Staro 05.07.2016., 10:31   #211
Neo-ST
Neo-ST's Avatar
Postovi: 8,375
Želimo live stream
Sent from my mobile using Tapatalk
Staro 05.07.2016., 11:18   #212
Volume
Datum registracije: Sep 2012
Postovi: 418
Ajde molin te oćeš isprobati jetove pa vidit ima li i dalje onaj sweetspot za brzinu (313) ili su šta minjali u vezi toga
Sent from my ONE E1003 using Tapatalk
Volume je offline   Reply With Quote
Staro 06.07.2016., 11:29   #213
Neo-ST
Neo-ST's Avatar
Postovi: 8,375
7:45
Zadnje izmijenjeno od: Neo-ST. 06.07.2016. u 11:36.
Staro 06.07.2016., 11:31   #214
Volume
Postovi: 418
Evo sinoć i meni stiga invite za alphu
Staro 06.07.2016., 11:50   #215
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Da, da.Izbacili su novi batch pozivnica i dodali XBONE i PS4 u Alpha-u, ali ovo su zadnje.Navodno bi se uskoro trebale pojaviti sluzbene informacije o closed BETA-i.
All you have is your fire and the place you need to reach.
Don't you ever tame your demons, always keep them on a leash.
Alph4Dawg je offline   Reply With Quote
Staro 15.07.2016., 10:55   #216
Igorr
Flajing super šiiiip
Igorr's Avatar
Lokacija: Zd -- Zg
Postovi: 1,683
5.1.4 setup:
Zvučnici - 2x Arendal 1723 S monitors, 1x 1723 S center, 4x 1961 height, 2x 1961 surround, XTZ 12.17 EDGE
Amps - Marantz Cinema 40 + ROTEL RMB-1585
Igorr je online   Reply With Quote
Staro 15.07.2016., 15:51   #217
jurbAs
jurbAs's Avatar
Postovi: 2,583
sigurno nabavljam napokon normalan FPS....
Staro 15.07.2016., 19:04   #218
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Autor jurbAs Pregled postova
Po cemu si to zakljucio?
Staro 15.07.2016., 19:51   #219
Dottore
Dottore's Avatar
Postovi: 7,656
Autor Volume Pregled postova
Evo sinoć i meni stiga invite za alphu http://uploads.tapatalk-cdn.com/2016...df6542eec3.jpg
Kako češ igrati kad si prodao komp?
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 15.07.2016., 20:27   #220
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
Autor Igorr Pregled postova
ovo zaista izgleda jako dobro, sad jos da call of duty napravi remastered verziju cod dvojke uff miline.
Staro 16.07.2016., 11:16   #221
Volume
Postovi: 418
Autor Dottore Pregled postova
Uzea sam skylake konfiguraciju, zato sam ono i proda
Al ionako se nisam baš naigra alphe, premalo slobodnog vrimena...
Staro 17.07.2016., 16:35   #222
Dottore
Dottore's Avatar
Postovi: 7,656
Koju skejlejk? Nigdje ne vdin.
edit?
jeli izašla beta?
Baš me oduševila pumperica
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 20.07.2016., 11:02   #223
jurbAs
jurbAs's Avatar
Postovi: 2,583
Autor Alph4Dawg Pregled postova
Po prilozenom videu nisam ja imao srece kao ti da igram
Pa normalno izgleda ok nauružanje lijepa grafika nadam se da su hitbox ispravili i to je to.
Da izbace COD 2 remasterd ja bi bio najsretniji voli WW tematiku.
Staro 20.07.2016., 13:23   #224
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
pa hitbox je riješen već na bf4. Nadam se da neće morat ić ispočetka kao na svakom bf do sad.
Staro 22.07.2016., 03:01   #225
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
+1 mozda i naprave, izbacuju modern warfare remastered, sad je abttlefield opet pokrenuo tu WW tematiku, a cod2 samo treba osvjeziti grafikom, sve ostalo ostaviti original.
Staro 23.07.2016., 12:49   #226
Ati freak
aka Striko
Ati freak's Avatar
Lokacija: Krapina - Zagreb
Postovi: 1,742
Autor Blue_Fatal1ty Pregled postova
Je, zato je ekipa "oduševljena" samom igrom.
Gadno je kad ti loše postane dobro.
Staro 23.07.2016., 16:37   #227
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Ne u potpunosti.Jos uvijek zna failat da ni sam ne razumijem WTF just happened 'n' how it happened.
Ali, da, svakako su poboljsali hitreg i recimo da je trenutno stanje zadovoljavajuce.
Sto se tice BF1, nisam imao problema sa hitregom.
TTK je, doduse, vrlo visok.Plus, hipfire je vise zahvalan nego ADS...
Serveri su vrtili na 60Hz default.
Staro 25.07.2016., 08:07   #228
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
Kad bi trebala krenut beta?
Staro 25.07.2016., 08:40   #229
jurbAs
jurbAs's Avatar
Postovi: 2,583
ako neko uleti u betu neka napise svoje iskustvo tu cisto da mi ostali smrtnici znamo sto mozemo ocekivati u 10-11mj
Staro 25.07.2016., 11:08   #230
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Ako se ne varam (nije sluzbeno potvrdeno), nekad poslije Gamescom-a, tamo krajem kolovoza.
Staro 25.07.2016., 17:36   #231
junkieee
junkieee's Avatar
Postovi: 990
Spominje se 24.8 negdje ako se ne varam.
Nego pošto si ti jedan od rijetkih koji je zaigrao alphu da mi reci iz prve ruke kakva je situacija sa hitregom? Jesu ga stvarno popravili?
Staro 25.07.2016., 18:23   #232
fler
These go to 11
fler's Avatar
Lokacija: Czarnia
Postovi: 1,849
Beta će biti otvorena za sve, nemaš frke
Staro 25.07.2016., 18:59   #233
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Autor junkieee Pregled postova
Pa, da budem skroz iskren, nisam imao problema sa hitregom.Serveri su po defaultu radili na 60Hz-a.
Kao sto sam i napisao, hipfire je vise zahvalan nego ADS.Eh, sad, veliku vecinu vremena smo se napucavali hipfire-om, pa nisam skroz siguran kakav je hitreg.
Weapon spread je ogroman i pritom mislim da je zbilja uzasno ogroman.Opet, moguce da to prikriva situaciju sa hitregom, jer su oruzja namjerno dizajnirana da budu neprecizna (kao, WW1 shema, ble) i da imaju ogroman bullet spread.
S druge strane, oruzja koja imaju optiku i s kojima sam imao priliku zaigrati, svaki metak je sjedao na predvideno mjesto.Naravno, bilo je situacija gdje sam precizno gadao i nisam dobio povratnu informaciju da je meta pogodena.Medutim, opet; moguce da je to samo radi bullet spreada i namjernog dizajna oruzja da budu neprecizna.
Sto se mene tice, mislim da moramo sacekati open BETA-u (jer je to vise nekakav demo, nego BETA) da bi saznali koja je stvarna situacija sa hitregom.
EDIT: Cisto da napomenem da sam zadovoljan hitregom generalno. Sasvim zadovoljavajuce i puno, puno bolje odraden posao nego u BF4.
Staro 26.07.2016., 09:18   #234
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
Ja sad ulijećem kao padobranac u temu ovako izvan svega
Ovo mi se jako sviđa što sam vidio u vezi BF1, i sigurno ću ovo kupiti i zaigrati
Samo me zanima, koja je generalno fora sa pristupima u closed Alpha, open Beta? Kaj trebam bit developer, youtuber ili?
Kome treba platit?
Staro 26.07.2016., 10:48   #235
Postovi: 16,847
Generalno je random. Prijaviš se negdje, i zovu te. Vjerojatno neki youtuberi ili pretplatnici imaju vjerojatno nekakve "veze" za dobiti, ali ja sam par puta dobio upad, a nemam nikakve špage.
Staro 26.07.2016., 12:57   #236
Tex Willer
Tex Willer's Avatar
Postovi: 280
Prijaviš se ovdje: https://www.battlefield.com/community/insider
i čekaš
Origin: Dead_Body_cRo
Tex Willer je offline   Reply With Quote
Staro 28.07.2016., 22:55   #237
Glavas_ZG
Datum registracije: Feb 2015
Postovi: 218
Izgleda su povećali broj prijatelja koje se može dodati na battlelogu sa 100 na više, tako da, add me Glavas_ZG
Glavas_ZG je offline   Reply With Quote
Staro 30.07.2016., 00:35   #238
georgy
georgy's Avatar
Postovi: 408
60
georgy je offline   Reply With Quote
Staro 06.08.2016., 13:23   #239
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
Bez potpisa.
Staro 06.08.2016., 14:55   #240
Dottore
Dottore's Avatar
Postovi: 7,656
Zanimljivo izgledaju.
Koliko vidim, po alphi jednoj mapi na youtube zauzeće RAM vuče cca 5,3 do 7Gb.
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
