Staro 19.02.2014., 01:36   #31
calypso
calypso's Avatar
Datum registracije: Oct 2002
Lokacija: Zagreb/Rijeka
Postovi: 1,954
Autor nino Pregled postova
Slovo G je izlizano.
Hehe, na mom su slova A, S, C, K, L, N i M... Nije dobro...
GMKTec K8Plus
2x EIZO EV2336WFS3-BK
23" 1920x1080 IPS
Dell Latitude 7390
32GB DDR4
512GB Samsung PM981, PCI-E 3.0 x4
intel UHD 620
13.3" FullHD IPS Touchscreen
Staro 19.02.2014., 02:52   #32
rendula
Lokacija: Zagreb, Trešnjevka
Postovi: 5,772
Da se ubacim u temu, ako moze procjena Thinkpada X220 s docking stationom?
Intel I5 2520M @2.5GHz
8GB(2*4G) RAM
ADATA XPG SX300 128GB SSD
Western Digital 1 TB WD Blue SATA III 7mm
Staro 19.02.2014., 07:54   #33
Dottore
Dottore's Avatar
Postovi: 7,644
Dock ovisi koji. Slim 250kn , normalni sa ostalim fičurima 500kn.
Pretpostavljam da nema garancije?
Laptop 2500kn, sa ssd i dodatnim diskom moglo bi dodatnih 800kn.
Sa garancijom ide gore 500kn više
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 19.02.2014., 09:03   #34
Keko2008
IT
Keko2008's Avatar
Datum registracije: Jan 2014
Postovi: 19
Autor calypso Pregled postova
G i R su malo izlizani, al to je najmanji problem, ionako koristim tipkovnicu spojenu na laptop ^^
da, moj bad za USB 3.0, išo sam kasnije gledat, ipak je to Allways On xD
Acer Emachines E727
Keko2008 je offline   Reply With Quote
Staro 19.02.2014., 10:55   #35
daxxx88
daxxx88's Avatar
Lokacija: Basel/Zg
Postovi: 1,229
right next to the G-spot
[ASUS ZenBook UX303UA - i7-6500U, 8GB RAM, Intel HD Graphics 520]
What man is a man that doesn't make the world better
daxxx88 je offline   Reply With Quote
Staro 19.02.2014., 21:57   #36
rendula
Postovi: 5,772
Autor Dottore Pregled postova
Hvala. Dock je onaj veliki, Mini Dock Series 3. Znaci cirka 3500 komplet.
Staro 05.03.2014., 00:17   #37
Mejzlik
tha pilot
Mejzlik's Avatar
Postovi: 647
T410 Ultrabay HDD adapter
Da ne otvaram novu temu...
Jel ima tko iskustva sa jeftinim Ultrabay HDD adapterima za Thinkpade sa ebaya? Originalni su 3x skuplji...?
Nabavio sam ultra povoljno T410 sa SSD-om, pa mi treba jos jedan HDD za storage.
Mejzlik je offline   Reply With Quote
Staro 05.03.2014., 02:37   #38
Dottore
Dottore's Avatar
Postovi: 7,644
Ja imam iskustva sa tim caddyem na T43p i stvar šljaka.
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 05.03.2014., 18:00   #39
Mejzlik
tha pilot
Mejzlik's Avatar
Postovi: 647
Thx, narucit cu si onda ovaj caddy, pa se nadam da ce biti ok.
Staro 28.03.2014., 17:08   #40
darkydark
N0teb00k n00b
darkydark's Avatar
Lokacija: Zagreb/Koprivnica
Postovi: 2,105
http://support.lenovo.com/en_US/deta...=HF004122&rd=1
Lenovo battery recall. Mislim sa je prikladno tu postat. Evenualno ak koji mod misli da to zasluzuje vidljivije mjesto nek prebaci.
1TB A2000, 2TB KC3000
Linđa
Truenas Scale
Staro 22.10.2015., 13:37   #41
MatijaV
MatijaV's Avatar
Datum registracije: May 2011
Lokacija: Koprivnica
Postovi: 131
Ekipa, imam mogučnost uzimanja:
T410i:
14.1 inch ekran LED Backlit
rezolucija 1440x900
Procesor Intel Core i5 M520 2.40 GHz, 3Mb Cache
6GB DDR3 memorija
CD/DVD - ROM
120 Gb WD HDD - 7200 RPM
Grafička Intel
osvjetljenje ekrana
3 x USB 2.0, 1 x USB 2.0 Allways On, Display port, esata
Cijena 1000kn
Sad mene interesira dali se može izvadit CD/DVD pogon i staviti ladica za HDD?
I dali je cijena korektna za to, po meni šta sam pročitao u temi je cijena ok.
I koja su Vaša iskustva s Think serijom?
Inaće ja imam Lenovo G500 3 godine već i prezadovoljan sam.
MatijaV je offline   Reply With Quote
Staro 22.10.2015., 13:41   #42
calypso
calypso's Avatar
Postovi: 1,954
Autor MatijaV Pregled postova
T410i:
rezolucija 1440x900
6GB DDR3 memorija
CD/DVD - ROM
Grafička Intel
osvjetljenje ekrana
Cijena 1000kn
Odlicna cijena za taj laptop, uzmi bez razmisljanja... Sto se tice ladice za disk umjesto DVDa, imam ti ja 3 komada za prodat (baci oko na trznicu)... Radi pouzdano, jer sam tako imao slozeno na T410 i T520...
GMKTec K8Plus
23" 1920x1080 IPS
Dell Latitude 7390
32GB DDR4
intel UHD 620
Staro 22.10.2015., 13:44   #43
[GOW]Nec
[GOW]Nec's Avatar
Postovi: 1,215
T410i:
rezolucija 1440x900
6GB DDR3 memorija
CD/DVD - ROM
Grafička Intel
osvjetljenje ekrana
3 x USB 2.0, 1 x USB 2.0 Always On, Display port, esata
Cijena 1000kn
InaČe ja imam Lenovo G500 3 godine već i prezadovoljan sam.
1. Može. Pogledaj po EBay-u, bitno je da maskica bude od ThinkPad-a, a ne bi škodilo da i onaj zubić ima koji drži drive na mjestu. Preživjet ćeš i bez njega, ali bolje da ima.
2. Dobra cijena za to što dobiješ.
3. To je ThinkPad T series sa Intel grafom. That's all you need to know. Ako ga budeš iole održavao, sva je sila da će te nadživjeti. Tebe i kutiju baterija.
[GOW]Nec je offline   Reply With Quote
Staro 22.10.2015., 13:50   #44
MatijaV
MatijaV's Avatar
Postovi: 131
Uzimam onda LAP sigurno, još samo jedno pitanje dockstation, dali ima kod nas za kupit?
Staro 22.10.2015., 14:26   #45
[GOW]Nec
[GOW]Nec's Avatar
Postovi: 1,215
Ima. To ti je Series 3 Lenovo dock, imaš ih i po njuški. Doduše, malo su precijenjeni s obzirom što nude.
Staro 22.10.2015., 15:18   #46
calypso
calypso's Avatar
Postovi: 1,954
Nedavno sam kupovao docking za T420 (isti ko i za T410), ali ubime kolko sam ga platio... Nis posebno skupo, tipa 250kn mislim...
GMKTec K8Plus
23" 1920x1080 IPS
Dell Latitude 7390
32GB DDR4
intel UHD 620
Staro 24.10.2015., 21:06   #47
marek45
Postovi: 399
Dobro ako novome t410 baterija drži 10 sati, koliko drži 5 godina starom?
Inače sam se sad zagrijao za nešto s njuškala. Dal bi se moglo ubost neku rabljenu t seriju, ugradit SSD (rabljeni i priključit na rabljeni vanjski monitor za 3000kn?
Namjena multimedija. Trenutno imam hp nx6325 (Turion 64 X2 TL-50, 4gb rama) i užasno je sporo.
Meni je želja nešto specifikacijama slično kao g710.
Zadnje izmijenjeno od: marek45. 24.10.2015. u 21:16.
marek45 je offline   Reply With Quote
Staro 24.10.2015., 21:54   #48
marek45
Postovi: 399
Staro 25.10.2015., 03:26   #49
calypso
calypso's Avatar
Postovi: 1,954
Lenovo T410 nema sta kostat 2600kn... Pred 4-5 mjeseci sam platio 2400kn T420 sa 160GB SSD diskom (intel)... U svakom slucaju, realna cijena za T410 je oko 1500kn sa obicnim diskom... Za 3000kn mozes sloziti T410, monitor nekakav, docking i SSD...
Baterija mu traje dosta, ali 10h je pretjerivanje, realnije je nekih 3-4 sata normalnog rada...
GMKTec K8Plus
23" 1920x1080 IPS
Dell Latitude 7390
32GB DDR4
intel UHD 620
Staro 25.10.2015., 10:23   #50
darkydark
N0teb00k n00b
darkydark's Avatar
Postovi: 2,105
Ima t420 sa i5+ssd 160+4gb +1600x900
Za oko 2000kn, taman u pricu stane monitor i 4gb rama :-)
Linđa
Truenas Scale
Staro 25.10.2015., 13:36   #51
marek45
Postovi: 399
Između g710 i thinkpada, jel ima smisla uzimati rabljeni laptop umjesto novog?
Zanemarimo prenosivost i kvalitetu izrade.
Namjena sve osim igrica i da previše ne zastari za 5 godina.
Jel thinkpad ima maintenence cover?
Zadnje izmijenjeno od: marek45. 25.10.2015. u 14:10.
Staro 25.10.2015., 14:24   #52
calypso
calypso's Avatar
Postovi: 1,954
Autor marek45 Pregled postova
Usporedjujes 'nekakav' laptop sa Thinkpad T serijom... Ako taj G710 kosta nov ispod 6000kn, onda je u pravilu niskoristi... Thinkpad T serija pocinje sa najjeftinijim modelima na oko 8000kn (IIRC), a najskuplji modeli (dakle, isti model laptopa, samo upgradean do kraja) kostaju i po 16.000kn...
To ti je onako - oces kupit novi Renault Megane ili 4 godine star Audi A4 za iste novce... Ja bih isao na A4...
Sto se garancije tice za Thinkpada - to je laptop od 1500kn, stvarno ti ne treba garancija za takav laptop jer za 1500kn kupis drugi, prebacis disk, prodas ostatak dijelova i nastavis dalje... Jedini nacin da ti se taj Thinkpad pokvari je da ga........ bacis upaljenog u more (prezivjet ce i pad sa balkona)...
T520 koji imam je star vec 4 godine i nikakvih problema sa njim nisam imao... Pao mi je ormar sa policama tezak preko 70kg na njega i nije mu nista, malo ga je ogrebao... Vise je nastradala moja glava nego laptop...
Inace, starom sam dao T61 iz tamo negdje 2008 ili 2009 godine... Radi i dalje ko da mu je prvi dan... Ti laptopi ce radit zauvijek dok stvarno ne postanu pretjerano zastarjeli...
Uzmi neki T410 ili T420 ako mozes, sto jefiniji, i onda kreni sa nadogradnjama... Nece te kostati previse, a slozit ces vrhunski laptop koji ce jos dugo vremena odolijevati zubu vremena...
Funfact: Ako te bas interesira, vrte se na medjunarodnoj svemirskoj stanici...
GMKTec K8Plus
23" 1920x1080 IPS
Dell Latitude 7390
32GB DDR4
intel UHD 620
Staro 25.10.2015., 14:33   #53
marek45
Postovi: 399
Ma sve 5. Al ajmo ovako.
Dakle sad imam nx6325 i za moje potrebe je ok samo što me sad stvarno žifcira sporost i opterećenost. (firefox s 10 kartica, obrada teksta, jednostavna obrada fotografija itd.)
Dakle ovaj g710 košta 2600 na njuški s garancijom i sad kažeš da ako uzmem t420/520 i nutra piknem SSD i više od 4gb rama da će to čudo raditi (po performansama) jednako kao i thinkpad i da će za 5+ godina biti jednako zastarjeli?
Koje si točno nadogradnje mislio?
Nemam puno para. Ovom mom nx6325 je i ekran otišao, pa je na monitor priključen stalno.
Otvoren sam za sve prijedloge.
Btw. što se tiče automobila ja bih radije uzeo novi duster, ladu vestu ili tak nešto nego stari audi/vw.
Staro 25.10.2015., 14:57   #54
calypso
calypso's Avatar
Postovi: 1,954
Nenenene, Thinkpad G710 koji nov kosta tih 3500kn i Thinkpad T serija (T420 recimo) nisu ni blizu ista klasa laptopa... Brzo ces shvatit kad pocnes koristit...
Nadogradi na 8GB RAMa, eventualno ubaci malo bolji ekran, dodaj docking station, ubaci neki mSATA SSD i stavi jos 500GB-1TB 2.5" za gluposti kojima ne treba brzina i miran si za sljedecih par godina...
Pogledaj ispod sto je u mom T520, pa ocijeni kako mozes nadogradit svoj... To su slicni laptopi, samo sto je moj 15.6", dok je T420 14.1"...
GMKTec K8Plus
23" 1920x1080 IPS
Dell Latitude 7390
32GB DDR4
intel UHD 620
Staro 25.10.2015., 15:06   #55
Dottore
Dottore's Avatar
Postovi: 7,644
Ja bi u potpunosti složio sa @calypso.
Tko kupi T seriju i brzo će shvatiti koliko je ISPLATIV. Trenutno imam tri iz T serije koju mi je teško riješiti. Ne bi prodao ni pod razno.
@calypso
Hvala što si meni sve pokazao igračke.
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 25.10.2015., 16:49   #56
marek45
Postovi: 399
Staro 25.10.2015., 17:25   #57
calypso
calypso's Avatar
Postovi: 1,954
Tvoj odabir - oces li 14" ili 15", oba su odlicna i kostaju jednako... Malo se cjenkaj, probaj skinuti cijenu 200-300kn za pocetak...
Racunaj da ti je 15" tezi i malo dzombastiji, 14" je oko 2kg...
GMKTec K8Plus
23" 1920x1080 IPS
Dell Latitude 7390
32GB DDR4
intel UHD 620
Staro 25.10.2015., 18:47   #58
Dottore
Dottore's Avatar
Postovi: 7,644
Još i 15" po pravilu ima malo bolje hlađenje.
HP 845 G8
RAM: 64GB DDR5
Graphic: AMD Radeon
Staro 28.10.2015., 23:16   #59
Mejzlik
tha pilot
Mejzlik's Avatar
Postovi: 647
T410, imam problema sa gubljenjem kontakta na konektoru dockinga, pa kod pomicanja po stolu, manjeg mrdanja se gube boje, slika na eksternom monitoru itd. (pocne tulit za ukapcanje/iskapcanje)...
Privremeno rjesenje mi je komad kartona u gornjem lijevom kutu izmedju dockinga i laptopa, kao da ga napinje na desnu stranu. Inace bez tog kartona docking mi bas ne funkcionira.
Docking sam kupio polovni, konektor mi izgleda cisto, makar je dosta klimav, pa neznam jel tak treba biti ili bi se moglo nesto pritegnuti?
Staro 29.10.2015., 10:55   #60
syss
syss's Avatar
Postovi: 10,805
ma da klimavi su i generalno su 3 koraka lošiji od serije 2... meni isto kenja kad zveknem po stolu jače ili nešto slično, pa sam sada nedavno stavio neki model sa usb3, očito apdejtani - same shit.
