#2435 |
Datum registracije: Sep 2015
Lokacija: GHAZIABAD
Postovi: 3
CAUSE There can be multiple causes for this problem. For details, please refer to Microsoft Knowledge Base Artircle 324103 titled "How to troubleshoot 'Stop 0x0000007B' errors in Windows XP". In the context of a BootManage Administrator driven unattended Windows installation, it is most likely that the problem is related to a missing, inappropriate or faulty third-party mass storage driver: 1. The Windows version does not contain a driver for the target system's mass storage host adapter. 2. An inappropriate or faulty third-party driver was added to the "textmode" part of the unattended Windows installation. 3. A third-party mass storage driver was added via "textmode", but the target PC's system disk requires the "standard" IDE driver. http://www.deskdecode.com/how-to-fix...top0x0000007b/ |
#2436 | |
Lokacija: slavonac
Postovi: 500
he,he |
#2438 |
Postovi: 126
Da li i kako se može promijeniti slika koja se prikaže kod bootanja i gašenja računala? Radi se o win7 ultimate. hvala |
#2439 |
Postovi: 23,569
is your frend > http://www.google.com/search?q=change+win7+boot+screenhttp://www.sevenforums.com/tutorials...ge.html?filter[2]=Appearance%20Personalize http://www.askvg.com/change-windows-...-boot-updater/ |
#2440 |
Postovi: 126
super, hvala ![]() |
#2441 |
Lokacija: U naslonjacu
Postovi: 108
Pozdrav. Isprike šta dižem temu iz mrtvih, ali da ne otvaram novu pitati ću tu. Vezano je uz remote spajanje na server (mali kući lab s više virtualnih mašina, a na njima je instaliran ad, dns server, exchange, dhcp). Uglavnom problem je kad se preko RDC-a idem spojiti preko IP adrese onda me odbije. Kada se spajam preko naziva servera onda se uredno spojim. Greška je sljedeća: http://imgur.com/oGjpCiW Na serveru neka nikakih ograničenja kad se tko može spajati na što greška upućuje . U event logu nikakvih upozorenja, greški. Pretpostavljam da je problem na DNS serveru. Google ne pronalazi ništa. Da li netko ima kakvo rješenje? |
#2444 |
Postovi: 108
Da, na domeni su svi. Takodjer se svi nalaze na vlanu kreiranom na vcentru. Znači remote s jednog na drugi server ide samo preko imena servera. U server manageru su svi online. Ping prolazi. @Destro: Lokalno. |
#2448 |
Postovi: 1,212
Možda je do koleginog accounta, ne računala. Provjeri da li se nalaziš u Remote Desktop Users grupi.
Jel' ima šta ženskih starih
što vole strance da nas vozaju u autu i kupuju skupe lance |
#2451 |
...samo te gledam...
Postovi: 2,833
Windows 7 Ultimate 64-bit, legalni, instalirani na laptop i ne potegnu niti jedan jedini update. Uredno instaliran IE 11 (što je preduvjet za normalan download bilo čega s weba), bez ičeg, samo gola instalacija Windowsa, već dvaput reinstalirani Windowsi i ne nađe niti jedan jedini update. Naravno da se ne uspijevam probiti do Windowsa 10 što je krajnji cilj, ne pomažu nikakve upute koje sam našao na webu. Ima netko takav problem? Ne znam treba li neki update skinuti ručno? |
#2452 |
Omicron Alpha resident
Lokacija: Bistra
Postovi: 5,087
Pa daj detalje - koju grešku baca? Kako je spojen na net, jesu li modificirane sistemske datoteke, jel je netko prčkao po group policy? Jel se netko igrao inženjera pa je gasio procese, uključujući WU i BITS?
#2453 |
Lokacija: n/a
Postovi: 1,258
Ako je kranji cilj Windows 10, onda preskoci sav WU i direkt ovdje: https://www.microsoft.com/hr-hr/soft...load/windows10 - bitno je da je 7 uredno aktivirana (i da je 7 SP1). E da, prije svega provjeri datum (sat) na laptopu ![]() Zadnje izmijenjeno od: nathan.fake. 09.11.2015. u 10:42. |
#2454 |
Lokacija: Vinkovci
Postovi: 531
@sinac Ako ti je 10-ka krajnji cilj, i vec imas ISO 10-ke, ne vidim razloga za gubljenje vremena na updejte za 7-cu,raspakiraj iso u folder i pokreni setup.exe, ako nemas ISO, napravi ga sa media creation toolom. |
#2455 | ||
Postovi: 2,833
Probat ću pa javim rezultat. Hvala. |
#2457 |
Lokacija: Bistra
Postovi: 5,087
Ili pričekaj da izađe Windows 10 November Refresh, instaliraj ga na komp i aktiviraj ključem od sedmice. Ako ti se ne čeka onda evo ti leđit verzija, napravljena od ESD-a sa Windows Update-a: 10586 Pro x64 en-US https://mega.nz/#!rkRRXTiR!yxDKPCEUA...S2FkrKl7b3zlf4
#2459 |
Datum registracije: Apr 2012
Lokacija: Kod kuće.
Postovi: 174
***************** Zadnje izmijenjeno od: tor. 13.11.2015. u 15:18. |
#2460 |
Postovi: 46
Tesko paljenje
Imam problem s kompjuterom na taj nacin da se nekad nece upalit. Znaci pritisnem tipku za paljenje i ventilator skupa sa lampicom se upali na pola sekunde. Zatim je ugasen 5 sekundi i onda se opet upali na pola sekunde. Onda izgasim komp iz napjanja na 10sekundi i ostavim ga tako 20ak minuta i onda se upali. To se dogadja i kad nije paljen cijeli dan ili kad ga ugasim pa ocu ubrzo ponovno upalit. Prvo sam sumnjao na napajanje, ali sam probao pokrenuti napajanje (spajanjem zelene i crne zice) i napajanje je proradilo. tako da mozda ipak nije do njega. Konfiguracija je sljedeca Core i5 750 Asus P7P55D PRO ASUS ATI Radeon HD4890 FSP Group Blue Storm II 500W DDR3 8GB, 2x4GB Nekako sumnjam najvise jos uvijek na napajanje da ne moze isporucit dovoljnu struju na početku ili na matičnu ploču. recimo sada kada je upaljen kompjuter i ako stisnem restart, komp ce se ugasiti i upaliti bez problema. No ukoliko odem shutdown i nakon toga ga idem palit e onda vise neće htjet. već moram ponoviti postupak od početka. Ako netko ima neku ideju, neka slobodno kaze. ![]() |
