#1231 | |
Flajing super šiiiip
Lokacija: Zd -- Zg
Postovi: 1,683
5.1.4 setup: Zvučnici - 2x Arendal 1723 S monitors, 1x 1723 S center, 4x 1961 height, 2x 1961 surround, XTZ 12.17 EDGE Amps - Marantz Cinema 40 + ROTEL RMB-1585 |
#1232 |
Vršni visioc
Postovi: 2,209
Bez potpisa. |
#1234 |
gadget freak
Lokacija: Jasenovac
Postovi: 2,224
http://www.overclock3d.net/reviews/g...ury_x_review/1 "There has been a lot of speculation about how near to the Titan X the Fury X gets. Much has been said about AMDs relative silence on the subject. That stupid assumption that if they aren't shouting about it from the rooftops that it doesn't get close. Sure it doesn't always match up to the Titan X, but equally it's never disgraced no matter what we threw at it. It isn't even aiming at that card anyway. Given how much of a surprise the GTX980Ti was when it released and the lengthy development time for any graphics card we'd assume that it was intended to go up against the GTX980, and if that is the case then mission completed with honours. Against the GTX980Ti it's, if anything, even more impressive. Both at stock the results are seriously close, yet the R9 Fury X costs less. There is almost nothing not to like. If you are hoping this is an overclocking beast voltage options are locked out, you can tweak the 'max clock' and power target but we didnt get anywhere with ours. Seeing as this will be a reference design only we dont think the vendors will get the chance to play with bios tweaks etc so it may well be a card to fit and forget and not one for the tweakers (going by how ours responded)."
#1236 |
CNE @ Verne global DC
Datum registracije: Feb 2015
Lokacija: Reykjavik, Iceland
Postovi: 493
#1237 |
PREMIUM
Datum registracije: Dec 2014
Postovi: 2,153
Sve u svemu razočaranje. U velikoj većini slabija od referentne 980ti, a i slabije se kloka. K tome ne treba ni spominjat 2gb više i nereferentne 980ti kojih ima za razliku od furyx i koje donose često značajan pomak u odnosu na stock. 980ti je no brainer. |
#1238 |
Datum registracije: May 2012
Lokacija: Našice
Postovi: 126
https://www.vessel.com/videos/em6VjGzlh Evo izašlo i kod Linusa, i nije on...Luke je...xulos će biti oduševljen... ![]() |
#1239 | |
Outer Space
Lokacija: Vinkovci
Postovi: 833
#1242 | |
Outer Space
Lokacija: Vinkovci
Postovi: 833
Zadnje izmijenjeno od: Romano.Cule. 24.06.2015. u 15:14. |
#1243 | |
Postovi: 8,376
Pa ne moraš bit perfekcionista da bi vidio kakvo je ovo sranje, ne bi da im je kasap iz Đakova sklapao karticu. Žali bože. Citiraj:
#1244 | |
Xulos :)
Postovi: 7,557
Prije nego sto krenete u rat s vjetrenjacama , ako pogledate ovu sliku , vidjet ce te da je bakrena "hitpajpa" kompletnog hladenja zavarena na backplate koji hladi kompletnu naponsku sekciju ![]() ![]() Ovdje se bolje vidi : http://core0.staticworld.net/images/...92012-orig.jpg Citiraj:
![]() Edit A bitno da trkeljaju a nisu pogledali sliku koju je ranez prije tjedan dana objavio gdje se dobro vidi cijelo hladenje. To hladenje koje ima fury je bolje rijeseno nego ijedna grafa do danasnjeg dana ![]()
The Rich pays to win. The Poor spends to lose. Zadnje izmijenjeno od: JuiceBox. 24.06.2015. u 15:29. |
#1245 |
Datum registracije: Apr 2013
Postovi: 1,336
Nije mi jasno kako nitko od Youtubera nije popljuvao onaj coolermaster logo na pumpi ![]() ![]() |
#1246 | |
Xulos :)
Postovi: 7,557
#1247 |
[ZA DOM]Rino
Lokacija: Kutina
Postovi: 762
#1248 | |
Datum registracije: Apr 2011
Postovi: 1,429
![]() ![]() ![]() Nažalost, nije ni 2. nego 3. najbrži (zapravo 4. ako uzmemo i nereferentne GTX980 Ti). Gledao sam malo na guru 3d, gigabyte GTX980 Ti G1 SOC u witcheru 3 nadmašuje Fury x za nekih 30% i na 4K i na 1440p rezoluciji. P.S. Nažalost, ipak nema hdmi 2.0. Zadnje izmijenjeno od: listerstorm. 24.06.2015. u 15:44. |
#1250 | |
aka Striko
Lokacija: Krapina - Zagreb
Postovi: 1,742
OOOOO hawkeruuu,... Come out and play... Do not hide under bed... Di ti je ta ultimativna razaračina svemocnog svemira? Ma kakav najjaci single GPU ? Cijenom je približe k****... Šta je to najbrže? Osim vodenog koje ce se raspasti za godinu dana ![]() Kolke si ono postotke spominjao??? 15%? od cega? ![]() ![]() Di ti je HDMI 2.0? Di si mi sada "genije"? ![]() |
#1251 | |
N0teb00k n00b
Lokacija: Zagreb/Koprivnica
Postovi: 2,105
Jedini "problematičan" dio mi je eventualno ovaj "sleeve" crijeva za vodenog koji nutra nije preko nekakvih termobužira lepo spojen sa cijevi nego samo visi, ostalo fakat ne kužim na kaj slika ukazuje...
#1253 |
N0teb00k n00b
Postovi: 2,105
Jedan full cover blok 100€ pa uvodnice po par € pa radijator pa pumpa... skup je to sport, ali da ladi, ladi pošteno ![]() Buraz imo full vodeno i srce mu se kidalo dok ga je moro prodat, sad dok ima laptop mu nije jasno zakaj si isti nije prije kupil ![]() Al fakat, di si onu sliku zvlekel i koja je šema s onda druga dva kruga nevezana uz sleeve? Ak me sjecanje dobro sluzi svaki taj pregib od 90 stupnjeva se racuna ko metar cijevi...
#1254 |
Postovi: 333
#1255 |
..starija garda
Postovi: 3,280
Koliko vidim FURY bolje pokazuje misice u 4K rezama, nego u manjim.. Očito HBM dio radi odlično, a sam GPU malo slabije, sve u svemu kad se sve zbroji tu je kao i 980ti. Eto svi oni koji su očekivali fejl FURYa su očito sad razočarani, ali ne sumnjam da neće nači neki argument da sve jedno nastave pljuvanje po AMDu i td. ![]()
#1256 |
Member
Lokacija: Kutina
Postovi: 979
Mene zanima kako bi skalirale perfomanse s povećanjem takta memorije, ovo je smiješno niska frekvencija. |
#1257 |
Postovi: 2,390
#1258 | |
..starija garda
Postovi: 3,280
![]() sta ce se desavati sa ostalim fury modelima koji će tek doći na tržište, ove i slijedećih godina, isto se može nagađati.. jer fury i njegovih iteracija ce biti i AMD makar ima s čime igrati ovu igru.. ali neće se desiti ništa revolucionarno u svijetu gdje kapitalizam vlada, to vam je valjda jasno ![]() Ali makar će se priča ubrzati ![]() ![]()
#1259 | |
Datum registracije: Nov 2014
Postovi: 1,972
Ja sam potpuno zadovoljan inicijalnim performansama. Sad malo peglanja drivera i to je to. Well done AMD |
#1260 | |
Postovi: 1,429
Fury x u prosjeku slabiji, a od nereferentnih GTX 980 Ti ponegdje i 30% (witcher, 1440p i 4K - guru3d). Nažalost, ispostavilo se da nema HDMI 2.0., tako da sasvim stoji ovo dolje, pogotovo boldano: Citiraj:
![]() well done AMD ![]() |
