#61 | |
Datum registracije: Jun 2010
Postovi: 14
#62 |
Postovi: 1,441
#63 | |
Postovi: 14
#65 | |
Postovi: 14
Evo šta je napravio: Clean Reinstall We use this name, but it's not about removing your settings, it's about making sure the program files are clean -- and do not contain alien code files. As described below, this process does not disturb your existing settings. Do NOT uninstall Firefox, that's not needed. (1) Download a fresh installer for Firefox 37.0.1 from https://www.mozilla.org/firefox/all/ to a convenient location if you have an older one. (Scroll down to your preferred language.) (2) Exit out of Firefox (if applicable). (3) Rename the program folder (64-bit Windows folder names) C:\Program Files (x86)\Mozilla Firefox to C:\Program Files (x86)\OldFirefox (32-bit Windows folder names) C:\Program Files\Mozilla Firefox to C:\Program Files\OldFirefox (4) Run the installer you downloaded in #1. It should automatically connect to your existing settings. Any difference? Note: Some plugins may exist only in that OldFirefox folder. If something essential is missing, look in these folders: \OldFirefox\Plugins \OldFirefox\browser\plugins |
#66 |
Lokacija: slavonac
Postovi: 504
Da li neko ima problema sa novim Malwarebytes anti-malware? Zakuca mi računalo na 100 %. Pomaže jedino uninstal...i onda sve radi normalno. Probao instalirat više puta sa različitih izvora... uvijek isto. Zakuca 100% i nemrda . Restart i uninstal, i sve 5. Starija verzija radi normalno. Windows home original. Dopuna. Kad instaliram mwb i pokrenem ga kao free, sve stane kako je napisano gore. Kad ga pokrenem na 14 dana u ful modu sve radi bez greške. Kad mu isključim live nadzor, opet sve stane. Evo, pa koga zanima. Pričekat ću novu verziju, možda riješe problem.
he,he Zadnje izmijenjeno od: zlatko. 29.12.2019. u 09:38. |
#67 |
dežurno smetalo
Lokacija: Krapinske Toplice
Postovi: 312
Jel može netko pomoć u vezi sljedeće situacije: Stari je uspio u obrtu pokupit neki malware (a možda i virus, nemam pojma) koji USB kada se otvori, samo pokazuje shortcut (od USB-a), te tek onda otvara filove (i zarazi komp) ![]() Jel netko imao iskustva s time, kako locirati i maknuti. Malware Bytes nađe nešt, ali nakon restarta isto. |
#68 | |
...samo te gledam...
Postovi: 2,836
#70 |
Pijem samo KAJ
Lokacija: Vž
Postovi: 2,697
Dobio sam jučer navečer poruku na mob da je nekakva sumnjiva radnja na mom gmailu i odmah sam promijenio password. Danas se idem logirati preko windowsa (Vivaldi) i dobivam poruku da je otkriven zlonamjerni software na ovom računalu i neka ga uklonim i da onda pristupim gmailu. Malwarebytes (free) ne nalazi ništa kao ni Win Defender. Na kompu je sve legalno da legalnije ne može biti. Savjeti? Hvala EDIT: Chrome ne radi paniku... |
#72 |
Pijem samo KAJ
Lokacija: Vž
Postovi: 2,697
Zadnje izmijenjeno od: Problem. 03.03.2022. u 11:54. |
#73 |
Postovi: 27
Probaj vidjeti pod ekstenzijama dali si slucajno nesto instalirao |
