Staro 28.07.2015., 21:34   #391
hprodigy
Datum registracije: Sep 2010
Lokacija: split
Postovi: 9
pomoc pri oc.q9300
Pozdrav,
Imam problem pri o.c-u svog procesora
konfa:
Cx500m 500w corsair
intel quad q9300 + zalamn cnps5x cooling
gigabayte GA-EP43-DS3
mem. 8gb OCZ platinum DDR2 1066 OCZ2P10664GK
Hdd samsung 500gb
Ati VX hd 4770 512 ddr5 ( planiram uzet MSI r7 370 2gb ili novu gtx950 kad izađe)
Windows 8.1 (murphy78)
Namjestio sam u biosu sljedece postavke po jednoj stranici sto sam nasao , imamo slicnu konfu pa sam probao:
http://forums.tweaktown.com/gigabyte...ight=p43+q9300 #post 8
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster -------------- : [Auto]
CPU Clock Ratio ---------------------- : [7]
Fine CPU Clock Ratio ----------------- : [+0.5]
CPU Frequency ---------------------: 2.8GHz (374x7.5)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control --------------- : [Enabled]
CPU Host Frequency (Mhz) --------------: [374]
PCI Express Frequency (Mhz) ---------- : [100]
C.I.A.2 ------------------------------ : [Disabled]
Advanced Clock Control ------- [Press Enter]
CPU Clock Drive ---------------------- : [800] ((((bilo je na 700))))
PCI Express Clock Drive -------------- : [800] ((((bilo je na 700))))
CPU Clock Skew (ps) ------------------ : [0ps]
MCH Clock Skew (ps) ------------------ : [0ps]
DRAM Performance Control
Performance Enhance ------------------- : [Standard]
(G)MCH Frequency Latch ---------------- : [Auto]
System Memory Multiplier -------------- : [2.66D]
Memory Frequency (Mhz) ---------------- : 995
DRAM Timing Selectable ---------------- : [Manual]
Standard Timing Control
CAS Latency Time -------- ?? ---------- : [5]
tRCD ------------------- ?? ---------- : [5]
tRP --------------------- ?? ---------- : [5]
tRAS ------------------- ?? ---------- : [15] (((((( na modulima pise 5-5-5-18 pa neznam dali ovo treba zamjeniti sa 18 ))))))
Advanced Timing Control
tRRD ------------------- ?? ---------- : [Auto]
tWTR ------------------- ?? ---------- : [Auto]
tWR --------------------- ?? ---------- : [Auto]
tRFC ------------------- ?? ---------- : [Auto]
tRTP ------------------- ?? ---------- : [Auto]
Command Rate (CMD) -------------------- : [Auto]
Driving Strength Profiles
Driving Strength --------- : 1066 << both channels
Channel A
Static tRead Value --------------------- : [9-7] (((((( pise 8 pa sam ostavio )))))))
Channel B
Motherboard Voltage Control
CPU
Voltage Types------------ Normal -------- Current -----
CPU Vcore --------------- ?.????? ---- : default+ as needed, up to 1.3625
CPU Termination --------- 1.200V ----- : [1.2]
CPU Reference ----------- 0.760V ----- : [Auto]
MCH/ICH
MCH Core ---------------- 1.100V ------- : [1.2]
DRAM
DRAM Voltage ------------ 1.800V ------- : [2.2]
Advanced BIOS Features
Limit CPUID Max. to 3 ------------------ : [Disabled]
No-Execute Memory Protect -------------- : [Enabled]
CPU Enhanced Halt (C1E) ---------------- : [Disabled]
C2/C2E State Support ------------------- : [Disabled]
x C4/C4E State Support ----------------- : [Disabled]
CPU Thermal Monitor 2 (TM2) ------------ : [Enabled]
CPU EIST Function --------------------- : [Disabled]
Virtualization Technology -------------- : [Disabled]
Integrated Peripherals
Legacy USB Storage Detect ------------- : [Disabled]
Kad upalim, nakon slike biosa, pojavi se crni ekran sa pustim brojkama kao inace i prije dizanja win
pise Verifying DMU Pool Data......
Beging to update Bios to.......
Bios Auto-Recovering...............................................................................
I dignu se windowsi ali u biosu je sve postavljeno na kao prije.. znaci oc nije uspio....
Sad do cega je nezam ...
Nije mi jasno dali ovo sto je u channel B timming setting nije kao u A sve na AUTO nego je postavljeno ovako:
http://postimg.org/image/cjwj9oqnr/
i ovo nisam mjenajo ostavio sam kako je prije bilo, nisam ni gledao kako je:
..... jeli to potrebno mijenjati?
hprodigy je offline   Reply With Quote
Staro 18.08.2015., 11:59   #392
smak420
smak420's Avatar
Datum registracije: Jan 2015
Lokacija: mars
Postovi: 104
e ovako, problems..
Ploča: Gigabyte EP35-DS3R v: 2.0, bios f13
Procesor: Q9300
Rami: 3x corsair TwinX ddr2 1.1 sa micronima 2gb, Kingmax 1gb 800 sa elpidom...prolaze memtest na 4-4-4-12
Napajanje LC power GP6550 2.0
javlja greške u OCCT medium, large database set te u PRIME95 blend testu.
bios:
400 fsb
vcore 1.18 - 1.35 probao
MCH: +1 - +2 probao
FSB voltage: ne diram
DRAM: +0.3
c1e i eist1 - uključeno isključeno ista stvar
javlja grešku prime: rounding was 0.5 expected less than 0.4, OCCT zakrešti grešku nakon 10 ak minuta
imam vent koji puše preko northbridga i meme
eh...cooler je šugavi artic alpine 11, ali temp ne prelazi 80 u small FTT i namjestio sam da dopušta do 85
prije mi je radilo bez problema na tim postavkama...
Ispravite me ako griješim, ali medium i large database više forsiraju memu i NB?
pošto je p35 chipset, nemogu se igrat sa ostalim postavkama i voltažama
smak420 je offline   Reply With Quote
Staro 18.08.2015., 14:17   #393
FSB voltage +0.1
CPU Voltage neidi preko 1.37V jer nema smisla.
DRAM ti je na 2.1V ako se ne varam (1.8V je default).
A ako su tu Microni, nebi se čudio da su već lagano u banani. Moj bet je da je memorija počela kenjat pogotovo ako je na samo 800MHz. Probaj neki drugi RAM ili tesitiraj samo sa Kingmaxom na 1.9V. Ako ti na kingmaxu bude OK, znači da je to. A tako probaj isto i drugi RAM ako na kingmaxu baci error.
Ploča ne bi trebala bit. Koliko god je Điđibajt mušićav i to što sam spalio hrpu P35 DS3L ploča, nisu se previše glupirale. Samo su crkle tako da probaj sa mermerijom to. Pa javi.
Staro 18.08.2015., 15:01   #394
ThePornstar
ThePornstar's Avatar
Postovi: 4,399
Autor smak420 Pregled postova
Možeš, ali ne na Điđinoj P35 ploči
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
Battery: 57 Wh internal
ROM: Android 9
ThePornstar je online   Reply With Quote
Staro 19.08.2015., 10:11   #395
smak420
smak420's Avatar
Lokacija: mars
Postovi: 104
FSB voltage +0.1
a memtest 5x prolaze jbg....probam tnx
teška srca priznajem, ali SVI ste bili u pravu. Vrijeme je za novu platformu. Koliko god ja sebe lagao da mi netreba ništa bolje, i imam više nego zadovoljavajuće preformanse od svega ovog...novo je novo.
izašao ddr4 a ja se još ebem oko ddr2 lol.
Zadnje izmijenjeno od: smak420. 19.08.2015. u 10:50.
Staro 19.08.2015., 16:04   #396
Nije stvar u tome što tebe zadovoljava ili ne. Stvar je u tome što ta starudija odumire i krepava i što nema poštene zamjenske stvari, a da ne košta koliko nova stvar koja je 5x bolja i ima garanciju 3 godine. Samo to
Ulaganje u s775 mašinu je besmisleno. 8 godina star socket i sad tu ulagati u DDR3 ploče i nekakve quadove je krajnja glupost, osim ako nemaš par somova onako za obrisat cipele
Lijepo neku s1150 ploču sa B ili Z čipsetom, 8GB DDR3 i kakav polovni CPU Pentium ili i3 i bog te veseli. Sadašnji Pentiumi i i3 u svemu prepišaju te Quadove iako ovi imaju te dodatne fizičke dvije jezgre. Pusti mitomaniju njuškalo švercera o tome kako Q9550 na 4GHz skoro pa jede i7 i tako to.
Staro 19.08.2015., 20:09   #397
Amepshi
Amepshi's Avatar
Lokacija: Bjelovar
Postovi: 739
Ulaganje u s775 mašinu je besmisleno. 8 godina star socket...
775 se zadržao neprirodno dugo kod nas. Da, bio je zakon, da mogao je napraviti čuda, ali nova je tehnologija toliko otišla naprijed.
Kada usporedim kako je jednostavno OC-ati Sandy i Ivy bridgeve u odnosu na 775 quadove, stvarno ne vidim smisla maltretirati se sa toliko starom tehnologijom.
Staro 19.08.2015., 20:22   #398
ThePornstar
Postovi: 4,399
Autor Amepshi Pregled postova
Što je da je, na 775 je bio gušt poštimavati svaku vrijednost i tražiti maksimum uz stabilnost. Još su i prvi "iX" procesori bili gušt, ali ovo dalje je bevzeze, pogotovo sa "k" glupostima. Bar meni
Da postoji nešto novije, a da se može poštimavati kao legendarni 775 - uzimam odmah
CPU: Intel i5 8250u
RAM: 16 GB
VGA: Intel UHD 620
OS: Win 10 Pro x64
ROM: Android 9
Staro 19.08.2015., 21:33   #399
Zadržao se dugo jer ga je i Intel gajio dugo. AMD odgovor nije imao, a prodaja je išla kao mutava.
Daleko od toga, bio je odličan socket, pogotovo kad je došao P45 i 45nm procesori. Moj ćaća gazi P5Q-E i Xeona E3110 sa 6GB RAMa. Kaj njemu treba (Autocad, Office, multimedia, net) i više nego super. Ali da mu rikne ploča... momentalno sve novo ide. Nema teorije da tražim s775 ploču i okidam 400+ kuna za nju.
Tako i svi koji imaju Quadove s775. Jasno da im se ne isplati prelazak nekamo ako nisu HC gameri ili neki uracpalac. No ako tako rikne ploča ili počne zebavat, lagano se okrećeš novim igračkama.
Staro 19.08.2015., 22:28   #400
smak420
smak420's Avatar
Lokacija: mars
Postovi: 104
Da...eto ja sam ipak imao dosta srece sa time...necu da spammam temu, al ajde..moja kratka PC životna prica hehe
jos do prije 2 godine, imao sam dual core e2160 i neku asus p5b-vd...clock sa 1,8 na 2.0
Malo googlao sto bi meni trebalo za zaigrat neke stare igre, pogledam po njuškalu i opa...
DFI x38 t2rb, 4 x 1gb ddr2 i q9300 za 400 kn. Naravno da sam uzeo.
Onda pljunuo još toliko za corsair TX650 i još toliko za GTX 260. SSD od 40 giga dobio, a 2 harda od 160 gb imao Pa dobim Xeona iz servera raspalog u frendovoj firmi...
za 1200 kn ja sam odjednom složio kantu koja je na mojoj plazmi 720p ganjala svaki k.. od igrice na ulta bez frke. Nenadjebiv osječaj
...dok ne počnu krepavat stvari....hehe
eto posralo me da dobijem i 4 x 2gb očito neispravnih precjenjenih twinX rama, pa frend kupuje novu kantu pa udjeli đabe još Gigabyte ploču..
ne radim, živim od invalidnine i sjeb mi je davati 3-4k koje nemam btw na novo i bolje..
al jbg, bumo morali
edit: a istina...nekako imam osjecaj ispod i5 4460 da mi i nije neki upgarade...jer kad i ako dajem tu lovu za novo, želim da ipak imam drastičan porast preformansi.
i da brko druže, imaš pivu
jedna 2gb pločica zaebavala....sad prolazi large data set u OCCT i blend test
hvala
Zadnje izmijenjeno od: smak420. 19.08.2015. u 22:46.
Staro 25.09.2015., 14:28   #401
smak420
smak420's Avatar
Lokacija: mars
Postovi: 104
nikad điđa više u moj pc!
ASUS p5q pro-fenomenalna ploča koju sam našao za lol..50 kn
Q9300 radi na 427 FSB za sada
2x2 gb ddr2 twinX 800 cl4
CPU Multiplier - 7.5x
FSB - 427MHz
PCIE 100MHz
FSB Strap to North Bridge AUTO
Dram Frequency - DDR2-854
DRAM Timing Control- 4-4-4-12 (ostalo auto)
Dram Static Read Control AUTO
Dram Read Training DISABLED
MEM OC Charger - AUTO
AI Clock Twister - AUTO
AI Transcation Booster AUTO
CPU Voltage(vCore) - 1.19375
CPU GTL reference AUTO
CPU PLL Voltage 1.52V
FSB Termination Voltage AUTO
Dram Voltage - 2.1
North Bridge Voltage - AUTO
South Bridge Voltage - AUTO
PCIE SATA Voltage - AUTO
Load-Line Calibration ENABLED
CPU Spread Spectrum - DISABLED
PCIE Spread Spectrum DISABLED
CPU Clock Skew AUTO
North Bridge Clock Skew AUTO
CPU Margin Enhancement - Optimized
C1E Support ENABLED
Intel Virtualization Tech DISABLED
CPU TM Function ENABLED
Memory Hole - DISABLED
CPU Core Temps at IDLE-
C0 - 47C
C1 - 40C
C2 - 40C
C3 - 41C
CPU Core Temp na OCCT small data set
C0 - 69C
C1 - 64C
C2 - 63C
C3 - 63C
i to sa šugavim coolerom ARTIC Alpine 11 plus.
Sad na redu kasapljenje ploče te stavljanje x5460 e0 i scythe mugen 2
Nazalost krepali mi rami tako da imam 2x2 gb corsair twinX 800 cl4, al našao sam za 120 kn adata 2x2 400 cl5.
nadam se 4.00ghz te 4-4-4-12 latencijama
Živio 775 socket!
P.S. prije nego me napadnete da kupujem starudiju, ovo je free stuff upgarade
te ako netko ima bios p5q pro za xeona isproban...
Zadnje izmijenjeno od: smak420. 25.09.2015. u 14:38.
Staro 25.09.2015., 14:48   #402
Barem je lako moddati BIOS od P5Q ploča. MMTOOL i samo u CPU PATCH ubaciš kodove i amen vozi.
Staro 25.09.2015., 14:58   #403
smak420
smak420's Avatar
Lokacija: mars
Postovi: 104
Je, vec gotovo
ruke su mirne, ne tresu se pa idem odrezat socket. Navecer javim rezultate testiranja i OC X5460 e0
dodane jos 2x1 gb...vec je testirana sa memtestom i occt large setom, pa nebi trebalo bit problema na 425 fsb
Edit:
konacno mi rade svi keksi skupih corsairovih twinX 8gb rama \o/, skoro sam ih bacio
fora je bila u asusovom ai tweakeru stavit zadnju postavku dolje umjesto OPTIMIZED u PREFORMANCE MOD.
Memtest 10 pass prolaze i blend test 5h.
Zadnje izmijenjeno od: smak420. 22.10.2015. u 09:37. Razlog: otkrio toplu vodu
Staro 22.10.2015., 19:45   #404
Talaba
Talaba's Avatar
Datum registracije: Jul 2014
Lokacija: Serbija
Postovi: 108
E ja sam imao taj procesor. Držao sam ga na 3.3Ghz da bi mi memorija radila na oko 800Mhz ako se ne varam. Ovo dole možeš da zadržiš a ostalo ploča mi je bila DFI a na gigabajt ne bih umeo da se snađem.
Talaba je offline   Reply With Quote
Staro 24.10.2015., 16:46   #405
Astral
Postovi: 2,523
pomoc sa q9450
Bok, konfa pod moj komp. Cilj je 3.6ghz za sad. Po dosadasnjim indikacijama trebalo bi ici sa 1.32v cca. No zeza me malo ploca. Sad testiram nju prvo da stabiliziram 450mhz fsb. Izgleda da bude ok sa ovim postavkama:
vtt 1.26v
Nb 1.22v
Gtlref auto
cpu pll 1.56v (tek tolko, ne znam jel icem pomaze)
sb auto
pcie auto
Dakle pitanje je da li za stabilizaciju ploce dovoljno dizat vtt i nb voltazu i kad je to stabilno onda dignem proc. Da li je jos koja voltaza bitna za stabilizaciju ploce?
Kolko sam skuzio ako stabiliziram plocu i onda procesor sa odredenom voltazom, pomogu gtlref mogu probat dobit vecu stabilnost procesora sa manjom voltazom. Ali ako sam zadovoljan sa voltazom (npr da nije preko 1.35v) onda ne trebam dirat gtlref uopce?
Pokusavam ga izbjec jer nisam bas upoznat sa tom opcijom.
Jel mi pristup ok ili da mijenjam nesto?
Temp su ok. Ispod 70c pod full load. Prime95
Astral je offline   Reply With Quote
Staro 28.10.2015., 23:42   #406
animATrIx
animATrIx's Avatar
Lokacija: Vukovar-Osijek
Postovi: 491
Pozz!
Imam i ja par pitanja, proljetos sam uzeo X5460 E0, MSI P45 Neo3 plocu i 4x2gb kingston 800 rama.
problem mi se javlja da nakon nekog vremena sto je cpu radio bez problema na 4.2ghz, sa malim podizanjem napona, s vremenom vise nije htio raditi na tom taktu i sad na jedvite jade ga odrzavam na 3.8ghz, fsb400, i to kad sam skontao overclock preko jumpera na ploci.
nikad nisam morao podizati napone ramova niti nb-a, a sada i kad probam bilo sta od navedenoga, ne zeli raditi vislje od tih 400mhz na fsb-u.
mogu reci da sam i zadovoljan sada kakvo je stanje, 3.8 je dosta dobar takt s obzirom da sve radi na stock naponima i ne grije se... al dok je radio na nesto visljem taktu osjetilo se da je jos malo "aktivniji"
edit: i da, ploca malo buca u biosu, tipa C1 i EIST su mi iskljuceni i mnozitelj je stavljen na 9.5x ali bez obzira na to u windowsima mi frekvencija ipak seta po mnozitelju od 6 do 9.5... isto tako i napon..
Zadnje izmijenjeno od: animATrIx. 29.10.2015. u 00:04.
animATrIx je offline   Reply With Quote
Staro 02.11.2015., 18:32   #407
smak420
smak420's Avatar
Lokacija: mars
Postovi: 104
Autor Astral Pregled postova
vtt 1.26v
Nb 1.22v
Gtlref auto
sb auto
pcie auto
Ja imam slicnu konfu, doduse p5q pro sa ddr2 i q9300 te X5460.
stabilizirao sam na 440 FSB sa cpu PLL na 1.60V ,
mislim da se za 450 fsb trebaš igrat sa GLT x0.63 ili x0.65, moj savjet da pričekaš ili pitaš druga Brku (član foruma), znat ce ti konkterno pomoci
i nekako mi je velik taj 1.32V vcore za tu frekfrenciju, meni q9300 radi 3300 na cca 1.27
Staro 02.11.2015., 21:14   #408
Astral
Postovi: 2,523
Tnx na odgovoru pa evo i update.
Zasad 1.32v, da, cini se malo puno s obzirom da je 1.26v dovoljno za 3.4ghz, ali tako to ide...
Mislim da bi mogo spustit voltazu kad bi znao odigrat dobro sa gtlref i cpu pll.
Uglavnom stabiliziro sam plocu na 450mhz, ali trebo sam:
VTT: 1.32v
vNB: 1.32v
Stabilan je i proc na 3.6ghz sa spomenutih 1.32v i 1.56v PLL.
Dal je to puno volti za plocu? Meni se cini da je s obzirom da je za 437mhz (4.5ghz) dvoljno 1.22v (vtt i nb), ali nejde sa manje. No ipak mislim da je u granicama za 24/7 koristenje.
Kako dalje? Brko pomagaj
Staro 02.11.2015., 21:22   #409
Sorry, na tapatalku sam pa ne vidim koja je ploča. Ako je neka iole bolja, to su skroz OK naponi.
Staro 02.11.2015., 21:30   #410
Astral
Postovi: 2,523
Asus P5Q3 (obicna, nije deluxe). Kad stignes ako mozes malo pojasnit gtlref, trenutno mi je na auto. I da li bi trebo povecat PLL? Mozda sa vecim PLL i sa pogodjenim gtlref mogu smanjit voltazu za procesor? Uglavno, htio bi to jos malo fine tunat.
Staro 02.11.2015., 21:33   #411
Ko će se sad toga sjetit ... Ja P5Q-E nemam od 08/2010, dakle preko 5 godina. Ako nađem notepad sa tim postavkama, javim.
Nemrem se napamet sjetit tih svih parametara. Ali vidi malo po forumu u starim temama, sve je tu. Siguran sam da piše o tome...
Staro 02.11.2015., 23:23   #412
Astral
Postovi: 2,523
Svejedno, ako nades javi plz. Hvala
Staro 08.11.2015., 09:41   #413
smak420
smak420's Avatar
Lokacija: mars
Postovi: 104
evo Q9550 e0 na 3.7 sa 1.306V, kasnije smanjio na 1.275V u biosu i odvrtio jos 1 sat small data set
http://valid.x86.fr/hlci70
BIOS postavke
uff glomazne slike
Zadnje izmijenjeno od: smak420. 08.11.2015. u 16:53.
Staro 08.11.2015., 21:47   #414
Astral
Postovi: 2,523
Znaci gtlref nisi ni taknul. Heh. Fini OC btw, dobar chip imas.
Staro 08.11.2015., 22:01   #415
smak420
smak420's Avatar
Lokacija: mars
Postovi: 104
Da memorija me koči, trenutno su 2x2gb corsair TwinX i 2gb kingston cl6, i jedan kingmax od 1gb, sve skupa 7gb
Corsair mi šalje nove dominatore jer ovi imaju life time warranty, pa sad cekam 4 x 2gb dominatore 10000 CL5, tek onda cu moci cmmon preformance level stavit na 10 cca i probat gurat 471 fsb za 4.0, proc očito može
Staro 08.11.2015., 22:25   #416
Ako me pamćenje služi, gtlref je za neki jači OC sa vodenim ili LN2 hlađenjem. Na ovim taktovima do i oko 4 GHz je potpuno nebitno. 0.63 je bila neka brojka ako se ne varam.
Ali 3.7 na 1.3V... nije to baš neki dobar čip. To da je 4.0 na <1.3V onda da. Ovako je to osrednje dobar čip.
Evo u mog čaće E5450 (Q9650) ide 1.15V 3.6 GHz a C0 je.
Staro 08.11.2015., 22:36   #417
smak420
smak420's Avatar
Lokacija: mars
Postovi: 104
nisam ni probavao niže jer me memorija koči, al posta normalno na 4.0 i vrti prime, u biosu je na 1.275...tako posto znam sto mi greske baca, vcore nije
kad stigne onda cu fine tuning neki bacat, a jos si razmišljam jel mi se isplati kasapit plocu radi ovog slanp x5460, jer plan je mrknut ovo za dobru lovu iza nove
Staro 08.11.2015., 23:41   #418
Nemoj kasapit ploču nego malo poturpijaj CPU sa šmirglom ili turpijom. Proc nećeš skenjat ali pinove na ploči bi mogao ako ti pobjegne ruka malo.
Staro 09.11.2015., 09:47   #419
Astral
Postovi: 2,523
Moj je na 3.6ghz sa 1.35v, sto je u odnosu na njegov chip, zesci uzas Nikad nemam srece sa tim stvarima. Promjenio 5 CPUa i ni jedan nije bio nest extra. jbg
Mislim da se vracam na 3.4ghz i 1.26v. Eventualno 3.5ghz sa 1.3v. Kupio sam novi cooler bezveze. 3.4/3.5 sam mogo i sa freezerom. Doduse ovaj LC drzi bar 10c u prosjeku manje temp.
Staro 09.11.2015., 10:04   #420
smak420
smak420's Avatar
Lokacija: mars
Postovi: 104
A vidjet cemo sta ce se dobit sa ovim Xeonom osim veceg multija. Ipak je tdp 120w naprema 95w, tako da sam skeptičan prema nekim manjim voltažama. Kako sada stvari stoje, ja zadovoljan. Ipak se osjeti tih parsto mhz
