Staro 21.12.2015., 20:27   #1
Karlo666
Karlo666's Avatar
Datum registracije: Oct 2010
Lokacija: Kaštel Lukšić
Postovi: 1,585
NVIDIA GeForce WHQL Driver 361.43
Issues and Updates:
Significant bug fixes:
[GM20x] Clock speeds remain above idle at 144 Hz on desktop
Lag in Star Wars Battlefront with SLI enabled after updating to driver 359.06.
Momentary loss of signal after scoring first goal in Rocket League
Game crashes on certain GeForce GTX 860M notebooks
Battlefield Bad Company 2 performance fix
Fermi GPU Changes:
As of Windows 10 November Update, Fermi GPUs now use WDDM 2.0 in single GPU configurations.
For multi-GPU configurations, WDDM usage is as follows:
In non-SLI multi-GPU configurations, Fermi GPUs use WDDM 2.0. This includes configurations where a Fermi GPU is used with Kepler or Maxwell GPUs.
In SLI mode, Fermi GPUs still use WDDM 1.3.
Sve u svemu meni je popravljen taj gadni above idle core clock @144Hz i naviše
http://i.imgur.com/wiDrsYt.png
Pošten trgovac:
1,2,3,
Karlo666 je online   Reply With Quote
Staro 21.12.2015., 23:04   #2
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
hmm, ja to nisam imao na 144hz...na 135mhz je na desktopu. weird.
Bez potpisa.
Staro 22.12.2015., 00:40   #3
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Issues and Updates:
Fermi GPU Changes:
Dobra zayebancija Ugl snimio, odradio par h bf4, sve ko po spagi.
Staro 22.12.2015., 10:59   #4
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Ma nek se yebu, moram opet na stare 353.62 -.-
Pomelo mi sig -.-
Staro 22.12.2015., 16:34   #5
Sphere
Datum registracije: Mar 2015
Postovi: 1,254
Vidi cuda, problemi sa zelenim drajverima
Sphere je offline   Reply With Quote
Staro 22.12.2015., 17:39   #6
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Tebe onda nes drugo jebe, moguce taj vrhunski komad os-a zvani win 7. Napravi acronisom image i zvekni 10ku ili 8.1 pa testiraj.
Staro 22.12.2015., 18:21   #7
seno
seno's Avatar
Datum registracije: Dec 2009
Lokacija: Bosna
Postovi: 762
Da li je fixed low gpu usage? Mene pojede to sranje ...
seno je offline   Reply With Quote
Staro 22.12.2015., 21:57   #8
Karlo666
Karlo666's Avatar
Postovi: 1,585
Autor Drvoje Pregled postova
Provjeri Event viewer za TDRove.
Pošten trgovac:
1,2,3,
Staro 22.12.2015., 22:26   #9
Drvoje
Drvoje's Avatar
Postovi: 4,037
Oću kad budem stavlja neke novije, trenutno nemam živaca, clean reinstall OS-a i igre mi je bija sasvim previše
Pomelo mi sig -.-
Staro 05.01.2016., 11:48   #10
BrusJr
BrusJr's Avatar
Postovi: 78
Pokušao sam staviti ove drivere na laptop sa grafičkama Intel 4000 i Geforce nvidia gt640m le, na win7 i kada se restartaju, windowsi se smrznu na Welcome screenu. Onda sam pokušao instalirati WIN8,1, kod njih se pak pojavljuje problem da ekran pocrni i dalje sve na slijepo. Zadnja opcija je bila Win10, kod njih se javlja ista priča kao i na Win7, čim se instaliraju, smrzava se.
Ima li tko ideju kako uopće instalirati noviju verziju drivera?
BrusJr je offline   Reply With Quote
Staro 05.01.2016., 17:08   #11
Karlo666
Karlo666's Avatar
Postovi: 1,585
Autor BrusJr Pregled postova
Ovdje su ti driveri za 640LE http://www.nvidia.com/download/drive...px/96885/en-us
Also prvo podigni Intel driver pa onda za GPU.
Pošten trgovac:
1,2,3,
Zadnje izmijenjeno od: Karlo666. 05.01.2016. u 18:12.
Staro 05.01.2016., 21:14   #12
BrusJr
BrusJr's Avatar
Postovi: 78
Probao i ovako, najprije update Intel4000, restart kompa, pa novi driveri za nvidia, već prilikom instalacije se komp smrzne i win7 i win10.
Staro 05.01.2016., 22:33   #13
Karlo666
Karlo666's Avatar
Postovi: 1,585
Ajde ovako.Skini Display driver uninstaller(DDU)
Skini također driver za Nvidiu i Intel s njihovih oficialnih stranica(nikako nemoj one sa proizvođača laptopa).
Pokreni DDU i poprati sve što kaže i pobriši sve(i Intel i Nvidiu) onda ćeš startati Laptop normalno ali nemoj spajati na Wi-Fi (Internet).
Instaliraj Intela prvo pa onda restart pa Nvidiu i oped jedan restart i to bi trebalo bit to.
EDIT
Više mi se čini da tebe zajebava chipset driver ili ga nemaš instaliranog.
Pošten trgovac:
1,2,3,
Zadnje izmijenjeno od: Karlo666. 05.01.2016. u 22:44.
