Staro 01.06.2016., 20:58   #1621
cccp
cccp's Avatar
Datum registracije: Feb 2004
Postovi: 1,030
Mislio sam biti Bristol Ridge + AM4 early adopter, ali izgleda ništa od toga. Neću više čekati.
cccp je offline   Reply With Quote
Staro 04.06.2016., 19:14   #1622
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
AMD AM4 Motherboard Spotted With Bristol Ridge A12-9800 Processor – Featured on HP OEM Machine
Fala kurcu. Barem su slike krenule leakati. AM4 is alive!
Kontradiktorne informacije o kompatibilnosti coolera (thermalright je rekao da paše)
One of the first to officially jump on the train is Noctua, which during the Computex 2016 show a mounting kit for socket AM4 will be used by Bristol Ridge and Zen-based Summit Ridge . On site reveals the company that both the distance between the holes on the motherboard to the height of the processor socket is higher, thus breaking more than 10 years of compatibility.
March 2006 launched the AMD socket AM2 processor family Athlon 64 X2. The base has since evolved into AM2 + (Phenom), AM3 (Phenom II), and finally the current AM3 + (AMD FX). Same mounting device has also been used for the CPU cooler to the FM1 (Llano), FM2 (Trinity) and FM2 + (Kaveri).
AMD breaks compatibility is not a problem for the owner of a cooler from Noctua and retains proof of purchase. The company maintains previous policy of sending out the mounting kit for new sockets - at no extra cost. This means that even 10-year-old Noctua coolers can be used with socket AM4.
wtf
Zadnje izmijenjeno od: Manuel Calavera. 04.06.2016. u 20:01.
Staro 04.06.2016., 22:02   #1623
vedranzeman
Lokacija: Kloštar Podravski
Postovi: 1,019
Vidi se po fotki ploče da su prešli s pravokutnog na kvadratni raspored rupa, znači zbogom kompatibilnosti.
Al ima to i svoje prednosti, u vidu mogućnosti montaže coolera u sva četiri smjera, te boljem raspoređivanju opterećenja.
Thermaright je kasnije napisao da im je AMD Germany poslao krivu informaciju vezanu uz kompatibilnost, ali originalna informacija se već bila proširila.
Tko nije skršio Socket A procesor na bilo koji način, neka prvi baci kamen!
vedranzeman je offline   Reply With Quote
Staro 08.06.2016., 16:58   #1624
Manuel Calavera
Postovi: 14,584
Staro 08.06.2016., 17:12   #1625
Bariarnil
Aiden Fierce
Bariarnil's Avatar
Datum registracije: Jan 2016
Postovi: 1,171
Fak
the Bariarnil
Bariarnil je offline   Reply With Quote
Staro 08.06.2016., 23:01   #1626
Zvone2772
interferometar
Zvone2772's Avatar
Postovi: 768
Zvone2772 je offline   Reply With Quote
Staro 24.06.2016., 00:25   #1627
Manuel Calavera
Postovi: 14,584
Staro 26.06.2016., 23:01   #1628
Manuel Calavera
Postovi: 14,584
Staro 30.06.2016., 22:01   #1629
NateC
Datum registracije: Jun 2014
Postovi: 199
Nadam se da će AMD konačno riješiti problem prevelikog TDPa, kao što su u grafama to rješili. 200W TDP za FX 9590 je previše.
NateC je offline   Reply With Quote
Staro 01.07.2016., 00:46   #1630
Bariarnil
Aiden Fierce
Bariarnil's Avatar
Postovi: 1,171
Autor NateC Pregled postova
Bilo je 220w
Ali nije 9590 problem.To je procesor na 5ghz
I intelov tdp bi tada bio viši.Problem je performans per watt.Tu je AMD uzas
the Bariarnil
Staro 02.07.2016., 00:47   #1631
Manuel Calavera
Postovi: 14,584
Staro 03.07.2016., 22:54   #1632
Nick7
Lokacija: Velika Gorica
Postovi: 1,519
Hmmm.. jedino sto mene zabrinjava tolika kolicna core-a po socketu.
U principu to znaci dosta slabi IPC.
Staro 03.07.2016., 23:02   #1633
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Zasto bi kolicina jezgri imala veze s IPC-om?
Staro 04.07.2016., 10:01   #1634
Nick7
Postovi: 1,519
Zato sto visoki IPC zahtjeva odr. broj tranzistora.
A jos uvijek je svaki 'core' ogranicen velicinom, pogotovo zbog zagrijavanja.
Zato i u postojecim arhitekturama, ako vec i uspiju ugurati puno core-a, oni rade na dosta nizim taktovima od onih s manje core-a.
Uzmi samo za primjer Intel procesore.
Jedina 'pomoc' su turbo frekvencije dok je svega par core-a optereceno.
Staro 04.07.2016., 13:05   #1635
Manuel Calavera
Postovi: 14,584
I da je tako, IMO bolje da više jezgri dođe u manistream kategoriju (recimo 6 ispod 3000kn), nego karikiram 10% bolj ipc.
Mada je mislim da se tu više radi o termalijama, zbog toga 2011v3 procesori sa više jezgri imaju manji clock
Staro 21.07.2016., 22:12   #1636
Manuel Calavera
Postovi: 14,584
Staro 21.07.2016., 22:59   #1637
Cuky
jedan i jedini :D
Cuky's Avatar
Lokacija: novi zagreb
Postovi: 5,227
Prekokrasno. Samo da budu kolko tolko u jednakom odnosu snaga s intelom pa da konacno bude neke konkurentnosti opet.
Staro 22.07.2016., 10:13   #1638
markecSMB
Lokacija: Cro
Postovi: 1,028
Autor čuks Pregled postova
Kako je ovo sve rekla kazala, meni se ne čini da nije baš sjajno jer prema navedenom je takt 2.8 GHz s boost 3,2.
I sad s 70% većim IPC od prethodne arhitekture (kako tvrdi amd), al s toliko manjim taktom ne izgleda dobro.
Moar coarz nije uvijek (odnosno jako jako jako rijetko) bolje, čak ni u DX 12 ni u VULKANU.
Evo primjera R9 390x s i7 6700k i i7 5960x u AOS
Dakle flagship od intela HEDTP s AMD titlom, optimiranim i vrlo vjerojatno jednom od rijetkih igri kod kojeg će bit znatna razlika (puno draw calla, jer ima puno malih jedinica i efekata).
http://www.pcper.com/image/view/6035...n=node%2F63600
I intel mainstreem i7 6700k je bolji.
Ako AMD i bude napravio za sebe revoluciju pa došao do i7 5960x performansi, čak i u DX naslovu u najboljim uvijetima će teško parirat intelu.
Kog vesele brojevi jezgri, moći će se veselit, al u praksi, čisto sumljam da će bit blizu intelu. Tak da će opet bit više jezgri, za manju lovu. Ko vrti cinebnch i winzip/winrar će profitirat, a ko vrti igre, ići će sporije.
Staro 22.07.2016., 10:47   #1639
MadBoY
MadModerator
MadBoY's Avatar
Lokacija: N/A
Postovi: 5,195
8 jezgreni proc ionako nije namjenjem gamerima. To ce biti CPU od skoro 1000 dolara. Quad core bi u finalnoj verziji trebao imati vece clockove. Mogao bi Zen ispasti jako dobar, ako quad core ostane na 65w TDP s 3,5-3,6 GHz clockovima.
Staro 22.07.2016., 11:41   #1640
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Autor MadBoY Pregled postova
Ja se kladim da će biti max $400
Staro 22.07.2016., 13:24   #1641
Manuel Calavera
Postovi: 14,584
Inače 8 core je kako se spominjalo 95w, kao što smo pričali ranije negdje mora biti trik jer su intelovi 8 core 140w. Dakle ili su slabiji, manji clock i sl. U biti vrlo je izvjesno kao što je hawker još pričao da " amd guru" the stilt misli da će imati manji clock od intela i lošiji OC potencijal, što je logično zbog proizvodnog procesa. To su prvi inžinjerski primjerci, clock naravno još može narasti
Staro 22.07.2016., 20:01   #1642
Bariarnil
Aiden Fierce
Bariarnil's Avatar
Postovi: 1,171
Aha već si posrao AMD-ov IPC gain :P
the Bariarnil
Staro 22.07.2016., 21:16   #1643
Manuel Calavera
Postovi: 14,584
Ja mislim da će hexa core + smt sigurno biti ispod 3000kn, sumnjam da će biti jeftiniji od intelovih i7 quadova. 8 core će biti iznad 3000kn sigurno, ali ne vjerujem da će cijenom biti blizu intelovim 8 core (možda 3500-4000kn). Quad (kojeg navodno neće biti odmah po lounchu) će ziher biti jeftiniji od intelovih i5-ica, ali ne jeftiniji od i3-ica, vjerojatno nešto skuplji. Taman popuni te rupe od intela
Staro 22.07.2016., 21:25   #1644
Bariarnil
Aiden Fierce
Bariarnil's Avatar
Postovi: 1,171
Agreed
the Bariarnil
Staro 22.07.2016., 22:18   #1645
MikaHR
Postovi: 1,264
MikaHR je offline   Reply With Quote
Staro 22.07.2016., 22:45   #1646
Bariarnil
Aiden Fierce
Bariarnil's Avatar
Postovi: 1,171
wccftech i njihova kontrola glasina
the Bariarnil
Staro 22.07.2016., 23:30   #1647
Manuel Calavera
Postovi: 14,584
Kakve glasine ako donose službene izjave sa "earnings call"
Wccftech odličan ove godine, više su ćoraka imali guru3d i sl.
Staro 23.07.2016., 00:22   #1648
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Autor Bariarnil Pregled postova
Nisam, posrao sam tvoje bezvezne negativne postove
Na pcadvisor sajtu su čak optimističniji od mene:
"AMD Zen UK price rumours: How much will the AMD Zen cost?
As the architecture has only been recently announced, there is no current news about its price.
However, we can predict a few price points, depending on the core-count of the processors:
FX-Zen Quad Core: Ł80 incl VAT
FX-Zen Six Core: Ł120 incl VAT
FX-Zen Eight Core: Ł180 incl VAT
APU-Zen Quad Core: Ł100 incl VAT
Staro 23.07.2016., 00:54   #1649
Manuel Calavera
Postovi: 14,584
Mislim da su im te cijene izrazito optimistične (čak i da zen bude ispod svakih očekivanja). U UK i3 6100 košta cca 110 funti, a oni čisti quad zen cijene 80 (860K je 60)
Staro 23.07.2016., 00:55   #1650
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
Shitty prediction
Dodaj oko 50% na svaku ovu cijenu.
