Staro 08.05.2016., 19:06   #151
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
Bez potpisa.
Staro 08.05.2016., 19:13   #152
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
"25% bump naspram 980Ti i titan x" klik rečeno tech youtuberima nakon lounch eventa
Kako su navedene dvije gpu tu negdje, očito se misli na referentne 980Ti/titan x
Staro 08.05.2016., 20:03   #153
Manuel Calavera
Postovi: 14,584
Evo još o async
Due to the pressure exerted by the industry to make Async compatible graphics cards however, Nvidia has been working actively to implement Async in their GPUs but were held back due to the fact that this was something that had to be implemented at a hardware level. Chip design usually takes a lot of time (in the lieu of many years) and if Nvidia has actually managed to properly implement Async in the Pascal based GTX 1080 – that would be quite an accomplishment. Something their CEO stated a few weeks back (regarding the P100 being capable of advanced preemption) made us think that Pascal might stick with the Preemption approach for now, but the press release from Nvidia states otherwise. So consider us pleasantly surprised!
EDIT
Par novih fičura objašnjeno klik
Zadnje izmijenjeno od: Manuel Calavera. 08.05.2016. u 20:20.
Staro 09.05.2016., 07:02   #154
markecSMB
Lokacija: Cro
Postovi: 1,030
Autor RaneZ Pregled postova
Pff, TAMAN za fhd. Napokon 100+ fpsa za nas 144herzaše
Imao sam doma tjedan dana (bratić bio u posjeti) http://www.amazon.com/Acer-XB270HU-b.../dp/B00UPVXDA8.
I baš mi je moj monitor bio do njegovog, i tih 144 Hz je fenomenalno. On je na 980ti imao otprilike iste performanse ko ja na 970 overclock (ja sam imao manju rezoluciju, FHD, a on 1440p). Nevezano za FPS gsync i 144 Hz su fenomenalni, čak i nevezano za igranje, pomicanje kursora po desktopu je glatko, manje ti se naprežu oči+ totalna eliminacija trganja slike. Gledanje lijevo desno u igri je puno puno glađe.
Poanta je da ne trebaš imat 100+fpsa da uživaš na 144 Hz, ali kako sam imao priliku vidjet FPS na 980ti, daleko je to od 100 fps u novijim igrama (na 1440p), a pogotovo jako daleko u 4k. Tak da i ove nove generacije neće moć vrtit 1440p na 1000+, a kamo li 4k.
Jedva čekam da dođu 4k monitori na 120 Hz, spreman sam dat 1k €, a grafičke kad dođu, dođu...
Staro 09.05.2016., 07:18   #155
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,556
Staro 09.05.2016., 07:53   #156
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Founders "edišn" - referentni modeli po većim cijenama
Pomelo mi sig -.-
Staro 09.05.2016., 10:10   #157
Garro
Postovi: 2,382
Premda je taj referentni hladnjak zbilja dobar (da se razumijemo - dobar za referentni, naravno da ima boljih), doći na ideju to nazvati "founders edition" i tražiti dodatnih 100$... :slow_clap: Briljantno... Porez na early adoptere (= budale) u najboljem izdanju ikad.
Razumijem da svi hoćemo sve najnovije i to odmah, ali da kupiš founders edition po toj cijeni bi trebalo biti dovoljan razlog da dobiješ besplatnu "nVidiot" tetovažu posred čela.
Osobno, čekam velikog Pascala i Vegu, Polaris ne očekujem da će biti nešto puno jači od moje trenutne kartice.
Staro 09.05.2016., 10:16   #158
syss
syss's Avatar
Postovi: 10,805
HAHHAHAHHAHHA kakvi asevi
Staro 09.05.2016., 10:20   #159
Asus30
Datum registracije: Mar 2016
Lokacija: x
Postovi: 134
founders edition,šta se sve neće izmislit
umjesto da je referentna jeftinija oni nabiju cijenu,katastrofa
Asus30 je offline   Reply With Quote
Staro 09.05.2016., 10:28   #160
Glavas_ZG
Datum registracije: Feb 2015
Postovi: 218
Autor Garro Pregled postova
Polaris ce biti jaci od GTX 1080 i to zamjetno jaci.
Glavas_ZG je offline   Reply With Quote
Staro 09.05.2016., 10:58   #161
MikaHR
Postovi: 1,264
jedino ako su napravili čudo. 1070 da, možda, 1080 ne.
MikaHR je offline   Reply With Quote
Staro 09.05.2016., 11:18   #162
Garro
Postovi: 2,382
Autor Glavas_ZG Pregled postova
Moguće je da si pobrkao Polaris i Vegu...
Osobno, navijam za AMD da zabije nVidia-u u zemlju, ove cijene koje nVidia ispaljuje i koncepti "founders editiona" su pomalo suludi.
Eh, ono što AMD-u treba je nešto u rangu 1070 za koji dolar niže ili nešto između 1070 i 1080 po cijeni 1070, to bi bio flagship killer. Low end i mainstream mislim da će standardno bolje odraditi od nVidia-e, ali jednostavno im treba nešto u high endu da konkurira Pascalu.
Staro 09.05.2016., 11:22   #163
Gilbert5
Agent 0
Gilbert5's Avatar
Lokacija: Kutina - ZG
Postovi: 4,309
Osobno mislim da će 1080 biti malo bolja od 980Ti, u 4K još dodatno bolja. Cijenom će biti također malo skuplja i eto opet iz šupljeg u prazno. Onda će ubiti GTX980 Ti s novi driverima i bok.
AMD će ponuditi malo sporiji proizvod po nižoj cijeni, i opet će sve biti po starom, kao i dosad.
Staro 09.05.2016., 11:31   #164
Garro
Postovi: 2,382
A zato ti prodaješ onu 980Ti na tržnjaku!
Staro 09.05.2016., 11:32   #165
syss
syss's Avatar
Postovi: 10,805
jer je u nadi spas
Staro 09.05.2016., 11:36   #166
Gilbert5
Agent 0
Gilbert5's Avatar
Postovi: 4,309
Pa bit će bolja, i zato bi prodao. Vjerujem da će do kraja godine i bolji modeli, pa...
Jer kad se već kupuje kartica od 5000kn, onda ju je najbolje kupiti čim izađe. A vjerujem da ću moći 1080 nabaviti uskoro i nešto povoljnije, pa dvije muhe jednim udarcem.
Staro 09.05.2016., 11:40   #167
Manuel Calavera
Postovi: 14,584
O čem pričaš ti? To su grafe od 299-350$
Bit će možda u rangu gtx 1070, vjerojatno i slabije
Ili si mislio na vegu?
Staro 09.05.2016., 11:56   #168
MikaHR
Postovi: 1,264
Evo malo leakova (Fury X/980ti rezultat u istoj verziji igre dole u linkovima)
Fury X:
http://www.ashesofthesingularity.com...b-a64cf2044a55
980ti:
http://www.ashesofthesingularity.com...c-7c6a44042dd7
1080 ~10% brža od Fury X i ~15% brža od 980ti
Staro 09.05.2016., 12:10   #169
Manuel Calavera
Postovi: 14,584
A gdje ti je score od gtx 1080 u tome?
Staro 09.05.2016., 12:19   #170
scarzz
scarzz's Avatar
Lokacija: Stuttgart/Rijeka
Postovi: 414
pa lijeva slika
po ovome 1080 i nije nesto posebno brza od 980ti i fury x jer tu fury barata sa 3 ultra settingsa naspram 3 high
scarzz je offline   Reply With Quote
Staro 09.05.2016., 12:30   #171
Glavas_ZG
Postovi: 218
Nisam nista pobrkao, najjaci model Polarisa koji sad izade ce biti jaci od GTX 1080.
Staro 09.05.2016., 12:43   #172
Manuel Calavera
Postovi: 14,584
Good stuff, ali ni u AMD-u ne misle tako
Eventualno u dx12 ako nvidia zakaže
Cijelo vrijeme je bila priča VR grafe za mase (min req. i nešto iznad). A nedavno se Roy osvrnio na nvidijinu ponudu kao "high end" i da oni s ovim lounchima ne idu tim putem
Recimo ako je suditi prema adoredtv (a za gtx 1080 i 1070 je izgleda pogodio, jer se poklapa sa nvidijinim info o snazi), najjača polaris 10 će se natjecati sa gtx 1070, eventualno nešto slabija (ne sjećam se točno koliko % je rekao)
Zadnje izmijenjeno od: Manuel Calavera. 09.05.2016. u 12:54.
Staro 09.05.2016., 12:44   #173
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
founders edition = preorder
Ko hoce, nek roka
Bez potpisa.
Staro 09.05.2016., 12:45   #174
Garro
Postovi: 2,382
Imaš li neke dokaze za potkrijepiti tu tvrdnju? Jer koliko ja vidim, AMD kaže da je Polaris 10 čisti mainstream: http://arstechnica.com/gadgets/2016/...ainstream-gpu/
Staro 09.05.2016., 13:10   #175
Manuel Calavera
Postovi: 14,584
Ako slučajno nekome nije jasno, ove se generacije gpu jače od gtx 970, R9 290, vjerojatno i od gtx 980 smatraju "mainstream". Samim time izjave o "mainstream" grafi od Roya i ranije "high-performance" od Raje nisu u suprotnosti
Kad dođe gtx 1080Ti, a možda i titanka i gtx 1070 će spadati u "mainstream" iako će možda biti u rangu 980Ti ili jača
Staro 09.05.2016., 13:19   #176
Glavas_ZG
Postovi: 218
Ovo sto si linkao nije official.
Za ovo sto ja tvrdim naravno nemam dokaze ali prema snazi GTX 1080 vrlo je vjerovatno da ce Polaris biti jaci.
GTX 1080 je oko 15% jaci od Fury X.
Razlika izmedju Fury X i Polaris kartice ce sigurno biti vise od 15%.
Staro 09.05.2016., 13:30   #177
Neo-ST
Neo-ST's Avatar
Postovi: 8,329
Kad bi Pascali trebali biti u nas, otprilike barem ?
Staro 09.05.2016., 13:38   #178
Manuel Calavera
Postovi: 14,584
Kako nije official? Frajeri su to svojim ustima rekli. Pa radi se o čipovima koji imaju nešto više od 200mm. Proces je napredniji od nvidijinog, ali ne toliko da bi polaris 10 stigla primjetno veće čipove od nvidije
Procjene su isključivo tvoje osobne
Staro 09.05.2016., 14:31   #179
Bariarnil
Aiden Fierce
Bariarnil's Avatar
Datum registracije: Jan 2016
Postovi: 1,171
Polaris 10 će biti tipa 490x i ona neće biti brža 45% od 390x (da bude brža od Fury X tolko joj treba).
Zaključak,Fury X ostaje najbrža AMD grafika do Vege,kada i Nvidia pljune Voltu.Kako je Manuel rekao,Polaris 10 i 11 isključivo mainstream
the Bariarnil
Bariarnil je offline   Reply With Quote
Staro 09.05.2016., 14:38   #180
Manuel Calavera
Postovi: 14,584
Čak se šuška da bi mogle biti nazvane R9 480 i 480X, ono što je sigurno je da je najslabiji model barem u rangu cca R9 290/390 ili 290X/390X (VR req.), sve iznad je bonus ako bude. Ključno je što bi kao trebala donijeti "pristupačnost" odn. bolji omjer performance per dollar i naravno per. per watt. Zadnje im je jako važno jer se planiraju vratiti na laptop tržište u velikom stilu
A nvidijina gtx 1060 u 9 ili 10 mjesecu (cca gtx 970+)
Zadnje izmijenjeno od: Manuel Calavera. 09.05.2016. u 14:48.
