Super Moderators
Datum registracije: May 2002
Postovi: 17,485
HD Tune 2.50
Za one koji slučajno ne znaju: HD Tune is a Hard Disk utility which has the following functions: Benchmark: measures the performance Info: shows detailed information Health: checks the health status by using SMART Error Scan: scans the surface for errors Temperature display Changes: Screenshot can be saved to a PNG file Added minimize button to title bar Added option to start HD Tune minimized Added option to run HD Tune each time Windows is started Added option to show temperature in both Celsius and Fahrenheit Warning message shows up if a critical hard disk temperature is reached Info: report SATA version, Native Command Queuing (NCQ), Interface Power Management Health: improved display and failure prediction Besplatan a dobar prog, nema ni megu. http://downloads.guru3d.com/download.php?det=1180 |
Postovi: 7,568
Skinul sam ga još popodne, sad malo prije sprobal...odličan programčić...naravno, ako ne najde kakvu grešku. |
Super Moderators
Postovi: 17,485
Ja ću ga sutra isprobati, imao sam raniju verziju i radila je čist ok. |
Postovi: 7,568
Ranija (2.10) je isto v redu...... još nisam sprobal 2.50 na svojem kompu....samo na sestrinom....bez greške. |
