Staro 19.05.2015., 01:52   #241
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
1 titan ima average preko 60fps na 1080p, gdje ti to gledaš? Gdje 280 ima isti fps kao 780Ti - jesi ti šta pio
Kažem potopuno očekivano... Prva next gen igra
Staro 19.05.2015., 01:54   #242
Hawker
Datum registracije: Nov 2014
Postovi: 1,972
Pratim kuknjavu po netu.
780ti jedva natuce 40-50fpsa na max.
Kakav next gen? Jesi vidio slike grafike sto ljudi stavljaju?
Hawker je offline   Reply With Quote
Staro 19.05.2015., 01:55   #243
Manuel Calavera
Postovi: 14,584
Nađi jednu open world igru što približno ovako izgleda...
EDIT
također zajebi razne divlje piratske verzije i kojekakve crackove - takvi slučajevi imaju različit fps od cracka do cracka
Staro 19.05.2015., 01:59   #244
Hawker
Postovi: 1,972
I koja je neigriva za 99% pucanstva koji taj izgled ne mogu vidjet ako nemaju 1000 eura grafu.
Jeftinije je kupit PS4 i tu igru.
P.S. A slike me bas i nisu impresionirale.
EDIT. ma kakvi pirati,placu ljudi koji imaju preorder igre pa je sad ne mogu igrat ako nemaju 1000 eura grafu da dobiju bar 60fpsa.
Staro 19.05.2015., 02:05   #245
Hawker
Postovi: 1,972
Evo malo kukanja sa neta:
2x vanilla titan at 1110mhz = 50 fps on a rog swift lol (full ultra)
his game is destroying my SLIed 680's in 1440p. I don't even know if I can get away with high.
Just ran the game on Ultra with out hairworks on 2560x1080 (1920x1080 didn't make a difference) and i was getting 30-44Fps on my 780ti
gaming is scaling horribly with r9 290 crossfire @4k max everything even HW. getting 12fps. lol
I'm playing and sadly SLI isn't working atm not sure why, and single 780 is getting slaughtered all max in 1440p 20fps lol
Well rip, installing the game atm but seeing people complaining about getting 10-40 fps with a 980. Was hoping for a solid 60 with my 980 at max.
EDIT: i napokon 60fps,
1080p/60fps with Titan Black and i7 4960X.
Dropped shadows to High with SSAO and Visibility foliage to Medium
EDIT: Trebace pricekat bar jedno 10 patcheva da izbjegnemo igrat na screenshot settinzima.
Zadnje izmijenjeno od: Hawker. 19.05.2015. u 02:15.
Staro 19.05.2015., 02:42   #246
Sphere
Datum registracije: Mar 2015
Postovi: 1,254
Inace osobno nikad ne igram igru po samom izlasku, cekam najmanje 6 mjeseci od izlaska da pocnem sa igranjem, ima gro ostalih naslova koje se treba preci tako da zasto se siliti na igru po prvom danu kada ce to kasnije sve biti optimiziranije i vjerojatno ce biti i koji DLC kroz to vrijeme ubacen.
Uostalom sta je sa onim patchom koji su najavili na isti dan izlaska igre, jel ova ekipa koja je probala igru skinula taj patch?
Sphere je offline   Reply With Quote
Staro 19.05.2015., 03:40   #247
Manuel Calavera
Postovi: 14,584
lolz
ako ne radi sli ili cf + igraju na ultra i forsiraju reze iznad 1080p nemaju se čemu čuditi. Samo što ekipa koja ima takve grafe nije navikla smanjiti detalje. možda su sivonje i msaa odvrnili ili onaj švabski test laže
Staro 19.05.2015., 05:28   #248
Sphere
Postovi: 1,254
Neke stvari mi stvarno nejdu u glavu, kako je moguce da ne radi SLI kada je vec prije koji mjesec sluzbeno testirano na 2x gtx 980?
Stvarno je zalosno da sa grafom od 5000kn ti nemozes maxati igru ma kakve god filtere ukljucio, pa mislim ono tu se radi o grafi vrijednoj vise nego 90 posto ljudi u Hrvatskoj ima vrijedne kompletne kompove.
Sa prijasnjim grafama tipa HD 7970GHz koje su u svoje vrijeme kostale blizu 4000kn do dan danas si mogao sve uredno peglati na kojim postavkama si htio, a sad grafe koje su tek izasle i kostaju jos vise nemogu ni sada kada su tek postale aktualne sve vrtiti na max postavkama, kako ce tek onda raditi za pola godine, godinu?
Znam da je trenutna smjena genracija i da next gen dolazi na vrata, ali opet nemogu to nikako shvatiti.
Jesu li igre stvarno toliko brzo napredovale u odnosu na hardver ili se namjerno u dogovoru sa velikim kompanijama rade lose optimizacije da bi se prisiljavalo ljude da kesiraju masnu lovu na skupe komponente...
Staro 19.05.2015., 06:30   #249
G-boy
G-boy's Avatar
Lokacija: VG
Postovi: 307
Na mojoj bestiji vrti 30 fps-a sa texturama na ultra i ostalo na high, SSAO i naravno bez hairworksa. Nije bilo nikakvog stucanja ni stuttera iako je tu i tamo znao fraps pokazat drop od 1-2 fpsa. Nisam puno nesto igrao, samo prvo jahanje okinuo da vidim ponasanje.
Uglavnom nisam ocekivao cuda, ali s ovakvom mid-range konfom mislim da radi zadovoljavajuce i nevjerojatno mi je kad procitam da netko sa gtx 970/980 ne moze postic stabilnih 50+.
G-boy je offline   Reply With Quote
Staro 19.05.2015., 09:13   #250
ivan77
Pa meni, Dragon Age: Inquistion izgleda bolje od ovog.
Staro 19.05.2015., 09:24   #251
xGAME
xGAME's Avatar
Lokacija: Chernobyl NPP
Postovi: 4,777
Ako je tako kako se priča, igra nikako izgledom ne odobrava ovakve performanse. Nikako. Kužim taj dio sa kosom i folliagem te AA opcijama, ali osim toga nikako. Ali ima i previše onih kojima je loša optimizacija ako im dropa tu i tamo 5 fpsa.
Ali mislim da će se to sredit s par patcheva, jer čitajući po netu igra ima veoma čudne dropove ponekad. A i Witcher nije igra koju se igra odmah po izlasku, nego se čeka i čeka dok se fixaju bugovi i performanse kao što je i do sada bio slučaj.
Isto tako, HBAO ne radi kako spada, pa koristite SSAO radije i dobit ćete 5-10 fpsa samo tako.
xGAME je offline   Reply With Quote
Staro 19.05.2015., 09:37   #252
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,162
Izgleda jako dobro na psu, kao i da;i.
Prerano mi je jos za davat zakljucke.
Pocet cu je igrat kad rijesim w2.
Staro 19.05.2015., 19:53   #253
Manuel Calavera
Postovi: 14,584
Staro 19.05.2015., 20:01   #254
hedgehog
hedgehog's Avatar
Datum registracije: Apr 2013
Postovi: 1,336
kak napraviš igru da ju 750Ti ne može pokrenut kak spada, a za medium detalje ti treba R9 290X? Dobra fora je sa minimum RAM koji kaže 6GB, odnosno preporučeno 8, a ovi kažu da potrošnja nikada nije prešla 2.1GB..gj
hedgehog je offline   Reply With Quote
Staro 19.05.2015., 20:04   #255
Manuel Calavera
Postovi: 14,584
750Ti realno ne zadovoljava ni min. zahtjeve tako da je to još OK - na low 1080p ima average 41fps
Staro 19.05.2015., 20:07   #256
hedgehog
hedgehog's Avatar
Postovi: 1,336
Pa to i kažem..znači ako nemaš karticu iz zadnje dvije generacije, i to jako dobru karticu nećeš igrat..koliko ljudi zapravo ima takvu konfu je dosta upitno, u principu sami sebi izbijaju lovu sa ovakvim glupostima..GTAV je pogodio priču..kad staviš low možeš ju pokrenut na krumpiru, ali će izgledat ko san andreas ali možeš igrat i na ultra ako imaš mašinu pa uživaš..ovo je bzvz po meni..
Staro 19.05.2015., 20:30   #257
Manuel Calavera
Postovi: 14,584
Evo još benchmarka - http://gamegpu.ru/rpg/rollevye/the-w...-test-gpu.html
Na high (imaju još very high i ultra) 7870 (gameworks off) na 1080p ima 37 fps min. i 41 average - pa nije uopće zahtjevna koliko se priča kad sa grafom iz min. req. praktično možeš na medium ili high igrati bez kerefeka. I u videu gore kaže da je velika razlika u zahtjevnosti između min. i max postavkama. Malo bolji fps od gamernexusa gdje 270X na medium ima 40fps average (možda je ruski test sa day one patchem), uglavnom benčmarci se jako razlikuju.
Prema ruskom siteu - igra uopće nije zahtjevna za cpu, još je najbolje kupiti fx 4300 za 570kn i vozi (ako potvrde i ostali testovi)
VRAM consumption never exceeded 2.7GB during our testing, which is noteworthy -- many of the games we've benchmarked lately (ACU, FC4, GTA V) have exceeded 4GB when the memory is available to the system. System RAM consumption hovered around 2.1GB.
Staro 19.05.2015., 22:32   #258
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,209
https://youtu.be/1fUGFmmikn4
Osobna razlika zanemariva a to mi je posao
Ja vam kazem da za godinu dve odosmo svi sa foruma na konzole
Bez potpisa.
Staro 19.05.2015., 23:00   #259
Manuel Calavera
Postovi: 14,584
To je dokaz koliko se zapravo igre mogu optimizirati, kad se potrudi. I dokaz koliko je pc zapravo nebitna platforma za gaming
Ispada da bi se sve igre svijeta bi se mogle na grafi tipa HD7850 vrtjeti na ultra/60 fps - kad bi se htjelo max potruditi i izvući zadnji atom snage
Staro 19.05.2015., 23:06   #260
Mileni
Mileni's Avatar
Postovi: 1,554
Ali zasto da se toliko potrude? Pa valjda je 75% igraca na PC-u odigrala prva dva nastavka bez da su igru kupili. A ovi kao idioti uloze toliki trud da bi prodali 1-2 mil komada?
Konzole = zarada. A i lakse je sve optimizirati i srediti.
I kao developer ih u potpunosti shvacam i podrzavam. Podrzavali bi ih i vi da ste na njihovu mjestu.
Nakon sto sam prva dva nastavka odigrao na PC-u, treci ce mi vjerojatno posluziti kao izlika da si ponovno kupim konzolu
Staro 19.05.2015., 23:23   #261
Manuel Calavera
Postovi: 14,584
Ma razumijem ja to, i sam sam pisao da 99% prodaje nekih naslova otpada na konzole, samo kažem da je to tehnički moguće tako optimizirati...
Što je najjače, na pc najviše piratluka + pc igrači daleko najviše troše na hardware = totalno neproduktivno, začarani krug
Staro 19.05.2015., 23:28   #262
Mileni
Mileni's Avatar
Postovi: 1,554
Naravno da je moguce. Patchevima ce to sigurno jos dodatno srediti. Ali im je neisplativo. Gejmam na pc-u jos od kad je duke nukem bio top hit, prije toga na zx spectrumu, itd. Ali mi nije problem koristiti konzole, dapace. Trenutacno mi cak i draze, jer je lakse dati 2500kn za konzolu i biti miran 5-6-7-8 godina. Izgubio sam odavno onu draz nadogradjivanja PC-a. Godine me stigle
Staro 20.05.2015., 01:53   #263
warlock25
warlock25's Avatar
Postovi: 2,327
ja na ps4 uzivam u igri.nevjerojatna grafika na ps4
Staro 20.05.2015., 09:15   #264
Deathwish
overpowered
Deathwish's Avatar
Postovi: 914
Evo da dam performance dojmove.
Komp je i7 2600k, 16GB RAM, Radeon R9 270 2GB
Detalji Medium, reza full hd, igra cisto ok radi, isključeni AA i ini kerefeki.
Imao sam 20 min vremena pa se nisam puno sa settinzima igrao no izgleda cisto ok na tim detaljima, tu i tamo primjetim texture pop in
@Work HP Zbook15
@Home Acer 5020
Deathwish je offline   Reply With Quote
Staro 20.05.2015., 17:30   #265
Romano.Cule
Outer Space
Romano.Cule's Avatar
Lokacija: Vinkovci
Postovi: 833
Ja nafrljio sve na ultra sa ukljucenim hairworks-om u 1920 i radi savrseno fludino.
Staro 20.05.2015., 18:43   #266
G-boy
G-boy's Avatar
Lokacija: VG
Postovi: 307
Moj bench brzinski:
Ultra: 33avg;27min
High: 49avg; 40min
Medium: 54avg; 46min
Low: 60avg; 54min
To je sa SSAO i iskljucenim Hairworksom i sve pod Postprocessing je ON.
Ne kuzim stvarno kakva je to galama s tim bencmarcima jer po ovome bi grafe daleko ispod preporucene minimalne 7870 trebale isporuciti barem 30 fps-a na nekih medium, a na low da i ne pricam.
Ovi dropovi se javljaju pretezito u sumi dok na otvorenom prostoru ili selu fps miruje i igra je u globalu vrlo vrlo fluidna, cak i na ultra se da igrati no to sad kako tko voli, meni osobno ispod 40 ne pase.
Tako da.. nista NEocekivano, znali smo da ce igra bit "teska" za hardver, no po ovome nista specijalno.
Staro 20.05.2015., 20:29   #267
ivan77
Stvara se histerija bez veze, već viđeno, u slučaju DAO: Inqusition, Watch Dogs, GTA 5.
Netom nakon izlaska pun je net članaka o tome kako ne radi na 9xSLI 290rxxx, za tjedan dana postaje jasno da je sasvim igriva igra debelo ispod preporučene konfe.
Staro 20.05.2015., 23:36   #268
Romano.Cule
Outer Space
Lokacija: Vinkovci
Postovi: 833
Evo jedan tip za 20 FPS-a 'ladno za ultra detalje sa hairworksom ukljucenim. U catalyst driverima dodajte aplikaciju witcher.exe i override tesselation stavite na 8 ili max 16 za boost od 20 FPS-a. Naime djubrad je u suradnji sa nvidiom namjerno overusala tesselation na 64x jer nvidia bolje barata sa tessom,ali ni to im nece pomoci od gnjeva bozje ruke :P Razlike nema nikakve.
Staro 21.05.2015., 01:50   #269
Manuel Calavera
Postovi: 14,584
Skužite očajan rad nvidia 7xx serije (uključujući i titan)... WTF?
http://www.guru3d.com/articles_pages..._review,5.html
gtx 760 slabija od 270X, gtx 780 jedva jača od gtx 960, 780Ti slabija od r9 290
Staro 21.05.2015., 07:30   #270
G-boy
G-boy's Avatar
Lokacija: VG
Postovi: 307
Mozda je to sve povezano s tom nafrljenom teselacijom sto je kolega Romano spomenuo, ocito je samo Maxwell dorastao tome.
