#91 |
Postovi: 34,037
Kaže GMSA da izgleda neće biti livestreama. http://www.gsmarena.com/watch_the_ht...news-17731.php
#92 |
Lokacija: Kutina, CRO
Postovi: 439
#93 |
Postovi: 439
-''new generation UltraPixel sensor with OIS and a bright ƒ/1.8 lens. We’ve packed in 12 million UltraPixels (1.55um per UltraPixel)'' -''HTC 10’s front camera is as impressive as its main camera. It features a large pixel sensor, an ƒ/1.8 lens and a screen flash, so shots come out brighter and richer. Its wide-angle lens fits more friends and fun into every photo. And, in a world first, it’s the only front camera with OIS for better selfies every time.'' -''HTC 10 combines vivid 4K video with the world’s first stereo 24-bit Hi-Res audio recording in a smartphone'' -''HTC 10’s camera is designed to launch almost instantly, in as little as 0.6 seconds. While our 2nd generation laser autofocus gives you focused shots faster'' -''Brilliant sound is at the very heart of HTC 10. In fact, it’s one of the few phones with certified* Hi-Res audio. Just press play and you’ll hear how Hi-Res audio processing, 24-bit DAC and our new high performance headset amplifier are all carefully tuned to work together to deliver a true symphony of sound.'' -''The new HTC BoomSound™ Hi-Fi edition speakers feature the same separated tweeter and woofer design as leading acoustic systems, with a dedicated amplifier for each speaker to deliver audio quality unprecedented from a smartphone.'' -''HTC 10’s fingerprint security keeps your data safe, but unlocks at just the touch of your finger - in a lightning fast 0.2 seconds. Our sensor recognizes your fingerprint from almost every angle and position. And its smart algorithm learns to recognize you even faster and more accurately over time.'' -''And a next generation 2K LCD display that is 30% more colorful and specially tuned to cinema color standards, so your movies look true to the director’s vision.'' -''Boost+. Able to dynamically allocate resources as required, it makes switching between apps smoother and maximizes battery life by reducing the power usage of background apps.'' -''The new HTC Freestyle Layout frees you from an on-screen grid and lets you get creative. Drag icons, stickers and widgets anywhere. Layer them, overlap them, group them and more. You can even link stickers to apps, and get rid of on-screen icons entirely. This space is yours, use it your way.'' -''We’ve engineered HTC 10 from the inside out to stay running longer – up to 2 days of normal use. Enough to keep you entertained for hours upon hours. It’s all thanks to our new PowerBotics system - which enhances hardware and software efficiency and delivers up to 30% longer battery life.'' -''Every HTC 10 comes with the latest Quick Charge 3.0 enabled Rapid Charger, and is made to stay cool while charging the battery quicker than ever - up to 50% in just 30 minutes'' Ovo miriše na hit, ja osobno ne vidim slabu točku, osim šarenog Sensea, manje više su pokupili sve šta valja sa drugih, kameru sa Nexusa i Samsunga, leću LGa, HiRes i bateriju Sonyja, dodali svoje i ovo zaista izgleda odlično! Evo i DxO ocjene: 88!
#94 | |
Postovi: 8,516
Također, cijena...ako netko ima toliko para i uđe recimo u dućan, želi novi flagship...ne znam baš da će se odlučiti za njega naspram S7... Nisu se potrudili previše distancirati po nečemu od drugih. Čekam da vidim slike kamere, dotad... Zadnje izmijenjeno od: Neo-ST. 12.04.2016. u 15:39. |
#95 |
Postovi: 1,570
To je meni, gledajući ovako čiste specifikacije, jedini minus. I naravno treba tu kameru vidjeti. Za Sense ne brinem . |
#97 |
Postovi: 1,554
Sve je to lijepo na papiru. I nadam se nekoj 'mini' varijanti, ali da zadrzi sve unutrasnje organe velikoga brace ![]()
"There he goes.One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die" |
#98 |
Lokacija: Sv.Nedelja
Postovi: 5,826
#99 | ||
Postovi: 8,516
To je Sense vs. Touchwiz, right there. Sent from my SM-G900F using Tapatalk |
#102 | |
gadget freak
Lokacija: Jasenovac
Postovi: 2,224
#105 |
Postovi: 5,826
#106 |
Postovi: 34,037
Cijene baš i nisu simpatične - 700-800€ u ovisnosti o državi http://www.gsmarena.com/htc_10_avail...news-17735.php
#107 |
Postovi: 1,554
Ocekivano od HTC-a. Mogu propasti jos vise, ali cijene nema sanse da spuste. Donekle shvacam i tu politiku, ali ovo im je bio savrsen trenutak da uz malo nize cijene naprave odlican posao. Steta sto su propustili tu priliku. Iako se i dalje nadam da ce ih m10 izvuci iz problema...
#108 |
Postovi: 5,826
#109 |
Lika u mom srcu
Lokacija: Canada, Toronto
Postovi: 9,887
napokon vrhunski uredjaj! opcenito, ovo sve ostalo je burek, ovo kupujem pa makar kostao 1000 dolara. vise mi je pun K nedorecenih uredjaja, samsunga, nexusa, lg-a i njihovih poluproizvoda. 10 bi trebao navodno imati kamera cip is nexusa 6P, a tamo radi vrhunski, a ovdje moze samo jos bolje! da 6P nije tako ogroman (imao ga), i danas bi mi bio na stolu, iako me upravo camera app uzasno smetao na nexusu jer je retardirano rudimentaran. |
#110 | |
Postovi: 439
#111 | |
Postovi: 1,554
Uostalom, skuplje je razvijati vlastiti proc nego kupiti gotovi. Sent from my E5823 using Tapatalk
#112 |
Lokacija: Osijek, Hrvatska
Postovi: 397
tko kupuje na rate ili uzima pretplatu njemu je gotovo ista cijena za flagship modele tako da bi i HTC tu mogao imati prođu. No tko ima keš i uzima novi flagship iz oglasnika vrlo vjerojatno ce uzeti s7 koji je vec ispod 4k kn. |
#113 |
Lokacija: Ri
Postovi: 1,923
Kako je ruzna ova zadnja strana. Iz nekog razloga onaj rub daje dojam da je mobitel puno deblji nego sto jest. Mob izgleda "OK" na papiru. Definitivno prerano za neku odusevljenost. |
#114 | |
Lika u mom srcu
Postovi: 9,887
ma daj mi nemoj u istu recenicu stavljati kineze i brand marke. |
#115 |
Postovi: 1,554
#117 |
Postovi: 4,707
Oho, čekam review kamere. Bojim se da neće moći stajati uz S7 i 6S, al nadam se da bude blizu. Debelo podržavam izbjegavanje dvostrukih identicnih aplikacija i Nexusifikaciju. Staklo na kameri nije sapphire? Izgrebat će se... |
#119 |
Lika u mom srcu
Postovi: 9,887
S7 je kifla od kamere kao i ovaj note5, previse procesinga, u bilo kojem uvjetu osim savrseno suncanog dana su slike burek, nexus 6p je daleko bolja kamera, samo sto samsung jako dobro placa youtubere i reviewere Mileni, znas ti jako dobro sto ja govorim, pravi se pametan nekom drugom |
#120 |
Nakon Intela i nVidije, imamo znači još jednog vendora koji je lošiji od konkurencije ali plaća youtubere i reviewove na netu koji lažiraju fotke i video zapise pa je bolji... de Gabre nemoj molim te. Te, ovo je HTC tema pa nije potreno uspoređivat Samsung i Nexus 6P. |
