#9032 |
Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,572
1x Asrock H110M-DGS, s1151, DDR4 1x Procesor Intel Core i5-6400 (6MB Cache, up to 3.30GHz), s1151 1x Gigabyte GTX960 WF2, 4GB GDDR5, GV-N960WF2-4GD 1x DDR4 8GB (1x8GB) PC3-17000 2133MHz CL15 Crucial 1x SanDisk X400 256GB SSD, 2.5” 7mm, SATA 6 Gbit/s 1x HDD 1TB WD Blue, 3.5", 7200RPM, 64MB Cache, SATA3 1x Fortron 500W, Hyper 80+ 1x Zalman Z1 midi tower Ukupno: 5.478,98kn Besplatno slaganje i dostava Sa 10-15% jačom grafom ali iz AMD tabora: 1x Asrock H110M-DGS, s1151, DDR4 1x Procesor Intel Core i5-6400 (6MB Cache, up to 3.30GHz), s1151 1x Gigabyte R9 380X G1 GAMING, 4 GB DDR5, 256-bit, 970/5700 MHz 1x DDR4 8GB (1x8GB) PC3-17000 2133MHz CL15 Crucial 1x SSD 120GB Kingston HyperX FURY, SATA3 1x HDD 1TB Toshiba, 3.5", 7200RPM, 64MB Cache, SATA3 1x Fortron 600W, Hyper 80+ 1x Zalman Z1 midi tower Ukupno: 5.508,00kn Besplatno slaganje i dostava Zadnje izmijenjeno od: ibme74. 21.05.2016. u 17:48. |
#9033 |
Datum registracije: May 2016
Postovi: 2
Pozdrav ljudi. Imam potrebu za novim kompom(samo"kantu"). Trebao bih nesto solidno za multimediju i igranje. Raspolazem s 4500kn i volio bih da je po mogučnosti Intel.Ako mi možete nešto sugerirati bio bih zahvalan! |
#9034 |
Postovi: 1,572
navarr07 INTEL: 1x Asrock H110M-DGS, s1151, DDR4 1x Intel Core i5-6402P (2.80GHz, Turbo : 3.4GHz, 4 core, 6MB, LGA1151) 1x DDR4 8GB (1X8GB) PC4-17000 2133MHz CL15 Corsair Value Select 1x Gigabyte GTX950 WF2 OC 2GB DDR5, 128-bit, 1279/6600 1x HDD 1TB WD Blue, 3.5", 7200RPM, 64MB Cache, SATA3 1x FORTRON 400W, HEXA 80+ 1x Zalman Z3 PLUS mid tower case UKUPNO: 4.495,98kn Besplatno slaganje i dostava Sa AMD-om možeš i na jaču grafu: 1x Gigabyte GA-970A-DS3P, sAM3+ 1x AMD X8 FX-8300 (16MB Cache, up to 4.20 GHz), sAM3+ 1x LC POWER Cosmo Cool CC-95 1x DDR3 8GB (1x8GB) PC3-12800 1866MHz CL10 Kingston HyperX Fury 1x Gigabyte GTX960 WF2, 4GB GDDR5 1x HDD 1TB Toshiba, 3.5", 7200RPM, 32MB Cache, SATA3 1x FORTRON 400W HEXA 80+ 1x Zalman Z3 mid tower case UKUPNO: 4.488,99kn Besplatno slaganje i dostava |
#9035 |
Postovi: 2
Puno hvala. Sad imam pitanje kako i gdje to naruciti? |
#9036 |
Postovi: 1,572
Ja sam ovo slagao u ADM-u Zadnje izmijenjeno od: ibme74. 22.05.2016. u 20:41. |
#9037 |
MiningMod
Postovi: 8,715
#9038 |
Lokacija: San Francisco
Postovi: 3
Hvala...zanima me kak bi to funkcioniralo sa integriranom grafom pošto bih volio uzeti windowse 10 , a opet da sam negdje oko 4000 ? A opet da ne izgubim puno na kvaliteti kompa. Zadnje izmijenjeno od: coconut. 23.05.2016. u 06:25. Razlog: nauči koristiti tipku Edit |
#9039 |
Postovi: 1,572
josip1980 1x Asrock H110M-DGS, s1151, DDR4 1x Intel Pentium G4400 (3MB Cache, 3.30 GHz), s1151 1x DDR4 8GB (1x8GB) PC3-17000 2133MHz CL15 Crucial 1x SAPPHIRE R7 360 2G D5, 2 GB DDR5, 128-bit, 1050/6500 MHz 1x SSD 120GB Kingston HyperX FURY, SATA3 1x HDD 1TB Toshiba, 3.5", 7200RPM, 32MB Cache, SATA3 1x FORTRON 400W HEXA 80+ 1x MS PHOENIX 2 Midi tower 1x Microsoft Windows 10 Home Cro 64-bit, KW9-00149 UKUPNO: 4.018,99kn Besplatno slaganje i dostava Sa integrušom uz mogućnost nadogradnje na jače grafe: 1x Asrock H110M-DGS, s1151, DDR4 1x Intel Core i3-6100 (3MB Cache, 3.80 GHz), s1151, box 1x DDR4 8GB (1x8GB) PC3-17000 2133MHz CL15 Crucial 1x SanDisk X400 128GB SSD, 2.5” 7mm, SATA 6 Gbit/s 1x HDD 1TB WD Blue, 3.5", 7200RPM, 64MB Cache, SATA3 1x Fortron 600W Hyper 80+ 1x Zalman Z1 mid tower case 1x Microsoft Windows 10 Home Cro 64-bit, KW9-00149 UKUPNO: 3.968,00kn Besplatno slaganje i dostava Zadnje izmijenjeno od: ibme74. 23.05.2016. u 09:09. |
#9040 |
Postovi: 11
Pozdrav! Ako može jedna konfiguracija za surfanje i malo manje zahtjevnog gejmanja, uglavnom FM i PES, sve skupa s periferijom do nekih 5000 kn i nek bude SSD unutra. Plaćanje bi bilo na rate. Unaprijed hvala! |
#9041 |
Postovi: 1,572
1x Asrock H110M-DGS, s1151, DDR4 1x Intel Core i3-6100 (3MB Cache, 3.80 GHz), s1151, box 1x DDR4 8GB (1x8GB) PC3-17000 2133MHz CL15 Crucial 1x Gigabyte GTX750Ti 2GB DDR5, 128-bit, 1085/5400 MHz 1x SSD 128GB SanDisk Z400s 1x HDD 500GB Toshiba, 3.5", 7200RPM, 32MB Cache, SATA3 1x Fortron Hexa 400w 80+ 1x MS Voyager midi tower 1x Acer V226HQLAbmd 21.5" LED Monitor, VA LED panel, Rezolucija: 1920x1080 1x Komplet Genius KM110X, tipkovnica + miš, USB Ukupno: 5,109.98 Kn na rate Besplatno slaganje i dostava |
#9042 |
Postovi: 430
#9043 |
Postovi: 11
#9045 |
Postovi: 11
#9047 |
Postovi: 11
#9048 |
Datum registracije: Dec 2010
Lokacija: Podravina
Postovi: 23
Konfiguracija do 4500kn
Pozdrav svima, molim vas preporuku za konfu do 4500kn za gaming, treba sinu od mog radnog kolege pa bilo bi dobro da je ukljuceno sve, komplet periferija i da ako moze postoji trgovina koja to odmah i sve sastavi, da se oni ne pate s tim ne kuze se bas u to, a i ja sam zahrdao sto se tog tice ![]() |
#9049 |
Postovi: 1,572
Uf malo novaca s obzirom da je za igrice a treba i periferija uz kantu... 1x Acer V226HQLAbmd 21.5" LED Monitor, VA LED panel, Rezolucija: 1920x1080 1x Komplet Genius KM110X, tipkovnica + miš, USB 1x Procesor Intel Core i3-6100 (3MB Cache, 3.80 GHz), s1151, box 1x ASRock H110M-DGS, s1151 1x DDR4 8GB (1x8GB) PC3-17000 2133MHz CL15 Crucial 1x Gigabyte GTX750Ti 2 GB DDR5, 128-bit, 1085/5400 MHz 1x HDD 1TB Toshiba, 3.5", 7200RPM, 32MB Cache, SATA3 1x Fortron Hexa 400w 1x Zalman Z1 midi tower Ukupno: 4.448,99kn Besplatno slaganje i dostava Ako ikako moze neka se protegne do 4.750 i uzme Gigabyte GTX950 posto je komp za igre |
#9050 |
act of God
Lokacija: Zagorski Bregi
Postovi: 452
Molio bih preporuku za malu gaming konfiguraciju. Kućište bi bilo CHIEFTEC BT-02 koje ima napajanje od 180W i mjesta za grafičku do 19 cm dužine koja zauzima samo jedan slot. Znam da se ne može ništa ekstra složiti sa tako slabim napajanjem ali jednostavno nemam mjesta za veće kućište jer je mala kuća. Možda bih mogao uzeti jače napajanje jer mislim da ima isto kućište sa 360W ako se baš ne može iskombinirati kombinacija koja troši malo struje a da može i igru zavrtiti. Dakle treba mi mITX ploča + procesor koji troši malo struje. Grafička da zauzima jedan slot i troši također što manje struje. Još fali RAM i SSD neki najmanjeg kapaciteta, HDD mi ne treba. Konfiguracija bi bila isključivo za igranje. Trenutno imam Intel HD Graphics 4400 (I3-4130T) i 4GB rama i može se nešto odigrati ali uglavnom na sranje postavkama i u malim rezolucijama pa svakako ako može bolje od toga. Budžet oko 4000 kuna ali može se rastegnuti. U par stotina kuna nije problem, hvala!
Pretty fucking dumb but smarter than most of you. |
#9051 | |
Asshole
Lokacija: RH
Postovi: 2,358
tesko da ces se na tome naigrat, ako je iskljucivo za gaming, jesi razmisljao o ps4 ? plus u dogledno vrijeme neki 82"+ lcd ? |
#9052 |
Postovi: 33,930
Kako misliš složiti gaming konfu koja zahtjeva malo jači proc sa tako slabim napajanjem? Dodaj tome i povećanu potrošnju jače grafe i imaš fail. Moraš odlučiti - gaming konfa ili iTX kućište. Oboje mogu samo u slučaju da nabaviš ovakvo nešto.
#9053 |
Postovi: 1,572
Jozo spoji krevete ![]() Gle tako nešto iskombinirati je nemoguće, uzmi ovu konfu sa micro towerom i zguraj ju negdje ![]() 1x ASUS B85M-K, s1150 1x Intel Core i5-4460 (6MB Cache, up to 3.40 GHz), s1150 1x DDR3 8GB (1x8GB) PC3-12800 1600MHz CL11 Kingston Value 1x Gigabyte GTX950 WF2 OC 2 GB DDR5, 128-bit 1x HDD 1TB Toshiba, 3.5", 7200RPM, 32MB Cache, SATA3 1x Fortron Hexa 400w 80+ 1x Zalman ZM-T1 PLUS micro tower case UKUPNO: 4.221,00kn Besplatno slaganje i dostava I najnovije igre će šljakati na solidnim postavkama ![]() Evo ovdje pogledaj kako bi to trebalo šljakati GTA 5 Battlefield 4 COD Black Ops 3 Far Cry Primal DOOM Overwatch Beta Assasins Creed Syndicate The Witcher 3 Rise of the Tomb Raider Just Cause 3 Dark Souls 3 Zadnje izmijenjeno od: coconut. 09.06.2016. u 10:24. |
#9054 |
act of God
Postovi: 452
Ništa onda, pušiona. Pogledat ću PS4. Hvala svima.
#9055 |
Datum registracije: Mar 2011
Postovi: 2,707
Samsung SSD 750 EVO 250GB KUĆIŠTE AeroCool PGS CS-101, Small Form Factor Case, bez napajanja be quiet! SFX Power 2 300W MSI GeForce GTX 750Ti-2GD5TLP Intel Core i3-6100 Crucial DDR4 8GB (1x8GB) 2133MHz CL15 Asrock H110M-ITX ~3980kn s popustom Možda se i može ![]() |
#9056 |
Datum registracije: Aug 2008
Postovi: 237
Možda da samo ubaciš 750ti u tu konfu. Imaš proc od 35w i grafu od 75w. Sve zajedno neće bit preko 120w u gaming loadu. 750ti ovak i onak nemre pogurat neki framerate da bi proc bio usko grlo. Dodaj još 4gb rama reda-radi. |
#9057 |
act of God
Postovi: 452
Ma ja sam samo htio nešto da je bolje od ove Intel integrirane 4400 jer i nisam neki gamer tj. nemam vremena bas za igranje prosle su te godine davno ali kad nađem dvije ure za odigrat nešto onda čupam kosu jer mi radi jedino Baldurs Gate i slične igre. Hvala, pogledam malo ovo poviše iako mi se na prvu čini kućište preveliko ali morat ću neki kompromis napraviti.
#9058 | |
Lokacija: Podravina
Postovi: 23
![]() Ps i ako moze na pm gdje se to moze kupit sastavljeno, vidim napisao si besplatno sastavljanje i dostava. Zadnje izmijenjeno od: skleky. 09.06.2016. u 18:48. |
#9059 |
Postovi: 1,572
Cek, ne treba ni monitor ili ne treba samo mis i tikovnica? Ako hoce i SSD morat ce se jos malo protegnuti, a steta je previse kresat na bitnim komponentama s obzirom da je za igrice 1x ASRock H110M-DGS, s1151 1x Intel Core i5-6402P (6MB Cache, up to 3.40 GHz), s1151 1x Gigabyte R9 380 WF2 OC, 2 GB DDR5, 256-bit, 980/5500 MHz 1x DDR4 8GB (1x8GB) PC3-17000 2133MHz CL15 Crucial 1x SSD 120GB Kingston HyperX FURY, SATA3 1x HDD 1TB Toshiba, 3.5", 7200RPM, 32MB Cache, SATA3 1x Fortron Hyper 500w 80+ 1x Zalman Z1 mid tower case UKUPNO: 5.142,98kn Besplatno slaganje i dostava Zadnje izmijenjeno od: ibme74. 09.06.2016. u 19:43. |
#9060 |
Lokacija: u mraku
Postovi: 846
Pozz. Jel mozete sloziti jednu gejmer kantu do 5000kn bez periferije u hg spotu,moze i links ak ispadne jeftinije? Intel ,a sto se tice grafi dajte dvije podjednake iz oba tabora. Sumnjam da ce narucitelj htjeti preko neta narucivati pa je opcija trgovine u koje mogu otici plus ovih par lokalnih u vinkovcima. Hvala... |
