#1831 | |
Lika u mom srcu
Lokacija: Canada, Toronto
Postovi: 9,887
ali nisam uspio isprobati, sinoc sam kasno dosao kuci tako da ga nisam jos spojio. Budem danas. Kako bi trebale biti postavke u ATI control panelu na kompu za ovaj monitor? Ili generalno, jer mi je trenutno na plazmu spojen komp, jel trebam drzati na Limited RGB, full RGB, ypbpr ili kako se vec zove... |
#1832 | |
Datum registracije: Sep 2012
Postovi: 418
#1833 |
Lika u mom srcu
Postovi: 9,887
pa evo ti link sa rjesenjem navodno https://pcmonitors.info/reviews/dell-u2414h/ samo napravis custom rezoluciju, i refresh rate stavis 59.999Hz i ima cak i utility koji instaliras i rijesi to trajno *Some games seem to ignore custom resolutions and will instead revert to using the default Limited Range RGB 16-235. That is why a preferred method for correcting the colour signal over HDMI is to use this utility. You just run the .exe file included in the .zip and click the button at the top right which is labelled ‘Set Full Range (0-255)’. You then simply restart your computer. You don’t have to re-run the tool every time the computer starts up, only if you ‘clean install’ a new graphics driver or replace your OS. |
#1834 | |
Postovi: 418
Tebi se odmah vidi razlika kad to napraviš? Evo i ode malo o ''rješenju'' tog problema https://pcmonitors.info/articles/cor...-and-amd-gpus/ |
#1836 |
Lika u mom srcu
Postovi: 9,887
ok, evo spojio sam ga, u postavkama sam normalno mogao pod Pixel color staviti FullRGB, iako u display properties je pod HDTV? kad odem u monitor postavke na samom monitoru, pod color input mi stoji RGB... valjda je to to onda? monitor ima strasnu bijelu, i kontrast cudo, odjednom vidim hrpe nijansi koje prije uopce nisam vidio ono forum mi je sad saren nijanse sive, roze, plave, bez... ![]() brightness sam spustio na 50, contrast na 75. ali mislim da cu jos smanjiti brightness.. jer sjedim u mraku edit: sad probao film staviti i lagano razocaranje, moja plazma ga POJEDE po pitanju crne i uniformnosti ekrana. ali dobro, nisam ga zato uzeo. Zadnje izmijenjeno od: Gabre. 14.11.2014. u 03:20. |
#1837 |
Džabe si krečio!
Postovi: 5,190
Meni je brightness na 5%, iznad toga mi je sve preblještavo ![]() Ja isto nisam bio zadovoljan prikazu boja, baš ću se poigrati sa ovime svime sad, otvorili ste mi oči, posebno kolega Volume ![]() Otkad sam ga kupio, nikako mi nije sjeo taj prikaz boja, sve mi je izgledalo isprano... |
#1838 |
Postovi: 418
Evo uspio sam i ja riješiti problem. Izgleda da nešto nije uredu s mini dp-om i zato nikako nisam mogao izvući full rgb iz njega. Danas sam uzeo običan dp kabel, spojio i napravio custom 1080p rezoluciju na 65Hz za svaki slučaj tako da su 3d programi prisiljeni koristiti postavke koje sam ja namjestio, a ne da vraćaju native 1080p čime bi opet možda koristili limited rgb i prepoznavali monitor kao HDTV. Također sam napravio custom color na monitoru R99, G92, B98 i brightness na 35. Ovo mi je sad pun pogodak, razlika nebo i zemlja u odnosu na ono šta mi je bilo prije ![]() |
#1839 |
Lika u mom srcu
Postovi: 9,887
ja kada saltam u ATI control panelu, bas vidim promjene, pokrenem film u Gom playeru, pauziram, stavim preko pola ekrana i onda mijenjao izmedju limited RGB, FullRGB i onih Ypbxzxz modova. i svaki mod pokazuje drugaciju boju tako da predpostavljam da radi. i svakako mi je na fullRGB najbolja slika. jos se moram poigrati sa brightnessom, jer mi je crna porazavajuce losa. a bogme i detalji u njoj. |
#1840 |
Postovi: 1,807
Loša crna se podrazumjeva kod lcd-a, manje ili više i na to treba računati/pomiriti se s tim u startu i nadat se da je ovo drugo barem ok. Uniformiranost ekrana, prikaz boja na cijelom ekranu, odaziv, input lag-ukolko je tu sve ok monitor je dobar. Valja napraviti neki kompromis u jačini pozadinskog tako da se dobije najviše crne kaj se može,a da pritom slika ne bude previše zagasita ili lišena detalja. Ukoliko te to toliko živcira nabavi si neku sobnu lampu, tj izbjegavaj gledati filmove u potpuno mračnoj sobi |
#1841 |
Lokacija: home
Postovi: 572
Gabre, zajebi gom ako ne podrzava madVR, instaliraj onda mpc-hc, pa madVR, pa pokreni neki film, otvori madvr settings i poigraj se s s catmul rom za image downscaling, za chroma i image upscaling probaj jinc (3 taps) s antiringing filterom. usput probaj i image doubling, ako je kartica dovoljno brza, jer je metoda efektivnija negoli upscaling sam (obrati paznju na luma doubling jer dobro funkcionira na default settingu). s tom kombinacijom izvuces najvise iz monitora sta se tice video prikaza. p.s. inace gledam filmove na monitoru. nekoliko sam puta svjedocio hd projekcijama na velikim televizorima, mahom lcdima. s br-om kao izvorom slika je ok, nista spektakularno. sa satelitskih hd kanala slika je odvratno losa.
iconography fucks with me...you look great in bloodstains... |
#1843 | |
Lika u mom srcu
Postovi: 9,887
meni je gom vec godinama default player, i preko njega s kompa pustam na plazmu filmove... morma priznati da nisam nikad bio odusevljen njegovim prikazom, ali iskreno nisam primijetio neku razliku ni kod drugih plazera pa sam ostao na njemu jer mi ima jako prakticne kratice preko tipkovnice... daj me uputi malo bolje sto kako gdje da podesim jer ovo sto si napisao mi je ko japanski trenutno ![]() |
#1844 |
Lokacija: home
Postovi: 572
naravno, nemas problema, kad uhvatim malo vise vremena veceras/sutra, sibnem ti sve potrebne elemente za download i screenshotse s podesavanjima playera na pm. @blackened: nadi icc profil na tft koji odgovara tvojim rgb postavkama.
#1846 | |
Lika u mom srcu
Postovi: 9,887
sto jos koristis osim njega |
#1848 | |
Postovi: 8,357
#1851 |
Lokacija: home
Postovi: 572
mad vr mora bit ekstraktiran unutar mpc foldera u pf.
#1855 |
Lika u mom srcu
Postovi: 9,887
stavio, malo usporedjivao isrte scene usporedno sa gomu bez madvr-a i mpc sa madvr-om... a ono, moras se truditi naci razlike kod HD materijala.. jedino di se stvarno osjeti se kod dvdripova, tu slika izgelda daleko bolje/ostrije nego na gomu ali posto takve ne gledam inace, onda su razlike zanemarive |
#1856 |
Lokacija: Zd
Postovi: 4,750
Kupujem novi monitorcek i ciljam na nesto kvalitetnije po mogucnosti sa mate premazom... Za oko mi je zapeo U2414H (1800kn) upravo radi odlicnog dizajna, tankih bezela i kvalitetnog ekrana. Moze netko podijeliti dojmove iz prve ruke, ili preporuku za nesto slicno... |
#1857 | |
Lokacija: Zagreb, Dubrava
Postovi: 502
#1858 | |
Lokacija: Zd
Postovi: 4,750
Inace, sto se tice slike i ostalih funkcija monitora (tilt, pivot i sl.) - tu nema frke? |
#1859 |
Postovi: 502
