Staro 04.08.2015., 07:58   #3931
snake29o3
snake29o3's Avatar
Lokacija: Croatia - Kutina
Postovi: 214
Na kraju sam otkantao coolicool i narucio sa ejiayu.it. Sve prošlo u najboljem redu, platio PayPal-om i šalju mi DHL-om, čekam tracking number sada. Javim koliko im je trebalo da stigne mob.
CPU: INTEL Xeon E5450 3.0 GHz 12 MB Cache
Cooler: Scythe Grand Kama Cross
Mainboard: Asrock P43DE3
RAM: 4 x 4 GB DDR3 1600MHz
GPU: XFX 8800 GT 512 MB DDR3 Alpha Dog XXX Edition
HDD: Kingston HyperX Fury 120 GB (OS) + ( 4 x Toshiba DT01ACA050 500 GB 32 MB (RAID 10) )
PSU: InterTech SL-500A
Case: Antec P180
OS: Proxmox VE
Cooler: Spire Kepler Rev.2
Mainboard: Gigabyte GA-965P-DS4
RAM: 4 x 2 GB DDR2 Kingmax 1066MHz
GPU: Palit GeForce 8400GS 512MB DDR2
HDD: Hitachi 160 GB (OS) + ( TOSHIBA 3 TB 64 MB DT01ACA300 + Toshiba 3 TB 64 MB HDWD130 (ZFS RAID1)
PSU: Xilence 420W
Case: Generic Midi Tower
OS: CentOS 7
Manufacturer: HP
Model: Z440
CPU: INTEL Xeon E5-1650 v4 3.6GHz ( 4GHz Turbo ) 15 MB Cache
RAM: 4 x 8 GB DDR4 ECC 2400MHz
GPU: nVIDIA Quadro P4000 8 GB
SSD: 2 x 240 GB RAID 1 + 256 GB
HDD: 2 x 3 TB RAID 1
Monitor: HP LA2405wg 24" 1920 x 1200
OS: openSUSE Tumbleweed MATE x64
BRAND: ASUS N705FD
CPU: Intel Core i7 8565U 1.8 GHz ( up to 4.6 GHz with TurboBoost)
RAM: 2 x 8 GB DDR4 2400 MHz
GPU: Intel® UHD Graphics 620 Integrated + nVidia GTX 1050 4GB DDR5
SSD: Crucial Micron 1100 256GB
HDD: Seagate ST1000LM035 1 TB 128 MB Cache
Screen: 17.3" 1920 x 1080
BRAND: HP Notebook 15-ba006nm
CPU: AMD Quad-Core A10-9600P (2.4 GHz, up to 3.3 GHz, 2 MB cache)
RAM: 4 GB DDR4 1866 MHz + 8 GB DDR4 1866 MHz
GPU: AMD Radeon R7 M440 Graphics 4 GB DDR3
HDD: 1 TB 5400 rpm
Screen: 15.6" 1920 x 1080 FullHD
OS: Windows 10 Pro x64
Poštene trgovine:
1, 2, 3, 4, 5, 6, 7
snake29o3 je offline   Reply With Quote
Staro 04.08.2015., 14:39   #3932
ivan77
Evo, i drugi radni dan, tablet visi na carini,
pa dajte,ljudi,red je već.
Staro 04.08.2015., 14:57   #3933
darmarH
darmarH's Avatar
Datum registracije: Jun 2014
Lokacija: zanzibar donji
Postovi: 386
Pretjeruješ.. Strpi se, vrijeme prolaska kroz carinsku ispostavu ne ovisi samo o broju ljudi na godišnjem nego i koliko je paketa prije tvojeg za obradu.. A s obzirom da si naručil iz kine svjesno si preuzel rizik torbanja paketa dulje vrijeme po raznim mjestima prije nego ga dobiješ u ruke.. Drugi put uzmi sa eu skladišta i plati više pa si miran..
umjetna inteligencija ne može se mjeriti sa ljudskom glupošću
darmarH je offline   Reply With Quote
Staro 04.08.2015., 18:00   #3934
ivan77
Krenulo gotova carina!
Staro 06.08.2015., 15:37   #3935
silver_tip
silver_tip's Avatar
Lokacija: doma
Postovi: 2,908
Ok, na brzinu se namam sta zaliti. Pismo sa carine je stiglo 03.08-mog. Isti dan sam poslao sve podatke.
Evo maloprije bio postar i donjeo paket. Davanja sveukupno 236kn i ok... tako negdje sam i ocekivao ali mi nikako nije jasna ova specifkacija:
Pa zar sugava maskica za mobitel podljeze carini ? Ajde da je paket izrazen kao jedna cjelina i sveukupni racun/davanja za isti ali ljepo su stavke iz paketa razdvojene na telefon i futrola za mobitel te svaka stavka ima svoju izrazenu cijenu.
Cemu takav obracun i razdvajanje ako i zasto ide PDV na obicnu futrolu vrijednosti ~50kn ?!?
silver_tip je online   Reply With Quote
Staro 06.08.2015., 16:54   #3936
frulex
Datum registracije: Sep 2013
Postovi: 692
Pa kao prvo, ni mobitel ni maskica ne podliježu carini jer je stopa 0% (kao što i piše na tom papiru) već samo PDV-u. A drugo, obično carina stavlja PDV na cjelokupni iznos pošiljke plaćen preko Paypala bez obzira što on uključivao, a to mogu biti i troškovi osiguranja paketa, dodatna oprema i sl. E, sad, zašto je to uvijek tako, to je pitanje koje treba provjeriti kod nadležnih...
frulex je offline   Reply With Quote
Staro 06.08.2015., 18:40   #3937
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
Autor frulex Pregled postova
Carini se vrijednost pošiljke, u ovom slučaju paket u kojem je to dvoje.
U vrijednost ide sve što je potrebno robi da dođe do granice - vrijednost robe i usluga, na koje idu carina i PDV (ako je potrebno).
Kao sto se u trgovini plaća PDV na sve, ne samo proizvodnu cijenu robe.
Igor Batinic
Staro 07.08.2015., 04:33   #3938
frulex
Postovi: 692
Hehe, Hrvatima najbrže u Europi (a i svijetu) stižu paketi iz Kine :
http://track-chinapost.com/China_Pos..._Time_Stat.php
Staro 07.08.2015., 05:44   #3939
FilipMisko
FilipMisko's Avatar
Postovi: 15
Cisto jedno osobno iskustvo.
Kupio sam prosle godine ZTE Nubia Z5S mobitel iz kine. Sa svim davanjima oko 1500kn, veoma isplativa investicija. (aliexpress.com) Mobitel je dosao jako sporo, no dobro to je do poste, ne do prodavaca. Prodavac odlican, mobitel na popustu, dosao u paketu sa punjacem sa dodatnim europskim adapterom (bez slusalica).
Sam mobitel je zvijer, hardverski narocito, no problem je sto dolazi sa preinstalled kineskim softwareom u obliku nepotrebnih android aplikacija. Daju se maknut, no s obzirom na svjetsku popularnost ZTEa, custom ROM je nemoguce naci, narocito za high-end telefone.
I to na stranu, mobitel sam po sebi, sa custom launcherom = zvijer, a cijena prava sitnica. No sada dolazimo do problema.
Mobitel mi je pao i unatoc screen protectoru i silikonskoj masci - napuklo staklo. Samo u donjem dijelu ekrana, no taman tamo gdje su 3 glavne android tipke i samim time, mobitel postaje beskoristan. Zovem uvoznika, sve moguce firme i servise koji imaju ikakvog doticaja sa ZTEom, no nitko niti ima, a niti zeli naruciti novi digitalizer. Rekoh narucit cu ga sam, no onda opet iznenadenje- ekran kosta 500kn+, a staklo cca 100, no nitko ga ne zeli popraviti ako sam dam staklo jer kazu na ZTE mobitelima najcesce dolazi do problema kod promjene stakla, samo cijeli ekran ce promijeniti. I tu dolazim do dileme prolaziti sav taj rizik ili nekako prodati taj mobitel pa kupiti novi. Opet problem, nitko ga ne zeli otkupiti... Na kraju ga u nekakoj zamjeni dajem za drugi, puno slabiji mob nekome tko se ima zivaca i volje sa time zafrkavati. Nakon par mjeseci koristenja sam na gubitku, no u redu, mogu se s time pomiriti.
Long story short - NE kupujte mobitele proizvodjaca koji kod nas nemaju uvoznistvo niti dobar servis. Od kineskih mobitela isplati se uvoziti jedino Xiaomi i Oppo. Ne-kineske mobitele ionako se ne isplati uvoziti iz Kine jer cijene nisu nista nize. Stranice poput AliExpressa su provjerene i imaju odlicne cijene (cak i kada platite 40% carine i pdva).
FilipMisko je offline   Reply With Quote
Staro 07.08.2015., 23:46   #3940
snake29o3
snake29o3's Avatar
Postovi: 214
Evo samo da se javim da je stigao Jiayu S3 Advanced.
Naručen 03.08.2015 na ejiayu.it, plačen paypalom.
Poslan 04.08.2015 DHL-om.
I evo danas, 07.08.2015 došao na kućnu adresu, bez dodatnih troškova.
Sa mobom sve u redu, sad slijedi mrcvarenje, hehe.
Moja preporuka za ejiayu.it.
Case: Antec P180
OS: Proxmox VE
PSU: Xilence 420W
OS: CentOS 7
Manufacturer: HP
Model: Z440
BRAND: ASUS N705FD
HDD: 1 TB 5400 rpm
Poštene trgovine:
1, 2, 3, 4, 5, 6, 7
Staro 08.08.2015., 00:03   #3941
frulex
Postovi: 692
Koliko para ukupno? Ja ga naručio s Aliexpressa, trebao bi idući tjedan doći DHL-om. Pretpostavljam da ćeš odmah Lollipop gore, vjerujem da je došao s KK... :-)
Staro 08.08.2015., 15:38   #3942
snake29o3
snake29o3's Avatar
Postovi: 214
254€
Sad još čekam futrolu i tempered glass da mi dodje.
Koliko je na aliexpressu i jel iz EU ili Kina?
Case: Antec P180
OS: Proxmox VE
PSU: Xilence 420W
OS: CentOS 7
Manufacturer: HP
Model: Z440
BRAND: ASUS N705FD
HDD: 1 TB 5400 rpm
Poštene trgovine:
1, 2, 3, 4, 5, 6, 7
Staro 08.08.2015., 16:07   #3943
frulex
Postovi: 692
Na Aliju sam uzeo iz UK za 233$ s maskicom, screen folijom i OTG kabelom...
Staro 09.08.2015., 11:22   #3944
snake29o3
snake29o3's Avatar
Postovi: 214
Da, KK je treuntno gore. Vidim na needrom da ima Lollipop, al je još u beti sve to, tak da ću vidjeti još ili pričekati stable verziju.
Case: Antec P180
OS: Proxmox VE
PSU: Xilence 420W
OS: CentOS 7
Manufacturer: HP
Model: Z440
BRAND: ASUS N705FD
HDD: 1 TB 5400 rpm
Poštene trgovine:
1, 2, 3, 4, 5, 6, 7
Staro 09.08.2015., 13:55   #3945
buljaka
Datum registracije: Aug 2014
Postovi: 2,945
Link? Tnx
Staro 09.08.2015., 15:40   #3946
frulex
Postovi: 692
Evo: LINK
Staro 11.08.2015., 13:31   #3947
frulex
Postovi: 692
Upravo stigao Jiayu S3 s Aliexpressa (ovog gore linka), cca 7 dana DHL-om, sve odlično prošlo, uređaj izvrstan...
Staro 17.08.2015., 19:47   #3948
Toorop
Mother Russia
Toorop's Avatar
Datum registracije: Mar 2013
Postovi: 326
Booook, ako uzmem mob od nekih 550$ s neta, na njega mi ide carina? ..iz US
Toorop je offline   Reply With Quote
Staro 17.08.2015., 19:59   #3949
partwish
Creeper
Datum registracije: May 2013
Postovi: 2,216
Autor Toorop Pregled postova
Ide 25% PDV-a, carinska stopa na mobitele je 0$. Platio bi 687,50$ + još neku siću od valjda 30ak kn.
Staro 17.08.2015., 20:01   #3950
Toorop
Mother Russia
Toorop's Avatar
Postovi: 326
Hm, hvala. i ne postoji nikakva shema za zajebati taj sistem ili nešto pa da ne platim toliko, ili da dam i tih 100 i nešto dolara i vozi?
Staro 17.08.2015., 20:03   #3951
partwish
Creeper
Postovi: 2,216
Postoji sistem, a zove se sreća. Ali u zadnje vrijeme i nije nešto česta. A da jednostavno kupiš uređaj u EU, onda nema nikakvih dodatnih davanja. O čemu se uopće radi?
Staro 17.08.2015., 20:04   #3952
Toorop
Mother Russia
Toorop's Avatar
Postovi: 326
Haha, razmišljah o toj sreći, da Radi se o Sony Xperia Z3+ mobitelu, tražim najjeftinije gdje mogu proći za čisti uređaj, ako znaš nešto u EU da je koliko toliko jeftino, ne srami se reći
Staro 17.08.2015., 20:20   #3953
partwish
Creeper
Postovi: 2,216
Na amazon.it imaš bijelu verziju s dostavom u HR za 602€, što je jeftinije nego kada platiš PDV na ovaj iz USA. klik. Ako te zanima požuri jer to je trenutno akcija koliko vidim i naravno provjeri da sam ti našao uređaj koji si tražio.
Staro 17.08.2015., 20:28   #3954
Toorop
Mother Russia
Toorop's Avatar
Postovi: 326
Hm, hvala! mislim da sam čak i pronašao način, bar mislim, kupit mob poslat ga u UK i onda iz UK oni šalju meni DHL-om u HRV. Izađe me mob 540$ + 56$ iz UK k meni što je nekih 4k kn... jao jao
Staro 17.08.2015., 21:02   #3955
partwish
Creeper
Postovi: 2,216
Misliš da Englezi puštaju robu u svoju državu bez carinskog postupka?
Staro 17.08.2015., 21:05   #3956
Toorop
Mother Russia
Toorop's Avatar
Postovi: 326
Koliko sam shvatio firmu koja se bavi time, placam samo tih 56$/51€ i u to je ukljucena i carina i slanje paketa i njihovo preuzimanje!? o.o
Staro 17.08.2015., 21:17   #3957
partwish
Creeper
Postovi: 2,216
Zvuči dobro, na tebi je da odlučiš želiš li riskirati.
Staro 17.08.2015., 21:22   #3958
Toorop
Mother Russia
Toorop's Avatar
Postovi: 326
Mislim da cu riskirati pajaviti dojmove ipak je ovo jeftinije od hrv i susjeda tenks na pomoci
Staro 23.08.2015., 22:11   #3959
picajzlaaa
picajzlaaa's Avatar
Datum registracije: Apr 2009
Lokacija: eu
Postovi: 806
Pozdrav, razmišljam da uzmem nešto sa gear best-a. Još neznam šta, ali bi uzeo nešto u stilu 5.5 inča phableta, novije, osam jezgri. Tipa xiaomi, Ulefone, Doggee, Lenovo K3 mi se isto svidio.. No to sad nije tolko bitno, zanima me na šta pazit, kolka su davanja, carina, pdv? Mogu li saznat koji mob je iz EU skladišta i da li tada bolje prolazim (osim šta mi brže stigne). Hvala, ak je već pisano, sorry, ne stižem prolazit svoh 130 strana ovaj tren
picajzlaaa je offline   Reply With Quote
Staro 23.08.2015., 22:19   #3960
RAUL
Lokacija: Worldwide
Postovi: 2,553
Davanja su ti 25% na cijenu sa shippingom plus 30 kuna troskova carine.Ukoliko se salje iz neke zemlje EU onda nema nikakvih davanja.Inace sto se tice Gearbesta od mene vise nece dobiti niti cent.Trenuto sam ih prijavio za jednu transakciju i sada cekam odgovor Paypala ( uvalili su mi lazni tracking preko SE poste i sada se prave grbavi )
