Staro 19.10.2015., 22:39   #601
_saiko
system kaiser
Postovi: 194
mozes i tri broja, s tim da je treci VOIP/SIP telefon i ide na RJ45.
Znaci kad uzimas 3 broja 1 i 2 su ti preko POTSa, 3. ti je preko SIPa.
Ne mozes birati recimo 2 na SIP jedan na POTS ili sva tri na SIP.
...OSIM.. ako izvuces config sa njihovog routera i malo ga promijenis
Onda mozes i sva tri izvuci na VOIP/SIP samo ti treba naravno telefon koji podrzava SIP.
Npr klasicni Grandstream, Cisco, pa i Gigaset C610IP uredno rade.
I da, sva tri su nezavisno, mozes paralelno sa 3 imati sesiju.
<FLEET>
MBO: Gigabyte GA-X58A-UD7 (rev. 2.0)
CPU: Intel Core i7-950 @ 3.2 GHz
Chipset: Intel X58
RAM: 6 x 4 GB DDR3-1600 (PC3-12800)
VGA: HD4850
HDD(OS): OCZ Vertex3 120GB
HDD(local storage): WD WD2002FAEX 2TB, 2x Seagate 500GB (RAID0@IRST/ICH10R)
ODD: Optiarc (?)
PSU: Silverstone SST-ST60F-P Corsair VX450
Display: Samsung Syncmaster 930BF @ 1280 x 1024
Display2: Panasonic TC-P55VT60 @ 1920x1080
Other: eSata dock
OS: Windows 7 Ultimate x64
Input:
Logitech MX1000 + Logitech UltraX cordless
Model: HP Z420
CPU: Intel Xeon E5-1650 6x core @ 3.2 GHz
Chipset: Intel Sandy Bridge-E
RAM: 4 x 16 GB DDR3-1600 (PC3-12800)
VGA: Nvidia
HDD(OS): Seagate ST500DM002 500GB
HDD(local storage): 2x WD WD5000AAKX (RAID1@C600 SAS/SATA ctrl)
Display: 2x HP LA2205wg 22" @ 1680 x 1050
OS: Windows 7 Enterprise x64
Model: HP Elitebook 8570
CPU: Intel i5 3360M
Chipset: Intel Ivy Bridge
RAM: 2 x 8 GB DDR3-800 (PC3-12800)
VGA: Intel HD4000
HDD: Samsung SSD 850Pro 512GB
ODD: DVD+/-RW
Display: 15.4" (1366 x 768)
Other: Fingerprint reader
Input:
Logitech V500 cordless
MBO: GA-P35-DS3P (rev. 2.0)
CPU: Intel C2Q Q6600 @ 2.4 GHz
RAM: 4 x 2 GB DDR2-800 @ 533 MHz
VGA: ATI Rage 3D @ PCI
HDD(OS): Seagate ST380815AS 80GB / Seagate ST3500418AS 500GB
HDD(storage01): 2x WD RE WD4000FYYZ 4TB (RAID10,f2@mdadm)
HDD(storage02): WDC WD20EARX-00P 2TB
HDD(storage_cctv): Seagate ST3250824AS 250GB
ODD: NEC DVD-RW ND-4551A
PSU: Corsair GS800
Display: -
LAN: Intel 82571EB @2x1Gbps LACP
Controllers: RS232 Oxford Semiconductor Ltd OXuPCI952
OS: Linux x64 (Ubuntu 14.04 LTS)
MBO: HP ProLiant DL120 G7
CPU: Intel Xeon E3-1220 @ 4x 3.10GHz
Chipset: Intel i875P-ICH5
RAM: 4 x 4096 MB DDR3-667 (PC3-10600)
HDD1: 2x MB2000EBUCF HUA723020ALA640 2TB 7200RPM (RAID1@P410)
Display: -
LAN: 82574L @ 1000Mbps FD
OS: Linux x86_64 (Ubuntu 14.04 LTS)
MBO: ASRock 4Core1333-FullHD
CPU: Intel Core 2 Duo E84000 @ 3.0 GHz
Chipset: ATI RS600+SB600
RAM: 1 x 512 MB DDR2-800
VGA: -
HDD: Seagate 500GB
ODD: DVD-RW
PSU: Corsair VX450(?)
Display: Panasonic TH-50PY800
LAN: @1Gbps FD
OS: Windows 8.1 Pro x64
Input:
Logitech Cordless DiNovo Edge
MBO: Intel D201GLY2 (ITX)
CPU: Intel Celeron 220 @ 1.2GHz
Chipset: SiS662
RAM: 1 x 512 MB DDR2-533
VGA: Intel
HDD: Sandisk 1GB CF @ CF2IDE
ODD: -
PSU: miniITX type(?)
Display: -
LAN1-Uplink: @1000Mbps FD
LAN2: @100Mbps FD
OS: Mikrotik OS 6.28
Model: Mikrotik RB2011UAS-2HnD
</FLEET>
cat.7 - where crosstalk is not an issue anymore.
Zadnje izmijenjeno od: _saiko. 19.10.2015. u 22:44.
_saiko je offline   Reply With Quote
Staro 19.10.2015., 22:59   #602
mirkoSzlikowsky
Surf Now Work Later
Datum registracije: Dec 2011
Lokacija: svemir
Postovi: 6
Ne kuzim.
Ako mi ISDN zamijene sa IMSom onda telefoni idu direktno na routerov RJ45 zar ne ?
A ne "paralelno" kao do sada.
mirkoSzlikowsky je offline   Reply With Quote
Staro 19.10.2015., 23:02   #603
mirkoSzlikowsky
Surf Now Work Later
Lokacija: svemir
Postovi: 6
Jel mogu uzeti neki VOIP gateway, na njega spojiti svu analogne ili ISDN aparate i njega uštekati u router pa preko njega sve posložiti ?
Staro 20.10.2015., 00:20   #604
_saiko
system kaiser
Postovi: 194
Autor mirkoSzlikowsky Pregled postova
Ne kuzim.
Jok...
Ako uzmesh jednu ili dvije linije obje ce linije ici na router u POTS (rj11) iliti najobicniji telefon analogni.
Ako uzmesh tri linije (max za obicne smrtnike...) onda ce prve dve ici u POTS (rj11) a samo treca ce ici u rj45 i jedino ce ona biti "pravi" voip.
Ne mozes ISDN tu kombinirati.
To je ono sto Tcom moze pustiti po profilu. Drugih kombinacija bez samostalnog editiranja konfiguracije na routeru nema.
Ako nadjes VOIP gateway sa ISDNom mozes u principu i tako, ali radije uzmi VOIP/SIP telefon i izvuci si liniju na njega.
Mozes kao sto sam i rekao upasti u admin na routeru i pustiti si ove druge linije isto preko VOIP/SIP telefona (gubis analogiju onda jer jedna linija je limitirana na jednu sesiju - znaci ne moze biti aktivna linija i na POTSu i na VOIP/SIP telefonu).
<FLEET>
Chipset: Intel X58
VGA: HD4850
ODD: Optiarc (?)
Other: eSata dock
Input:
Model: HP Z420
VGA: Nvidia
CPU: Intel i5 3360M
VGA: Intel HD4000
ODD: DVD+/-RW
Input:
PSU: Corsair GS800
Display: -
Display: -
VGA: -
HDD: Seagate 500GB
ODD: DVD-RW
LAN: @1Gbps FD
Input:
Chipset: SiS662
VGA: Intel
ODD: -
Display: -
LAN2: @100Mbps FD
</FLEET>
Staro 20.10.2015., 07:39   #605
mirkoSzlikowsky
Surf Now Work Later
Lokacija: svemir
Postovi: 6
Thx.
Zaboravio sam da router ima 2 RJ-11......sorry....
Staro 22.10.2015., 22:19   #606
mirkoSzlikowsky
Surf Now Work Later
Lokacija: svemir
Postovi: 6
Da li netko ima iskustva sa gigasetima ?
Ja bi ISDN slusalicu registrirao na staru analognu bazu , tako da iskoristim ISDN telefon.
Da li to funkcionira ?
Staro 22.10.2015., 22:32   #607
Postovi: 23,491
Možeš upotrebiti i "ISDN bazu", trebaš samo pronjuškati po dokumentaciji,
ako se dobro sjećam, netko je bi pitao / tražio, analogni signal spojiš na "dva vanjska kontakta" (1 - 8) ...
Staro 09.11.2015., 16:44   #608
HumWeed
HumWeed's Avatar
Lokacija: Lava Reef
Postovi: 1,131
ja opet nekuzim zasto s tim ims-om il kak god se to zove
oni ogranice covjeka na samo jedan telefon u uporabi
ja cim spojim drugi u drugi utor rutera, sve ode u bananu pa ni prvi neradi vise
mislim odakle im pravo nametati takvo nesto ?
dok oni koji su jos na starom, mogu imati i 3-4 telefona spojena u zidu
Why would you invite a mushroom to a Christmas party? He's a fun guy to be with.
Why do mummies like Christmas so much? Because of all the wrapping.
Why does Santa have three gardens? So he can "ho ho ho".
HumWeed je offline   Reply With Quote
Staro 09.11.2015., 17:28   #609
Postovi: 23,491
Moraš sagledati / shvatiti kako odr. tehnologija radi,
sve bitno već piše u temi, samo trebaš malo potražiti,
i na INS - u (VoIp - u) možeš imati više telefona, trebaš ih spojiti u paralelu sa istog izlaza / porta na routeru,
više puta smo linkali odgovarajuće "razdjelnike",
spajanje drugog telefona u drugi port na routeru nije rješenje / ovisi o pameti pojedinog routera,
skoro u pravilu drugi port je namjenjen drugoj / dodatnoj liniji a ne da bude duplikat / paralela prvoj liniji.
