Staro 14.12.2014., 23:17   #7411
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Mozes ovako "malo" poboljšati
1 x Procesor AMD FX X6 6300 3.5Ghz (4.1GHz) box
1 x LC POWER LC-CC-95, socket 775/1155/1156/AMD
1 x GIGABYTE GA-970A-DS3P, AM3+
1 x Crucial 8GB DDR3 1600 Mhz (PC3-12800) CL11
1 x Seagate HDD, 1TB, 7200rpm, SATA 6, 64M
1 x MSI Video Card Radeon R9 280 GAMING GDDR5 3GB/384bit
1 x Zalman Z3+, USB3.0 black
1 x Fortron Hyper 500W, 80+
Ukupno: 4908,00 kn
Staro 14.12.2014., 23:24   #7412
d3xt3r
Datum registracije: Dec 2014
Postovi: 4
Super, hvala.
d3xt3r je offline   Reply With Quote
Staro 15.12.2014., 15:08   #7413
Smartic
Smartic's Avatar
Datum registracije: Mar 2011
Postovi: 2,707
Stane FX 8320
Thermaltake Hladnjak za procesor, Thermaltake Contac 21
AMD FD8320FRHKBOX, FX Series X8 8320 CPU
XFX R9-280A-TDFD, DD Radeon R9 280 933M 3GB DDR5 2xmDispayPort, HDMI, 2x DVI
Sharkoon VS3-V Chrome Tower ATX kućište, bez napajanja, crno
XFX-P1-550S-GREN 550W Power Supply Black Edition, Bronze Certified, Full wired
Gigabyte GA-970A-DS3P
Seagate ST1000DM003, 1TB, 7200 rpm, 64MB, SATA 6Gb s, Barracuda The Power of One
Patriot Sig.,D3, 1600Mhz, 8GB (1x 8GB)
Iznos: 4.937,35kn
Staro 15.12.2014., 22:08   #7414
Hazy
Datum registracije: Jun 2014
Postovi: 23
Moze gaming konfa za 3500 kn.Bez periferije.
Hazy je offline   Reply With Quote
Staro 16.12.2014., 09:07   #7415
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
1 x AMD Athlon X4 860K, Black Edition Kaveri (3.7GHz,4MB,95W,FM2+) box
1 x Asrock FM2 FM2A88M EXTREME4, mATX
1 x Crucial 4GB DDR3 1600 Mhz (PC3-12800) CL11
1 x Gigabyte GV-R726XWF2-2GD, AMD Radeon™ R7 260x, PCI-E 3.0,2048MB GDDR5
1 x SILVERSTONE Strider ST40F-ES 400W, 1x120, 80+
1 x Raijintek Arcadia, USB3.0, black
3500kn
Staro 16.12.2014., 20:25   #7416
d3xt3r
Postovi: 4
Autor FRipper Pregled postova
Ukupno: 4908,00 kn
Ne razumijem se baš u računala pa me zanima jel bi moglo u ovu konfiguraciju ići taj AMD FX 8320 i dal se to isplati ili je dovoljan i ovaj FX 6300?
Staro 16.12.2014., 20:53   #7417
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,584
Autor d3xt3r Pregled postova
jesi vidio 3 posta iznad?
Nema neke razlike trenutno u gamingu (pogotovo mainstream grafom), osjetio bi eventualno u MP BF4 i sl...
Staro 16.12.2014., 21:21   #7418
d3xt3r
Postovi: 4
Vidio sam, zato i pitam jer vidim da je Smartic spomenuo taj procesor, ali je promijenio neke komponente. Mene zanimalo jel ide u onu konfiguraciju koju je stavio FRipper taj procesor. Ali ako nema neke razlike onda ostaje ova koju je FRipper složio, hvala.
Staro 16.12.2014., 23:09   #7419
RaNz0
Lokacija: Zagreb/Križevci
Postovi: 346
jel bolje do 4000 kn uzeti intel, ili amd konfiguraciju za igranje? zašto?
konfiguracija će biti kupljena karticom, pa treba biti iz jedne trgovine. molim preporuku, hvala
RaNz0 je offline   Reply With Quote
Staro 17.12.2014., 00:09   #7420
Manuel Calavera
Postovi: 14,584
amd - jer dobiješ bolji cpu za nove i buduće igre, od intela bi te mrvicu jeftinije izišao i3 za takav buđet.
Procesor AMD X6 FX-6300
Matična ploča Gigabyte GA-970A-DS3P,AM3,A970,D3,S3,U3,A
Spire Kepler Rev.2 hladnjak 115X/775/AM2-3/FM1-2
Crucial Module 8GB, 240-pin DIMM, DDR3 PC3-12800, CL=11, Unbuffered, NON-ECC
Grafička kartica XFX AMD Radeon R9 270A 2GB DDR5, XFX-R9-270A-CDFC
Toshiba DT01ACA100 1TB 3.5''
CORSAIR Power Supply, Builder Series CX 80+ Bronze, 430 Watt, ATX, EPS12V, PS/2, EU Version
MS PHOENIX kućište bez napajanja
4056kn
izbačena pržilica (os možeš i sa usb-a snimit)
edit - na kartice ide 8% gore u ovim primjeru, onda samo zamjeni grafičku za gtx 750 ili 260x, hard od 500gb, eventualno 4gb rama...
Staro 17.12.2014., 17:49   #7421
snorky_vk
snorky_vk's Avatar
Lokacija: u mraku
Postovi: 846
Jel moze netko u hgspotu vk slozit mi konfu za 3000kn.max 3100 cca. Samo kuciste. cad i koja igra namjena. Tnx
snorky_vk je offline   Reply With Quote
Staro 17.12.2014., 18:14   #7422
Smartic
Smartic's Avatar
Postovi: 2,707
Napajanje FORTRON Hexa Plus, 400W, 80+, active, 12cm
Kućište SHARKOON VG4-S, bez napajanja, crno
Tvrdi disk 500 GB, SEAGATE Barracuda ST500DM002, 3.5", 7200 rpm, SATA III
Memorija A-DATA 4 GB DDR3, 1600 MHZ DIMM, bulk
Grafička kartica XFX AMD Radeon R7 260X,1GB DDR5
Procesor Intel Pentium G3258, 3.2 GHz, Socket 1150
Matična ploča MSI H81M-P33, socket 1150
Ukupna cijena: 2.995,65 kn
Staro 17.12.2014., 19:47   #7423
snorky_vk
snorky_vk's Avatar
Lokacija: u mraku
Postovi: 846
Hvala. Biti ce slicno. Sad sam bio u trgovini. napajanje ce biti xilence eco 450w i 1tb toshiba. Tako je ispalo .ono sto su imalo na stanju smo stavili, a da bude u budjetu.komp treba hitno veceras, riknio stari lap, a treba zavrsiti nesto danas i sutra u cadu...
Zadnje izmijenjeno od: snorky_vk. 19.12.2014. u 23:42.
Staro 17.12.2014., 20:36   #7424
eXactMat
Lokacija: Poreč
Postovi: 29
Pozdrav ekipa, evo prijavio sam se na forum po preporuci prijatelja koji mi je rekao da mogu vas pitati za savjet u vezi slaganja konfiguracije. Pa da krenem. Grafička(HD4870 1GB) mi je vrisnula ko gica pred kolinje i sad sam na mukama jer ne mogu zaigrati apsolutno nikakvu igru osim briškule . Dakle, treba mi konfiguracija za gaming i koja bi bila aktivna cca 3-4 godine. Najviše igram wot, ali s promjenom grafe i svega ostalog, mislim da cu se baciti i na druge igre.Ovo je trenutna konfiguracija:
1-KUČIŠTE -Thermaltake soprano DX
2-HARD -Toshiba DT01ACA100 750 GB
3-PROCESOR -Intel core 2 Duo E8500 3,16 Ghz
4-MATIČNA -Gigabyte X48-DS4(Chipset beachwood)775
5-MEMORIJA -OCZ 2Raper 2x2 gb ocz2rpr10662g
6-GRAFIČKA -Radeon HD4870 (1gb) RU770XT
7-NAPAJANJE -Chiftec CFT-750-14
8-MONITOR -Dell P2414H
9-HLADNJAK VGA-Setsugen 2 (star 1 mjesec )
Znači, treba mi pomoć oko slaganja a budžet je cca 4000-5000 kn, bez monitora i kučišta. Molim vas da mi napišete nekoliko verzija ako nije problem. Jako se dvoumim između Nvidije i Ati-a. Do sad sam imao Ati navedenu karticu koja nikad nije imala problema i sad nakon 6 godina, otišla je u zasluženu mirovinu. Također se dvoumim da li da mijenjam i napajanje ili da ga ostavim pošto radi.Ako može, napišite mi verzije s INTELOM i AMD-ovom matičnom i procom i navedite mi prednosti i mane.
Ispričavam se na ovako dugačkom postu ali gori mi pod nogama.
HVALA unaprijed na pomoći.
LP
P.S. Ako može, navedite mi koliko bi se moglo dobiti novaca kad bi isao prodati ove postojece komponente preko njuškala. Naravno osim ove grafičke koja ne radi za sve osim za internet :P
Zadnje izmijenjeno od: eXactMat. 17.12.2014. u 20:41. Razlog: dopuna
eXactMat je offline   Reply With Quote
Staro 17.12.2014., 22:15   #7425
Smartic
Smartic's Avatar
Postovi: 2,707
Ja bih zadržao i disk, a gore staviš SSD. Ako ti je WoT primarna igra, svakako Intel.
Patriot Sig.,D3, 1600Mhz, 8GB (1x 8GB) PSD38G16002
Patriot SSD Blaze R545/W430, 120GB, 7mm, 2.5"
Procesor Intel Core i5 4460
Matična ploča ASRock H87-PRO4, 1150
Grafička kartica Gigabyte Radeon R9 280 WF3 OC, 3GB GDDR5, HDMI, DVI
XFX 550W Easy rail Bronze, XFX-P1-550S-GREN
=4.999kn
Bez napajanja je to ~4550kn, iako je tvoje dosta staro, na papiru ovo odrađuje s pola snage. Trebalo bi biti u redu...
Stare komponente:
CPU: 200-250kn
Matična: 250kn
RAM: 250kn
Staro 18.12.2014., 00:13   #7426
eXactMat
Lokacija: Poreč
Postovi: 29
Da li ima još tko kakvu preporuku?
Staro 18.12.2014., 08:20   #7427
RaNz0
Postovi: 346
4056kn
hvala
Staro 18.12.2014., 08:29   #7428
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
Autor eXactMat Pregled postova
Ok je preporuka od smartića, samo izmjena tog ssd-a u Intel 520, 120gb i slobodno napajanje isto tako ostavi i da, nisam siguran da gigabyte grafa stane u to kućište pa ako ne stane idi na MSI R9 280
Staro 18.12.2014., 08:59   #7429
eXactMat
Lokacija: Poreč
Postovi: 29
Da li uzeti GTX 970 G1 WINDFORCE ili ASUS R9 290 4GB DIRECT CU2 OC??
Razlika u cijeni je cca 600 kn.
Staro 18.12.2014., 09:49   #7430
llama
llama's Avatar
Datum registracije: Aug 2014
Lokacija: Slavonija
Postovi: 84
GTX ti trosi manje struje i koliko sam cuo, pretjerano se ne grije dok radeonka trosi vise struje i ponovno, kako sam cuo, dosta se zagrije. Gledao sam sad na googlu malo i vidio da gtx-ica daje i vise fps-ova
^koliko ti je ovo pomoglo ne znam ;D :P ali ja bih osobno isao na gtx-icu ali mozda neki jeftiniji model.
3.2.2015.-"Reći ću vam samo jednu stvar - zapamtite VukoWar"
llama je offline   Reply With Quote
Staro 18.12.2014., 13:56   #7431
Manuel Calavera
Postovi: 14,584
970 je malo jača, troši drastično manje struje (možeš koju kn uštedjeti na napajanju, za 290 bi bilo najpametnije 650w kvalitetno ili jače), ima više featurea i sl... Minus joj je izvjesniji coil whine...
r9 290 je osjetno jeftinija, asusova je OK, cooler je dobar (tj. ne pregrijava se), pa sam odluči što ti se isplati
Staro 18.12.2014., 17:35   #7432
eXactMat
Lokacija: Poreč
Postovi: 29
Znači koju god da uzmem, nisam promašio. Realno za jednog prosječnog korisnika, da li je to vrijedna razlika od cca 600 kn i da li bi je ja uopce primjetio?
Staro 18.12.2014., 19:02   #7433
Manuel Calavera
Postovi: 14,584
a ovisi od igre do igre. Tako da je relativno to dal bi osjetio (također imaš i posebne nvidia grafičke feature). Najbolje da si pogledaš neke testove, al ovako u globalu, što se tiče samih perfomansi - nije velika razlika
Staro 18.12.2014., 19:14   #7434
eXactMat
Lokacija: Poreč
Postovi: 29
Ovako, ovo je trenutno na pameti. Molim za što brži odgovor, jer upravo se spremam naručiti.
Proc: i5 4690k
Matična: GA-Z97-D3H
Grafička: ASUS R9 290 DIRECT CU II OC 4 GB
Memorija: Kingston hyper x fury black 1866 mhz 2x4 gb
Napajanje ostaje moje chiftec 750 koji sam naveo prije u postu
Kučište ostaje moje thermaltake soprano dx
S tim da kroz mjesec, dva mislim uzeti drugo kučište i napajanje, ali prvo da prodam ove moje komponente i da legne nova plaća.
Evo trebam brzo mišljenje o ovome navedenom.
Hvala i LP
Staro 18.12.2014., 19:19   #7435
Manuel Calavera
Postovi: 14,584
Napajanje nije cvijeće, al trebalo bi raditi. Na papiru ima i više nego dovoljno snage...
Samo provjeri dal ti stane u case grafa, ta asusica je 28.7cm
EDIT - stane s micanjem hdd cagea
Q: What is the longest graphics card that may be used with this chassis?
A: 12.29" is the length of the longest card on the market. This chassis will fit this size of card with the removal of the HDD cage. Standard size fit for the chassis 9.6".
Staro 18.12.2014., 19:30   #7436
eXactMat
Lokacija: Poreč
Postovi: 29
Evo to ovako izgleda.
ID:	14247   Click image for larger version
Staro 18.12.2014., 19:38   #7437
adaksinjo
adaksinjo's Avatar
Datum registracije: Dec 2011
Lokacija: Virje
Postovi: 590
moj prijedlog ti je da uzmes zalman z3+ ili recimo zalman r1 koji su oko 300kn. uzmi jeftiniju graficku (usparaj 600kn) i imas za novo kuciste.
nek ti ekipa u ducanu sastavi kupljene komponente, a iduci mjesec sam ubacis novo napajanje.
Staro 18.12.2014., 20:04   #7438
Manuel Calavera
Postovi: 14,584
ma OK je, nemaš cage unutra
Staro 21.12.2014., 10:05   #7439
jacobbb
jacobbb's Avatar
Lokacija: somewhere
Postovi: 565
Pozdrav,
treba mi preporuka za konfiguraciju. Neki budžet mi je do 4 - 4,5 tisuća kuna. Glavna zadaća kompa je obrada video materijala HD ali i 4K HEVC. Ovo drugo me u biti najviše muči koliko bi komp za te pare mogao obavljati takvu zadaću pa ako može preporuka od nekoga tko ima iskustva sa istim. Pretpostavljam da bi tu trebala neka jača mašina? Ono što bi još bilo dobro je da grafička ima video izlaze da se danas-sutra može priključiti i na TV (neki hdmi izlaz bi valjda tu trebao?) te da je komp što tiši jer osoba koja će raditi na njemu će ga držati u spavaćoj sobi i vjerojatno će nekad ostati i upaljen preko noći pa da se ne čuje. Što se igrica tiče - nula bodova, sigurno se neće nikada nikakva igrica instalirati na to. Monitor, tipkovnica, miš - ne ulaze u gornju cijenu.
Ako netko može pomoći i zna 100% da će konfiguracija koju složi biti adekvatna za takvo što (osobito naglavašavam za 4k hevc obradu) molio bi da napravi neku konfiguraciju do 4 - 4,5 tisuće kuna. Hvala
jacobbb je offline   Reply With Quote
Staro 21.12.2014., 10:31   #7440
FRipper
MiningMod
FRipper's Avatar
Postovi: 8,715
1 x Intel Core i7-4790 Soc 1150 CPU
1 x ASRock B85-PRO4, 1150
1 x MSI Video Card GeForce GT 740 GDDR5 2GB/128bit
1 x SEAGATE HDD DESKTOP SSHD 3.5" / 1TB / 64m/ SATA/ 7200rpm
1 x Optički uređaj Samsung SH-224DB SATA Bulk Crni
1 x Zalman Z1, USB3.0 black, 2x120mm
1 x Fortron Hexa+ 400W, 80+, active, 12 cm
5600 kn
+ kasnije ako bu potrebe dodati još 8gb rama...
