Staro 14.10.2005., 08:26   #1
Fred
Postovi: 10
Dva napajanja
Pozdrav svima !
Zbog proširenja dva harda i dvije dodatne ladice stavio bih još jedno napajanje radi 5 i 12 V
3.3 i drugo nebi koristio
dali mogu paralelno spojit dvije žice za start napajanja (smeđa + ???? ) ako možda znate
Unaprijed hvala svima!
Fred je offline   Reply With Quote
Staro 14.10.2005., 10:49   #2
domy_os
domy_os's Avatar
Postovi: 18,829
Možeš, samo spoji ova dva pina na slici.
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Zadnje izmijenjeno od: domy_os. 22.02.2006. u 22:23.
Staro 14.10.2005., 11:41   #3
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
s čim i kako da upalim napajanje koje nije uopće ukopčano u ploču?
i da li je to moguće uopće?
Staro 14.10.2005., 13:07   #4
domy_os
domy_os's Avatar
Postovi: 18,829
Connecting 2 ATX PSU's together
Introduction
Why would I want two power supplies (PSUs) in one computer, is this guy crazy? I hear you ask. Well I wouldn't dispute that :-) but many of you will need either an expensive powerful PSU or two cheap 230/250W power supplies if you continue to upgrade your comp. The Athlons now take up quite a bit of your power. Add a few PCI cards and a couple or five CDR / CDROMS and you're about to blow your poor old PSU. Now add a couple of USB items and you're really pushing the poor thing. With the advent of RAID arrays you are looking at 80W+ just to start your HDs up. Whoops, you have blown it for sure. Oh no my comp won't work, what should I do? Well, you can either go out and buy yourself a brand new, very expensive, powerful PSU or you can rummage around and find a couple of cheap lower powered PSU's at around £10 to £15 ($15-$22 USD) and link them together. Preventative maintenance is far cheaper than the cure so if you upgrade before you blow your PSU you will already have one PSU.
The aims of this Project:
In this project not only do I intend to show you how to connect two PSU's together without cutting the cables of the PSUs but I also intend to show you some of the tricks of the trade, i.e. soldering, the use of silicone sealant, striping cables, the best way to join two, or even three, cables and, above all, safety when dealing with electric. Please remember that we are dealing with a maximum of 12V DC and none of the tips and tricks in this article should be applied to mains voltages. Even though the output of a PSU is only a maximum of 12V DC if you allow any form of short or arcing, especially with the high current a PSU is capable of, it could quite easily cause a fire. This can be prevented by the correct use of insulation.
This method of connecting 2 PSUs together may not work with all PSUs. Before purchasing any of the apparatus mentioned below please disconnect your PSU from your motherboard and drives etc. Using a piece of wire, connect pin 14 to one of the 6 grounds, i.e. pins 15, 16 and 17 to name but 3. If your PSU kicks in then you are probably safe to continue. If your PSU doesn't kick in then you may like to try shorting pins 7 & 8 as well.
The motherboard plug with the retaining clip to the top. The pins have been clearly numbered
Equipment required:
2 x ATX PSUs, a case capable of taking 2 x ATX PSUs, 2 x ATX extension cables, 1 tube/can of silicone, a length of 3.2mm (1/12")bore heat shrink sheathing, 3 cable ties, a soldering iron and fine flux cored solder, a cigarette lighter, a steady hand and a brain, hmm I'm not sure where these two items are available from :-)
Test equipment
If possible a cheap/disused motherboard, CPU and stick of memory, and a Volt/Multimeter that is capable of measuring 12V DC. You want to connect as little as possible until you have checked you haven't done anything wrong.
Theory
Connect pin 15 from both PSU's together and connect pin 14 from both together. On the slave PSU connect pins 7 and 8 together.
The Master PSU is the one which must be connected to the motherboard and I would recommend one that has a high wattage 3.3/5V rail because some CPUs, in particular the Athlon, require this high wattage. It may also supply 12V to supplement the 12V supplied by the slave PSU if required. You can check some of these out at AMD. The Slave PSU, which mainly feeds the 12V required by harddrives, CDROMs etc, can be any PSU with a decent 12V rail, even your existing one.
The colours of the cable may differ so make sure you use the pin numbers, Pins 15 and 7 (Black) are ground wires, pin 14 (green) is the power on cable and pin 8 (grey) is the power good cable.
Staro 14.10.2005., 13:09   #5
domy_os
domy_os's Avatar
Postovi: 18,829
Making the adaptor
Lets get started
Take one of the ATX extension cables and carefully remove the cable ties. Take care not to damage the insulation of the cables.
Once you have removed the cable ties locate pins 14 and 15 and cut the cables, leaving the tails as long as possible attached to the socket. We now need to locate pins 7 & 8 and cut the cables about 2.5 inch (60mm) long, again leaving the cables attached to the socket. Remove all other cables, cutting them as close as possible to the socket. Bare the ends of the four cables by about 10mm (3/8"). For an easy way to strip cable take a look at our hints and tips section.
Looking from the back of the socket with the clip recess uppermost the pin numbers have been clearly marked.
Insulation
Insulation is one of the most important aspects of this project, do not overlook any part thinking you will be safe. Accidents do happen and if something that is capable of turning out this kind of current arcs then it could quite easily cause a fire.
It is important to seal the cut ends of the cables. I used silicone sealant for this. Run a bead of silicone over the end of the socket and smooth the silicone using a wet finger. See hints and tips
Once the cable joints have been made it is important to slide the heat shrink insulation over the joint and heat it with a cigarette lighter until the insulation has shrunk tight to the cable. Keep the lighter moving to avoid burning the insulation
Jointing the cables
We will start by connecting pins 7 and 8 of the Slave PSU socket. Cut a length of heat shrink insulation, slide it over one of the cables and push it down as far as possible. Do not skimp on the insulation, cut it about a 1.5 inch (40mm) long. To see the correct method of jointing cables see hints and tips
Once you have soldered the joint pull the heat shrink insulation over the joint and warm it with a cigarette lighter.
Up: is a photo of the slave PSU socket the joint made and insulated.
We will now connect the two PSU sockets together. Take the second ATX extension and cut the cables from pins 14 and 15, approximately half way, then bare the ends of the cables. Slide a length of heat shrink insulation over the socket end of the wire. Flick the ends of the wires to open up the individual strands and mate all three cables from pins 14 ensuring that the socket from the slave PSU is at the same end as the plug from the master PSU. Twist the strands together and solder the joint ensuring you do not blob the solder on (otherwise the insulation will not feed over the joint). Pull the insulation over the joint and heat it. Repeat this step for pins 15, don't forget to slide a length of insulation onto your cable first.
Securing the cables
Once you have completed this fasten a cable tie round the cables, just below the joint at the plug end, and pull it tight. Bend the socket for the slave PSU back up so that both sockets are next to each other and fasten a cable tie close to both ends
Complete
The motherboard and the Multimeter are connected to the Master PSU and the CD Rom is connected to the slave PSU
As you see two PSU's will fit into a full tower case quite easily though you may struggle with the Midi cases. The arrow is pointing to the two sockets of the lead we have just made
Staro 14.10.2005., 13:10   #6
domy_os
domy_os's Avatar
Postovi: 18,829
Hints and Tips
Three of the main reasons why people fail to make good soldering joints are:
1) They did not "tin" the tip of the iron when they bought it. "Tinning" is not difficult, very lightly sand the end of the tip, heat the iron and touch the tip with flux cored solder. When the iron is hot enough the solder will run freely over the tip. Wipe off any excess solder with a slightly damp cloth, being careful not to burn your fingers or your wife's best tablecloth.
2) They have a dirty tip which requires only that iron be heated and wiped clean with a damp cloth.
3) A failure to heat the cable being jointed sufficiently. Ensure the iron is hot enough to heat the cable sufficiently so that a thin layer of molten solder runs freely throughout the joint, avoiding an excess of solder which will build into blobs
To join the cables flick the very end of the cables with the thumb to open up the individual strands and push the cables together. Twist the strands between your thumb and finger, the cables will now hold together and are ready for soldering.
When soldering the cables start towards one end holding the soldering iron underneath the cable. Touch the solder onto the top of the wire and, when the solder begins to melt, slowly move along the joint until it is soldered.
The easiest way to smooth the silicone sealant is to spit on your finger and very lightly wipe the silicone. Keep your finger moist but make sure there is no silicone on your finger before putting it anywhere near your mouth. Keep a piece of kitchen towel handy
The easiest way to strip the insulation off cable is to close your hand and extend your thumb, bending it back at the end. Grip the cable between your finger and thumb, if need be wrap the cable in between your other fingers. Hold the side cutters in towards your hand and resting on your thumb. Grip the cable taking care not to cut right through it and lever the side cutters over the top of your thumb. It's worth practicing.
Staro 14.10.2005., 14:40   #7
--=firefly=--
--=firefly=--'s Avatar
Lokacija: Rijeka, Croatia (Hrvatska)
Postovi: 57
Par slika se nece uvecati...
Mozda bi ovo mogo bit stiki?
--=firefly=-- je offline   Reply With Quote
Staro 14.10.2005., 14:49   #8
Bran
nemam kaj napisati
Bran's Avatar
Datum registracije: May 2003
Lokacija: Međimurje
Postovi: 1,303
Nisam znao da se i to može. Opet sam nešto naučio.
@ Fred kako je prošlo. Radi?
Staro 14.10.2005., 14:50   #9
domy_os
domy_os's Avatar
Postovi: 18,829
Zato što im je to već max. veličina.
Staro 14.10.2005., 14:55   #10
--=firefly=--
Postovi: 57
Aha, sorry nisam skuzio
Btw ovo je i mene bas zanimalo kako se da sredit, malo cu se pozabavit time u dogledno vrijeme
Staro 14.10.2005., 16:40   #11
Veki-os
Veki-os's Avatar
Datum registracije: Jun 2004
Postovi: 3,996
Ovo bi stvarno trebao biti sticky,evo moj glas za to
Staro 14.10.2005., 16:48   #12
sick_boy
sick_boy's Avatar
Postovi: 680
Sticky!!! Sticky!!!:clap: :clap:
iBase MI980VF-4700EQ Motherboard
Intel Core I7-4700EQ (2.4-3.4Ghz, 4 cores, 8 threads)
16GB DDR3L RAM 1600 MHz
250 GB Samsung 860 Evo mSATA SSD
1TB Seagate Barracuda 7200 2.5" HDD
ATI RX550 4GB
Kolink Satellite mATX Cube Case
Delta Electronics GPS-350EB-200 A ATX 350W PSU
Acer 27" 1440p 75Hz Freesync IPS monitor
Cherry MX Board 1.0 keyboard, brown switches
LOGITECH G305 Lightspeed mouse
Arch Linux/Win 10
Lenovo Idepad 5 pro:
AMD Ryzen 7 6800HS
16GB DDR5 RAM 5600 MHz
1TB Micron nVme HDD
16" 2160x1600 16:10 IPS Display
Windows 11
Fujitsu Esprimo:
Intel(R) Core(TM)2 Duo CPU E7500
4GB DDR2 RAM
WDC WD1600AAJS-0 160GB
Seagate ST4000DM000 4TB
openmediavault 4.1.17
Philips 55PUS7373/12 55" 4K HDR VA Direct LED TV
Toshiba 50" QLED 4K Dolby Vision/Dolby Atmos TV
TCL 40ES560 40" FullHD TV
Pioneer BDP-160 BD player
Maxell SB-3000 soundbar
Onkyo TX-SV444 AV Receiver
Onkyo DX-7333 CD Player
Audio-Technica AT-LP2XGY gramofon
Mirage 290is bookshelf speakers
sick_boy je offline   Reply With Quote
Staro 14.10.2005., 19:07   #13
Dawar
OMG, thats the funky shit
Dawar's Avatar
Lokacija: in The Republic of Peščenica
Postovi: 1,221
STIKI STIKI STIKI
Dawar je offline   Reply With Quote
Staro 14.10.2005., 20:43   #14
GoGzS
GoGzS's Avatar
Lokacija: Novi Zagreb
Postovi: 979
Ala ste ga zakomplicirali, evo kako je Bibe to lijepo i jednostavno obijasnio
Bipe mudro prozbori
svako napajanje na konektoru koji ide u maticnu ima zelenu zicu, koju kada spojis sa grnd (masom) zicom (crnom), pali napajanje. upravo se to dogodi na maticnoj ploci kad ti palis komp.
malo zarezi izolaciju na obje zelene zice i spoji ih medusobno komadom zice
btw. molim bez komentara slike, nisam graficar, spavao sam 4 sata i nisam dobre volje
To je sva mudrost, i pogledajte sliku kako to najlakše realizirat:
GoGzS je online   Reply With Quote
Staro 14.10.2005., 21:02   #15
domy_os
domy_os's Avatar
Postovi: 18,829
Neće se svako napajanje tak upalit. Evo ja se danas malo igrao s Codegenom od 300 W i ne jebe.
Staro 09.11.2005., 11:52   #16
starnet
Postovi: 17
Neće samo u slučaju kada je neispravno.
starnet je offline   Reply With Quote
Staro 09.11.2005., 12:25   #17
domy_os
domy_os's Avatar
Postovi: 18,829
Ispravno je, već par dana radi u jednom kompu.
Staro 27.02.2006., 20:56   #18
bego2
bego2's Avatar
Postovi: 2,724
Ja bum probao to napravit kad nabavim dva shitna napajanja.:burn:
bego2 je offline   Reply With Quote
Staro 17.07.2006., 12:18   #19
mustra
mustra's Avatar
Postovi: 59
imam pitanje: gdje mogu nabaviti ova dva konektora 20 pinska ženska koja se inače nalaze na ploči ????????''''
mustra je offline   Reply With Quote
Staro 17.07.2006., 12:22   #20
domy_os
domy_os's Avatar
Postovi: 18,829
U Chipoteci bi trebalo bit...
Staro 18.07.2006., 11:11   #21
mustra
mustra's Avatar
Postovi: 59
Autor domy_os
heheeh trebalo bi biti ali nema : bonker2
došo tamo i pito za konektor lik mi kaže da ima na matičnoj ploči!!!!! hmmhm ma da
Staro 18.07.2006., 19:53   #22
marikris
made in Usora
marikris's Avatar
Postovi: 215
Autor domy_os
Neće se svako napajanje tak upalit. Evo ja se danas malo igrao s Codegenom od 300 W i ne ***************e.
probaj spojiti izmedu zute i crne otpornik 10ohma/10W te spojiti zelenu i crnu i trbalo bi ti raditi
za detaljnije informacije upisi u google "How to convert Computer ATX to lab power supply"-tamo ti pise sve sto sto trebas znati
marikris je offline   Reply With Quote
Staro 18.07.2006., 23:53   #23
domy_os
domy_os's Avatar
Postovi: 18,829
Nemam pojma više gdje je to napajanje... Uglavnom, sva ostala napajanja palim spajanjem zelene i mase, al ovo jednostavno nije htjelo.
Staro 17.01.2007., 17:03   #24
LiNuXeR
Lokacija: ZGB
Postovi: 55
jel neko skužio šta treba ovdje, jel se napajanje ttreba pokrenut ili samo napravit klik kao kod mene samo klikne i nisam shvatio ono sa 7 i 8 pinom ako neće.
LiNuXeR je offline   Reply With Quote
Staro 17.01.2007., 19:40   #25
domy_os
domy_os's Avatar
Postovi: 18,829
Treba se upalit kad spojiš zeleni pin s bilo kojim crnim, a ako neće onda spojiš sivi i susjedni crni (sedmi i osmi) zajedno s onim prethodnim.
Staro 07.02.2007., 17:46   #26
mat
Postovi: 2,105
Autor GoGzS Pregled postova
cek samo malo nije mi sad nesto jasno
poslje pricate o uzemljenju spajanjem sa (bilokojom?) crnom zicom. dali je dovoljno spojiti zelene zice iz oba napajanja ili treba jos nesto? i zasto je prvi tutorial ubio pinove 7 i 8 a poslje se vise nista o tome ne prica?
mislim logicno je da napajanje tako i tako se treba samo pokrenuti i onda ce davati struju kome god.
e da i cime preporucate izolaciju nakon zavrsetka operacije? izolir traka dosta? nebi se bas igrao sa silicijem i upaljacem ako nije nuzno
edit:
bump?
Zadnje izmijenjeno od: mat. 08.02.2007. u 12:54.
mat je offline   Reply With Quote
Staro 08.02.2007., 14:55   #27
mat
Postovi: 2,105
alo zar nitko? wolwerine?
Staro 16.03.2007., 23:53   #28
Angelus
A mighty pirate!
Angelus's Avatar
Postovi: 429
postoji lakši način za to,eo ovako,malo varira od napajanja ali u biti najčešćče je,da zelenu i najbližu crnu zdesna spojite,pametno je na prekidač,da napajanje možete gasit palit,i to je to,samo nemojte sad to odma napravit,jer sam reko da nemoraju biti iste boje žice,a i da radim po pamćenju pa se baš ne sječam
Angelus je offline   Reply With Quote
Staro 12.08.2007., 13:05   #29
q-man
Daedra worshipper
q-man's Avatar
Postovi: 44
da rezimiramo:
1. ako palimo jedno napajanje, dovoljno je spojiti zelenu i najbližu crnu? crna je masa, ali što je zelena? jel netko izmjerio napon na njoj ili je u stvari bitno samo zatvoriti omski krug?
2. ako spajamo dva skupa, logično je pojiti 12v sa 12v (žute žice) pa dobijete isti napon sa zbrojenim amperima. masu na masu naravno. pretpostavljam da i ovdje, ali na oba napajanja, treba spojiti zelenu s masom i to svako napajanje za sebe?
3. teoretski je moguće dva napajanja spojiti 12v i 12v u seriju pa se dobije 24v sa amperima polovinu zbrojenog. da li je netko pokušao?
q-man je offline   Reply With Quote
Staro 12.08.2007., 15:19   #30
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
Zelena je tzv. PS-ON, kad je kratko spojena s masom napajanje radi.
Ne, ne spajaju se naponski vodovi (tko zna kako bi to ispalo), nego jedan dio uredjaja spojis na jedno napajanje, drugi dio na drugi. Onda ne spajas zelenu s masom jer ti ploca pali napajanja, nego spojis na jedan od gornjih nacina.
Ne kuzim po kojoj teoriji al dobro. Mozes dobit 24 ak potrosaca spojis na +12 i -12 volti no amperaza je mizerija.
