Staro 15.04.2016., 09:37   #2371
Tvrdi
Sremium
Datum registracije: Oct 2013
Postovi: 2,854
Autor T}{OR Pregled postova
Promjene iz 0.5.5 PT:
https://www.reddit.com/r/WorldOfWars...rom_0542_live/
Par izuzetaka:
- Pensa dobija neki buff na oklop lol
- Indianapolis CA premium preload vjerojatno znači ono što znači
- The AA consumable carriers get only increases the AA power by 75% for IJN carriers, and 25% for USN carriers, as opposed to the 200-300% increase cruisers get.
- Engine repair time has been reduced to 60 seconds
- Rudder repair time has been reduced to 40 seconds
- New Death animations which change depending on if you died from: fire, shelling, torpedoes, detonation, or if you've sunk while beached
- Firing detection penalty of: Storojevoy, Derzky, Izyaslav has been reduced by 1km, 3km torpedo's range increased by 1km
- Kirov has an additional superstructure hitbox
- Ishizuchi's shot delay has been reduced to 25 seconds (was 30) ... kao Tirpitz valjda
- US 8in55 Mark 14 Model 1 artillery's armor model is changed, probably buffs ... topovi na Pensa/NO buff??!
itd...
hahah što ti bi da prodaš možda najzabavniji brod u igri...Pepsi here I comeee :-))) BTW, sad kad imam dovoljno premium brodova za farmanje love isplati mi se igrati i t10....za sada mi je plan krenut na Hindenburga...možda i Khabu sad kad sam blizu tog....I možda jedan BB tak da imam sve tri klase (osim CV)...Yamato? :-)))
Zadnje izmijenjeno od: Tvrdi. 15.04.2016. u 10:48.
Staro 15.04.2016., 10:03   #2372
T}{OR
DBS
T}{OR's Avatar
Datum registracije: Nov 2010
Postovi: 1,855
Prodao sam ju jedino iz razloga da financiram Baltimore. Kasnije se lako vratim na Pensu jer je T7 kikiriki naprema T10.
No, ako fakat izbace Indianapolis to će vrlo vjerojatno biti moj prvi premium USN brod. USN CA mi leže, tako da re-training kapetana može biti samo gušt. Recimo da stave Indy na T7 i kao premium posebni feature s radarom... Jao.
Sent using Tapatalk.
Staro 15.04.2016., 11:05   #2373
BladeRy
BladeRy's Avatar
Datum registracije: Aug 2008
Postovi: 2,000
Ermmmm
Rijesenje torpedo spama na WG nacin....
  • Fubuki's, Kagero's and Shimakaze's added torpedoes reload faster. - Fubuki's torps reload in 100 seconds, Kagero reloads in 120 and Shimakaze's reload in 150 seconds-- however this is not the case for the new torps.
  • Fubuki's new Ibuki torps reload in 90 seconds (10 seconds faster)
  • Kagero's new Zao torps reload in 104 seconds (16 seconds faster)
  • Shimakaze's new Zao torps reload in 131 seconds (19 seconds faster)
Hoce sad ovo bit standardna torpeda za ove DDove, tj, top tier il startna? Jerbo shima ima Type 93 mod 1 i Type 93 mod 3, osim sta im smanjuju domet na koja se torpeda odnosi sta? Al posto daju 2 razlicite vrijednosti brzeg reloada, ocito vrijedi za oba...
I ovo je bice dataminano, jer su dali neke promjene u MSgID stvarima sta su inace ispod haube, zato je vjerovatno nerazumljivo ponesto.
Staro 15.04.2016., 11:07   #2374
Tvrdi
Sremium
Postovi: 2,854
http://forum.worldofwarships.eu/inde...isappointment/
ovakvi me postovi uvijek obeshrabre da se vratim t9 i t10 mečevima...ali opet -20% repair cost plus torpedo wall nerf bi trebao valjda bar malo poboljšati situaciju...
Staro 15.04.2016., 11:24   #2375
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Ja ću ti samo reći kako i s Taihom i s Baltijem zarađujem podosta u T9. Jest, imam premium pa je osjetno više nego što bi bilo bez, ali i bez premiuma sam redovito u plusu. Grdo je ako ništa ne napraviš u partiji i potope te rano tu nema sumnje. Ali ako imaš dobre partije može se, barem u T9. I još koristim 3 x premium consumable na Balti (repair, radar i heal).
Autor BladeRy Pregled postova
Ermmmm
Igrao sam Mutsukija, 200 partija, a on je na "crnoj listi" radi jako sporih torpeda i dugog reloada koja za svoj tier imaju super domet. Hatsuharu mi je još bolje legao a smatra se mrvicu boljim od omraženog Mutsukija. Recimo s njime sam 16. na EU serveru po WR. Ovo je nerf za loše igrače koji spamaju torpeda na daljinu i buff za one koji su ionako dobri (tipa meni leži Fubuki i koristim 10km torpeda).
Dakle 20km torpeda ćeš sad vidjet skoro km dalje, sporija su i imaju dulji reload. 12 km torpeda su pristojna. Ali Zao torpeda sa 8km i preko 70 čvorova su ubitačna na malim udaljenostima. No, traže lansiranje debelo unutar radara. High risk high reward gameplay im je cilj. Kako će to izgledati u praksi vidjet ćemo.
Zadnje izmijenjeno od: T}{OR. 15.04.2016. u 11:54.
Staro 15.04.2016., 11:31   #2376
Tvrdi
Sremium
Postovi: 2,854
PA to je ok. A ne da kreteni spavaju iza dok mi budale idemo napred...Tako nešto bi trebalo i BBima uvest...
Staro 15.04.2016., 11:46   #2377
BladeRy
BladeRy's Avatar
Postovi: 2,000
Najbolje mi je da dodgeam torpeda koje je bacio DD iz mog tima..iza mene u Atagu. I vidim ih tek kad UI pocne vristat da pazim na torpeda dok se napucavam a torpeda mi dolaze zguza... zivili teammateovi.
Instaliram PT verziju pa da vidim na sta to lici, samo 4.5gb klijent download. Pitanje je na koliko ce se napohat, al rekli su da su sredili file sistem, sredili loading i to... budemo vidili. Javim dojmove, al ovo sta reklamiraju za bolji karusel, bolje potapljanje brodova i da mozes radit preview armora i to, ja patim na takve male stvari.
Staro 15.04.2016., 12:13   #2378
Tvrdi
Sremium
Postovi: 2,854
Mene sinoć u Atagu lik skoro 2 puta torpao dok sam bio fokusiran na drugi brod. On u Hipperu polukoso paralelno iza mene ide i sije torpeda ko budala (i ne puca btw), baš mu se jebe za mene. A ni blizu da imaju domet do prvog neprijatelja. Neki igrači su baš totalno limitirani u bulji. Da stvar bude gora nakon prvog puta sam ga zamolio da prestane ali je ponovio stvar. Ne jebe živu silu. Na kraju pratije mislim da nije imao više od soma dmga. Totalna ameba.
I ja.
Staro 15.04.2016., 12:48   #2379
BladeRy
BladeRy's Avatar
Postovi: 2,000
E bas tako, gadjam nekoga na 15km od sebe, on je 5-8km iza mene i posere spread torpeda da se rasire ko govno po livadi tako da imam sta dodgeat...a torpeda nemogu doc do nikoga jer nema 25km dometa...a i da ima, sa tolikim spreadom nije u stanju pogodit otok a ne brod. Ja se nadam da je to neki "Bot", jer ako je zivi igrac onda stvarno jebiga.
A u zadnjih par dana sta sam grindao Zaoa, nasi cruiseri potapaju DDove i BBove. Ok, jos mogu shvatit da je torp spread zakacio DDa isped njega, iako nije ni to trebao bacat....al bog ga ubio kako je torpao slucajno svoj BB? Sta je radio iza BBa?
Ja eventualno zavrsim iza BBa samo ako se okrecem, al igram agresivno ko kreten pa sam prva linija fronte. Al ako si iza BBa tako da bacis spread i potpois ga, e onda stvarno...
Staro 15.04.2016., 13:18   #2380
Tvrdi
Sremium
Postovi: 2,854
Mogli bi koju diviziju s Atagom bacit kad se vidimo u igri. Najbolje se uči tako novi brod hehe Polako se ufuravam i sve mi se više sviđa iako često previše srljam. Imam DE i pržim vatre ko blesav a AP je solidan. Sad već i torpeda koristim malo bolje haha
Staro 15.04.2016., 13:31   #2381
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Ajd ako nije frka molim te baci oko na nove premium skinove koji očito dolaze s 0.5.5. Liku na redditu se nije dalo stavljati popis brodova.
Staro 15.04.2016., 13:39   #2382
Tvrdi
Sremium
Postovi: 2,854
Koji sad novi premium skinovi? Samo vizualna promjena ili?
Nego, s azijskog WG sajta:
Dynamic Divisions
You can now create a division on the go... even during a match!
Ne kužim kaj to znači...
EDIT: novi nišani
http://imgur.com/a/ugqVd
Staro 15.04.2016., 13:44   #2383
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Autor gnujko Pregled postova
Iz reddit linka:
New camouflages: Indianapolis, Ranger, New York, Flint, Cleveland, Black, and more but i'm too lazy to shift through 3 MB of text for specifics.
Kako su na popisu Ranger, New York i Cleveland, između još nenajavljenih brodova moja pretpostavka je da se radi o premium kamuflažama. Dakle +50% XP i oba bonusa do T7. Od T8 i smanjeni troškovi (T8 -5%, T9 -10%) održavanja broda.
Staro 15.04.2016., 13:51   #2384
Tvrdi
Sremium
Postovi: 2,854
Ovdje rusi streamaju 0.5.5 public test...počinje u 19h
Staro 15.04.2016., 14:00   #2385
Flayer
Why So Serious?
Flayer's Avatar
Datum registracije: May 2005
Postovi: 151
Gnujko....
Dynamic Divisions
To znači da možeš napraviti diviziju kada si već u partiji ako želiš s nekime odnosno onaj ko prvi napravi diviziju tada je Commander i može zvati još 2 člana za vrijeme igre.
If you're in control, you aren't going fast enough.
Flayer je offline   Reply With Quote
Staro 15.04.2016., 14:06   #2386
Tvrdi
Sremium
Postovi: 2,854
Autor Flayer Pregled postova
Gnujko....
Dynamic Divisions
Je al me zanima dal mi možemo upast unutra dok onaj koji zove u diviziju već igra i/ili dok traje odbrojavanje..ili to vrijedi za partiju iza...?? ako je prvi slučaj onda to nema smisla...ono vidim da gubimo i pozovem još 2 frenda da okrenemo stvar...ili?
btw, sad vidim da Shima bude imaop brža torpeda, a acc skillom 81 KTS....ali zato domet nešto više od 6km a conc par sto metara manje...bit će sad valjda veća fora igrat te više tierove.....i za shima drivere i za nas koji smo na drugoj strani....bumo vidjeli
Staro 15.04.2016., 14:27   #2387
BladeRy
BladeRy's Avatar
Postovi: 2,000
Jos PT nije live, screenshotam sve sta bude zanimljivo i postam ako me tko ne preduhitri.
@Gnujko
Ma igras Ataga kao cloaky cruisera i samo palis na range, BBovi gore da je milina, znam napravit po 7-10k dmga salvom HEa na BBa, Ap na cruisere ih vrlo brzo iznenadi, volim ih navuc da plovim broadside 2 He salvoa ako oni tuku HE isto, onda je mentalitet napucavanja u fazi, promjenim na AP i napravim 17-20k salvu pa popizde od bjesa kad iz izbrises
Torp kao area denial il ako tko dolazi pa da se ima cime zabavit. Prednost su mu brze turete, ako mislis da su spore probaj Ibukija il Zao, tamo vrtis brod a turete toliko spore da ni rotaciju broda nemogu pratit. Nakon Ibukija i Zaoa, sa uzitkom sam nazad na Atagu.
Mozes stat na 13-15km range i tuc HE il se bas zaletit na njih, imas front arc torpeda da si zivi horror drugima koji trebaju okrenit cijeli brod za torpeda. Jos plus 9.1km detection range je zivi cruiser abuse Jedina mana broda je reload od 16 sec i ocajan AA. Al kad vidis sta sve mozes napravit sa 16 sec reloadom, da je brzi reload ajme ga njima.
Staro 15.04.2016., 14:33   #2388
Tvrdi
Sremium
Postovi: 2,854
@Gnujko
Skužio sam da prži sa HE ko lud (pogotovo sa DE skillom)....torp area denial je isto isprobano na jednom NO...kad se skrivamo iza otoka onda pošaljem salvu ako mislim da će me pratiti oko jedne strane otoka i uredno popije bar jedan torpedo...budem došao na svoje s tim brodom, samo da odigram više partija....
Staro 15.04.2016., 14:40   #2389
Flayer
Why So Serious?
Flayer's Avatar
Postovi: 151
Prema pročitanome sam dobio dojam da se moš u igri se spojit u div sa 2 stranca npr.
Sumnjam da moš upast u partiju ako je ona već krenula (obzirom da je MM već namjestio 12 vs. 12) ili dok traje odbrojavanje (no možda dok traje odbrojavanje će biti i moguće ako ti napraviš div i pozoveš još 2cu).
Ali nagađam da je to opcija za onda kada su timovi već poznati tipa...krene bitka i skužiš lika od prijašnjih partija i pozoveš ga u div.
Staro 15.04.2016., 18:26   #2390
BladeRy
BladeRy's Avatar
Postovi: 2,000
Evo detalji sa PT servera, ubacim nove stvari nakon bitke il kako otkrijem.
Dinamicko vrijeme je cool, uletio je ciklon, visibility 8km, tuce kisa i vjetar...
nifty.
Carusel view je, vise manje ono sta je i trebao bit.
Info o detaljima broda je malo prosiren.
Uhvatio sam potapanje broda sa malo blize. Torpediran je, polako se okretao na bok i onda prelomio, cute. Drugi se totalno okrenio.
Ostala pitanje i sta vas zanima tocnije, napisite pa pogledam.
Loading times su sranja, od obecanog ubrzanja ni O. Na starom WoWs-u loadam prije pocetka runde il max do 19:45, na ovome, redovito unutar 18te minute.
Zadnje izmijenjeno od: BladeRy. 15.04.2016. u 21:11.
Staro 15.04.2016., 21:33   #2391
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Zanimljivo. Fora su ova potapanja odnosno animacije i vrijeme će fino dat štimung cijeloj igri.
Jesi bacio oko dal ima kakvih novih premium kamuflaža? Zanima me recimo NC ili Taiho...
Staro 15.04.2016., 21:37   #2392
Smoki_Gs
Smoki_Gs's Avatar
Lokacija: Gospić
Postovi: 452
Veceras se bas lijepo plovilo Bilo je svega i svacega,provala,smijeha,citadeliranja Yamata,nasjedanja na torpeda u prvih 2 minute -.- (ja) i tako dalje Evo nekih primjera,mislim da je bilo oko 7 pobjeda i 3 poraza ukupno.. Sudionici su Thor i Thronia
Smoki_Gs je online   Reply With Quote
Staro 15.04.2016., 21:54   #2393
BladeRy
BladeRy's Avatar
Postovi: 2,000
Server je crkao, al cim dodje up pogledam ta 2 broda. Nisam geldao bas nove kamuflaze jer neznam koje su nove a koje stare.
Staro 15.04.2016., 23:02   #2394
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Samo dal brod ima ili nema premium camo. Trebao bi imati 3 normalne, jednu za 50 dublona i ako je T8 još jednu za 3000 dublona. Ako je T9 4000 dublona itd...
Staro 15.04.2016., 23:52   #2395
BladeRy
BladeRy's Avatar
Postovi: 2,000
Mogu to vidit samo ako unlockam brod, po brodu je 4k expa, pa mi je lakse nafarmat exp sa nekim brodom, sve prebacit u free exp i onda tako unlockam brodove.
Tako da radim na tome
Staro 16.04.2016., 09:13   #2396
QS
QS's Avatar
Datum registracije: Mar 2009
Postovi: 284
Ajde za njubaru nabacite kakav tutorial sa "specifičnim leksikom" (znam kratice za klase i te sheme al me spizdi "citadeliranje" i slično).
Počeo igrat prije tjedan dana možda, vozam BBove i švabe (trenutno T3) - jel ima kakav hint, savjet, trik, whatever dok sam na niskim tierovima da lakše doveslam do vas na T7+
Kome se da tipkat naravno, jebiga pregledao forum uzduz i poprijeko i ovo sto noob tutoriala ima je ili outdated ili nezavrseno (ko jedan car koji je napisao uvod prije godinu dana i onda ispod "ako se ovo ljudima svidi, dovrsit cu bla bla")
By Neptune's beard!
QS je offline   Reply With Quote
Staro 16.04.2016., 10:07   #2397
Flayer
Why So Serious?
Flayer's Avatar
Postovi: 151
Citadela je vitalan dio broda tj. strojarnica pod dimnjacima ili spremište granata pod turretima te pogodak u taj dio broda u razini vode nosi najviše štete odnosno ako ti više granata sjedne u citadelu postoji šansa da skineš brod jednom salvom te od toga dolazi izvedenica "citadeliranje" tj pogodak u citadelu
Također pogodak ili torpedo (jedan) u spremište granata može dovesti do "Detonation" - detonacije i brod explodira odmah
Nema neki trik za brže napredovanje osim igrati i igrati da se brže skupljaju XP-i, da se prije može otključati viši Tier broda.
Malo brže buš napredovao sa Premium account-om jer jebiga nosi više XP-a po bitki i više kredita ali to je osobni odabir.
Naravno dok se penješ po ljestivici uči na greškama da ih ne ponavljaš u višim Tier-ovima jer se tamo manje prašta - ko ja jučer npr. sa Smokijem stojimo na nos nasuprot druge 2 Caroline i kaj ja napravim? Krenem napred i lijevo te okrenem bok (broadside) Carolinama koje me izbuše po citadelama (70%HP-a u njihove 2 salve ). Zake sam to napravio...neznam ni sam
Ostale kratice:
https://www.reddit.com/r/WorldOfWars...onyms_in_wows/
Super tutorijali sa objašnjenjima:
http://worldofwarships.eu/en/content/guides/
Staro 16.04.2016., 13:31   #2398
Lun
Lun's Avatar
Datum registracije: Jan 2010
Postovi: 408
Lun je offline   Reply With Quote
Staro 16.04.2016., 13:47   #2399
BladeRy
BladeRy's Avatar
Postovi: 2,000
@Thor
Ni NC ni Taiho nemaju nove kamuflaze.
I novo ginjenje DDova je zakon, ako ga strefe torpeda, prokleti DD iskoci iz vode koliko ga digne eksplozija. Naravno ne poleti u zrak, al izgleda kao snimke torpedo hitova u WW2, realno i uzivancija. Neke animacije koje sam vidio, su bile detonacije u brodu nakon sta je unisten, nazalost jos nisam ulovio detonaciju cijelog broda kad rokne magazin il nesto. Tako da sam ulovio dosad 3-4 animacije potapanja.
Neke su glupe, tipa Yama dobio po nosu a tone mu guzica prvo... ako je izbusen sprijeda, onda voda ulazi sprijeda i tone sprijeda prvo...al ok, da ne cjepidlacimo, inace overall, nelos patch.
Zadnje izmijenjeno od: BladeRy. 16.04.2016. u 14:34.
Staro 16.04.2016., 14:59   #2400
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Hvala. Pogledao iChaseov video - ovo s promjenjivim vremenom izgleda brutalno. A i animacije isto.
@ QS: Definitivno pogledaj filmiće koje je Flayer stavio. A ona ako imaš kakvih pitanja objasnimo.
Zadnje izmijenjeno od: T}{OR. 16.04.2016. u 15:09.
