeri je negdje u Siemensu, ili ce ti je potvrdit/demantirat neko s foruma) razmisli o porijeklu te tastature. Slicna stvar je bila sa Siemensovim kucistima koje si mogao nabaviti (a gdje drugdje) u Info Gami, koja se, naravno, ne mogu kupiti odvojeno. O Info Gami ti dovoljno govori cinjenica da se braticev frend se ekipom jednom igrao "ko ce dobit vise novih komponenti u kompu kupljenom kod Info Game".
3. Monitor je demo pretpostavljam, am I right?
4. Posto se cini da imas love, preporucam ti ATi 9500pro 128 i kupovinu u nekom ducanu koji je na boljem glasu (za moje prilike su to Ve-Mil i HgSpot)
Staro 14.01.2003., 17:54   #3
sc00pe
Postovi: 14
ne, nemam love - bas zato i kupujem u info gami gdje mogu dobiti 16 % popusta.
i da kopi pejstao sam (sherlock holmese... stvarno tesko za shvatit).
WTF?
Staro 14.01.2003., 18:35   #4
Elven
Elven's Avatar
Postovi: 2,721
moras znati da kupnja u Info Gami moze biti veliki rizik, a ako nesto crkne nece dugo zamjeniti 8meni je npr. riknuo novi monitor, lijepo pise da je rok zamjene monitora 45 dana!!, ali ko lud moze 45 dana bez monitora, pa sam lijepo poslao starog tamo nakon 20ak dana i on se fino vratio sa monitorom (istina, to je bio demo monitor)
WTF?
Demo monitori su (po terminima info game) rabljeni monitori, koji su radili kao izlozbeni primjerci. Moj je naprimjer kupljen 21.12. 2001., a proizveden je "November 2000". Nisam dosad imao nekih velikih problema, slika je zadovoljavajuca, jednako je i sa monitorom od frenda (Fujtisu e17nesto), ali mnogi ce ti reci da treba od takvih monitora bjezat ko od crnog vraga. sorry, ali kad su monitori u pitanju, nisam dovoljno kompetentan da dam svoje misljenje, mogu ti samo dati iskustva sa demo monitorima (a ona za sad nisu losa), iako bi ti ja radje preporucio neki novi ADI iz Ve-Mila, ili bilo koji novi 17", jer je 1600kn premalo za novi 19 (osim KDS). Valjda mozes kupit tamo konfu bez monitora.
Zadnje izmijenjeno od: Elven. 15.01.2003. u 08:47.
Staro 14.01.2003., 20:29   #5
RAK
Feldwebel
RAK's Avatar
Datum registracije: Feb 2002
Lokacija: bolnica
Postovi: 3,739
Pazi da te ne bi iznenadil cijena koju ćeš platiti u Info-gami. Ne želim te pokolebati. Izvoli proćitati mail i vrati se sa saznanjima. Ja saznao. Sada je red na mlađe da se školuju.
Mi "starci" od 23 godine znamo.
Tih kao mačka
Brz kao gepard
Jak kao lav
Elegantan kao leopard
Nisam to ja, to je moj komp.
Staro 14.01.2003., 23:17   #6
Aeron
Aeron's Avatar
Datum registracije: Jan 2002
Postovi: 295
Aeron je offline   Reply With Quote
Staro 15.01.2003., 15:45   #7
sc00pe
Postovi: 14
Poslat cu im request za ponudu.
Naprosto ne vjerujem da su tak sjebani.
Staro 16.01.2003., 13:24   #8
Elven
Elven's Avatar
Postovi: 2,721
dobro, ali molim te javi se cim ti nesto krene po zlu. ne zato da bi ti mogli reci "we told you so" nego da podijelis iskustva s nama
Staro 16.01.2003., 13:33   #9
RAK
Feldwebel
RAK's Avatar
Lokacija: bolnica
Postovi: 3,739
Radi se o jednostavnom markentiškom triku. Radi pa im opravdavam.
Osnovna cijena je toliko i toliko. Cijena za gotovinu je 13% niža. Popust od 16% nije na cijenu u gotovini nego na osnovnu. S pravim popustom od 3% si možeš rit obrisati kada je cijena ionako viša za 4-5% u odnosu na vrijeme prije popusta.
sc00pe mi je poslao i primjer pa ako nekoga baš interesira...
Tih kao mačka
Brz kao gepard
Jak kao lav
Staro 16.01.2003., 17:52   #10
Aeron
Aeron's Avatar
Postovi: 295
Pa stavi primjer...nije da ga je teško napisat valjda
Staro 16.01.2003., 18:55   #11
RAK
Feldwebel
RAK's Avatar
Lokacija: bolnica
Postovi: 3,739
Ona stvar sa početka teksta košta poprilici onoliko koliko je bez popusta.
Ista, kompatibilna ili sl. stvar košta u drugim trgovinama isto ili manje.
Računaj pa ćeš vidjeti.
Tih kao mačka
Brz kao gepard
Jak kao lav
