#2461 |
Propali Amigaš
Lokacija: Nin
Postovi: 7,005
Ma ako gledamo samo CPU tu je razlika vjerojatno max 30-ak wata u prosjeku, pomnoženo sa brojem sati |
#2462 |
..starija garda
Postovi: 3,280
#2463 |
Member
Lokacija: Kutina
Postovi: 979
Ali to je samo jedna komponenta, različiti čipseti odnesu desetak wata, četiri ddr3 u odnosu na jedan skoro deset wata, koji ventilator više, HDD, optički pogoni puno troše i eto ti kod istog CPU i GPU tridesetak wata razlike a da ne govorim o grafičkoj s istim GPU različitih proizvođača imaju po desetke wata razlike pa ti to sve pohvataj kod usporedbe. |
#2464 | |
Propali Amigaš
Lokacija: Nin
Postovi: 7,005
#2465 | |
Propali Amigaš
Lokacija: Nin
Postovi: 7,005
"GW2 desperately needs a DX12 client. With how many draw calls are sent during large WvW fights/world bosses, and DX9 confining them to 1 core at a time, the performance is awful. Even with an i7 5960x and 4x SLI GTX TItans($5000 build!), you're lucky to get 30 fps in a huge WvW battle at max settings. With DX12, it would significantly reduce the CPU load from draw calls, and provide better multithreading support for it. This would greatly increase framerates in CPU bound situations such as WvW. Depending on their hardware and how well the developers implement it, framerates could see see as much as a 300% boost in the most intensive situations. With Windows 10 being a free upgrade for the majority of the playerbase(win 7 users or newer), DX12 would resolve performance issues for the majority of players. The only downside to creating a DX12 client is cost & time, which I'm sure is what's keeping management from pushing one. But let me say that as a player, if we get a DX12 client, I will definitely purchase HoT. " |
#2466 | |
Member
Lokacija: Kutina
Postovi: 979
Ili kako će netko reći moja i5 konfiguracija manje troši od tvoje FX 8320 konfe, ma zajebi milojko, tvoja grafa troši duplo više pa moj FX PC troši manje. Ne postoji CPU kao PC. Zadnje izmijenjeno od: gil. 05.10.2015. u 16:40. |
#2467 |
Datum registracije: Mar 2009
Lokacija: osijek
Postovi: 86
Razlika potorsnje fx-a i i5 je 65W prema specifikaciji. Hep struja visa tarifa 1,1kn, niza o,6kn. Sto ce tek reci overklokeri na ove usporedbe, jer kod njih je razlika i po 200W |
#2468 |
Member
Lokacija: Kutina
Postovi: 979
Opet puno faktora za usporedbu, default postavke razlika 30 wata ako govorimo o e verziji FX_a, ako klokaš i5 možeš i prestići po potrošnji FX i opet op prc milojko. |
#2469 |
All-rounder
Datum registracije: Sep 2013
Postovi: 1,323
Haswell 84W, 8320e 95W. A u praksi oba rade na podjednakoj potrošnji (50% loada - oko 50-60W). Neš ti razlike... Čak i proc od 125W TDP bi radio u tom području 50-60-70W pod loadom veći dio vremena. 20W razlike čini razliku od 1kws svakih 50 sati rada pod loadom. Dakle, manje od 1kn svakih 50 sati rada. |
#2470 |
Lokacija: osijek
Postovi: 86
Ne znam bas da je to teza. Ovdje se vise proteze kako se kod amda za malo novaca dobije proc koji se nakloka i radi kao neki intel. Po meni je ta potrosnja onda drasticno veca. Jedno je sigurno amd korisnici su vise overklokerski obrazovani ![]() |
#2471 |
Member
Lokacija: Kutina
Postovi: 979
U svijetu kućnih korisnika sve je čušpajz, netko ko zna podesiti će svoj sistem da radi optimalno a netko drugi treći će imati overkill konfu i trošiti nepotrebno više i to vrijedi za nas obične čobane, u biznis vodama moja razmišljanja padaju u vodu isto tako i kod onih kojima svaki fps život znače. |
#2472 | |
..starija garda
Postovi: 3,280
#2473 |
Datum registracije: Aug 2008
Postovi: 237
Pozdrav ekipa, vidim nastala je prava rasprava o temi koji sam mislio potaknuti, ali sam odustao jer sam shvatio da bi se fanovi suprostavljenih tabora potukli, što se tu skoro dogodilo ![]() http://www.pcper.com/reviews/Systems...ou-Really-Need |
#2474 | |
Postovi: 14,584
![]() Darkydark ti je već fino objasnio http://forum.pcekspert.com/showpost....postcount=8284 Znači ti uopće ne pričaš o potrošnji X cpu vs Y cpu, nego nepostojanje čitavog PC u kući povrh toga što je 1 osoba manje u kućanstvu (ubaci tu svoju potrošnju struje). Dakle di je tu tvoje paljenje svijetla, više pranja veša, tvoje korištenje štajaznam fena, mikrovalne, tvoje gledanje tv-a... Ti si sve to svalio na proc Stričeki iz YT su ti fino izmjerili potrošnju sistema, stavili formule (samo treba staviti cijenu HEP-a). Okladio bi se u ljevo jaje da niti jedan video nisi saslušao do kraja Zadnje izmijenjeno od: Manuel Calavera. 05.10.2015. u 19:26. |
#2475 |
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
Ko je darkydark? Neki astrofizičar zbog kojeg bi sve zakone fizike i logike trebali zanemariti i vjerovati njemu na riječ da neću osjetiti razliku nečega što troši duplo do troduplo više...za što je dao pokriće u kojem smislu? Tj doveo je zakone fizike na koljena....da je 1 X 2 ili 1X 3 i dalje = 1 (uz vašu varijablu što je ptihvatljivo da bi bilo neosjetno...a o tom se isto može pričati) Isto kao i YOutube i forumi postoje da bi mi mogli baljezgat gluposti...neki to rade tekstom neki u podcastu. Testovi postoje da bi se utvrdilo činjenično stanje. Naravno,samo kod nekih jer razno razni Mulderi sugeriraju da je cijeli svijet korumpiran i da "Trust no1" kodeks još postoji u ovome svijetu te da isključivo treba slušati fanboye po forumima i njihova iskustva. Stiso bi fejspalm like ali ga nema. |
#2476 | |
Propali Amigaš
Lokacija: Nin
Postovi: 7,005
#2477 |
Fascinantno mi je ovo zazivanje štednje električne energije na procesorima. Doma imate vešmašine i bojlere pune kamenca koji vuku ko blesavi sa kojima bi se moglo ušparat stotara mjesečno... al ne, ajmo reć da AMD nosi 70kn mjesečno na struji ![]() OK, troše više od Intela, ali braćo moja mila, pa nije to 2kW grijač u bojleru niti trofazni elektromotor od 50kW. |
#2478 |
Postovi: 14,584
A plazme tko ima ![]() Ja kaem radi se o par kn mjesečno, samo treba izračunati. Plus što su frajeri za referencu uzeli scenarij full loada od nekoliko sati na dan, svaki dan u godini. Tko ne vrti stress testove i ne vrti rendering njegov cpu nije vidio full loada. Znači u real life scenariju možda ni za žvaku mjesečno ne možeš uštedjeti na procesoru Dakle pričam o ovim testovima (u prvom i5 u drugom i7 vs 8350, stock vs OC) https://youtu.be/4et7kDGSRfc?t=9m https://www.youtube.com/watch?v=fBeeGHozSY0 Dakle ne pričamo o tome da amd pandan ne troši više, to nije sporno, nego koliko se ta razlika osjeti na računu Zadnje izmijenjeno od: Manuel Calavera. 05.10.2015. u 19:53. |
#2479 |
decki ak niste imali 3x 290x u kompu koje majnaju scrypt, niste vidjeli kaj je potrosnja ![]() |
#2480 |
Lokacija: osijek
Postovi: 86
U gornjim testovima je cak i mali i3 cesto jaci od fxa. Naravno fx je grijeh drzati stock. Po svemu sudeci tko slaze novi stroj i ima veci buđet treba ici na intela, jer ga intel u 3god nece izac skuplje. Mi ostali mozemo iskoristit ostatak komponenti i ici na fx-a. |
#2482 |
Terror Absolut!
Datum registracije: May 2014
Lokacija: Earth
Postovi: 802
Pozivam se na ono što govori Drug Brko i apsolutno je u pravu. Kod ljudi koji koriste računalo u taskovima koji ne iziskuju 24/7 full load nema smisla uopće gledati potrošnju već ostale stavke (prvenstveno performanse čipa). Onaj tko je unutar malog budgeta bi trebao gledati jeftinije FX i Phenom alternative, ali bilo tko tko se bavi iole ozbiljnijim poslom od kojeg zarađuje - bilo to renderiranje, streamanje videa ili nešto treće trebao bi ulagati u Intel. Možemo govoriti o isplativosti FX-a naspram Xeona i i7-ice, ali onaj kojem zaista treba više threadova i kojem zarada ovisi o tome će uzeti ovo drugo. |
#2483 |
Postovi: 753
Ja sam bio jednom izracuno pa kefa ![]() ![]() Uglavnom ja sam doma za sebe izracuno mjesecnu potrosnju. S time da mi je PC upaljen cijeli dan i noc, od toga 2-3 sata se igram, ostalo idla ( jer sam vecinu dana na poslu ), malo youtube poslje i citanje zabave ovdje ![]() |
#2484 | |
Propali Amigaš
Lokacija: Nin
Postovi: 7,005
http://www.titancomputers.com/Titan-...630-p/a375.htm |
#2485 |
Lokacija: osijek
Postovi: 86
Drug Brko je u dusi amd-ovac ![]() I koj je sada fx za preporuku? Gledao sam danas fx 8350 na 4,4ghz u GW2 i solidno to odrađuje. |
#2488 |
Lokacija: osijek
Postovi: 86
Hoce to ici na tih 4,4 sa freezerom extreme na Asus M5A97 le R2.0? |
#2489 |
..starija garda
Postovi: 3,280
Na toj LE verziji ploce da mi treba svaki mhz bi ga ja drzao ajmo reci do 1.35v pa dokle ide, a preko 4 bi svakako presao.. Hawker (ili ravkan) bolje zna koliko sta mozes ocekivat pri kojoj voltazi pa ce ti on dat sigurno neke smjernice..
#2490 |
Datum registracije: Nov 2014
Postovi: 1,972
FX 8320E ,najisplativiji procesor naseg vremena. E verzije su najbolji klokeri (extreme low leak) Ja drzim 8320E na katastrofalnoj Asrock extreme3 zalosti i drzim ga na 4,2 uz neku sitnu voltazu. EDIT: Kad sam ga testirao na Sabertooth 990FX R2.0 (na njoj je 8370) lakocom sam postigao 5,2 ghz s tim sto mu za 5ghz treba 1,45v,a za 4,9 treba 1,39 (manje od FX8370) Zadnje izmijenjeno od: Hawker. 05.10.2015. u 23:13. |
