#8701 |
MiningMod
Postovi: 8,715
Pa ako ne treba da igre rade na ultra, može se fina konfa složiti za tu lovu. Kasnije se lako nadogradi ako bude potrebe 1 x Intel CPU Desktop Core i5-4460 (3.2GHz, 6MB,LGA1150) box 1 x Matična ploča Asus B85M-K (S1150,DDR3,VGA/DVI,USB3.0,LAN,SATAIIII) mATX 1 x KINGSTON ValueRAM DDR3 (8GB,1600MHz(PC3-12800)) CL11, Retail 1 x Seagate ST1000DM003, 1TB, 7200 rpm, 64MB, SATA 6Gbs 1 x Gigabyte NVIDIA GeForce GTX 750Ti, 2GB DDR5, 128 bit, DVI-I*1/DVI-D*1/HDMI 1 x XFX TS 450W, 80+ Bronze - 60mj. 1 x Zalman Z1, USB3.0 black, 2x120mm Ukupno: 4500,00 kn |
#8702 |
Datum registracije: Jan 2013
Lokacija: Planet Zemlja
Postovi: 1,632
Uzmi onda ovo i GG 1x Procesor AMD X8 FX-8300 (16MB Cache, 8x3.30 GHz up to 4.20 GHz), sAM3+ 1x LC-CC-95 CPU Cooler 1x Gigabyte GA-970A-DS3P, sAM3+ 1x Gigabyte GTX950 WF2 Overclocked, 2GB GDDR5 1x DDR3 8GB (1x8GB) Kingston HyperX Fury 1866MHz 1x HDD 1TB Toshiba 3.5" 7200RPM 32MB Cache SATA3 1x Napajanje XFX P1-450S-GREEN TS Series 450W PSU 80+ Bronze 1x MS RANGER midi tower kućište bez napajanja 4.500,00kn |
#8704 |
covjece ova graficka je ko suvo zlato..u kom to ducanu??? Zadnje izmijenjeno od: coconut. 24.01.2016. u 09:45. |
#8705 |
Datum registracije: Dec 2010
Postovi: 28
ASROCK FM2A88M EXTREME4+, AMD A88X, DDR3 AMD X4 860K BOX, Black Edition, s. FM2+, 3.7GHz, 4MB cache 8 GB, G.SKILL RipjawsX series, F3-12800CL10S-8GBXL, DDR3 1600MHz 51.210.359 389 1000.0 GB WESTERN DIGITAL Blue, WD10EZRZ, SATA3, 64MB cache, 5400okr./min XFX AMD RADEON R7 360 Core Edition, 2GB DDR5 LG GH24NSD1, 24x, SATA, Dual layer, crna, bulk ANTEC VSK-4000B, MIDI, crno, bez napajanja ANTEC VP500PC ES, ATX v2.3, 120mm vent. Ukupno 3782 kn uzimo bih PC za igranje. Volio bih da bude dugo u igri i da ima novije komponente za do 4000 kn. Sta kazete na ovu konfiguraciju? Zadnje izmijenjeno od: coconut. 24.01.2016. u 09:47. |
#8706 |
MiningMod
Postovi: 8,715
Može se to bolje za par kuna više: 1 x AMD FX X6 6300 (3,5GHz,14MB,95W,AM3+) box 1 x CPU Hladnjak LC-CC-95, Intel/AMD, 90mm 4-pin 1 x GIGABYTE GA-970A-DS3P, AM3+, R2.0, 4+1 Phase, 125W CPU 1 x KINGSTON ValueRAM DDR3 (8GB,1600MHz(PC3-12800)) CL11, Retail 1 x Seagate ST1000DM003, 1TB, 7200 rpm, 64MB, SATA 6Gbs 1 x Gigabyte NVIDIA GeForce GTX 750Ti, 2GB DDR5, 128 bit, DVI-I*1/DVI-D*1/HDMI 1 x Optički uređaj LG GH24NSD1 SATA Bulk Black 24x 1 x MS KNIGHT crno kućište, bez napajanja 1 x Fortron Hexa+ 400W, 80+ 4040Kn Besplatno slaganje i besplatna dostava |
#8708 |
Dal ova polovna konfa redi 3500 kn?? Intel i5 3570 3.4 Ghz - turbo 3.8 Ghz Asus p8h67-m evo Corsair 6 gb ddr3 1600 mhz (3x2 gb) Obično kućište (120 mm led plavi) Msi hd 7850 2 GB GDDR5 Twin frozr (imam kutiju i račun, garancija istekla) Xfx 650w 80+ bronze (daje 636w na 12v - sposoban držati 2 grafičke bez problema) Dvd čitač Wd black 1500 GB (bez bad sectora, health na 100%)...ja mislim da ne jer je lik vec kupio polovnu a i grafu je kupio polovnu |
#8710 | ||
sto da napisem ?!
Postovi: 880
moze i na pm ako je neka tajna itd. djeluje mi maksimalno dobro za tu cijenu... ![]() iii ova Citiraj:
momci |
#8711 |
#8714 |
Postovi: 1,632
Ako ne planiras u buducnosti nadogradivati: 1x AMD Athlon X4 840 (4MB Cache, up to 3.80 GHz), sFM2+ 1x Gigabyte GA-F2A68HM-S1, sFM2+ 1x Gigabyte GTX950 OC 2GB GDDR5 1x DDR3 8GB (1x8GB) Kingston HyperX Fury 1866MHz 1x HDD 1TB Toshiba, 3.5", 7200RPM, 32MB Cache, SATA3 1x Napajanje XFX P1-450S-GREEN TS Series 450W 80+ Bronze 1x MS VOYAGER midi tower UKUPNO: 3.569,97kn Ako planiras (i5/r9 380 i sl.) onda ovo: 1x Procesor Intel Pentium G3260 1x Matična ploča MSI H81M-P33 iH81 1x KINGSTON 8GB 1600MHz DDR3 CL10 DIMM HyperX FURY Black Series 1x MSI GF GTX950 2GD5 2GB GDDR5 1x Toshiba DT01ACA050 500GB 3.5'' 1x Fortron napajanje Hyper 500W 1x MS VOYAGER kućište bez napajanja Ukupno: 3.525,17kn Zadnje izmijenjeno od: coconut. 25.01.2016. u 18:50. Razlog: nema potrebe quotati post iznad svoga |
#8716 |
Postovi: 1,632
vec si napravio tu temu iako ti je odmah na vrhu glavna tema za to "Konfiguracije u rangu od 3.000 do 5.000 kn" i admin ti je premjestio pitanje tamo i ti opet pravis. Odi tu, tamo ti je prvi post i imas odg. http://forum.pcekspert.com/showthrea...10528&page=291 |
#8718 | |
Datum registracije: Jan 2016
Lokacija: sinj
Postovi: 8
#8719 | |
Lokacija: Lepoglava
Postovi: 4
#8720 |
Datum registracije: Mar 2015
Postovi: 7
Pozdrav ekipa. Gledam da si uzmem nešto za gaming s čime bi mogao igrati nove stvari barem na high postavkama. Uzeo bi samo ssd jer imam stari hard. Išao bi oko 5000kn ukupno, ali može i nešto više ako je baš potrebno. Trenutno gledam nešto ovakvoga što je već preko 5000 pa bi bilo super da sam negdje fulao s komponentama ili fulao dućan pa da se nešto uštedi. Navedene cijene su za gotovinu (kakti neki popust) Matična Asrock s1150 H81M-HDS R2.0 436.45 Kn Procesor Intel Core i5-4460 3.20GHz, 1150 Box 1,752.79 Kn Grafička MSI Radeon R9 380 GAMING GDDR5 2GB 1,779.11 Kn Kingston 8GB 1600MHz DDR3 CL10 DIMM HyperX FURY Black Series 336.38 Kn Patriot SSD Blaze R545/W430, 120GB 392.59 Kn Zalman Z1 NEO mid tower case 329.66 Kn Napajanje Real Power RP500 ECO Silent Retail bronze 500W 369.00 Kn |
#8722 | |
Postovi: 1,632
1x Procesor Intel Core i5 4460 1x GIGABYTE GA-H81M-S 1x Gigabyte R9 380 WF2 OC GDDR5 2GB/256bit, 970MHz/5500MHz 1x Kingston 8GB 1866MHz DDR3 CL10 HyperX Fury 1x Patriot SSD Blast R560/W425, 120GB, 7mm, 2.5" 1x Fortron napajanje Hyper 500W 1x Zalman Z1 mid tower Sveukupno: 5.049,66kn AMD: 1x AMD FX-8300 (8x 3.3GHz, Turbo Mode 4.2GHz, 16MB,95W,AM3+) box 1x LC Power CPU Hladnjak LC-CC-95 - 90mm Intel/AMD 1x Gigabyte GA-970A-DS3P 1x GIGABYTE R9 380 GAMING GDDR5 4GB/512bit, 990MHz/5700MHz 1x Kingston 8GB 1866MHz DDR3 CL10 DIMM HyperX FURY Black 1x Patriot SSD Blast R560/W425, 120GB, 7mm, 2.5" 1x Fortron napajanje Hyper 600W 1x Zalman Z1 mid tower Sveukupno: 5.175,70kn |
#8723 |
Postovi: 7
Možda ja tu nešto griješim, ali u ovoj prvoj kombinaciji za matičnu kaže da je 1333MHz i 1600MhZ memorija a vidim da je kombinirano s 8GB 1866MHz rama. O kojem se dućanu radi u ovom pitanju? može i pm ako se ne smije javno. U svakom slučaju hvala za prijedlog Zadnje izmijenjeno od: coconut. 02.02.2016. u 12:05. |
#8724 |
Postovi: 1,632
Nema veze sebi ploca spusti na 1600mhz a cijena je ista... Ne znam jel smoje pisat trg, ako je problem molim admina da obrise post... *** Zadnje izmijenjeno od: coconut. 02.02.2016. u 12:06. Razlog: ne može se pisati trgovina |
#8725 |
Postovi: 2,327
pozdrav ljudi bratu bi trebao slozit gamersku konfu da moze igrat sve nove igre na max detaljima u fullhd-u Raspolaze sa 5000 kn.Ssd,hard,mon ima znaci grafa,proc,ploca,cooler,ram,psu,kuciste treba
Zadnje izmijenjeno od: warlock25. 02.02.2016. u 18:56. |
#8726 |
MiningMod
Postovi: 8,715
1 x AMD FX X8 8300 (3.3GHz,16MB,95W,AM3+) box 1 x CPU Hladnjak Alpenföhn Ben Nevis, 120mm, PWM 1 x Gigabyte GA-970A-UD3P (AM3+,DDR3,SATA III,LAN,USB 3.0, S/PDIF) 8+2 Phase, 125W CPU 1 x KINGSTON ValueRAM DDR3 (8GB,1600MHz(PC3-12800)) CL11, Retail 1 x Grafička PowerColor PCS+ R9 380, 4GB 256bit GDDR5 1 x Fortron Hyper 600W, 80+ - 60mj. 1 x Kućište Cougar MX200, crno, USB3.0 Ukupno: 4995,00 kn *Sa slabijom pločom GA-970A-DS3P ispada 4885,00kn Zadnje izmijenjeno od: FRipper. 02.02.2016. u 23:34. |
#8728 |
Datum registracije: Feb 2015
Postovi: 600
Procesor AMD X8 FX-8300 GIGABYTE Main Board Desktop AMD 970A (SAM3,DDR3,SATA III,LAN,USB 2.0/3.0) ATX LC Power CPU Hladnjak LC-CC-120 - 120mm Intel/AMD XFX R9 380 4GB, XFX-R9-380P-4DF5 Kingston HyperX 8GB DDR3-1866 CL10SDRAM Zalman kućište Z3 PLUS mid tower case Fortron napajanje Hyper 600W Sveukupno: 4.881,11 Procesor Intel Core i5 4460 Matična ploča ASRock H81M-HDS R2.0 XFX R9 380 4GB, XFX-R9-380P-4DF5 KINGSTON 8GB 1600MHz DDR3 CL10 DIMM HyperX FURY Black Series HX316C10FB/8 Zalman kućište Z3 PLUS mid tower case black Z3+, USB 3.0, bez napajanja, ZAL-Z3 PLUS Fortron napajanje Hyper 600W 5.039,78 kn |
#8729 |
MiningMod
Postovi: 8,715
http://www.nabava.net/search.php?tp=...C+120mm%2C+PWM jednostavno samo copy-past u nabavu A konfa od kolege ODO http://www.nabava.net/search.php?tp=...%2F3.0%29+ATX+ ![]() |
#8730 |
Postovi: 1,632
1x AMD FX X8 8300 (3.3GHz,16MB,95W,AM3+) box 1x LC Power CPU Hladnjak LC-CC-120 - 120mm Intel/AMD 1x Gigabyte GA-970A-DS3P,AM3,A970,D3,S3,U3,A 1x GIGABYTE Radeon R9 380X GAMING GDDR5 4GB/256it, 980MHz/5700MHz 1x Kingston 8GB 1866MHz DDR3 CL10 DIMM HyperX FURY Black Series 1x Fortron napajanje Hyper 600W 1x Zalman Z1 mid tower case UKUPNO: 4.999,93kn |
