Nvidia Geforce WHQL Driver Info Thread
Poštovani kolege, obzirom da je do sada bila navika i praksa da se svakim izlaskom novog nVidia drivera otvara i nova tema, odlučili smo da sada pa ubuduće imamo jednu temu za drivere. Naravno, slobodni ste i dalje linkati driver i napisati changelog kao i u prijašnjim temama, samo što ćemo sada sve izlaske novih drivera popratiti u ovoj temi, bez naknadnih otvaranja novih. Zahvaljujem ![]() |
Zmaj od Bosne
Datum registracije: Dec 2011
Postovi: 218
New feature and fixes in driver 372.54 Game Ready - Provides the optimal experience for No Man’s Sky, Deus Ex: Mankind Divided, Obduction, F1 2016, and the Open Beta for Paragon http://www.geforce.com/drivers New Features - Support for updated BatteryBoost technology. Enabled mclk switches on 144 Hz G-SYNC monitors in multi-monitor use cases in order to lower power consumption. Support OpenGL VR SDK 1.4 (Windows). Added a Windows cross-API interop between Vulkan and DirectX 11. This enables Vulkan app compatibility with existing DirectX 11-based HMD runtimes. Added driver support for DXGI 2 VR. SLI Profile - Added or updated the following SLI profiles: Deus Ex: Mankind Divided - added DirectX 11 SLI profile No Man’s Sky - added (Beta) SLI profile Space Engineers - added DirectX 11 SLI profile Fixes: [368.69, GP104] Corrected high DPC latency. [Space Engineers] Need SLI profile for DirectX 11 version. {Mac OS X] Higher quality CUDA icon needed to take advantage of Retina display. [368.69, GeForce GTX 1080] CUDA 7.5 and CUDA 8.0RC fail bandwidth test. [SLI, Witcher 3] Shadow darkness intensity changes randomly during gameplay. [368.81, Windows 10 x64] Netflix Windows Store app stutters in full-screen mode. [GeForce GTX 980 Ti, Windows 10 x64] Low GPU usage/scaling in Guild Wars 2 with SLI + Surround. [Call of Duty: Black Ops III] Illegal instruction crashes occur on NVIDIA hardware. [Quadro K5000, Windows 10 x64] Hyper-threading performance loss of 4–16 times with recent Quadro drivers compared to 354.56. [364.51, Windows 10] After driver update, Steam controller on-screen keyboard shows only white screen. [SLI, 368.39, GP104] GTX 1080 SLI can't be enabled if third graphics card installed in system. High GPU idle clocks occur with two DisplayPort displays. [1739442] [Steam VR] Vive on the Link Box mini-DisplayPort is not detected after a sleep/resume or a hot unplug/plug. RFE: Vulkan ability to auto-promote border-less full screen to full-screen exclusive. [368.39, Windows 10, Windows 8] Micro-stuttering and lower OpenGL performance compared to Windows 7 occurs on Optimus notebooks. ![]()
Datum registracije: Feb 2015
Postovi: 218
Izašao je novi driver: WHQL 372.70 http://www.geforce.com/drivers/results/107008 Game Ready Driver Release Notes http://us.download.nvidia.com/Window...ease-notes.pdf |
aka Edo, aka Syncros
Postovi: 1,771
Meni je ovaj 372.54 rušio Handbrake. Prilikom dodavanja video fajla u Handbrake Nvidia bi javila ono unable to remove device i puff nema drivera više. Restartam stroj i sve ok dok ne probam ponovno. Win7 je u pitanju. Sent from my G2 |
Datum registracije: Aug 2008
Lokacija: Gospić
Postovi: 452
I ja sam presao na .70 ,i NAPOKON mi se rijesio jedan problem,kojeg nisam imao na GTX 970 a na GTX 1060 jesam sa ovom verzijom prije .70 ... Naime problem je bio taj sto dok gledam na jednom monitoru film/seriju a na drugom monitoru igram Football Manager trzala je igra,tocnije imala microsttuter i video je imao neke trzaje,kao da grafa nije imala snage za to dvoje ![]() ![]()
http://forum.pcekspert.com/faq.php |
#9 | |
Aiden Fierce
Datum registracije: Jan 2016
Postovi: 1,171
To je čak frustrirajuće.Daj mi reci kolko si para dao za 1060,i gdje si kupio?I kolko je glasna ![]()
Lokacija: Gospić
Postovi: 452
Ma to je bio dio neke zamjene s frendom,970 za 1060 ![]() ![]() Evo,jos gledam seriju i igram Football Manager,grafa je na 47 stupnjeva,ventovi nula ![]()
Datum registracije: Mar 2015
Lokacija: Doma
Postovi: 144
Zmaj od Bosne
Postovi: 218
NVIDIA GeForce 375.57 WHQL Game Ready Drivers Battlefield 1, Titanfall 2, Civilization 6 Game Ready Driver Released
Zmaj od Bosne
Postovi: 218
Oprez kada instalirate nove 375.57 driver Known issue Windows 10: Windows Tile Crashing Issue + Windows Mail Crashing Issue Acknowledged -- Will be hotfixed [Forza Horizon 3] Possible driver memory leak. [1826143] [SLI] [GeForce GTX 970M] Level loading hangs in Gears of War 4. [1826307] [GeForce GTX 1070][Alienware Graphics Amplifier] The graphics card is not detected upon installing the driver. [200236450] [347.09, GM204] Blank screen observed on an ASUS Tiled display when system resumes from shutdown or hibernation with Fast boot option enabled from BIOS.[1591053] Known issue Windows 7: [SLI] Blank display is observed on disabling SLI with two displays connected. [200172046]
#16 |
Postovi: 218
Novi 375.70 driver http://www.guru3d.com/files-details/...-download.html koji se i nije pokazao kao najidealniji te je izdan hotfix 375.76 http://www.guru3d.com/files-details/...-download.html |
#17 |
Lokacija: Rijeka / Grobnik
Postovi: 4,158
nesto se spominje bloatware i "spija" s*anja u novijim driverima. jel to tako? mene osobno samo interesira driver i physx. ostatak nikad ne stavljam... edit: http://forums.guru3d.com/showthread.php?t=410729&page=2 jel netko ovdje proba ovo iz posta 43? mislim da cu odsad tako instaliravat... Zadnje izmijenjeno od: geronimo_2. 04.11.2016. u 09:36. |
#18 |
Lokacija: Kloštar Podravski
Postovi: 1,019
Izašao je novi driver, 375.86. Ima li koga hrabrog da isproba? ![]() http://www.geforce.com/drivers/results/111026
Tko nije skršio Socket A procesor na bilo koji način, neka prvi baci kamen! |
#19 | |
Postovi: 218
![]() GeForce 375.86 WHQL Windows 10 Fixed Issues [375.70] Smearing and ghosting reported with latest NVIDIA drivers. [1834593] [375.63, GeForce GTX 980 Ti] Artifacts in GIFs after driver update. [1831043] [SLI, GeForce GTX 1080] Unable to enable Surround with SLI HB bridge; singleribbon SLI bridge works fine. [1827915] Battle Carnival is falsely detected as Bionic Commando. [1825885] [G-SYNC, 372.70, GeForce GTX 1080] G-SYNC monitor flickers at 144 Hz, not reproduced with 368.81. [1822079] [SLI, 372.54] Wrong memory usage values in games on Pascal GPUs in SLI mode. [1801306] [G-SYNC, GP102] Periodic flickering on desktop at 165 Hz when dragging or resizing windows with G-SYNC enabled. [1799297] Windows 8.1/Windows 8/Windows 7 Fixed Issues GeForce Experience icon missing on system notification tray. [200248470] [GeForce GTX 980 Ti] Unable to detect multiple TV models from Loewe Technologies GmbH. [1788948] Zadnje izmijenjeno od: Glavas_ZG. 17.11.2016. u 07:47. |
#20 | |
Lokacija: Grobnik - Rijeka
Postovi: 3,253
#22 |
Postovi: 3,253
Vidim ja da meni Mafia 3 još lošije radi nego neki dan. Evo možebitnog razloga http://www.pcgamer.com/nvidias-lates...ffer_pcgamerfb |
#23 |
Postovi: 1,019
E hebi ga sad, ja instalirao ove zadnje jučer, jer sam morao maknuti one hotfix 375.76 jer su bili u banani, fajl "C:\Users\xyz\AppData\Local\NVIDIA\NvBackend\backend.log" mi je u kratkom roku bio narastao na 500+ GB! ![]() Nvidia u zadnje vrijeme nikako da izbaci dobre drivere. ![]()
#25 | |
Postovi: 218
https://www.techpowerup.com/227928/n...hotfix-drivers |
#28 |
Datum registracije: Aug 2011
Postovi: 533
Da li itko ima problema sa crashanjem drivera ( nvlddmkm has stopped working ). Manifestira se kao crni ekran od par sekundi. Jedino što uspješno rješava problem je "prefer maximum performance" mode u nvidia control panelu ali mi se onda grafa nikad ne downclocka što je dosta iritantno. Probao sam 10 različitih drivera s prethodnim čišćenjem DDU-om, ne pomaze. Konfa je gigabyte z87m-d3h, MSI gtx960 4GB, 4670k, 16gb kingston rama. Corsair ax850 Windows 10 64bit |
#30 |
Postovi: 533
