Staro 11.08.2015., 12:17   #1801
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
Zanimljivo, i kod mene, 9800XT, počela bacat artefakte...to je jedini komad hatdvera koji mi je crkao, ako zanemarim miševe i tipkovnice
I meni Sapphire X800Pro Uz HP laptop sa ATi integrirkom, jedino sto mi je crklo, od mog hardvera
Staro 11.08.2015., 14:30   #1802
Brain32
Brain32's Avatar
Postovi: 498
E da znači nisam jedini, onak nevjerovatno znao sam nailazit kod ekipe na HIS 9600XT klasikanere kojima je malterne nogomet igran pa su radile, ja sam imao 9550XT koju sam rastegnuo ko Elizabeta Gojan gaće brijem da ta i dan danas radi, ovo đubre mučko HD4850 bila mi je najjača grafulja koju sam do tada imao, mazio i pazio, stavio joj Accelera da joj ne bude vruće, nisam ju OC niti 1Mhz i đubre rikne mjesec i pol dana nakon isteka gare...
Brain32 je offline   Reply With Quote
Staro 11.08.2015., 15:02   #1803
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
I da nadodam malo ulja na vatru o superiornom sapphireu
Article posted on May 10th 2013:
Average Failure rates:
- Gainward 1,27% (vs 2,05% before)
- PNY 1,32% (vs 1,56% before)
- Gigabyte 1,54% (vs 1,82% before)
- ASUS 1,69% (vs 1,53%before)
- MSI 1,81% (vs 1,69% before)
- Sapphire 3,51% (vs 1,32% before)
The expression the "first will be the last" holds true in this case compared to the previous year. Gainward gets the lead, with Sapphire in an obvious last position due mostly in part to their 7870 models, which when removed from the equation reduces Sapphire's failure rate to 2.06%.
Here are the models that had return rates higher than 5%:
-15,76% Sapphire Radeon HD 7870 OC Edition 2 GB
- 14,29% Sapphire Radeon HD 7970 OC Edition 3 GB
- 11,88% Sapphire Radeon HD 6770 1 GB
- 11,82% Sapphire Radeon HD 7870 GHz Edition 2 GB
- 7,07% ASUS ENGT520 SL/DI/1GD3/V2(LP)
- 6,98% ASUS GTX680-DC2O-2GD5 2 GB
- 5,80% Sapphire Radeon HD 7970 3 GB
- 5,32% Gigabyte GeForce GTX 560 Ti OC 1024 MB
Other than the 7870, we see that two other Sapphire models surpassed the 10% mark, of which one 7970 (the 11197-01) and one 6770 (the 11189-10).
Znači da nema sapphirea amd-a na listi pojedinačnih gpu nebi bio barem na prva 3 mjesta
Mada vidljivo je da se u godinu dana situacija može okrenuti i za više nego duplo (znači ovisi od serije, ili čak batcha)
Zadnje izmijenjeno od: Manuel Calavera. 11.08.2015. u 15:10.
Staro 11.08.2015., 15:09   #1804
SaleFFS
Varilnik
SaleFFS's Avatar
Postovi: 1,648
A i većinom ovisi i koliko je prodano pojedinih modela. Normalno da će najprodavaniji imati i najveći postotak kvarova ili obrnuto. Samo te informacije koliko je koje marke prodano nije u ovoj listi postotaka kvarova.
Moje iskustvo je da sam imao sve i svašta u proteklih 15+ godina i mogu reći da mi je jedina krepala VTX 5670 u garantnome roku. U zadnje vrijeme imam samo XFX od 4850 pa na dalje i sve rade uredno.
SaleFFS je online   Reply With Quote
Staro 11.08.2015., 15:42   #1805
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Autor SaleFFS Pregled postova
Zbilja? Od kada važi takva matematika?
Staro 11.08.2015., 15:46   #1806
SaleFFS
Varilnik
SaleFFS's Avatar
Postovi: 1,648
O čemu ti? Primjer, ako je prodano 500.000 Saphhire kartica istog čipa i 100.000 Gigabyte kartica također istog čipa u nekom vremenskog razdoblju, hoćeš reći da je računica ista za broj krepanih kartica u određenom postotku?
Staro 11.08.2015., 15:50   #1807
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Hoću reći da ne znaš matematiku. Tužno, ali eto
Staro 11.08.2015., 15:53   #1808
SaleFFS
Varilnik
SaleFFS's Avatar
Postovi: 1,648
Kužim što hoćeš reći uvijek će biti isti postotak, očito sam se krivo izrazio ali mislim da kužiš što sam htio reći no eto umjesto da me ispraviš ti pametuješ
Staro 11.08.2015., 15:55   #1809
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Pa ispravljam te. U tvom primjeru 5000 Sapphire i 1000 Gigabyte kartica će značiti isti postotak kvara
Staro 11.08.2015., 15:59   #1810
SaleFFS
Varilnik
SaleFFS's Avatar
Postovi: 1,648
Ma moja greška, kada brzam onda se i krivo izrazim
Staro 11.08.2015., 16:09   #1811
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Sapphireu je izgleda presudila HD 7xxx serija kartica (konkretno 7870 čak 2 puta za njihove dvije 7870 verzije)
Pomelo mi sig -.-
Staro 11.08.2015., 16:37   #1812
Manuel Calavera
Postovi: 14,584
Što je zanimljivo te HD7870 su im bili super cooleri, a najjeftinije gpu. Bolje je to bilo od ovih novih malih dual-x. Samo eto izgleda 2013 velik return rate, osobno nisam čuo da nešto posebno krepavaju, ali tko sam ja, statistika je neumoljiva. BTW odnosi se samo za francusko tržište, ali je opet veće i relevantnije od našeg
Staro 11.08.2015., 17:13   #1813
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Sad ste me bacili u bad, čekam svaki dan da mi crkne Nitro
Staro 11.08.2015., 17:42   #1814
Wizzard
Wizzard's Avatar
Postovi: 493
Činjenica je da je Sapphire najveći amd-ov partner i naravno da ima najveći postotak fail čipova ali to ništa ne umanjuje Sapphireovu kvalitetu..Imao sam dosta njihovih kartica u rukama i od svih koje su riknule to je jedna 4870 sa referetnim kulerom..na njoj propucala mema nakon 2,5godine i druga ustvari nije riknula nego je jedan vent otkazao poslušnost..7950 dual-x (imao sam ju baš ja) poznata serija gdje je jedan vent otkazivao poslušnost ..tak da ono nebih se posebno dvumio između karata prilikom kupovine ..još samo da dignu garu gore kao recimo asus ili msi...
CPU: Amd Ryzen 5 9600x cooled by Ac Freezer 36 Co
MBO: Gigabyte x870 Gaming X Wifi 7
RAM: 2x16gb ddr5 Kingston Fury Beast Rgb Expo 6000mt
VGA: ASRock Intel Arc B580 Challenger OC 12Gb
HDD: Nvme Kingston KC 3000 1TB+Cruical SSD BX500 1TB+1000Gb WD10EZEX-22MFCA0
PSU: SeaSonic G-Series (Gold) Modular 550 W
Case: Endorfy ARX 700 ARGB
Mause: Logitech G403 Hero
Monitor: Asus Tuf Gaming VG249 24"
OS: Win 10 X64 Pro
Wizzard je offline   Reply With Quote
Staro 11.08.2015., 17:54   #1815
Manuel Calavera
Postovi: 14,584
A otkud ti to da je nitro loš? Nit je isti cooler, nit je ista serija, nit ima kakvog feedbecka za tako nove stvari
Staro 11.08.2015., 18:01   #1816
darkydark
N0teb00k n00b
darkydark's Avatar
Lokacija: Zagreb/Koprivnica
Postovi: 2,105
Mene zanima kolko su ljudi clockali te 7870 grafe, jer akbse dobro sjecam svi su ih do zla boga dizali, ja sam svoju 7850 drzao na 1150 kolko je isla bez dizanja napona, kolega drzao 7870 na 1200 i nabio joj volti i volti unutra :-)
1TB A2000, 2TB KC3000
Linđa
Truenas Scale
Staro 11.08.2015., 18:05   #1817
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Autor Wizzard Pregled postova
I ti se krivo izražavaš?
Postotak NIJE ISTO što i apsolutni broj kvarova
Čak dapače, kao najveći njihov partner očekivao bi da dobijaju najkvalitetnije čipove,
te da se najviše i trude podržati AMD brand kvalitetom
Staro 11.08.2015., 18:08   #1818
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
Autor darkydark Pregled postova
Offtopic, ali da replyam na pitanje.
Kakvih 'volti i volti'? To je neki očajan primjerak onda bio od grafe.
Ja sam imao msi-evu tf3 oc model, stock je bilo 1050, bez diranja u išta, samo slider u afterburneru na 1200 i vozi.
Staro 11.08.2015., 19:15   #1819
Wizzard
Wizzard's Avatar
Postovi: 493
Ma da na to sam mislio..vrućine vjerovatno djeluju na mozak.. ma kako god i dalje mislim da je sapphire odličan proizvođač grafičkih karti..
OS: Win 10 X64 Pro
Staro 11.08.2015., 20:36   #1820
Hawker
Datum registracije: Nov 2014
Postovi: 1,972
Moja giga 7850 ne moze preko 1050.
Hawker je offline   Reply With Quote
Staro 11.08.2015., 21:15   #1821
Drvoje
Drvoje's Avatar
Postovi: 4,037
On računa tj. moli se da to bude dan prije isteka gare - razbojnik
Nek zaključaju voltažu, pa su veći dio krkanijade riješili, ovi manji dio naprednih krkana će ionako FLASHAT
BTW Prošlo je zlatno doba rudarenja GPU-om, pa im se možda failure rate smanji
Pomelo mi sig -.-
Staro 11.08.2015., 23:04   #1822
Sphere
Datum registracije: Mar 2015
Postovi: 1,254
Ici cu sutra ili preksutra u kupnju nove GPU, pa me zanima koji model r9 390 da uzmem, koji ima najmanje mušica i potencijalnih problema, posto su nove grafe pa se jos nisam previse informirao.
Ja sam pikirao na MSI r9 390 gaming i Gigabyte r9 390 G1 Gaming. Cijena do nekih 3100kn, drugi modeli me ne zanimaju a i grafe preko 30cm mi ne stanu u kuciste.
Zanima me i jesu li bolje klokerke od gtx 970, ja imam XFX 550w napajanje sa stock i5 4670k, pa se nebi igrao sa OC-anjem zbog slabog napajanja, ali njega cu vjerojatno mijenjati kroz 2-3 mjeseca, pa cu odma i uzeti neki High end hladnjak za proc da i njega nafrljim, vrijeme mu je
Zadnje izmijenjeno od: Sphere. 11.08.2015. u 23:09.
Sphere je offline   Reply With Quote
Staro 11.08.2015., 23:33   #1823
draksa
Postovi: 333
Mislim da ce ti bit dosta to napajanje za OC CPUa. Ja dok sam uzimao 390 sam trazio MSIevu ali nisu imali tada u ADMu pa sam uzeo Asusovu. Neces pogrijesit ni sa jednom od te 2
draksa je offline   Reply With Quote
Staro 11.08.2015., 23:49   #1824
Sphere
Postovi: 1,254
Mislim da cu i ici na kraju po tu MSI r9 390 u ADM.hr, do sada sam isto imao MSI model gtx 760 i sve 5 sa tim vendorom, dat cu im svoje povjerenje opet
Staro 11.08.2015., 23:53   #1825
Manuel Calavera
Postovi: 14,584
Taj msi je brutalan cooler. Imaš review iste na jay2cents
Staro 12.08.2015., 00:01   #1826
Sphere
Postovi: 1,254
Gledao sam, nije samo sta dobro hladi, nego mi i jebeno izgleda grafa, bas se vidi koliko je radijator glomazniji od gtx 970 modela, a i dolazi sa backplateom koji ima ljepo iscrtanog zmaja i ima svijetleci logo na hladnjaku
Staro 12.08.2015., 00:25   #1827
Manuel Calavera
Postovi: 14,584
i aktivno hladi vrm
Staro 12.08.2015., 06:15   #1828
Garro
Postovi: 2,378
MSI 390X ima neku nebuloznu potrošnju struje, ne znam da li 390 model pati od istog problema: http://www.techpowerup.com/mobile/re...Gaming/28.html . Također, MSI se nije proslavio sa pouzdanošću odnosno stavljanjem jeftinih ventova na TwinFrozr hladnjake (post od Romano.Cule: http://forum.pcekspert.com/showpost....postcount=1573 ).
Osobno nemam loših iskustava sa MSI-jem, ali eto...
Staro 12.08.2015., 08:00   #1829
Sphere
Postovi: 1,254
Citao sam na par stranica o toj potrosnji, na nekima je visoka, na nekima normalna, neznam sta da mislim na kraju, vjerojatno je to samo sa r9 390x modelima, ja uzimam obicnu r9 390.
Staro 12.08.2015., 09:28   #1830
Sam Fischer
Džabe si krečio!
Sam Fischer's Avatar
Postovi: 5,190
Autor draksa Pregled postova
Koliko ti je bučna u loadu ta grafa?
Vidim da je identičan cooler kao i na 290(x) seriji, a loadu je ipak malo izvan mojih standarda (kod mene je Asusova 290X OC verzija)
