#391 | |
Postovi: 1,011
![]() Ali gotovo uvjek je postojao osjecaj da se prvom vozacu posvecuje vise paznje i da su bolidi "odporniji" na raznorazne bolescine, govorimo o ferariju, naravno ![]() |
#392 |
Freelancer
Lokacija: Bilje (Osijek)
Postovi: 5,329
#393 |
Osobni opis - pitaj me
Postovi: 2,317
agreed . iako volim rikija, dobar i konkretan vozac, kao zapeo kao i alonso (ovu sezonu barem) u itekako losoj momcadi .zamislite, kimi + riki......... e da je barem tako poslozeno, gledao bi i navijao bezbrizno za oba propeta konjica, a smijao se na svaki fail RB-a . NHF ikome, jednostavno ne volim RB, a volim ferrari (i bmw, kojeg nazalost vise nema u F1), plus par vozaca nevezano za momcad.
#394 |
Freelancer
Postovi: 5,329
Nekuzim zasto novinari i dalje pricaju da je ove godine dozvoljeno 4 motora ? Pa jel nisu dogovorili da bude ipak 5 komad akao i prosle sezone? F1Fanatic text kaze : "Daniel Ricciardo will have to use his fourth and final Formula 1 V6 engine in Spain next month following his last-gasp failure in the Bahrain Grand Prix."
#396 |
Freelancer
Postovi: 5,329
Po Autosportu i Horneru ispadne da je to vec rjeseno/dogovoreno jos u Maleziji? "Red Bull team principal Christian Horner has confirmed Ricciardo will move onto the fourth in Spain."All the [post-race] fireworks went off and the engine obviously wanted to join in," said Horner. "It failed 200 metres before the line, but thankfully we had enough momentum to coast over the line. "I think that the engine will be a coffee table in the future - that's three out of four now for Daniel. "He'll be on engine four in Barcelona." Ricciardo's engine situation will be improved when the agreement to allow each driver to have a fifth engine is officially rubber-stamped. This was agreed in Malaysia, although even with a fifth V6, Red Bull will inevitably face penalties later in the year. "We unanimously agreed on it in Malaysia, all of the teams," said Horner. "Bernie [Ecclestone] said it only has to formally go through the Strategy Group and the F1 Commission to be signed off and that can be done by fax vote." Horner added that, while the engine failure was a concern, he's not too worried about it provided it's not a new weakness. "So long as it's a repeat failure and not a new failure," said Horner when asked about concerns over reliability. "Whilst disappointing, the failures are ones there are solutions in the pipeline for."
#398 |
Postovi: 333
Mora se sastat neko povjerenstvo FIAe il tako nesto,a sad kad ce se sastat je na njima Pitanje je hoce li prije toga eksplodirati i taj 4ti motor ![]() |
#399 | |
Freelancer
Postovi: 5,329
.Brijem da ce do kraja sezone svi korisititi vise od 4 motora tako da bi u tom slucaju to pravilo 10 mjesta bilo ionako nebitno vecinu vremena kad bi se svi pomicali nazad po 10 mjesta, eventualno bi se malo izmjenjivali iz utrke u utrku .
#400 |
Freelancer
Postovi: 5,329
Da, zanimljivo rjesenje a i morali su nesot radikalno smislit da "stignu" ekipu koja ima sezonu vise u razvoju/testiranju. Sve bi to islo puno brze da je moguce testirati aute u sezoni kao nekad .
#401 |
Never Forgetti
Lokacija: .
Postovi: 1,640
Posebno me vesele zadnje dvije rečenice ![]() |
#402 | |
Postovi: 2,317
![]() buttonu osobno priznajem da je (tada) jedini znao sacuvati duze gume, te ako se dobro sjecam, dobro je prolazio dok pada kisa. dok s druge strane, nisam tocno siguran zasto spanjolska placipicka, ali taj isti alonso je itekako pokazao i dao sve od sebe unazad par godina te da je imao bolid na razini ovogodisnjeg ferrarija, bilo bi jos zanimljivije nego sto jest. sve 5, ja isto tako smatram hamiltona nekom vrstom vjecnog razmazenog djeteta, vettela definitivno placipicka (zapravo cijeli RB skupa s njim, dok webbera i rikija NE), rosberg je rang masse, kimi legenda cim zine....... ali button stvarno ne znam po cemu je specijalan, pogotovo kada se usporedi sa alonsom koji je barem klasu bolji i konkretniji vozac. ono sto je osvojio prvenstvno je hmmmm....... zasluzan virgin i bolid, nikako vozac .
#403 |
Je suis Schumi
Postovi: 1,524
Button je ok lik, zato se ljudima svidja. Takav je i Kimi. Ne rade nikad sranja. Sad kad malo bolje razmislim, Ferrari je mogao Kimija imati na prvom mjestu ili cak 1-2. Ali ne, šupak Vettel je odlucio ne pustiti Kimija na pocetku dok je bio brzi i onda se jos vozikao po pijesku, sjebao krilo i unistio sigurno mjesto na podiju.
Di sam stao? -Stalji smo onda kad je *ebem Šćepanović ![]() |
#404 |
Postovi: 2,317
ovo je druga prica za vettela. vjerujem da dobar dio navijaca propetog konjica ga nije docekao veselo znajuci kakav je bio u RB-u, ali opet kazem - to je druga prica. i da, naravno da je kimi mogao cak i do hamiltona, definitivno odlican ferrari, odlican kimi, los dan vettela (jer iskreno, nije bas poznat po onakvim greskama). nego da se vratimo, mogu ja navijati za super-duper osobu kao takvu, ali ako u smislu natjecanja ta osoba nije top, džabe ste krečili .da budemo nacisto, nemam ja nista protiv buttona i skroz se slazem s njegovim karakterom ovo sto si napisao. isto i za webbera, kao i ricciardo. to su ok ljudi, nema tu bahatosti, nema tu snobizma, ljudi.
#405 | |
Lokacija: n/a
Postovi: 6,128
Kimi se mora poceti bolje kvalificirati ako misli imati bolje rezultate u utrkama. |
#406 |
Je suis Schumi
Postovi: 1,524
Realno, Kimi je odvozio jako dobro dosadisnji dio sezone. Imao je odredjenih problema i probio se dosta s obzirom di je startao. Vettel je uvijek bio iza ove dvojice iz Mercedesa i vrebao prilike. Tako da ova s boljim kvalificiranjem itekako stoji. Mozda se kasnije u sezoni pokazu tocnima one nase forumske prognoze da ce Kimi guziti kmecavca ![]()
#407 | |
Never Forgetti
Lokacija: .
Postovi: 1,640
Alonso mi dize tlak jos od vrimena Renaulta, jednostavno ne mogu podnit njegovo cmizdrenje ma koliko izvlacio iz bolida.
#408 |
Lokacija: Zagreb, Trešnjevka
Postovi: 5,777
http://www.gp1.hr/helmut-marko-optuz...nje-ferrariju/ Klasicni red bull. Ne znam kako itko moze za njih navijati, hrpa toliko antipaticnih i losih ljudi. |
#409 | |
Never Forgetti
Lokacija: .
Postovi: 1,640
#410 |
Freelancer
Postovi: 5,329
Button opet pobjedjuje ???? https://www.youtube.com/watch?v=eXVtmIIjCVw
#411 |
Datum registracije: Apr 2011
Lokacija: Usa
Postovi: 628
Šta bi vi radili, da Vam proizvođač proda motor F1 koji u prosjeku traje 1 motor jedna utrka (Riki). Ja sam davno rekao da Renault ove godine jedino dobro plasira lažna obećanja. RB će vjerojatno morati izaći iz ovog braka. Spominje se mogućost ulaska VW u F1, tako da će doći opet vrijeme RB-a. Ova izjava o Ferariju i Mercedesu može nekom biti smiješna, ali vjerujem da tu ima dio istine. |
#412 |
Je suis Schumi
Postovi: 1,524
Vrijeme Red Bulla sigurno neće doći, bar ne tako skoro. Osim ako se sin Adriana Neweya ostavi utrkivanja i nakon toga prebaci na dizajniranje bolida ![]()
#413 |
Fresh Juice
Postovi: 4,579
Pol sata on board snimki iz Monze prošle sezone. Dobre snimke http://www.formulino.hr/pogledajte-p...arda-iz-monze/ |
#414 |
Never Forgetti
Lokacija: .
Postovi: 1,640
#415 |
Lokacija: Beertopia
Postovi: 2,013
21. godišnjica. Kud vrijeme leti
54' / 74' / 90' / 2014
I'm only here to see how the story unfolds. Any self-respecting leading man would do the same. |
#416 |
Je suis Schumi
Postovi: 1,524
Zbilja. Sjecam se kad sam poceo gledati F1 par godina nakon toga i kad su pricali o Njemu, a tad nisam imao nista osim Slavka Cvitkovica i ostalih mu kolega i nesto kasnije Auto kluba. Istinska velicina F1 i sporta opcenito ![]()
#417 | |
Never Forgetti
Lokacija: .
Postovi: 1,640
#418 |
Lokacija: Beertopia
Postovi: 2,013
@Brkati Stream na jubitu ![]()
#419 |
Postovi: 333
Zadnje izmijenjeno od: draksa. 02.05.2015. u 13:37. |
