Staro 28.09.2015., 18:00   #2461
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Don’ts
  • Don’t rely on the driver to parallelize any Direct3D12 works in driver threads
    • On DX11 the driver does farm off asynchronous tasks to driver worker threads where possible – this doesn’t happen anymore under DX12
    • While the total cost of work submission in DX12 has been reduced, the amount of work measured on the application’s thread may be larger due to the loss of driver threading. The more efficiently one can use parallel hardware cores of the CPU to submit work in parallel, the more benefit in terms of draw call submission performance can be expected.
To se pretpostavljam odnosi na ovo od ashes benchmarka
Curiously, their driver reported this feature was functional but attempting to use it was an unmitigated disaster in terms of performance and conformance so we shut it down on their hardware. As far as I know, Maxwell doesn’t really have Async Compute so I don’t know why their driver was trying to expose that.
analiza
nVIDIA, on the other hand, does much better at Serial scheduling of work loads (when you consider that anything prior to Maxwell 2 is limited to Serial Scheduling rather than Parallel Scheduling). DirectX 11 is suited for Serial Scheduling therefore naturally nVIDIA has an advantage under DirectX 11.
People wondering why Nvidia is doing a bit better in DX11 than DX12. That's because Nvidia optimized their DX11 path in their drivers for Ashes of the Singularity. With DX12 there are no tangible driver optimizations because the Game Engine speaks almost directly to the Graphics Hardware. So none were made. Nvidia is at the mercy of the programmers talents as well as their own Maxwell architectures thread parallelism performance under DX12. The Devellopers programmed for thread parallelism in Ashes of the Singularity in order to be able to better draw all those objects on the screen. Therefore what were seeing with the Nvidia numbers is the Nvidia draw call bottleneck showing up under DX12. Nvidia works around this with its own optimizations in DX11 by prioritizing workloads and replacing shaders. Yes, the nVIDIA driver contains a compiler which re-compiles and replaces shaders which are not fine tuned to their architecture on a per game basis. NVidia's driver is also Multi-Threaded, making use of the idling CPU cores in order to recompile/replace shaders. The work nVIDIA does in software, under DX11, is the work AMD do in Hardware, under DX12, with their Asynchronous Compute Engines.
PS. Don't count on better Direct X 12 drivers from nVIDIA. DirectX 12 is closer to Metal and it's all on the developer to make efficient use of both nVIDIA and AMDs architectures.
Zadnje izmijenjeno od: Manuel Calavera. 28.09.2015. u 18:35.
Staro 01.10.2015., 21:41   #2462
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
Tužan dan. Ležajevi otišli na jednom od tri venta na GB g1 970 :/
Ova pila od integruše (HD530) je toliko jaka da nemre 60Hz u winsima vec 59
Bez potpisa.
Staro 01.10.2015., 23:47   #2463
Thermaltake
1
Postovi: 3,601
Autor RaneZ Pregled postova
Nisam čitao unatrag, jel ovo prvi slučaj sa GB G1 970 ventovima, zasad sam čuo samo pozitivna iskustva.
Zadnje izmijenjeno od: Thermaltake. 01.10.2015. u 23:56.
Staro 02.10.2015., 00:36   #2464
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
Da, ovo mi je druga sa tim hladjenjem, nikad problema do sad...čudno. Usrao se da nije coil whine počeo...jer je sličan zvuk na višim rpm. Pili ko bušilica kod zubara
Bez potpisa.
Staro 02.10.2015., 20:28   #2465
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,873
jedno pitanjce gledam uzishop za gtx 960 kad gtx 960 ti nikako da se pojavi mi se isplati moju prodat naravno sve ovisi za kolko je mogo prodat mi se isplati dodplatit 350-400 kuna za 10 fpsova više za ovu grafu
ovu sam gledo jer ima 4gb rama umjesto 2
https://www.uzishop.hr/nvidia-gpu/37...960&results=31
ili ove s 2gb rama
https://www.uzishop.hr/nvidia-gpu/31...960&results=31
https://www.uzishop.hr/nvidia-gpu/34...960&results=31
Staro 02.10.2015., 20:41   #2466
Manuel Calavera
Postovi: 14,584
Ne isplati ti se mjenjati gtx 760 za gtx 960, nije to ništa bitno jače da bi opravdalo zamjenu
Staro 02.10.2015., 20:46   #2467
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,873
pitanje je, da li je 350-400 kuna vrijedno 10 fpsova više??po meni i nije možda do 300 kuna i je.
Staro 02.10.2015., 21:44   #2468
Sphere
Datum registracije: Mar 2015
Postovi: 1,254
Za GTX 760 mozes dobit 1200kn, sve iznad toga je preforsirano i pitanje je oces ju prodat. Tako da bi te zamjena ispala 600kn za neki bolji model gtx 960.
Uglavnom ne isplati se, igraj se na gtx 760 dok ne skupis za neku r9 390/gtx 970.
Sphere je offline   Reply With Quote
Staro 02.10.2015., 21:53   #2469
Manuel Calavera
Postovi: 14,584
Inače "10fps" je jako relativan pojam. Pitanje je na kojem fps-u dodatnih 10? Ako je to 20 vs 30 ili 30 vs 40 fps onda jest solidna razlika, ako se radi recimo o 70 vs 80 onda je to k.... od ovce, a ne upgrade.
Gtx 960 nije toliko jača
Staro 04.10.2015., 21:10   #2470
luka_os
Datum registracije: Mar 2009
Lokacija: osijek
Postovi: 86
Nije neka razlika u performansama, ali ce vjerojatno biti kad pocnu izlazit direct x12 igrice
Po meni za sada ostati na toj, pa kasnije uzeti nesto dx12
luka_os je offline   Reply With Quote
Staro 05.10.2015., 08:29   #2471
Do kraja 2016 će na tržištu biti 10 dx12 igara od kojih će 3 valjda biti vrijedne spomena.
A kad se tržište "razbukta" negdje sredinom/krajem 2017, tada će i R9 390 i GTX 970 biti za otpis, prvo zbog isteka gare, i drugo naravno performanse.
Staro 05.10.2015., 11:33   #2472
zvonac
zvonac's Avatar
Lokacija: Sv.Nedelja
Postovi: 5,826
A do onda će izić nvidia volta, a pascal pada u drugi plan, odnosno pascal će onda bit lanjski snijeg..
Taman vrijeme za promjenu grafe gtx970..
Staro 05.10.2015., 17:22   #2473
Autor zvonac Pregled postova
Kao i Ultimativnog Future Proof Best Buya ikada - R9 390 8GB
Staro 05.10.2015., 17:46   #2474
luka_os
Lokacija: osijek
Postovi: 86
Te grafe vise ne stanu u kuciste, vec se ormar mora narucit. Najbolje da uzmem zamrzivac pa imam all in one.
Staro 05.10.2015., 19:26   #2475
Stanu, stanu. Mislio sam da meni G1 (prvotna želja te ideja) nebi stala u Ćifa Big Towera, a sad vidim da bi mogla stati i veća.
Nego, eto, 2 tjedna od akvizicije Strixice, nekih 10-tak sati gaminga, nit ju čuo nit ju vidio, a od Coil whinea ni C ni W. Samo riječi hvale...zasada
Tako da je sad to već druga grafička za redom za koju mi je esc govorio da je promašaj.
Staro 05.10.2015., 20:57   #2476
ssarik
Terror Absolut!
ssarik's Avatar
Datum registracije: May 2014
Lokacija: Earth
Postovi: 802
A jesi našao mjerodavnog.
ssarik je offline   Reply With Quote
Staro 05.10.2015., 21:11   #2477
esc
Lynnfield
Datum registracije: Sep 2012
Postovi: 1,023
Zadnje izmijenjeno od: esc. 06.10.2015. u 05:59.
esc je offline   Reply With Quote
Staro 04.11.2015., 03:21   #2478
Manuel Calavera
Postovi: 14,584
Od sada se gtx 960 proizvodi samo sa 4gb
http://wccftech.com/nvidia-aib-relea...force-gtx-960/
Staro 04.11.2015., 10:30   #2479
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Sad su se to sjetili?? I opet su nam ga stavili, sto sa korisnicima koji su kupili sa 2 ? Hoce dobit nove grafe posto su ipak po testovima shvatili da je 2 gb premalo?
Staro 04.11.2015., 10:32   #2480
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
Ali ček, to je i dalje 128-bit sabirnica? Tko je tu lud?
Staro 04.11.2015., 11:47   #2481
Sn4k3
Sn4k3's Avatar
Lokacija: Zd
Postovi: 4,752
Autor xulos Pregled postova
To bi bila jako lipa gesta, ali mislim da je jako nerealna .
Ipak nitko nikog nije natira da kupi karticu sa 2Gb...
Uostalom evo koliko razlike ima u korist 4Gb...
Da, i dalje 128bit. Pa nece minjati sabirnicu, samo su nadodali jos 2Gb rama...
Al svejedno i sa tako uskom sabirnicom ova grafa ima jako dobre performanse
unatoc jako maloj razlici u fps-u koju dobijes sa ovim ekstra ramom...
Kad bi izbacili nesto tipa gtx965 sa 192-bitnom sabirnicom i 4Gb rama, e to bi bija posa...
Staro 04.11.2015., 14:34   #2482
ODO
Datum registracije: Feb 2015
Postovi: 596
Ja sam svoju uzeo u 3.mjesec, već tada se znalo da dolaze 4GB modeli, pa sam se na kraju ipak odlučio na 2GB. Ne bih rekao da su ikome stavili, onaj s većim budžetom je jednostavno uzeo 970-icu. 960-ka nije high end grafa i sa ta 2GB opet nema igre koju ne možeš igrat na medium/high postavkama na 1080p. A vrtio sam Shadow of Mordor, FC4, Witchera 3 i GTAV.
Bi li sad kupio onu sa 4GB, vjerojatno da, ali nije da me nešto puno smeta.
ODO je offline   Reply With Quote
Staro 04.11.2015., 17:53   #2483
Dottore
Dottore's Avatar
Postovi: 7,693
Već se znalo.
Gledao sam razliku u nabavi cca 300-4ookn razlike prije 2 mjeseca.
Autor Sn4k3 Pregled postova
Veća i sporija memorija. Gledaj brzine takta memorije. Još kad bi OC odradio i bilo bi 5% viška FPS
HP 845 G9
CPU: AMD Ryzen 7 PRO 6850U
RAM: 64GB Samsung DDR5 4800
Graphic: AMD Radeon 680M
LCD: 14" IPS @ 1920 x 1200
OS: Windows 11 Pro 25H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
Staro 04.11.2015., 20:26   #2484
Manuel Calavera
Postovi: 14,584
Baš, pa nije nitko nekoga tjerao da kupuje verziju od 2gb. Izbor je postojao od starta
Inače 4gb verzija navodno ima šemu sa memorijom kao gtx 970 (3.5gb + 0.5gb sa 1/7 bandwidtha), bilo je na forumu
http://www.techpowerup.com/forums/th....211040/page-3
Inače gpu IMO ima odliču cijenu za 4gb verzije, navodno bi mogla još dodatno pasti sad kad krenu samo 4gb proizvoditi, a amd izbaci još 380x
Čim se pojavila rekao sam vam da će jako pasti cijena, u samom početku su 2gb verzije bile 2 soma, a sad su 4gb verzije 1700+ kn i to ove sa 3 god. garancije
Staro 04.11.2015., 20:28   #2485
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Autor Dottore Pregled postova
Već se znalo.
Sad je razlika skoro 100kn
Onda ja nešto krivo gledam jer npr. Gigabyte model ima iste brzine (tj. memory bandwith) za 2 i 4GB modele.
Duplo veći bandwith (224 GB/s) dolazi (logično) sa 256 bit. sabirnicom i istom 7000MHz freq. memorije (na jačim GTX 970/980 modelima).
Pomelo mi sig -.-
Staro 04.11.2015., 20:41   #2486
ODO
Postovi: 596
Moja se još ne da.
Staro 04.11.2015., 22:25   #2487
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,575
Nemoj mi s tim solidarnim forama . Kupis bmw 320d i za iste pare nakon pol g se prodaje 330d jer ovaj su odlucili nepravit posto je preslab, a ovaj 330d je prije pol g bio bar 20% skuplji, to je sasvim ok ? Nije. i pederski je kako god okrenes, nije velika stvar ali brate mili nisu ni ljudi glupi jer 4 gb verzija je u startu bila skuplja . Tako da puse i oni koji su iskesirali vise za 4 gb i ovi koji su za istu lovu mogli kupit 4 gb a dobili su 2 .
Staro 05.11.2015., 00:28   #2488
Sphere
Postovi: 1,254
Šta ima veze, ionako su Nvidia useri navikli i na gore stvari od toga
Odes fino na AMD i nemas te brige
Staro 05.11.2015., 01:55   #2489
Manuel Calavera
Postovi: 14,584
Pa nisu fore. Meni ovo nije ništa dramatično i čudim se reakcijama...
Prvo - ta gpu sa 2gb nije nikakav crap (u 99% situacija nema razlike u peformansama u odnosu na 4gb na gpu takvog ranga, AC unity i možda još koji, naravno u budućnosti će biti i više). Naravno da je 4gb više futureproof i bolji izbor, ali nije razlika za glavu. Kad 2gb verzija postane generalno preslaba postat će i 4gb, ipak je ista gpu
Drugo - nisu ništa slagali. Nisu napisali da je 2gb, a ono 1gb. Zašto bi trebali vraćati novce? Nerealno. Pogle čak i ovu situaciju sa gtx 970 (3.5+0.5), nije ništa slagano - ona 4gb tehnički ima (problem je u nečem drugom - što se slagalo za ROPs i sl. e to već je punokrvni false marketing)
Treće - postojao je izbor
Četvrto - novac. Potpuno je normalno da je pala cijena, tako bude sa svakom gpu. I gtx 760 je bila 2300kn u početku, pa jako brzo 2000kn, a na kraju 1800kn. Konkurentna R9 380 2gb je isto bila 2 soma (ma i preko), a sad ima 4gb za 1800kn, a 2gb verzija nije isto mnogo jeftinija. Takav je trend
Peto - Razlog/pozadinska politika. Kao što piše u linku - leveliranje tržišta. Zagužvalo se puno modela jako blizu. Od slabijih gtx 950 je ispala jača nego li je itko očekivao, nabrijani modeli udaraju u guzicu gtx 960, ako gtx 960 4gb još dodatno pojeftini imali bi gtx 950, 960 sa 2gb i gtx 960 4gb u 100kn svaka (pa već je sad tako, jedna mora van). A konkurencija R9 380 je sve jača u odnosu na nju, čak se i prodaje iznad MSRP za razliku od gtx 960, još sad izbacuju R9 380X koja će popuniti jednu finu rupu između 960/380 i 970/390, a kako sada stvari stoje nvidia možda uopće neće imati odgovor na nju (960Ti), jer od čega će je napraviti? Zbunili su sami sebe, a amd u tom segmentu od R9 380 - R9 390X vraća market share (bilo je pisalo da je gotovo sve u tom segmentu, msrp+). gtx 960 je napravljena od plovice gm204 (gtx 980) i IMO ispala je dosta dobro (nije duplo slabija), gtx 950 je oskaćena gtx 960 (IMO ispala je odlična, iznad očekivanja, osim potrošnje), gtx 970 je čudno osakaćena gtx 980 i sad bi još kao trebali oskatit osakaćenu gtx 970 da bi dobili gtx 960Ti...
EDIT
Tako da pozdravljam što nvidija pokreće pojeftinjenja u ovom segmentu i što je tu jeftinija, što je weird sičjuejšn. Nema veze što je mrvu slabija, nvidia je uvjek skuplja, pa i gtx 760 je bila skuplja ili podjednaka od apsolutno bolje R9 280, čak i 280X jedan period lol.
Zadnje izmijenjeno od: Manuel Calavera. 05.11.2015. u 02:24.
Staro 05.11.2015., 08:50   #2490
karlo10
šekler
karlo10's Avatar
Postovi: 115
Ma i 2gb 960 je super grafa za full HD. Za sad nisam naišao na neke probleme osim ako AA ne nafrljiš u bijesne cifre. Onaj neki normalni vrti bez problema.
Za veće rezolucije ovak i onak nije, proban DSR (inače nemam kak drugačije) i to je čak i u Doti 2 u nekim situacijama (čitaj preko 30-tak unita na ekranu) ubije. Tak da za veće reze nebi ni tih dodatnih 2gb pomoglo, nego treba ipak i jači gpu.
Napomena: Od početka ju imam na 1500 MHz core i 7400 memorija podignutu, pa govorim za taj slučaj. Na stock nisam probavao, jer takav free performance boost se ne odbija.
karlo10 je offline   Reply With Quote
