Staro 18.05.2016., 13:10   #511
schetz
schetz's Avatar
Postovi: 1,570
Bluetooth crashes in MMB29X.Z1.3582 and later...
Some of you have experienced restarts when it comes to Bluetooth in the latest software. This is not harmful for the phone, in this case it is just a sign of bad software programming. The phone is trying to interpret something that just doesn't makes sense so the only option is to reboot.
More technical details:
Once again we integrated the FM-radio which needed some changes in Bluetooth as well. We actually needed to integrate a new driver for Bluetooth (a driver is a piece of software needed to communicate with the hardware). This driver implements (among other functions) a read function and a write function where the read function reads from the Bluetooth chip and the write function writes to the Bluetooth chip.
Whenever an app wants to get some music from Bluetooth, it calls the kernel driver read function and supplies a little memory buffer and a length of the memory buffer so the read function can fill it.
The funny thing with this vendor supplied driver was that it didn't even care about the length of the buffer, if the Bluetooth accessory has a lot of music in the pipe, the driver will just write all of it into this buffer. Since the buffer size doesn't suffice in all cases, the phone reboots...
The solution is to respect the length of the supplied buffer and let the app ask for more data whenever it has emptied the buffer.
Sorry about this, we have a solution on its way...
EDIT: This particular programming problem is called "Buffer overflow".
https://en.wikipedia.org/wiki/Buffer_overflow
To je zapravo fix fix-a za BT , jest da je moglo i bez toga, ali u vrlo kratkom vremenu ispravljaju..
Šteta da nije tako s official i kod njih i kod drugih...
Danas novi update na MM Concept Z3:
updated camera i nešto vezano baš za concept.
Inače, spominjao se i ovdje BT bug, to se tamo riješava isto, čisto kome se da čitati, tamo objašnjavaju sve i rješavaju obično u 7-10 dana..
schetz je offline   Reply With Quote
Staro 18.05.2016., 14:37   #512
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Ili ako te i malo BK za svoj telefon, flešaš si unbranded verziju zadnjeg official FWa bez ikakvog rizika ili posljedica i ne čekaš svog lopovskog operatera da izbaci OTA update pun svojih rozih idiotarija koje cuclaju bateriju
Neznam,meni nijedan T-Comov servis ne cucla bateriju
Staro 19.05.2016., 16:48   #513
Bubba
E Pluribus UNIX
Bubba's Avatar
Datum registracije: Oct 2002
Lokacija: M82
Postovi: 6,759
Buduci sam ja glup i neobrazovan paor i te informatike mi nisu najbliskije, voljan sam nekome ponuditi razuman novac (dakle, protuvrijednost alkohola) da mi zaflesa taj jebeni mobitel, Z3.
Vita jela zelen bor, molim brzi odgovor.
Programer
Staro 19.05.2016., 17:31   #514
Zvao sam te u Karlovac na čevape dok je Vojo Šešelj još bio u zatvoru... poziv i dalje vrijedi sa proširenom ponudom uflešavanja mobitela.
Staro 20.05.2016., 14:23   #515
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Bubba....bnema ti druge nego na Kordun
Nego,stigla Xpera X u T-Com....
Staro 20.05.2016., 21:16   #516
bubimir13
bubimir13's Avatar
Lokacija: Kutina, CRO
Postovi: 439
Ako tko nabavi, mada sumnjam jer je Sony fan baza sve tanja, nek javi dojmove.
bubimir13 je offline   Reply With Quote
Staro 20.05.2016., 22:56   #517
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Pa kako su krenuli sa regresijom u pogledu baterije i stagnacijom u polju kamere(koja je ionako loša bila) nije ni čudo da su ljudi otišli konkurenciji.
Ionako još nebu ni HTCa ni X Performansa do ljeta stoga bumo sačekali rivjue
Ko za kufera upravo izašao rivju,....
I to bi bilo to,nije XP već X ali baterija je midranger,kamera opet(dijele istu),ubili su zvuk....good bye Sony,welcome HTC
Zadnje izmijenjeno od: trouble. 20.05.2016. u 23:06.
Staro 21.05.2016., 00:39   #518
bubimir13
bubimir13's Avatar
Postovi: 439
Al najjača fora ovo što vidim na reviewu... U settingu zaslona ima opcija da uključiš da dva puta stisneš power tipku da ti upali kameru... Sve ok, samo što telefon ima JEBENU posebnu tipku za tu kameru
Definitivno su sad jeli lude gljive i em je uređaj preskup za ono što nudi, jer budimo realni niko više ne puši ovih 23mpx, to je možda bilo wow do Z3 al poslije više nije bilo čak niti smiješno već tragikomično. O softverskim stvarima ne želim ni započinjat jer idu u stilu korak naprijed puzajući pa 3 nazad skokom
Staro 21.05.2016., 20:55   #519
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,759
Uspio sam flashati Z3, cak je proslo bezbolnije nego sto sam mislio. I ondah mi je Sony alat@PC ponudio neki update na 575 verziju. Kul.
Programer
Staro 22.05.2016., 12:49   #520
2 die 4
2 die 4's Avatar
Postovi: 2,250
RedGreenBlue
Staro 22.05.2016., 18:39   #521
japa
japa's Avatar
Lokacija: Apsurdistan
Postovi: 248
Autor Bubba Pregled postova
Jeli ti sve ostalo kao prije update? Mislim postavke, apps i ostale datoteke koje si imao?
japa je offline   Reply With Quote
Staro 22.05.2016., 20:35   #522
Delpiero
Delpiero's Avatar
Datum registracije: Aug 2008
Lokacija: Split, Croatia
Postovi: 380
Jedno pitanje ako netko zna... prijatelju mi se na Z3 odvojio ekran zajedno sa staklom sa gornje strane od kucista mobitela (grubo rečeno dao da je popustilo "ljepilo" baš sa rubova ekrana koje ga drži pričvršćenog za kučište). Vidi se i spoj - onaj flat kabel koji spaja ekran i unutrašnjost i ništa nije oštečeno već samo odvojeno i mob radi.
Što da radi ili gdje da odnese a da ga ne "oderu"? Imao ko sličnu sitaciju?
Delpiero je offline   Reply With Quote
Staro 22.05.2016., 20:38   #523
Ako je pod jamstvom, neka ga nosi na servis. To pokriva garancija.
Staro 22.05.2016., 21:32   #524
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Autor Delpiero Pregled postova
Ma uopće ne kaj si pop the cherry? Prvi puta?
Staro 22.05.2016., 21:33   #525
Delpiero
Delpiero's Avatar
Postovi: 380
Nije više pod jamstvom , zato i pitam
Sent from my SM-N910F using Tapatalk
Staro 22.05.2016., 21:34   #526
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
A nosi onda u neki servis,ionače to je opče poznati problem za Z3 seriju...
Staro 22.05.2016., 22:08   #527
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,759
Autor japa Pregled postova
Sve sam zdrobio, tako da ti ne znam reci. S druge strane, kada se napravio onaj update koji mi je ponudio Sony PC software, sve je ostalo kak je bilo, to da.
Moze li se ukljuciti ona fora "sharinga" prostora izmedju interne memorije i SD kartice, nesto mi je ostalo u sjecanju da to Android 6 podrzava?
Programer
Staro 22.05.2016., 22:46   #528
Mileni
Mileni's Avatar
Postovi: 1,554
Moze, no samo preko ADB-a. Ali imaj na umu da moras imati stvarno extra skupu i brzu sd karticu, inace ti ne gine jako spor mobitel. IMHO gluparija sto je google to uopce ubacivao, ne isplati se bez extremno skupe i kvalitetne sd kartice, a cak i tada je upitno.
Ja imam class 10 scandiska, 128GB. I nije mi se bas isplatilo
"There he goes.One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die"
Staro 23.05.2016., 23:15   #529
Bubba
E Pluribus UNIX
Bubba's Avatar
Lokacija: M82
Postovi: 6,759
Autor Mileni Pregled postova
Ma OK, cisto informativno me zanimalo. Bitno mi je ionako da je sve "u cisto" instalirano i da ne gnoji previse. Osim sto su (IMO) bezrazlozno promijenili par featureova kod poziva, nista spektakularno nisam primjetio, osim klasicnih sprdacina poput:
a) ne mogu kopirati dijelove SMS/WhatsApp poruka
b) nema agregirane liste odlaznih/dolaznih poziva jednog kontakta
c) i dalje integracija Skype poziva i GSM poziva ne radi kako spada, odnosno ima sva neocekivana i kriva ponasanja
Sve u svemu, osim za dokone tinejdjerke zeljne pelfija, na sredini 2016. ne postoji suvisli poslovni mobitel. Zivio BlekBeri!
Programer
Staro 23.05.2016., 23:20   #530
Buger
Postovi: 4,391
Bio moj Z3C na servisu zbog odljepljivanja prednjeg stakla, sve riješeno za 10 dana . Inače danas je stigao i MM update preko ažuriranja sustava (VIP). Sve dobro šljaka, malo je ručniji od L5.1, ali dobro
Zanima me gubi li se rootanjem garancija i kako je to najjednostavnije napraviti? Htio bih rootati mob samo da mogu obrisati ove bezvezne aplikacije tipa Whats New i Google ovo, Google ono...
Staro 24.05.2016., 13:09   #531
japa
japa's Avatar
Postovi: 248
OK jučer se pojavio 6.0.1 OTA update za Z3 (VIP mreža) instalirao sam i sve 5 osim wifi-a. Jednostavno je spor i sporo radi sve vezano za net. Testirao sam na speedtest i ping je prevelik, a brzina ni pola one sa 5.0. Citam po netu i ima dosta ljudi koji spominju taj problem. Ima jos netko ovdje taj problem i moguce rijesenje :-) ?
Staro 24.05.2016., 15:30   #532
Buger
Postovi: 4,391
Meni se čini kao da mi internet malo sporije radi te kao da mi chrome malo šteka... Isti mob i softver
Poslano sa mog D5803 koristeći Tapatalk
Staro 24.05.2016., 19:59   #533
japa
japa's Avatar
Postovi: 248
E pa baš to, da.
Staro 24.05.2016., 20:29   #534
nino
nino's Avatar
Postovi: 12,613
Meni danas stiglo z3 compact. Upalio i odma na 6.0.1 apgrejd i nekon toga jopet neki apgrejd stigo od 190mb, a jos ni sim nisam turijo unutra. 😂
Sent from my MotoG3 using Tapatalk
Staro 25.05.2016., 09:31   #535
Buger
Postovi: 4,391
Čini mi se da sa firefoxom radi brže... Iako sam dojma da je mobitel malo sporiji nego sa L5.1, možda mi se samo čini...
Staro 25.05.2016., 09:43   #536
Kapica
Lokacija: Varazdin
Postovi: 108
negdje sam vidio neki mention da treba wipe cache-a napraviti za problem sa sporim wifi-em.. probaj googlat to...
Kapica je offline   Reply With Quote
Staro 25.05.2016., 10:24   #537
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,824
Citam recenziju od Xperie X, pa skupa je pun kufer, 5tkn, Performance bu sigurno bila oko 5800kn, ne nudeci nis novog... A Sony prakticicira sve manje baterije. Eh di su dobra stara vremena dok je Z3 palio i zario.. Sony, ne bu dobro!
Staro 26.05.2016., 11:41   #538
bubimir13
bubimir13's Avatar
Postovi: 439
Performance bude 700€+ sigurno. .575 je stigao za većinu Z3 serije, navodno ispravlja hrpu bugova, upravo flasham. Za Wifi ja nikad nisam imao problema, ali baš nikad na MM niti sa Z5c niti sa Z3c tako da ne znam koje bi se rješenje moglo izvuć, ali sam čitao da upravo .575 rješava to zbog boljeg drivera.
Staro 26.05.2016., 17:40   #539
Buger
Postovi: 4,391
Kod mene je .575. Što se tiče Chromea i štekanja, deinstalirao sam sva ažuriranja i ponovo ga instalirao i čini mi se da bolje radi...
Gubi li se rootanjem garancija?
Staro 26.05.2016., 23:19   #540
japa
japa's Avatar
Postovi: 248
Probao sam sve, ali još nista nije pomoglo sa stekanjem kod surfanja. Ne znam da napravim downgrade na Lolipop ili da vidim oce izdat kakvu zkarpu..
