Staro 04.04.2015., 22:14   #1
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,140
[Fedora 21] Konfiguriranje Samba share-a
Ok...trebam pomoć iskusnijih od sebe jer ja više neznam u kojem smjeru krenuti i što zeza. Nemogu nikako osposobiti samba share na Fedori 21. Firewall i Selinux su onemogućeni, probao sam ručno, preko system-config-samba i preko webmina - banana. Maksimalno što uspijem dobiti jest da mogu vidjeti glavni foder ali nemam pristup nakon toga. Trenutačni smb.conf je ispod. Bilo kakav savjet/hint je dobrodošao.
Code:
# This is the main Samba configuration file. For detailed information about the
# options listed here, refer to the smb.conf(5) manual page. Samba has a huge
# number of configurable options, most of which are not shown in this example.
# The Official Samba 3.2.x HOWTO and Reference Guide contains step-by-step
# guides for installing, configuring, and using Samba:
# http://www.samba.org/samba/docs/Samba-HOWTO-Collection.pdf
# The Samba-3 by Example guide has working examples for smb.conf. This guide is
# generated daily: http://www.samba.org/samba/docs/Samba-Guide.pdf
# In this file, lines starting with a semicolon (;) or a hash (#) are
# comments and are ignored. This file uses hashes to denote commentary and
# semicolons for parts of the file you may wish to configure.
# Note: Run the "testparm" command after modifying this file to check for basic
# syntax errors.
# Security-Enhanced Linux (SELinux) Notes:
# Turn the samba_domain_controller Boolean on to allow Samba to use the useradd
# and groupadd family of binaries. Run the following command as the root user to
# turn this Boolean on:
# setsebool -P samba_domain_controller on
# Turn the samba_enable_home_dirs Boolean on if you want to share home
# directories via Samba. Run the following command as the root user to turn this
# Boolean on:
# setsebool -P samba_enable_home_dirs on
# If you create a new directory, such as a new top-level directory, label it
# with samba_share_t so that SELinux allows Samba to read and write to it. Do
# not label system directories, such as /etc/ and /home/, with samba_share_t, as
# such directories should already have an SELinux label.
# Run the "ls -ldZ /path/to/directory" command to view the current SELinux
# label for a given directory.
# Set SELinux labels only on files and directories you have created. Use the
# chcon command to temporarily change a label:
# chcon -t samba_share_t /path/to/directory
# Changes made via chcon are lost when the file system is relabeled or commands
# such as restorecon are run.
# Use the samba_export_all_ro or samba_export_all_rw Boolean to share system
# directories. To share such directories and only allow read-only permissions:
# setsebool -P samba_export_all_ro on
# To share such directories and allow read and write permissions:
# setsebool -P samba_export_all_rw on
# To run scripts (preexec/root prexec/print command/...), copy them to the
# /var/lib/samba/scripts/ directory so that SELinux will allow smbd to run them.
# Note that if you move the scripts to /var/lib/samba/scripts/, they retain
# their existing SELinux labels, which may be labels that SELinux does not allow
# smbd to run. Copying the scripts will result in the correct SELinux labels.
# Run the "restorecon -R -v /var/lib/samba/scripts" command as the root user to
# apply the correct SELinux labels to these files.
#======================= Global Settings =====================================
[global]
	null passwords = yes
	security = share
	max log size = 50
;	encrypt passwords = yes
	server string = Samba Server Version %v
	cups options = raw
	map to guest = bad user
	workgroup = MYGROUP
	log file = /var/log/samba/log.%m
	load printers = no
# ----------------------- Network-Related Options -------------------------
# workgroup = the Windows NT domain name or workgroup name, for example, MYGROUP.
# server string = the equivalent of the Windows NT Description field.
# netbios name = used to specify a server name that is not tied to the hostname.
# interfaces = used to configure Samba to listen on multiple network interfaces.
# If you have multiple interfaces, you can use the "interfaces =" option to
# configure which of those interfaces Samba listens on. Never omit the localhost
# interface (lo).
# hosts allow = the hosts allowed to connect. This option can also be used on a
# per-share basis.
# hosts deny = the hosts not allowed to connect. This option can also be used on
# a per-share basis.
# max protocol = used to define the supported protocol. The default is NT1. You
# can set it to SMB2 if you want experimental SMB2 support.
;	netbios name = MYSERVER
;	interfaces = lo eth0 192.168.12.2/24 192.168.13.2/24
;	hosts allow = 127. 192.168.12. 192.168.13.
;	max protocol = SMB2
;	guest account = nobody
# --------------------------- Logging Options -----------------------------
# log file = specify where log files are written to and how they are split.
# max log size = specify the maximum size log files are allowed to reach. Log
# files are rotated when they reach the size specified with "max log size".
	# log files split per-machine:
	# maximum size of 50KB per log file, then rotate:
# ----------------------- Standalone Server Options ------------------------
# security = the mode Samba runs in. This can be set to user, share
# (deprecated), or server (deprecated).
# passdb backend = the backend used to store user information in. New
# installations should use either tdbsam or ldapsam. No additional configuration
# is required for tdbsam. The "smbpasswd" utility is available for backwards
# compatibility.
;	passdb backend = tdbsam
# ----------------------- Domain Members Options ------------------------
# security = must be set to domain or ads.
# compatibility.
# realm = only use the realm option when the "security = ads" option is set.
# The realm option specifies the Active Directory realm the host is a part of.
# password server = only use this option when the "security = server"
# option is set, or if you cannot use DNS to locate a Domain Controller. The
# argument list can include My_PDC_Name, [My_BDC_Name], and [My_Next_BDC_Name]:
# password server = My_PDC_Name [My_BDC_Name] [My_Next_BDC_Name]
# Use "password server = *" to automatically locate Domain Controllers.
;	realm = MY_REALM
;	password server = <NT-Server-Name>
# ----------------------- Domain Controller Options ------------------------
# security = must be set to user for domain controllers.
# compatibility.
# domain master = specifies Samba to be the Domain Master Browser, allowing
# Samba to collate browse lists between subnets. Do not use the "domain master"
# option if you already have a Windows NT domain controller performing this task.
# domain logons = allows Samba to provide a network logon service for Windows
# workstations.
# logon script = specifies a script to run at login time on the client. These
# scripts must be provided in a share named NETLOGON.
# logon path = specifies (with a UNC path) where user profiles are stored.
;	domain master = yes
;	domain logons = yes
	# the following login script name is determined by the machine name
	# (%m):
;	logon script = %m.bat
	# the following login script name is determined by the UNIX user used:
;	logon script = %u.bat
;	logon path = \\%L\Profiles\%u
	# use an empty path to disable profile support:
;	logon path =
	# various scripts can be used on a domain controller or a stand-alone
	# machine to add or delete corresponding UNIX accounts:
;	add user script = /usr/sbin/useradd "%u" -n -g users
;	add group script = /usr/sbin/groupadd "%g"
;	add machine script = /usr/sbin/useradd -n -c "Workstation (%u)" -M -d /nohome -s /bin/false "%u"
;	delete user script = /usr/sbin/userdel "%u"
;	delete user from group script = /usr/sbin/userdel "%u" "%g"
;	delete group script = /usr/sbin/groupdel "%g"
# ----------------------- Browser Control Options ----------------------------
# local master = when set to no, Samba does not become the master browser on
# your network. When set to yes, normal election rules apply.
# os level = determines the precedence the server has in master browser
# elections. The default value should be reasonable.
# preferred master = when set to yes, Samba forces a local browser election at
# start up (and gives itself a slightly higher chance of winning the election).
;	local master = no
;	os level = 33
;	preferred master = yes
#----------------------------- Name Resolution -------------------------------
# This section details the support for the Windows Internet Name Service (WINS).
# Note: Samba can be either a WINS server or a WINS client, but not both.
# wins support = when set to yes, the NMBD component of Samba enables its WINS
# server.
# wins server = tells the NMBD component of Samba to be a WINS client.
# wins proxy = when set to yes, Samba answers name resolution queries on behalf
# of a non WINS capable client. For this to work, there must be at least one
# WINS server on the network. The default is no.
# dns proxy = when set to yes, Samba attempts to resolve NetBIOS names via DNS
# nslookups.
;	wins support = yes
;	wins server = w.x.y.z
;	wins proxy = yes
;	dns proxy = yes
# --------------------------- Printing Options -----------------------------
# The options in this section allow you to configure a non-default printing
# system.
# load printers = when set you yes, the list of printers is automatically
# loaded, rather than setting them up individually.
# cups options = allows you to pass options to the CUPS library. Setting this
# option to raw, for example, allows you to use drivers on your Windows clients.
# printcap name = used to specify an alternative printcap file.
;	printcap name = /etc/printcap
	# obtain a list of printers automatically on UNIX System V systems:
;	printcap name = lpstat
;	printing = cups
# --------------------------- File System Options ---------------------------
# The options in this section can be un-commented if the file system supports
# extended attributes, and those attributes are enabled (usually via the
# "user_xattr" mount option). These options allow the administrator to specify
# that DOS attributes are stored in extended attributes and also make sure that
# Samba does not change the permission bits.
# Note: These options can be used on a per-share basis. Setting them globally
# (in the [global] section) makes them the default for all shares.
;	map archive = no
;	map hidden = no
;	map read only = no
;	map system = no
;	store dos attributes = yes
#============================ Share Definitions ==============================
;[homes]
;	comment = Home Directories
;	browseable = no
;	writable = yes
;	valid users = %S
;	valid users = MYDOMAIN\%S
;[printers]
;	comment = All Printers
;	path = /var/spool/samba
;	browseable = no
;	guest ok = no
;	writable = No
;	printable = yes
# Un-comment the following and create the netlogon directory for Domain Logons:
;	[netlogon]
;	comment = Network Logon Service
;	path = /var/lib/samba/netlogon
;	guest ok = yes
;	writable = no
;	share modes = no
# Un-comment the following to provide a specific roving profile share.
# The default is to use the user's home directory:
;	[Profiles]
;	path = /var/lib/samba/profiles
;	browseable = no
;	guest ok = yes
# A publicly accessible directory that is read only, except for users in the
# "staff" group (which have write permissions):
[Pics]
	path = /home/tomek/Pictures
	writeable = yes
	create mode = 777
	directory mode = 777
	browseable = yes
	guest ok = yes
	public = yes
Staro 04.04.2015., 22:32   #2
Postovi: 23,571
Hm, ako se ti ne snalaziš u Ljinuxu kako ćemo tek mi smrtnici ?
Ovo šta si poviše je neki generic / defaultni konfig ?
Pitam zato jer ne vidim tvoje promjene, prvo mi je palo u oko ime workgrupe pa onda dalje ...
za početak jesi probao ovako > http://www.server-world.info/en/note...ora_21&p=samba
Staro 04.04.2015., 22:37   #3
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,140
Autor Nikky Pregled postova
Nije Linux što je nekad bio. Samba mi je rak rana. Neznam zašto. Ubuntu - nema frke. Mint - malo zezanja al da se. Arch - bezbolno. Kvaka je i u sučeljima odnosno kaj app postavi za defaultno (Mint+Mate je najbezbolnije). Al ovo nikak neće. I sad me baš puklo da doznam zašto.
P.S.- prvih 20 rezultata na googlu isprobano kao i dobar dio samba dokumentacije.
Staro 04.04.2015., 23:22   #4
Postovi: 23,571
Dobro, ajmo probati nas dva step by step,
prvo odg. na ovih par stvari:
- kako ti se zove workgrupa
- koji je mrežni segment odnosno ip adrese te lok. mreže
- jel ima win mašina na mreži, pogotovo ovih novijih (W7, W8), ovo pitam radi onog igrokaza oko domain master browser ...
Staro 04.04.2015., 23:36   #5
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,140
Mislim da je sve to nebitno. Želim složiti lokalni share - nezaštićeni bez lozinki i sranja za pristup sa moba (android 4.4 + ES file explorer) i telke (Panasonic 42AS600). Oba uređaja nađu kako god da postavim sustav na kompu - samo ih pristup samim fajlovima hebe.
Staro 04.04.2015., 23:37   #6
Postovi: 23,571
Jesi možda probao / provjerio ovo > http://jamesmcdonald.id.au/it-tips/f...elinux-enabled
Staro 04.04.2015., 23:59   #7
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 5,140
SeLinux je disejblan kao i firewall.
