Staro 03.04.2016., 20:31   #2251
zgmmax
zgmmax's Avatar
Postovi: 1,662
Sad sam sa NC skinuo Iowi 30k u jednoj salvi, sa time da sam ju pogodio sa samo 3 shella.
To mi je do sada rekord u jednoj salvi
Staro 04.04.2016., 02:19   #2252
Smoki_Gs
Smoki_Gs's Avatar
Datum registracije: Aug 2008
Lokacija: Gospić
Postovi: 452
Nice,moze se Iowa samljeti brzo,ali,nesto u zadnje vrijeme mi nekako se sreca okrenula s njom...... Necu ju ukleti sad
Ali,evo za laku noc,primjer iz Smokijeve skole SealClubbanja I jedan primjer kad se protivnicki team zamisli da je GG na startu,pa se opasno zeznu (u tom gameu sam ukrao kill na Fubukiju,i neznam zasto,ali trebao je bit Devestating na Atagu i Hindenburgu,obojici sam prek 50% skinuo
ID:	16356   Click image for larger version
ID:	16357   Click image for larger version
ID:	16358   Click image for larger version
ID:	16359   Click image for larger version
Staro 04.04.2016., 10:41   #2253
T}{OR
DBS
T}{OR's Avatar
Datum registracije: Nov 2010
Postovi: 1,855
Kako mi je Shokaku trenutno najdraži brod u igri, malo sam guglao o njegovom kraju. Ono što sam ovdje našao je u blagu ruku šokantno:
The sinking of Shokaku
By 1330 the fires on Shokaku were growing much worse and flames began spouting from the flight deck and elevator wells and could be seen from the other ships. Moreover, the bow continued to subside into the sea, and the situation soon became hopeless as the forecastle came awash. Reluctantly Captain Matsubara bowed to the inevitable and gave word that all hands should come up on deck, and prepare to abandon ship. Thorough check was to be made that no one remained below to perish. Officers groped their way through burning and smoke-filled compartments, calling out names and looking for any one left behind. Several hundreds of the ship's company now gathered on the flight deck aft, where the fire had not yet reached, and assembled for roll call. Others energetically threw wreckage and rafts overboard to men who had been blown into the water, or leaped into the sea and swam to the floats themselves.
On the flight deck aft, the men waited in supernatural calm as the chiefs and officers made their head count, even though explosions continued to rock the ship and the flight deck was now starting to slant perceptibly downwards. In fact, at that very moment the seas were swallowing the forecastle and rising up to the level of the flight deck itself. As the bow settled, wreckage and bombs and burning planes in the hangar began to slide and bump forward. It was then that total catastrophe, even greater than that already in progress, struck.
Either it was touched off by one of the fires, or was set off by tumbling as the ship nosed forward, but at 1408 an aerial bomb on the hangar deck forward exploded. Immediately the volatile gases that had been accumulating below were ignited, and the Shokaku was rent by an ominous grumble deep down inside. This was followed by a truly devastating cacophony of "four terrific explosions" followed by several smaller ones as the forward bomb and torpedo magazines were touched off. In a prolonged convulsion of three minutes the Shokaku literally began to blow apart at the seams.
The men gathered aft were caught completely off-guard--they had assumed they had several minutes to evacuate; in reality they now had only seconds. They were sent tumbling and sliding down the flight deck as Shokaku's shattered bow plunged under the waves. Water surged over and across the flight deck and poured in a torrent through the open No.1 elevator into the hangar. The inrush yanked the stricken carrier downward, causing her fantail to rear terrifyingly and suddenly into the sky.
Screaming and frantically trying to grab anything to hold onto, the mass of humanity on Shokaku's flight deck aft slid down the incline to their deaths and a "fiery hell" as they fell headlong into the open and blazing No.3 elevator into the cavernous inferno that had been the hangar. Survivors already in the water were horrified and the sight of the white-clad mass streaming down to incineration in the elevator pit would remain with them for the rest of their lives. The blazing carrier's stern continued to rise, till it was nearly vertical, and in a scene reminiscent of the sinking of the Titanic, then corkscrewed downwards with a "groaning roar" and collapsed into the deep, disappearing amid churning seas, fire and smoke. Bobbing among the wreckage littered waters the scattered patches of survivors began "to sing Shokaku's song with blood tears". The time was scarcely twelve past two----only two minutes had elapsed since the induced explosion. (Position: 12°00' N, 137°46' E)
Staro 04.04.2016., 12:47   #2254
Flayer
Why So Serious?
Flayer's Avatar
Datum registracije: May 2005
Postovi: 151
Neznam jel ste vidjeli...fino sam se nasmijao
If you're in control, you aren't going fast enough.
Flayer je offline   Reply With Quote
Staro 04.04.2016., 22:00   #2255
Smoki_Gs
Smoki_Gs's Avatar
Lokacija: Gospić
Postovi: 452
Lexi,Yorck,Atlanta,Tirpitz,Aoba .... )
Kako je kjut kad enemy CV odluci ne ici na snipe....
ID:	16362   Click image for larger version
ID:	16363   Click image for larger version
Zadnje izmijenjeno od: Smoki_Gs. 04.04.2016. u 22:16.
Staro 04.04.2016., 22:55   #2256
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Već vidim carnage koji ćeš ti radit s Lexijem.
Enivej, mali top tip za gledanje CV replay-a. Kako bi se vidjele komande avionima potrebno ih je sve selektirati tokom gledanja replay-a. Shift + onoliko gumbi koliko je eskadrila na CV-u. Isprobao danas na jednom svom Shokaku replay-u i radi ko urica. A ja mislio da su CV replay-i za baciti...
Staro 05.04.2016., 11:43   #2257
Lun
Lun's Avatar
Datum registracije: Jan 2010
Postovi: 408
I tako, nakon Kirova, koji je (izuzev topova) škovaca od broda, buđola (T6) je i bez B hulla i retrainanog kapetana - zvijer. Novi kralj T6 cruisera.
Lun je offline   Reply With Quote
Staro 05.04.2016., 11:51   #2258
Tvrdi
Sremium
Datum registracije: Oct 2013
Postovi: 2,854
Autor Lun Pregled postova
Je. Iako s Kirovom sam radio dar mar. Odn. više citadelirao s njim nego s Buddyem ali je dosta slabiji oklop i detonira samo tako. Dal je Buddy kralj t6? Je, ako gledamo AP punch (a solidan je i HE) ali nije okretan kao neki drugi brodovi...
Staro 05.04.2016., 12:19   #2259
mitra
mitra's Avatar
Postovi: 668
Taman odigrao zadnju partiju sa Svetlanom i skupio XP za Kirova...ali...u toj sam ga partiji imao na suparnickoj strani i izbusio sa ga Svetom, uvalio 2 citadele i potopio na kraju...sad neznam da li da se veselim sto sam ga otkljucao ili hehe.
Ugl morat cu imati posebnu taktiku za Kirova kad ga budem vozio...drzi se podazine
Uploading...
mitra je offline   Reply With Quote
Staro 06.04.2016., 14:17   #2260
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Ne igram zadnjih dana radi obaveza / posla, pa ne ostaje drugo nego surfati na poslu.
Nove misije za one koji igraju ruske CA, mogućnost osvajanja premum brodova:
http://worldofwarships.eu/en/news/co...steel-contest/
I malo novosti s RU foruma:
- Hipper uskoro dobiva novi Atlantski pramac (u testiranju je trenutno)
- Königsberg dobiva avion
- Atlanta će dobit nekakav buff
Staro 06.04.2016., 14:29   #2261
Lun
Lun's Avatar
Postovi: 408
Napokon sam se riješio Pensacole, NO je fin brod. Pensacolini topovi sa normalnim concealmentom. Radar je fenomenalan, dosta DDova se još nije priviklo da postoji. Ostatak WoWs populacije je i dalje retardiran, tako da mi winrate tone.
U dvi partije sa Hiryuom sve skupa 10 potopljenih brodova, confederate i high caliber u svakoj - popušim obje.
Staro 06.04.2016., 14:43   #2262
Tvrdi
Sremium
Postovi: 2,854
Autor T}{OR Pregled postova
toooo
Staro 06.04.2016., 14:43   #2263
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
2 od 6 krakena nafarmanih s Hiryuom su bili porazi. Tako da znam kako ti je.
Pričekaj malo s NO prije konačnog dojma. I Smoki, i ja i još ljudi je na prvu bilo oduševljeno brodom. Da nakon malo duljeg igranja skužiš kako je najteži T8 CA za igrati. Doduše, ti si od prve krenuo s radarom tako da je situacija malo bolja.
Je, puno ekipe ne zna za radar još. Farmanje DD killova s NO je gušt samo takav.
Napokon sam se riješio Pensacole...
Staro 06.04.2016., 14:48   #2264
Tvrdi
Sremium
Postovi: 2,854
Zadnja 2-3 dana situacija se solidno mijenja...sad ne pale dim kad ih detektaju već bježe ko ludi..il odma na mapi pogleda di je NO i onda na drugu stranu....osim toga ja ne dijelim takvo oduševljenje s radarom...trajanje kolko? 30ak sekundi i onda cooldown 5min...
Staro 06.04.2016., 14:53   #2265
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
NO je support CA. Japanski su YOLO igrači a RU/KM snajperi na daljinu. Kao takav, radar je najviše od koristi kad se upali u krugu dometa još nekoga ko može pucat po DD-u. Ako već nisi u diviziji, drži se svojih. Jedan Benson je pobrisan kad me nije vidio iza otoka a upalio je dim ispred našeg NC-a, Montane i još jednog broda. Mislio je da će ga dim spasiti - jok, bio je First Blood. Kako je Lun bio samnom u Hipsteru u diviziji istu partiju, pomoću radara pao je i Fubuki. NO s(Y)olo s radarom služi za tjeranje DD-a više nego ubijanje. Što isto nije loša stvar. Premium reload je must have za 4 min cool down.
Malo info o nerfu torpedo wall-a, odnosno Kagera i Shime:
3. You said you had plans to nerf high tier torpedo spam. What are they?
Why don't you nerf premium vehicles? (Premium ships have overall better stats than their standard counterparts),
A. Our current plan is the following: we may change the stats on certain Japanese torpedoes - spamming torpedoes at long distances will be less effective. Moreover, to encourage a more aggressive (and interesting) gameplay, we will first add a new type of torpedoes which will deal large amounts of damage but will require some degree of ingenuity and skill. It's only a plan and you will see our final decision in the patch notes. Limiting the number of certain ships is our final solution and we'd like not to come to this.
There is nothing wrong in the fact that certain premium (or standard) ships show better performance than their counterpart. If we notice that a premium ship is doing a lot better or that its popularity is too high, we rather remove it from sale than nerf it. We think it's a better approach to customers. There can be exceptions to this rule, but until now, we didn't need to take extreme measures.
If you're being bullied by Atago's and Tirpitz's, you could always take out a tier 9-10 ship and get back at them.
Ovaj odgovor o OP premium brodovoma neću ni komentirati...
Staro 06.04.2016., 15:03   #2266
Tvrdi
Sremium
Postovi: 2,854
Ha čuj, lovicaaa
Staro 06.04.2016., 16:11   #2267
Lun
Lun's Avatar
Postovi: 408
Sad mi je najveći problem kapetan koji se još retraina i rudder shift. No to će se riješit za nekih 15k XPa. Jednostavno sam se jedva čekao riješit 15km concealmenta, ako se to uopće može nazvat concealment. Prosječan dmg sa pensacolom, nešto iznad 39k.
Par situacija sa NO radarom: shimakaze se smokao ispred mene, pa sam mu izbjegao sva osim jednog torpeda od 15, i upalio radar. Tip se od panike spucao u otok Benson se isto smokao na 8km i loži po meni, BBu i još 2 cruisera, dok je skužio da imam radar, bilo je kasno.
NO je jako sličan japanskim cruiserima (za razliku od Pensacole), ima bolji rudder shift, turret rotation i AP shellove, minus torpeda ofc i nešto lošiji concealment. Prije AFT (mogami) nerfa, NO je defeinitivno bio najgori CA, sada je po meni nešto bolji od mogamija, barem zbog radara i AP shellova.
U te dvi partije sa Hiryuom sam napravio oko 300k dmga, sad mi je prosjek 94k, brod je fenomenalan, ranger mu nemože ni prismrdit. Danas sam snipeao AS rangera bez problema, fightere pošaljem na njegove fightere, sve ostalo na njega. Trenutno, ranger nema nikakve šanse sa bilo kojim loadoutom protiv kompetentnog Hiryu kapetana.
Staro 06.04.2016., 21:01   #2268
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
Zanimljivo, Mogami i dalje ima koliko toliko solidan WR (ispred NO). Unatoč nerfu i svemu.
Kako imam iskustvo u Random borbama 100 vs 50 u odnosu Hiryu naprema Shokaku (kojeg sam primarno igrao u Timskima), moji dojmovi su slijedeći:
  • samo jednom sam naletio na 2-0-2 Rangera koji me totalno cockblockao cijelu partiju, imao sam samo jedan strike i opet bio korisniji od njega svom timu, u pravili tu partiju samo paziš gdje su mu lovci i GG
  • strike Ranger je jedini T7/8 CV koji me uspio snajpati u Hiryu, sad to očekujem svaku partiju i uvijek držim lovce na udaljenosti da mogu reagirati na vrijeme dok ne vidim što drugi CV vozi i gdje su mu DB/TB
  • Hiryu je najveći stress-free CV u igri, upravo radi Rangera jer ga većina ekipe ne zna voziti (igra AS) i radi 2-2-2 sexa od loadouta
Ranger sumnjam da se solo može obraniti od napada. No Lexi to itekako može. Ako se sa Lexi igra full strike onda ga treba složiti za max AA jer je to CV s najboljim AA u igri. Čak možda i boljim od Midway-a. Ako već ne onda u svom tieru. Drugim riječima upgrade za +20% AA skupa sa BFT i AFT skillom. Domet preko 7 km i prije nego i stigneš reagirati pojede solidnu količinu aviona.
Najveći problem koji Hiryu / Shokaku mogu sresti je Ranger / Lexi strike sa kapetanom od 15 bodova. U prijevodu to znači 21 DB. Niti sa dva lovca, i ako imaš kapetana od 15 bodova odnosno 2x5 lovaca oni nemaju dovoljno municije da tiih poskidaju sve. Moraš bit dobar sa manual strafeom.
Što se tiče snajpanja samog. To je dvosjekli mač. Na T9 je redovita taktika koju očekuj svaku partiju. Na T7/8 riskiraš izgubiti puno aviona ako ne prođe. Dva su uvjeta kad ja 90% slučaja idem na snipe: 4 CV-a u partiji i kad je na drugoj strani Lexi koji ne ide na snipe već rješava moj tim. U ostalim slučajevima snajpam samo ako se ukaže prilika ili igram T9.
Staro 06.04.2016., 22:12   #2269
Flayer
Why So Serious?
Flayer's Avatar
Postovi: 151
Ti mater...trećinu HP su mi skinuli - repair 118061
ID:	16373   Click image for larger version
ID:	16374   Click image for larger version
ID:	16375   Click image for larger version
Staro 06.04.2016., 22:22   #2270
Smoki_Gs
Smoki_Gs's Avatar
Lokacija: Gospić
Postovi: 452
Baltimore otkljucan..... Ali se jos nisam odlucio kupiti Lexi ili Balti..... Danas sam s Rangerom se izivljavao malo po ljudima,u 3 od 4 partije uspjesan strike napravim,i uvijek iznad 100k dmg,cetvrtu partiju sam se morao solo defat od 2 DDa -.- Skinem obadva al me njihova vatra ubila
Sa NO se nema posto izlazit van bez Hydro/Radar..... Krene game,i samo cekas da vidis pozicije BBa,i kad negdje krene cap na bazu onda je hunt na DD on Danas sam detonirao Kieva jednog koji me je sa jedno 10 km htjeo iz smokea izrostiljat,i kad je detonirao,onda na chatu 100 pitanja,kako sam znao da je tamo,kako sam ga vidio,cheater...ovo,ono...
Staro 06.04.2016., 23:16   #2271
Tvrdi
Sremium
Postovi: 2,854
Its the captain, not the ship.
Staro 06.04.2016., 23:52   #2272
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
@ Flayer: Montana - zašto?
Autor Smoki_Gs Pregled postova
Znači skužili su te konačno?! Napisao par riječi o NO na službenom forumu ako nekoga interesira, upravo s time u vidu:
http://forum.worldofwarships.eu/inde...s-need-a-buff/
EDIT: Malo ću citirati sam sebe, da pojasnim što sam htio reći...
Osim navedenih situacija kada je snipe jedna od najboljih taktika, sa japanskim CV-ima imaš jako brzo servisiranje TB-a. Toliko da ja u dosta zadnjih partija prvo dižem TB-e, lovce pa onda DB-e. TB-i jure na obližnji cap. Ako se tamo nađe DD - jao si ga njemu. Lovci obično idu na poziciju izvan capa, na našoj strani da stignu reagirati i pokrivati TB-e kod povlačenja. Rijetko kad sam vidio da je netko prije mojih TB-a stigao do capa s lovcima.
Na ovaj način si ili potjerao njihove DD-e iz capa ili pomogao osigurati svojima cap. Što daje tvom timu prednost odmah u startu. To samo po sebi češće dobiva partije nego CV snipe na koji potrošiš puno vremena, i još ako ne uspije i puno aviona. Ovako ako i fulam DD i ne uspijem ga ili dobro oštetiti ili čak potopiti mi se većina aviona vrati natrag i brzo je servisirana za novi napad. Onda u pravilu razmišljam o snipeu ili pomaganju timu gdje je gusto.
Zadnje izmijenjeno od: T}{OR. 07.04.2016. u 09:14.
Staro 07.04.2016., 09:42   #2273
Tvrdi
Sremium
Postovi: 2,854
Potpuno su te obuzeli CVi, Thore. Ali to je razumljivo. Iz mog iskustva igranja ove igre mogu reći da iskusan i iznadprosječan igrač za kormilom CVa može vrlo lako presuditi partiju.
Zadnje izmijenjeno od: Tvrdi. 07.04.2016. u 09:53.
Staro 07.04.2016., 09:53   #2274
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
CV-i su najteža klasa za igrati, zato sam ih ostavio za kraj. Tek sam krenuo s njima nakon što sam dugo igrao ostale 3. U zadnje vrijeme ekipa prijavljuje dosta CV botova. Navodno je i sam WG skužio problem i namjeravaju reagirati po tome. EDIT: Zato se te razlike između CV igrača još više vide.
Može se reći da su me obuzeli. Shokaku mi je najdraži brod u igri trenutno. Odmah iza njega je Carolina s kojom u zadnje vrijeme nižem +100k partije samo tako, a onda su tu ostatak T8, Pensa i Koni.
@ Smoki: moj prijedlog je uzmi Baltija. Onda ja mogu propisno vozit Taiha s tobom u diviziji dok te besramno iskorištavam za AA.
Objektivno, više ti preporučam Lexi. Ali Balti / Taiho je dobar combo. Navodno su osjetno buffali XP za srušene avione s CA.
Zadnje izmijenjeno od: T}{OR. 07.04.2016. u 10:01.
Staro 07.04.2016., 22:25   #2275
Flayer
Why So Serious?
Flayer's Avatar
Postovi: 151
Da me ebeš neznam
Od Des Moines-a sam bio još nekik 140k XP-a kad sam mogao otključati Montanu, a kako sam veliki BB fan....reko "what the hell" i upeco ga
Jer imam Fusa, Amagija, North Carolinu, New Mexica kojeg sam naknadno prodao jer sam skužio da samo stoji i da ga niš ne vozim jer se guštam na Amagiju i Fusu koji imaju puno bolji spread odnosno grupacija granata im je puno uža u praksi - onak...mrtvi kapital
Odlučio uz Šimu, Gearing-a imati i Montanu u desetki.
Dugoročni plan je još Des Moines (sada prvi na listi), Hindenburg i Zao (zadnji jer do njega imam najviše - Furutaka je zadnja istražena ).
To je moj neki plan za dalje...a kak imam 10 brodova (ne računajući ARP govna - osim ARP Hei koji će imati uskoro kapetana od 16 bodova) pod "Elite" ili Premium statusom, okrenem 3-4 runde sa svima....i eto ti cca 100k XP-a biti će brzo to....veći problem je skupit srebrninu
Zadnje izmijenjeno od: Flayer. 07.04.2016. u 23:20.
Staro 07.04.2016., 23:29   #2276
Smoki_Gs
Smoki_Gs's Avatar
Lokacija: Gospić
Postovi: 452
Evo,ja moram... Nemam izbora.... Prisiljen sam od vise sile(Mitra) ..... Da vam svima kazem kako smo pobijedili 6 za redom partija.... Rekao je ako ne objavim ovo da ce mi se zavuc pod Iowu i posavijat propelere i da ce mi ostavit otvorene prozore na citadeli i svasta nesto.... Sad sam u strahu,nadam se da ce mi Iowa prezivit......
Staro 07.04.2016., 23:32   #2277
mitra
mitra's Avatar
Postovi: 668
U redu, sad mozes ici pajkiti i odmoriti se....sutra te ceka isto....bez 6 pobjeda ne idem nigdje
Uploading...
Staro 08.04.2016., 08:24   #2278
T}{OR
DBS
T}{OR's Avatar
Postovi: 1,855
T9 partije? Najs. And I missed it. Imaš to ponovit predvečer kad se ja pojavim i ispeljam Taiha. Or else...
Staro 08.04.2016., 09:56   #2279
Smoki_Gs
Smoki_Gs's Avatar
Lokacija: Gospić
Postovi: 452
T9 i T5 i T6 ..... Dear god,neces mi i ti valjda polomit nest na Iowi..... :/
Staro 08.04.2016., 10:07   #2280
Tvrdi
Sremium
Postovi: 2,854
Lun bio si u pravu..ovaj Atago je multipurpose brod i zabava samo takva..ali nikako nije za početnike..imao sam sreću jer mi ostao kapetan od Mutuskija s 12 bodova a njegovi skillovi idealni za Ataga...samo da još skupim pare za conc upgrade i to će biti to...Jedina prava mana ovog broda je relativno spori rudder...Velika citadela ali sve CA u višim tierima mogu biti pobrisane ako se ne pazi tako da...jučer sam imao bliski susret s Mogamijem (nakon što sam riješio fubukija). Uglavnom ovaj juriša a ja bacim hrpu torpeda (brzih) s dometom 10km...i popije jedan i dok je izbjegavao ostala, opalim ga s AP....3 citadele...Velim bit će mi lakše kad conc upgrejd ubacim i kad mi se kapetan retraina...
