Staro 12.04.2016., 13:59   #91
Postovi: 33,922
Kaže GMSA da izgleda neće biti livestreama.
http://www.gsmarena.com/watch_the_ht...news-17731.php
Staro 12.04.2016., 14:03   #92
bubimir13
bubimir13's Avatar
Lokacija: Kutina, CRO
Postovi: 439
bubimir13 je offline   Reply With Quote
Staro 12.04.2016., 14:18   #93
bubimir13
bubimir13's Avatar
Postovi: 439
-''new generation UltraPixel sensor with OIS and a bright ƒ/1.8 lens. We’ve packed in 12 million UltraPixels (1.55um per UltraPixel)''
-''HTC 10’s front camera is as impressive as its main camera. It features a large pixel sensor, an ƒ/1.8 lens and a screen flash, so shots come out brighter and richer. Its wide-angle lens fits more friends and fun into every photo. And, in a world first, it’s the only front camera with OIS for better selfies every time.''
-''HTC 10 combines vivid 4K video with the world’s first stereo 24-bit Hi-Res audio recording in a smartphone''
-''HTC 10’s camera is designed to launch almost instantly, in as little as 0.6 seconds. While our 2nd generation laser autofocus gives you focused shots faster''
-''Brilliant sound is at the very heart of HTC 10. In fact, it’s one of the few phones with certified* Hi-Res audio. Just press play and you’ll hear how Hi-Res audio processing, 24-bit DAC and our new high performance headset amplifier are all carefully tuned to work together to deliver a true symphony of sound.''
-''The new HTC BoomSound™ Hi-Fi edition speakers feature the same separated tweeter and woofer design as leading acoustic systems, with a dedicated amplifier for each speaker to deliver audio quality unprecedented from a smartphone.''
-''HTC 10’s fingerprint security keeps your data safe, but unlocks at just the touch of your finger - in a lightning fast 0.2 seconds. Our sensor recognizes your fingerprint from almost every angle and position. And its smart algorithm learns to recognize you even faster and more accurately over time.''
-''And a next generation 2K LCD display that is 30% more colorful and specially tuned to cinema color standards, so your movies look true to the director’s vision.''
-''Boost+. Able to dynamically allocate resources as required, it makes switching between apps smoother and maximizes battery life by reducing the power usage of background apps.''
-''The new HTC Freestyle Layout frees you from an on-screen grid and lets you get creative. Drag icons, stickers and widgets anywhere. Layer them, overlap them, group them and more. You can even link stickers to apps, and get rid of on-screen icons entirely. This space is yours, use it your way.''
-''We’ve engineered HTC 10 from the inside out to stay running longer – up to 2 days of normal use. Enough to keep you entertained for hours upon hours. It’s all thanks to our new PowerBotics system - which enhances hardware and software efficiency and delivers up to 30% longer battery life.''
-''Every HTC 10 comes with the latest Quick Charge 3.0 enabled Rapid Charger, and is made to stay cool while charging the battery quicker than ever - up to 50% in just 30 minutes''
Ovo miriše na hit, ja osobno ne vidim slabu točku, osim šarenog Sensea, manje više su pokupili sve šta valja sa drugih, kameru sa Nexusa i Samsunga, leću LGa, HiRes i bateriju Sonyja, dodali svoje i ovo zaista izgleda odlično!
Evo i DxO ocjene: 88!
Staro 12.04.2016., 14:34   #94
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,275
Autor bubimir13 Pregled postova
Mogli su barem osnovnu vodootpornost riješiti. Ne treba IP68 da možeš ronit s njim, ali osnovna, da si miran ako ti pokisne ili se prolije nešto po njemu...
Također, cijena...ako netko ima toliko para i uđe recimo u dućan, želi novi flagship...ne znam baš da će se odlučiti za njega naspram S7...
Nisu se potrudili previše distancirati po nečemu od drugih.
Čekam da vidim slike kamere, dotad...
Zadnje izmijenjeno od: Neo-ST. 12.04.2016. u 14:39.
Staro 12.04.2016., 14:36   #95
schetz
schetz's Avatar
Postovi: 1,570
Autor Neo-ST Pregled postova
To je meni, gledajući ovako čiste specifikacije, jedini minus. I naravno treba tu kameru vidjeti. Za Sense ne brinem .
schetz je offline   Reply With Quote
Staro 12.04.2016., 14:43   #96
MeanBoss
|CTS|MeanBoss|
MeanBoss's Avatar
Lokacija: Sinj
Postovi: 1,005
Zna li netko otprilike koliko dodje zamjena ekrana za m8.. Prijatelju puklo! :/
Sent from my SM-G920F using Tapatalk
Staro 12.04.2016., 14:58   #97
Mileni
Mileni's Avatar
Postovi: 1,554
Sve je to lijepo na papiru. I nadam se nekoj 'mini' varijanti, ali da zadrzi sve unutrasnje organe velikoga brace
"There he goes.One of God's own prototypes. A high-powered mutant of some kind never even considered for mass production. Too weird to live, and too rare to die"
Staro 12.04.2016., 15:01   #98
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,816
Staro 12.04.2016., 15:25   #99
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,275
Subjectively, for whatever reason navigation does feel noticeably smoother and responsive compared to the Galaxy S7, especially when dealing with long scrolling lists in apps like Reddit is Fun. I’m not sure if the HTC 10 is actually smoother here or if Samsung is just doing something different when it comes to touchscreen response because it’s entirely plausible that the Galaxy S7 just gives less momentum to a swipe, but it’s something I’ll have to test with more than just subjective testing. Regardless, something as simple as swiping through the app drawer causes what looks like dropped frames on the S820 GS7 while the HTC 10 is flawlessly smooth here.
To je Sense vs. Touchwiz, right there.
Sent from my SM-G900F using Tapatalk
Staro 12.04.2016., 15:30   #100
Postovi: 33,922
Šta je s proširivošću memorije?
Staro 12.04.2016., 15:33   #101
zvonac
zvonac's Avatar
Postovi: 5,816
Autor coconut Pregled postova
Proširiva je...
Uff, ak je tak sve kako piše na papiru, kamera bi trebala bit vrhunska..
Staro 12.04.2016., 16:35   #102
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
+1
Staro 12.04.2016., 16:50   #103
zvonac
zvonac's Avatar
Postovi: 5,816
The 10 is IP53 certified.
Staro 12.04.2016., 16:57   #104
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,275
Autor zvonac Pregled postova
Opa. Izvor? Kako mi je to promaklo...
Znači osnovna zaštita protiv prašine i prskanja je ipak tu.
Staro 12.04.2016., 17:07   #105
zvonac
zvonac's Avatar
Postovi: 5,816
Staro 12.04.2016., 18:15   #106
Postovi: 33,922
Cijene baš i nisu simpatične - 700-800€ u ovisnosti o državi
http://www.gsmarena.com/htc_10_avail...news-17735.php
Staro 12.04.2016., 18:39   #107
Mileni
Mileni's Avatar
Postovi: 1,554
Ocekivano od HTC-a. Mogu propasti jos vise, ali cijene nema sanse da spuste. Donekle shvacam i tu politiku, ali ovo im je bio savrsen trenutak da uz malo nize cijene naprave odlican posao. Steta sto su propustili tu priliku. Iako se i dalje nadam da ce ih m10 izvuci iz problema...
Staro 12.04.2016., 20:11   #108
zvonac
zvonac's Avatar
Postovi: 5,816
Staro 12.04.2016., 20:28   #109
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
napokon vrhunski uredjaj! opcenito, ovo sve ostalo je burek,
ovo kupujem pa makar kostao 1000 dolara.
vise mi je pun K nedorecenih uredjaja, samsunga, nexusa, lg-a i njihovih poluproizvoda.
10 bi trebao navodno imati kamera cip is nexusa 6P, a tamo radi vrhunski, a ovdje moze samo jos bolje!
da 6P nije tako ogroman (imao ga), i danas bi mi bio na stolu, iako me upravo camera app uzasno smetao na nexusu jer je retardirano rudimentaran.
Staro 12.04.2016., 20:37   #110
bubimir13
bubimir13's Avatar
Postovi: 439
Autor Mileni Pregled postova
Djelomično mislim da je i to što osim softvera u HTC uređajima skoro da i nema ništa in-house za razliku od ostalih OEMa koji barem nešto već imaju što pojeftini. Nije to neki razlog al sigurno da kad se sakupi da ispadne visoka cijena, jer evo i BB je nedavno priznao da je Priv sahranila visoka cijena i da se ne isplati boriti se na flagship razini ako nisi spreman na nižu cijenu a to vodi ka nižem profitu...
Staro 12.04.2016., 20:40   #111
Mileni
Mileni's Avatar
Postovi: 1,554
Ne bih se složio. Pogledaj neke jače kineze tipa xiaomi, oneplus, itd. Najjači mogući hardware, a duplo niza cijena. Koriste 95% istog hardwarea kao i HTC.
Uostalom, skuplje je razvijati vlastiti proc nego kupiti gotovi.
Sent from my E5823 using Tapatalk
Staro 12.04.2016., 20:48   #112
ćubi
ćubi's Avatar
Lokacija: Osijek, Hrvatska
Postovi: 397
tko kupuje na rate ili uzima pretplatu njemu je gotovo ista cijena za flagship modele tako da bi i HTC tu mogao imati prođu. No tko ima keš i uzima novi flagship iz oglasnika vrlo vjerojatno ce uzeti s7 koji je vec ispod 4k kn.
ćubi je offline   Reply With Quote
Staro 12.04.2016., 21:14   #113
Rista
Rista's Avatar
Lokacija: Ri
Postovi: 1,922
Kako je ruzna ova zadnja strana. Iz nekog razloga onaj rub daje dojam da je mobitel puno deblji nego sto jest.
Mob izgleda "OK" na papiru. Definitivno prerano za neku odusevljenost.
Staro 12.04.2016., 21:16   #114
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
ma daj mi nemoj u istu recenicu stavljati kineze i brand marke.
Staro 12.04.2016., 21:17   #115
Mileni
Mileni's Avatar
Postovi: 1,554
Autor Gabre Pregled postova
A HTC je? Shvabo?
Staro 12.04.2016., 21:32   #116
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,275
Ova isturena kamera će najebat ako se mob ne stavi u neki case, a ako se stavi u case onda mu džaba sav metal i glamur.
Zašto nas dovode u takve situacije ?
Staro 12.04.2016., 21:32   #117
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Oho, čekam review kamere. Bojim se da neće moći stajati uz S7 i 6S, al nadam se da bude blizu.
Debelo podržavam izbjegavanje dvostrukih identicnih aplikacija i Nexusifikaciju.
Staklo na kameri nije sapphire? Izgrebat će se...
Staro 12.04.2016., 21:42   #118
A HTC je? Shvabo?
Republika Kina
Staro 12.04.2016., 21:43   #119
Gabre
Lika u mom srcu
Gabre's Avatar
Postovi: 9,887
S7 je kifla od kamere kao i ovaj note5, previse procesinga, u bilo kojem uvjetu osim savrseno suncanog dana su slike burek, nexus 6p je daleko bolja kamera, samo sto samsung jako dobro placa youtubere i reviewere
Mileni, znas ti jako dobro sto ja govorim, pravi se pametan nekom drugom
Staro 12.04.2016., 21:46   #120
Nakon Intela i nVidije, imamo znači još jednog vendora koji je lošiji od konkurencije ali plaća youtubere i reviewove na netu koji lažiraju fotke i video zapise pa je bolji... de Gabre nemoj molim te.
Te, ovo je HTC tema pa nije potreno uspoređivat Samsung i Nexus 6P.
