Staro 17.09.2014., 12:15   #31
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,251
Autor Dottore Pregled postova
Uf, sviđa mi 960 .
Moze link?
Slobodno me dodajte na PSN
Staro 17.09.2014., 12:51   #32
ukiy
ukiy's Avatar
Datum registracije: Apr 2008
Lokacija: ST
Postovi: 398
Evo i detalja o MSI GTX 970 Gaming
MSI’s GTX 970 is not a card for casual gamers. GTX 970 GAMING is a real monster. It has two huge 100mm propeller-blade fans accompanied by a nice black and red shroud.
GeForce GTX 970 has 1664 CUDA cores, 384 less than GTX 980. MSI’s 970 GAMING is factory-overclocked to 1140 MHz, with a boost clock at 1279 MHz. It has 4GB GDDR5 memory across 256-bit interface. This particular card has a TDP of 148W, so two power connectors, from which one is 8pin, were not really required.
Unlike reference card, MSI’s model has only a ‘default’ set of display connectors: DVI-I, DVI-D, HDMI and DisplayPort. GeForce GTX 970 will launch on Friday, the price remains unknown.
ukiy je offline   Reply With Quote
Staro 17.09.2014., 13:20   #33
realmadrid
realmadrid's Avatar
Datum registracije: Aug 2010
Postovi: 239
jedino što sam uspio iskopati o GTX 960, a da je vezan uz specifikacije: http://www.game-debate.com/hardware/...TX%20960%202GB
BTW, mislim da bi bilo ok temu preimenovat u GTX 900 series
realmadrid je offline   Reply With Quote
Staro 17.09.2014., 13:21   #34
arnso
arnso's Avatar
Datum registracije: Aug 2011
Postovi: 79
http://wccftech.com/nvidia-geforce-g...retail-329349/
Navodno bi referentna 970 ipak mogla biti 299 dolara. Najbolje da pricekamo do petka
Zadnje izmijenjeno od: arnso. 17.09.2014. u 13:33.
arnso je offline   Reply With Quote
Staro 17.09.2014., 13:47   #35
listerstorm
listerstorm's Avatar
Datum registracije: Apr 2011
Postovi: 1,428
Autor Disco Pregled postova
Naravno, najbolja im je bila fx5800, to je bila the grafa u svoje vrijeme, tiha, brza stedljiva, jednostavno savrsena.
Koliko se sjećam, FX serija je, što se gaminga tiče, možda bila i najveći fail jer su tadašnje radeonke bile maltene bez konkurencije (9700 pro je rasturio sve što je Nvidia imala u to vrijeme).
Staro 17.09.2014., 13:54   #36
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,251
Autor listerstorm Pregled postova
Pa zato sam je i spomenuo, sarkazam, jelte
@realmadrid: ovo izgleda sve super (pogotovo TDP od samo 100W!!), ali cini mi se da 2gb polako postaje premalo za 1080p.
nVidia klasicno skrta sa RAM-om
A sto se tice cijene 970ice od 299$ iliti cca 2100-2300kn, pa super, kupjem odma
Staro 17.09.2014., 14:37   #37
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
Mislim da ce ref. model od 300$ bit sa jeftinim PCBom i da ce se isplatit protegnut do skupljih. Mislim da ce se to osjetit i na taktovima i performansama.
Mene vise muci kronicni nedostatak dobrih igri na PCu. Ne znam kaj bi uopce igral sa tak jakom grafom.
MAGARAC je online   Reply With Quote
Staro 17.09.2014., 14:40   #38
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,251
Autor MAGARAC Pregled postova
Ma naravno, ova od MSI-a mi izgleda odlicno!
Ovu koja mi je trenutno u kompu je referentna, pa je imala neki srot hladnjak koji se cuo kao usisavac u IDLE-u, i onda sam kupio ovo cudoiviste od shamana da ga vrtim na minimalnim okretajima, a kartica se jadna smrznula pod njim
Ako se dobro sjecam, razlika pod Furmarkom, izmedju ovog i originalnog hladnjaka je 20-30 stupnjeva!
I to, original na ful okretajima, a ovaj na minimumu.
Staro 17.09.2014., 14:46   #39
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
Vidim po 750Ti, iako ne mogu bit siguran da ce tak bit i sa ovima. Malo bolji modeli redovito postizu puno vise taktove od jeftinijih, preko 1400mhz. Ak bu tak kod ovih, onda je sve jasno.
Staro 17.09.2014., 15:57   #40
Brlja
Postovi: 874
Autor ukiy Pregled postova
Kako mi je srce zaigralo od samog pogleda na nju. A pazi TDP od 148W. Sama će se isplatit nakon cca 37 000 sati gejmanja u razliku na moju trenutnu!
Brlja je offline   Reply With Quote
Staro 17.09.2014., 18:55   #41
esc
Lynnfield
Datum registracije: Sep 2012
Postovi: 1,023
Autor Brlja Pregled postova
ne sviđa mi se baš,plastika...one prijašnje serije 500 msi TF su imale lim jel tako?
mogli su nabacit barem 3gb rama za 960 ako je istina ovo da će imat samo 2gb vrama
esc je offline   Reply With Quote
Staro 17.09.2014., 19:06   #42
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,848
kolko će bit 960 brža od 760?,ne znam kako je bilo sa prijašnjim karticama ali nvidia mi se čini uvjek prvo izbaci skuplje kartice onda jeftinije valjda da se više 980 i 970 proda.
Staro 17.09.2014., 19:16   #43
Brlja
Postovi: 874
A gle sad sam tek skužio da je to plastika... Ali meh, nije to toliko važno iskreno.
Staro 18.09.2014., 14:24   #44
lateralus_eye
lateralus_eye's Avatar
Postovi: 602
http://wccftech.com/nvidia-geforce-g...ictured-glory/
UPDATE: According to latest reports, NVIDIA will set the price of the GTX 970 down to $299 USD. However the GTX 980 would remain around $549 USD. Expect that non-reference cards will be priced higher at around $20 to $50 more.
Cijena za 970 <3!
lateralus_eye je offline   Reply With Quote
Staro 18.09.2014., 15:12   #45
Garro
Postovi: 2,375
Uz ovakvu cijenu 970, imam osjećaj da će brzo pasti cijena 980...
Nego, jel netko prodaje svoju 780ti? Vrlo rado bi jednu udomio.
Staro 18.09.2014., 16:12   #46
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,251
http://wccftech.com/nvidia-maxwell-g...faster-r9-290/
Procurili prvi bencevi.
Kazu da je 980 15% brza od r9 290x, a 970 10% brza od r9 290.
Staro 18.09.2014., 16:15   #47
tole_
Casual Racist
tole_'s Avatar
Lokacija: Sneed's feed and seed (formerly Chuck's)
Postovi: 422
Pitanje je ima li itko uopce 780ti
Ovo je neka rafinirana verzija Gigabyteove GTX680SOC heh
Zadnje izmijenjeno od: tole_. 18.09.2014. u 16:24.
tole_ je offline   Reply With Quote
Staro 18.09.2014., 16:21   #48
Brlja
Postovi: 874
A čuj 970 kak si fino chilla na 65 stupnjeva u loadu. Onak laganica.
Staro 18.09.2014., 16:27   #49
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,251
Ali potrosnja je stvarno impresivna, pogotovo u usporedbi sa r9!
I jos ako je istina ovo o cijeni za 970...
Nadam se da AMD ima spremno nesto dobro kao odgovor na ovo.
Staro 18.09.2014., 16:44   #50
esc
Lynnfield
Postovi: 1,023
pa nema ništa spremno ali sigurno će spustit cijene
Staro 18.09.2014., 16:58   #51
Litra
Litra's Avatar
Lokacija: Zagreb, Dubrava
Postovi: 502
Mislim da ću udomit jednu gtx 970 ako će cijene bit kako se priča
Litra je offline   Reply With Quote
Staro 19.09.2014., 06:07   #52
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,251
Stigli prvi rivjui, guru 3d ih ima par komada, ova 970 mi je najzanimljivija:
http://www.guru3d.com/articles-pages...-review,7.html
Cijena 329$ kako se i nagadjalo, a potorosnja kod ove gaming MSI 970 je manja od 760!
Prodano
EDIT: eh da, ako ih vidite gdje za kupit, slobodno napisite ovdje
Zadnje izmijenjeno od: Disco. 19.09.2014. u 07:40.
Staro 19.09.2014., 08:56   #53
Drvoje
Split resist itself!
Drvoje's Avatar
Postovi: 4,037
Nekako mi smrdi da bi ih Uzi moga prvi ponudit na našem tržištu.
Pomelo mi sig -.-
Staro 19.09.2014., 10:40   #54
RaneZ
Vršni visioc
RaneZ's Avatar
Postovi: 2,207
Yep. Cekamo
Bez potpisa.
Staro 19.09.2014., 11:19   #55
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
Takve su grafe trebakle bit od davno.. Sad ce AMD morat rezat cijene brutalno..
Meni je 980 zanimljiva ali otom, potom. Prvo nek dode FC4, GTA5 i nes vrijedno igranja jer je ovo sad jadno..
Staro 19.09.2014., 12:23   #56
realmadrid
realmadrid's Avatar
Postovi: 239
Meni je Gigabyte-ova 970 prebolesna - hladna i da se lijepo OC-ati. Jedino pitanje je cijena - UK oko 300 funti, znači kod nas debelo iznad 3 soma.
Staro 19.09.2014., 12:58   #57
tole_
Casual Racist
tole_'s Avatar
Postovi: 422
Svabija 300-350eur, znaci kod nas 2600-2800kn. Sve vise od toga je lihvarenje.
Staro 19.09.2014., 15:40   #58
arnso
arnso's Avatar
Postovi: 79
Staro 19.09.2014., 16:09   #59
Disco
Prvoklasni Krkan
Disco's Avatar
Postovi: 5,251
Ma daju se one obje iskoristit, imaju onu neku novu shemu da igru renderiraju u rezi vecoj od nativne pa onda spustaju, pa to kao izgleda puno bolje (kazu na rivjuima da stvarno izgleda bolje); vjerovatno sam ovo krivo napisao ali tako nekako
Ili si mislio da su igre jadne?
A ja cu to iskoristavat naveliko jer 970 totalni overkil za moj trenutni monitor (1280x1024)
Staro 19.09.2014., 16:24   #60
MAGARAC
MAGARAC's Avatar
Postovi: 5,984
Meni su igra jadne vec zadnjih par godina, ne sve ali vecina. Tu i tamo iskrsne nes dobro ko FC3, Metro ili slicno a ostalo je bezveze ili ide na puno starijem HWu bez veze..
Mislio sam da ce cijene za 970 bit malo blize 2000kn a ispada da ce bit blize 3000 tak da ni AMD ne mora puno intervenirat.
Tu shemu ja koristim stalno. 2600x1800 downsampling..
