#1652 |
Datum registracije: Mar 2011
Postovi: 2,707
1 x Intel Core i7-6700K (4.0GHz, 4 core, 8MB), nema cooler !! 1 x Gigabyte GA-Z170-D3H, s1151, Intel® Z170 Express 1 x DDR4 8GB (1x8GB) Kingston HyperX, 2133MHz,CL14, HX421C14FB/8 1 x Samsung 250GB 850 Series Basic, Kapacitet 250 GB, 2,5" 1 x SCYTHE Ashura SCASR-1000, s. 2011/775/1155/1156/1366/AM2/AM2+/AM 1 x Fractal Design Define S Black, bez napajanja 1 x Napajanje Fractal Edison M 550W, 80PLUS GOLD,modularno, crno 1 x Gigabyte GF GTX970 G1 GAMING, 4GB GDDR5, DVI, DP, GVN970G14GD-00 10.496,89Kn Konfa jako slična prethodnoj, ali s još boljim(i modularnim) napajanjem. |
#1654 |
Datum registracije: Mar 2015
Postovi: 1,254
Mamutarka Evo jedan prijedlog, po mojem ukusu: 1 x PNY GTX 980Ti 6GB GDDR5 XLR8 Gaming, GeForce GTX 980Ti, 384 bit 1 x Procesor Intel Core i5-4460 (3.20GHz,1MB,6MB,84 W,1150) Box 1 x Asrock B85 ANNIVERSARY - Supports 4th Gen & 5th 1 x DDR3 8GB (2x4GB) Kingston, 1866MHz, CL10, HyperX Fury 1 x Napajanje Fortron 600W, Hyper, PPA6003302, 12cm ventilator 1 x OCZ SSD ARC 100 240GB, Kontroler OCZ Barefoot 3 M10 1 x TOSHIBA 1TB, 7200rpm, SATA 6 Gb/s, 32MB, DT01ACA100 1 x Zalman Z3 mid tower case. 192(W)x465(H)x430(D)mm. MB standard Ukupno: 10.539,98Kn besplatno slaganje i dostava! Mislim stvarno ako se ne bavis nekim poslom od kojega zarađujes, davati 3000kn za i7 nema smisla jer ga neces ni priblizno iskorisititi, također ni od klokanja procesora u igrama nema neke dobiti. |
#1656 |
ODUZIMAM VAM RIJEČ
Postovi: 13,355
ma lako za hdd, bio to caviar black iz sadašnjeg kompa ili neki novi ali htio bih skylake ![]() e sad i5 6600k ili i7 6700k je jedino di mogu dvojiti
#1658 |
Postovi: 1,254
Ako netrebas HDD, tj imas WD black mozes njega ostaviti, a sada ici na GTX 980ti + Skylake+SSD, mislim da bi ti to bilo najbolje od svega. Intel Core i5-6500 ASUS Z170-P D3 Cosmo Cool LC-CC-95 - CPU cooler Kingston Technology HyperX FURY 8GB 2133MHz DDR4 Kit of 2 FSP/Fortron Hyper 600 Kingston Technology HyperX FURY SSD 240GB Zalman Z3 Ukupno: 4 846,00kn, UZI bespaltno slaganje i dostava, + imas 3 posto popusta kao clan foruma sa time je to 4700kn. Za ostatak uzmes http://www.adm.hr/product_info.php?products_id=16872 i ispada te 10600kn, ugradis ju sam, to je cas posla, ili se protegnes 350kn ako mozes na ovo http://www.futura-it.hr/katalog/komp...tg1gaming-6gd/ |
#1659 |
ODUZIMAM VAM RIJEČ
Postovi: 13,355
a jeste navalili s tom 9800ti a konfa nije uopce za gaming ![]() možda odigram malo wow, ili neki noviji naslov, primarno se plejka 4 igra za pucačine je komp, a slabo je dobrih na pc
#1660 |
Postovi: 1,254
Iskreno, neznam cemu onda ti uopce dajes tolike nove za komp ako se igras na PS4, dovoljan ti je komp od 5000kn za iducih 5 godina, s time da samo zamjenis grafu svake 2 ako ti je bitno igrati sve na max postavkama. Od tog i7 po tome sta pricas neces imati također nikakve koristi isto kao ni od gtx 980ti za svoje potrebe, osim ako se bavis necim.... |
#1661 |
ODUZIMAM VAM RIJEČ
Postovi: 13,355
plejka je za sport i aute a komp za pucačine mmorpg itd. po računici i5 6600k je svega 800tinjak kn jeftiniji, neznam sad dal uzimat to umjesto i7, a za grafu davat prek 6k kn mi je suludo uvijek bilo..mislim da ce 970 zadovoljit moje potrebe iducih sigurno 5 godina, ak ne zamjenim ju za 2
#1662 |
Postovi: 1,254
Ja bi na tvome mjestu samo ubacio gtx 970 u ovu konfu koju imas i eventualno SSD 240GB, posto je to jos uvijek konfa spremna sve vozit bez problema uz novu grafu. Onda za 2 godine kad ti ta gtx 970 bude preslaba to sve prodaj a uzmi komplet novo racunalo. Sta se tice toga sta ti planiras slagat, ja sam ti vec dao svoj prijedlog kako bi ja. Od tog Skylakea i DDR4 memorije nema nista naspram haswella, samo sta je ogromna razlika u cijeni, jer su maticne skupe ko vrag, a i memorija je skuplja. EDIT: Gore imas i moj prijedlog sa Skylakeom i5 6500 i DDR4 ali nije klokabilan, a nije da bi nesto i dobio sa klokanjem. Sta se tice grafi iducih 5 godina sigurno nebudes zadovoljan ni sa jednom sadasnjom grafom, eventualno 2-3 i to sa titanx/gtx 980ti/r9 fury x, a upitno je i opcenito kakvi ce tada biti standardi i potrebe. Zadnje izmijenjeno od: Sphere. 08.09.2015. u 22:59. |
#1663 |
Terror Absolut!
Datum registracije: May 2014
Lokacija: Earth
Postovi: 802
Aj se malo strpi dok Skylake ploče ne dođu na police u većem broju, pogotovo ovaj H170, B150 i H110 chipset, pa onda uzmi ploču jednog od tih chipseta, a što se tiče ostalih komponenti: Intel Core i5-6500 Cosmo Cool LC-CC-95 CPU Cooler 2x Kingston Technology HyperX FURY 8GB 2133MHz DDR4 OCZ SSD ARC 100 240GB Gigabyte GeForce GTX 970 G1 GAMING - ako baš mora biti nVidia, inače R9 390 koja je u ovom trenu puno bolji izbor Fractal Edison M 650W, 80+ GOLD modular Fractal Define R5 S matičnom bi te izašlo ~9000kn. Procesor za gaming puno i previše u svakom obliku, cooler da ga malo bolje ohladi i stiša, 16GB RAM-a čisto eto, i 8 bi za gaming i većinu rada bilo više nego dovoljno pa tu odluči želiš li uštedjeti 400-tinjak kn, SSD odličan, grafa isto iako bih ja radije R9 390 iz drugog tabora (snažniji raw power, vjerojatno će demolirati GTX970 u DX12), napajanje top class (dobar ulog ako kasnije misliš ići na SLI ili neku masniju grafu), općepoznatno kućište koje praktički nema mana. Sve u svemu - po meni - jedna izbalansirana i vrlo uredna konfa. |
#1665 |
Postovi: 1,254
To je to od Skylakea sta ce bit, uostalom i da recimo dođu bili bi sigurno skuplji 300kn od ovih 6700k/6600k, u tome slucaju bi mogao komotno ici na profi platformu 2011-v3 i7 5820k sa 6 jezgri i prikladnu plocu. |
#1666 | |
Postovi: 2,707
![]() http://www.nabava.net/search.php?tp=0&q=i5-6600K http://www.nabava.net/search.php?tp=0&q=i7-6700K Neće biti nikakvih 6770K/6590K, to je to. |
#1668 |
Datum registracije: Sep 2015
Lokacija: krk
Postovi: 1
zdravo ekipa.. može prjedlog za gaming konfu.. imam 7001kn + https://tpucdn.com/reviews/Phanteks/...mages/luxe.jpg + https://www.asus.com/Motherboards/H97PRO_GAMER/ preferiram nvidiu i intel |
#1670 |
Postovi: 1,254
Preporucio bi ti da uzmes r9 390 umjesto gtx 970 jer je jaca grafa, a dolaskom DX 12 igri jos ce se odraziti od gtx 970. Ovaj model je na finoj akciji Gigabyte R9 390 ako si za samo ju zamjeni sa ovom gtx 970 koju sam ispod stavio, napajanje je dovoljno. Najbolje bi bilo ovako: 1 x Intel® Xeon® Processor E3-1231 v3 (8M Cache, 3.40 GHz) 1 x Patriot SSD Blast 240GB, 7mm, 2.5" Ukupno: 3078,00 kn - GeForce GTX970 iChill, INO-C97V-2SDN-M5DSX ili GIGABYTE Video Card AMD Radeon R9 390 GDDR5 8GB/512bit, 1000MHz/6000MHz, PCI-E 3.0 x16, HDMI, DVI-D, - Crucial Module 8GB, 240-pin DIMM, DDR3 PC3-12800, CL=11, Unbuffered, NON-ECC - XFX 550W Easy rail Bronze, XFX-P1-550S-GREN - Toshiba DT01ACA100 1TB 3.5'' Ukupno: 4.016,16kn u slucaju GTX 970, 3928,65kn u slucaju R9 390 Graficka je jedan od najhladnijih modela sta se tice gtx 970, sta se tice R9 390 super akcija za dobar model sa 3 godine garancije, procesor je isti kao i7 4770, napajanje ima 5 godina garancije, imas 240GB SSD, 1tb HDD po super cijeni, 8GB rama. Zadnje izmijenjeno od: coconut. 11.09.2015. u 07:19. |
#1673 | |
MiningMod
Postovi: 8,715
1 x Gigabyte GF GTX970 G1 GAMING, 4GB GDDR5, DVI, DP 1 x Fortron Hyper M 600W, 80+, modular 1 x Kingston DDR3 1600MHz,C11, 8GB 1 x Seagate HDD, 1TB, 7200rpm, SATA 6, 64M Ukupno: 6994,00 kn |
#1675 |
Datum registracije: Oct 2014
Lokacija: Kutina
Postovi: 7
Pozdrav.. evo brat se sprema za kupnju nove gaming konfe do 9000 kuna (par sto kuna vise-manje, nije bed). Kupuje iskljucivo u Futuri i nakon sto je njima poslao upit, oni su mu poslozili ovu konfu: 1 x INTEL Core i5-4690K (3.50GHz,1MB,6MB,88 W,1150) Box, INTEL HD Graphics 4600 2 x Crucial 8GB DDR3 1600 Mhz (PC3-12800) CL11 1 x GIGABYTE Z97X-GAMING 7 (S1150,DDR3,VGA/HDMI/DVI,USB3.0/USB2.0,RAID,LAN,SATAIII/SATA Express/M.2) ATX Retail 1 x SSD SAM 250GB 850 EVO Basic 1 x Toshiba 2TB,7200rpm, 64MB HDD 1 x Kućište Antec GX505 1 x Fortron Raider S 550W, 80+ SILVER 1 x CPU Hladnjak Raijintek Themis Black, 120mm, PWM 1 x Grafička kartica STRIX-GTX960-DC2OC-2GD5 Šta mjenjati? Ja bih mu preporucio neku gtx970 umjesto ove (kao sto sam sebi prije planirao kupiti). Sta bi mjenjali od ovoga da bi dobio pribliznu cifru? Molio bih i ime proizvođača (ne samo specifikacije) da može lakše posložiti konfu kod narucivanja. Hvala unaprijed |
#1676 |
Postovi: 1,254
dado-brado Ovako uzmi, cak je i gtx 970 i r9 390 preslaba grafa za ovaj buđet, stavio sam r9 fury koja je 20 posto jaca od gtx 980, tako da ces bit duze vrijeme miran. Ovo iz future sta su mu slozili nije dobro balansirano. 1 x VGA Sapphire R9 FURY 4G HBM PCI-E HDMI / TRIPLE DP TRI-X (UEFI), full retail 1 x Procesor Intel Core i5 4460 1 x Asrock Intel 1150 Socket B85 ANNIVERSARY Chipset MB 1 x Desktop Memory Device KINGSTON ValueRAM DDR3 SDRAM Non-ECC (8GB,1600MHz(PC3-12800),Unbuffered) CL11, Retail 1 x Super Flower Golden Green 550W, 80+ Gold 1 x OCZ SSD ARC 100 240GB,R480/W430,75K,S3 1 x Toshiba HDD 1TB,7200rpm, 32MB 1 x Zalman R1 mid tower case Ukupno: 9324,80 kn, Futura, kako si trazio. |
#1679 |
Mutant Year Zero
Postovi: 509
