Postovi: 23,532
Linksys WRT1900AC
![]() Ova zvjerka zaslužuje svoju temu na PC Ekspertu, za početak treba navesti par bitnih detalja. Još u Ožujku 2013. Cisco je prodao Home Networking business i vodeći brand Linksys, Belkin International Inc. Nakon te transakcije Belkin zadržava Linksys brand i nastavlja podršku za sve njihove uređaje. Ranije ove godine nastaje ideja o uređaju koji će biti dostojni nasljednik legendarnog WRT54GL, tako je nastao WRT1900AC. Sami pogled na kućište daje jasnu asocijaciju na WRT54GL. Najvažnije karakteristike a ostalo pogledajte u linkovima: WRT1900AC Hardware Specifications - 80211ac Wi-Fi (backwards compatible with 802.11a/b/g/n) - Speeds up to 1300Mbps on the 5Ghz band - Speeds up to 600Mbps on the 2.4 Ghz band - Gigabit WAN & LAN ports - 1 x eSata/USB 2.0 port - 1 x USB 3.0 port - 1.2GHz dual-core ARM-based processor - 128MB Flash Memory - 256MB DDR3 RAM - 4 exchangeable external antennas WRT1900AC Software Features - Browser based set-up for installation from device PC/Mac, smartphone or tablet - Can be configured as: Router, Range Extender (aka Repeater) or Wireless Bridge - Free Linksys Smart Wi-Fi account - Linksys Smart Wi-Fi can be accessed from a browser or the Linksys Smart Wi-Fi app for iOS and Android - Share printers or storage devices through USB or eSata - Built in DLNA certified media server and FTP Server to share files - Drag and drop media prioritization to prioritize bandwidth for devices, applications or games - Parental controls to prevent access to websites or block access during certain hours - Dynamic DNS services supported: No-IP, DynDNS and TZO - Built-in speedtest to test broadband upload and download speed - Open Source Ready Review Linksys WRT1900AC 802.11ac Smart Wireless Router OpenWrt - Update on Linksys WRT1900AC support OpenWrt Wiki - Linksys WRT1900AC DD-WRT - Linksys WRT1900AC O ozbiljnosti izvedbe možda najbolje govore ove slike unutar uređaja 1 ili 2 (namjerno stavljeno kao link jer su velike slike). Interesantan detalj je službena suradnja sa OpenWRT zajednicom kako bi osigurali alternativni fw ako to korisnik zaželi. Koliko sam vidio OpenWRT je operativan ali se još bore sa nekim funkcijama i detaljima, DD-WRT je u funkciji a ako je vjerovati napisanom speedtest je 20% bolji u odnosu na originalni fw. Važno je naglasiti da originalni fw ima "sve šta đaku treba" i radi uredno. Na kraju dođe pitanje, koliko ta zabava dođe ? Za naše uvjete prilično skupo, trenutna cijena cca €2xx sa polaganim padom kako je to uobičajeno. That's all ![]() |
Datum registracije: Aug 2013
Postovi: 4,332
Ahh.., ko da gledam 90-60-90 komada.., samo za odlikase ![]() |
#5 | |
Lynnfield
Datum registracije: Sep 2012
Postovi: 1,023
Ako mi može udvostručit brzinu od t-coma bez dodatnog plaćanja onda ga uzimam |
Lokacija: Hrvatistan
Postovi: 4,164
1. odličan uređaj, vjerojatno hardverski neuništiv (osim u naletima bijesa) 2. u startu otključan za linux firmware 3. linux firmware je native a ne fakin đava virtualka ![]() 4. modem je samo dodatna komponenta koja obicno prva stradava uslijed nevremena i bolje da je odvojeno, a i provideri najebu svoje pizdarije na modeme (voip, tv) koje je malo teze za iskonfigurirati na custom romu 5. ako je imalo sličan wrt54gl, dosel bude sa JTAG pinovima zahvaljujuci kojima nema šanse da ga zbrikaš krivim flešanjem e sad, jedino kaj me brine je to dal bude mu "samo" 256mb rama dovoljno. ipak je u pitanju linux ruter koji sam po sebi ima puno mogucnosti (torrent, web server, web filtering, QoS, dlna) |
Lynnfield
Postovi: 1,023
dobro, kužim da je to kralj među ruterima, bilo bi dobro da ima i konkurencije pa bi i cijena bila manja, pa bi ga možda i obični useri kupili i zaje***se s njim sviđa mi se 5. stavka, ja sam jednog zbrikao kažem zezao sam se sa tim wrt54gl, imao sam ga ja sam inače povezan žično Zadnje izmijenjeno od: Nikky. 23.09.2014. u 17:05. |
Postovi: 23,532
A eSata/USB 2.0 port i USB 3.0 port si zaboravio ![]() Kad sam nabrzinhen čitao vidio sam da je Uboot složen kako treba, u prevodu kad zezneš fw ima recovery procedura kojom lako ubaciš ispravni fw ... Pa divljenje je relativno opravdano karakteristikama, da se može napravit pošten uređaj kad se hoće, ... eno ga je ED uvrstio u cjenik po naruđbi za sitnih 1.929 krznenih životinja. |
Postovi: 1,346
evo par testova sa jedne (po mom mišljenju) meritornih stranica: http://www.smallnetbuilder.com/wirel...-router-review http://www.smallnetbuilder.com/wirel...iew-more-tests http://www.smallnetbuilder.com/wirel...r-retest-redux |
#11 | |
Postovi: 4,332
Postovi: 23,532
Ovdje nije riječ o kao u drugim temama gdje smo govorili koja je propusnost adsl parice, pa koliko je "otvoreno" na DSLAM portu, pa na koju brzinu se sinhronizirao modem, pa koju brzinu je klijent zakupio ... Ovdje se radi o cca 20% povećanju speedtest, znači wan <> lani, sa alternativnim fw (mislim da se radilo o DD-WRT) a na istim uvjetima (linija, ugovorna brzina, ...). Znam na što aludiraš ali vani ima operatera koji na određenoj infrastrukturi, recimo cable ili optika) daju do 100 Mb, kod nas to možeš dobiti na optici ... E sad, ovo 20% povećanje je ekipa prijavljivala na istom uređaju (iz naslova) nakon šta je ubacila odr. alternativni fw. To je moguće jer je "špina dovoljno otvorena" od strane isp - a samo sada uređaj bolje hendla promet i time postiže veću brzinu / bolji rezultat. U gornjem primjeru tj. "spojnom putu" namjerno nema DSL - a jer se on bitno razlikuje u odnosu na cable a pogotovo optiku. Kod optike nema od - do brzine nego je ona fiksno postavljena (uvjetima ugovora i/ili teh. mogućnosti spojnog puta). Dakle razlika se pojavljuje u tome kako pojedini uređaj može (hw) i zna (fw) hendlati određeni promet. Negativan (hw) primjer bi bio ko da sad na pouzdano dobru ADSL2+ liniju koja može "dati" 12 Mb spojiš staru Kasdu (po specs 8/1), ako je u Bridge mode na kompu ćeš dobiti nešto ispod 8, a ako je u Router modu pod većim teretom bi mogao dobiti značajno niže. Nadam se da si me razumio. Stvari se značajno mijenjaju / kompliciraju kod bržih broadband konekcija. |
Postovi: 4,332
Danke, razumio u potpunosti ![]() |
Postovi: 1,346
Zadnje izmijenjeno od: lobo64. 07.08.2015. u 19:56. |
