Lokacija: Lokacija
Postovi: 210
MSI K8N NEO4-fi
Jel imao tko iskustava s njom? Koja razlika izmejdu te i MSI K8N NEO4 Platinum? |
Lokacija: Lokacija
Postovi: 210
Zar nitko nema ovu plocu? Stvarno sam se nadao da cu ovdje dobit odgovor, ipak je ovo "pcekspert" forum... Izgleda da od ovog "pcekspert" moze ostat samo "pc"... steta... lame |
Postovi: 7,568
MSI Neo4 Platinum: ________________ • Supports Socket 939 for AMD® Athlon™ 64 FX / Athlon™ 64 processor • Supports up to 3500+, 3800+ Athlon 64 FX 53, or higher CPU Chipset • NVIDIA® nForce4 Ultra Chipset - HyperTransport link to the AMD Athlon 64/Athlon 64 FX CPU - HyperTransport supporting speed up to 1GHz (2000MT/s) - Supports PCI Express x16/x1 interface - Two independent SATA controllers, for four drives - Dual Fast ATA-133 IDE controllers - IEEE 802.3 NVIDIA MAC for 1000BASE-T Main Memory • Supports dual channel DDR 266/333/400, using four 184-pin DDR DIMMs. • Supports a maximum memory size up to 4GB without ECC. • Supports 2.5v DDR SDRAM DIMM. Slots • One PCI Express x16 slot (supports PCI Express Bus specification v1.0a compliant) • One PCI Express x4 slots (support PCI Express x2 only) • One PCI Express x1 slots (support PCI Express Bus specification v1.0a compliant) • Four 32-bit v2.3 Master PCI bus slots (support 3.3v/5v PCI bus interface). On-Board IDE • An IDE controller on the NVIDIA nForce4 Ultra chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA133/100/66 operation modes. - Can connect up to 4 IDE devices On-Board SATA • NV RAID supports 4 SATA II ports(SATA 1 to 4). Transfer rate is up to 300MB/s. NV RAID (Software) • Supports up to 4 SATA and 4 ATA133 Hard drives - RAID 0 or 1, 0+1, JBOD is supported - RAID function available for ATA133+SATA H/D drives Silicon Image's SATARAID5™ (Software) • RAID 0 or 1, RAID5, RAID10, and JBOD groups are supported • Support up to 4 SATA devices connected to a single controller Audio • 7.1 channel audio codec RealTek ALC850. - Compliance with AC97 v2.3 Spec. - Meet PC2001 audio performance requirement. LAN • Supports dual LAN jacks - 1 LAN supports 10/100/1000 Fast Ethernet by Marvell 88E1111 PHY - 1 LAN supports 10/100/1000 Fast Ethernet by Marvell 88E8053 IEEE1394 • VIA 6307 chipset - Supports up to two 1394 ports. (Rear panel x1, pinheader x1) - Transfer rate is up to 400Mbps On-Board Peripherals On-Board Peripherals include: - 1 floppy port supports 1 FDD with 360K, 720K, 1.2M, 1.44M and 2.88Mbytes - 1 serial port - 1 parallel port supports SPP/EPP/ECP mode - 1 Audio jack(5-in-1), coaxial/fiber SPDIF out - 1 IrDA pinheader - 1 D-Bracket2 pinheader - 10 USB 2.0 ports (Rear x 4 / Front x 6) - 2 RJ45 LAN jacks - 2 IEEE 1394 connectors (Rear x 1/ Front x 1) MSI Neo4-F: __________ Supports Socket 939 for AMD® Athlon™ 64 FX / Athlon™ 64 processor • Supports up to 3500+, 3800+, Athlon 64 FX 53(55), or higher CPU Chipset • NVIDIA® nForce4 Ultra Chipset - HyperTransport link to the AMD Athlon 64/Athlon 64 FX CPU - HyperTransport supporting speed up to 1GHz (2000MT/s) - Supports PCI Express x16/x1 interface - Two independent SATA controllers, for four drives - Dual Fast ATA-133 IDE controllers - IEEE 802.3 NVIDIA MAC for 1000BASE-T Main Memory • Supports dual channel DDR 266/333/400, using four 184-pin DDR DIMMs. • Supports a maximum memory size up to 4GB without ECC. • Supports 2.5v DDR SDRAM DIMM. Slots • One PCI Express x16 slot (supports PCI Express Bus specification v1.0a compliant) • One PCI Express x4 slots (support PCI Express x2 only) • One PCI Express x1 slots (support PCI Express Bus specification v1.0a compliant) • Four 32-bit v2.3 Master PCI bus slots (support 3.3v/5v PCI bus interface). On-Board IDE • An IDE controller on the NVIDIA nForce4 Ultra chipset provides IDE HDD/CD-ROM with PIO, Bus Master and Ultra DMA133/100/66 operation modes. - Can connect up to 4 IDE devices On-Board SATA • NV RAID supports 4 SATA II ports. - Transfer rate is up to 300MB/s. NV RAID (Software) • Supports up to 4 SATA and 4 ATA133 Hard drives - RAID 0 or 1, 0+1, JBOD is supported - RAID function available for ATA133+SATA H/D drives Audio • 7.1 channel audio codec RealTek ALC850. - Compliance with AC97 v2.3 Spec. - Meet PC2001 audio performance requirement. LAN • Supports Gigabit LAN - Supports 10/100/1000 Fast Ethernet by Marvell 88E1111 PHY Internal I/O Connectors - ATX 24-Pin power connector - 4-pin ATX 12V power connector - CPU / System x 2 / NB FAN connectors - CD-in connector - Clear CMOS jumper - Chassis intrusion switch connector - 1 x IrDA infrared module header - 1 x MSI D-Bracket 2 Connector - Front panel audio connector - Front panel connector - 3 x USB 2.0 connector support additional 6 ports - 1 x Floppy disk drive connector - 4 x serial ATA connectors - 2 x ATA133 HD connectors Back Panel I/O Ports - 1 x Parallel - 1 x Serial port (COM 1) - 1 x PS/2 Keyboard - 1 x PS/2 Mouse - 1 x Coaxial SPDIF out - 1 x 6 in 1 Audio jack (S/SPDIF out) - 4 x USB 2.0 - 1 x RJ45 LAN Jack BIOS • The mainboard BIOS provides "Plug & Play" BIOS which detects the peripheral devices and expansion cards of the board automatically. • The mainboard provides a Desktop Management Interface(DMI) function which records your mainboard specifications. • Supports boot from LAN, USB Device 1.1 & 2.0, and SATA HDD. |
