Staro 21.08.2005., 19:18   #1
Shinobi1337
Postovi: 25
Pomoc pri kupnji kompa
1446 kn(links)
AMD ATHLON 64 3500+ (2 200GHz) BOX SOCKET S939 VENICE --> 1760kn (raj)
ASUS EAX800XL/2DTV, ATI RADEON X800 XL, PCI-Ex16, 256MB DDR 256-bit DDR, VIVO, 2xDVI-I, TV-out, engine clock 392MHz, memory clock 700MHz, RAMDAC 400MHz, max resolution 2048x1536, 2nd DVI and VGA output --> 2165(raj)
Caviar 80 GB, WD800JD, SERIAL ATA, 8MB cache, 7200 rpm --> 466 (raj)
KINGSTON DDR 1GB DDR400 DUAL CHANNEL ( 2 x 512MB) KVR400X64C3AK2/1G -->950kn(raj)
LG DVDRW 16x DoubleLayer +/- Retail crni -->416kn(raj)
CREATIVE LABS SB Audigy2 ZS, bilk -->525kn(raj)
SM 730BF Matisse, 17" TFT, 1280x1024, 300cd/m2, 600:1, 160°/160°, 4ms (G to G) Worlds record breaking response time, the fastest monitor ever, Silver/Black, MagicTune, MagicBright 2, Analog/Digital, TCO'99, LS17BIDKSV The best monitor for gaming and multimedia -->2440kn(raj)
UKUPNO 10168kn
Ukljucujuci hdd 40gb i lg cdrw iz starog kompa.
Jos 1000 mi ostane za kućište,napajanje i hladenje...
Sad mi recite komentare na kofiguraciju,i preporucite ove tri stvari koje mi flae,dali mi je dovoljno 1000kn za to.
Imam na raspolaganju 11k kuna...Ovih dana malo po netu citam o svim komponentama,i jos sam zbunjeniji nego prije...koji su vasi savjeti?
Slozio sam jednu konfiguraciju pa mi recite sta mislite o tome...
MBO DFI LAN PARTY UT nF4 SLI-D, DDR, zvuk, S-ATA, FW, 2xG-LAN, PCI-E, s. 939 --> 1446 kn(links)
UKUPNO 10168kn
Zadnje izmijenjeno od: Shinobi1337. 21.08.2005. u 20:34.
Shinobi1337 je offline   Reply With Quote
Staro 21.08.2005., 19:40   #2
Dawar
OMG, thats the funky shit
Dawar's Avatar
Lokacija: in The Republic of Peščenica
Postovi: 1,221
Bolje si uzmi u raju od pixelviewa 6800gt za 2165
Dawar je offline   Reply With Quote
Staro 21.08.2005., 19:43   #3
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
MBO DFI LAN PARTY UT nF4 SLI-D, DDR, zvuk, S-ATA, FW, 2xG-LAN, PCI-E, s. 939 1446 links
CPU AMD Athlon64 3200+, 2.0GHz, 64bit, L2 cache 512kB, socket 939, BUS 800MHz, 0,9®, Venice 1363 info gama
RAM PC-3200, 1024MB, DDR, OCZ, KIT, Gold VX, DDR 400 MHz, 2x512MB 1709 links
Cooler Arctic-Cooling Freezer 64, socket 754/939/940 157 links
Hard disk Hitachi 160 GB Deskstar T7K250, 7200 RPM SATAII, 8 MB 687 autronic
Kuciste COOLERMASTER Centurion 5, silver, CAC T05, MIDI, bez PS 396 links
DVD-RW NEC ND 3540 386 autronic
DVD ROM TOSHIBA 16x 48x, black, SD-M191T, bulk 136 links
ASUS EXTREME N6800LE, GeForce 6800LE, PCI-Ex16 1673 diskont24
Monitor 19" Samsung 959NF, 110 kHz, 0.25mm, NaturalFlat 1715 links
Labtec Internet Keyboard linsk 100 kuna
Logitech mx 510 350 links
10118 kuna
ili ako bas os ati
ASUS EAX800XL/2DTV, ATI RADEON X800 XL, PCI-Ex16 2165 raj
10568
blup
mc_fish je offline   Reply With Quote
Staro 21.08.2005., 19:45   #4
Dawar
Dawar's Avatar
Postovi: 1,221
Napajanje CHIEFTEC 410W, 12cm vent., ATX2 ver 2.0
364,64 341,37
Kućište AeroCool AERO Engine JR., MIDI, silver, bez PS
540,73 506,21
Ventilator PAPST 80mm, 9dB, N/2GLLE
106,63 99,83
To ti je sve u linksu.
Staro 21.08.2005., 20:03   #5
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
a sad na obrazlozenje: venice corovi su svi isti...tj razlika je samo u max mnozitelju...koji ti uopce ne treba...govorim iz iskustva!!!imao sam winchesterea 3500 i nons top mi je mnozitelj bio 9 a ne 11...3200 ima mnoziltej 10 da ti klok bude okrugao
ploca je svakako dobar izbor tu nemam nikake zamjerke na tome.
grafa i hard je tvoja odluka makar ti je sad najbolji izbog hitachi tj bivsi ibm...seagate novi je dosta glasniji makar nimalo slabiji
kingston ima ecc sto ti jako usporava perfomanse...to da je stabilnost veca je...al nije vazno jer imas vx iliti utt
zvucna ti netreba
a crt 959no je 19" samsung i jedan od najboljih monitora ikada napravljen
pa sad dali oces poslusat ili ne...tvoja je odluka...ja sam ti slozio 2 konfiguracije jace i brze od tvoje za jeftinije pare
blup
Staro 21.08.2005., 20:37   #6
Shinobi1337
Postovi: 25
Dobro,uzmem slabiji procesor i jacu memoriju na svoju konfiguraciju....
Sto se tice monitora bas zelim lcd,nemam mjesta za crt.Ja mislim da je ovaj poprilicno dobar,pohvalili ga i na pcekspertu.
Hvala na prijedlozima,ako se sjetite jos cega...
Zasto mi zvucna ne treba?Cesto slusam mjuzu sa kompa,imam surround u sobi,pa mislim da je bolje koristit dobru zvucnu nego integriranu na ploci.Ili grijesim?
Sto se tice tipkovnice i misa uzet cu Logitech MX3100.
Staro 21.08.2005., 21:13   #7
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
integrirani zvuk ti je vise nego dobar
blup
Staro 21.08.2005., 21:50   #8
Apollo
Cmdr. Lee Adama
Apollo's Avatar
Postovi: 47
540,73 506,21
106,63 99,83
Oba proizvoda ne vrijede te pare. Aerocool je nekim lijep nekima ruzan al nema bas prostora tako da je neki chieftec ili coolermaster bolji odabir. Ja bi osobno uzeo Sharkoon Silvation za 600kn. Papst je precijenjen jer je na nizim okretajima traktor i 4/5! Bolji odabir je po meni Sharkoon Silent Eagle ili kako se vec zove. ;I
Apollo je offline   Reply With Quote
Staro 21.08.2005., 22:18   #9
ZED
a.k.a. LOPOV
ZED's Avatar
Postovi: 2,022
Fish ipak mislim da je bolje da covjek doda neku sicu i pikne
ram pc-4400, 1024mb, ddr, corsair c25, kit, twinx, ddr 550 mhz, 2 x 512mb 1870kn
Zabranjene reklama u sigu.
Staro 21.08.2005., 22:37   #10
Dawar
Dawar's Avatar
Postovi: 1,221
Pa nisu toliko loši znam da su tihi jedino što nisu baš jeftini. A kućište je zakon da imam toliko love odmah bi ga kupio ima naprijed velik vent i dobro je za modanje. A pogotovo ako želiš koliko toliko hladan komp neradi ga bezveze aerocool
Staro 21.08.2005., 22:44   #11
Shinobi1337
Postovi: 25
Sjetih se jos necega...Uzimam maticnu koja podrzava SLI,pa bi bilo glupo ne uzet graficku koja takodjer podrzava sli,pa da u buducnoxti kupim jos jednu i ugradim...sta vi preporucujete,da bude do 2 i pol milje?
Staro 21.08.2005., 22:45   #12
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
a istina ja sam vx iz prve dobio ovakav kakv je(dobar) a sad vidim 3. sreca na pce-u lol onda bolje tccd corsaira al pazi da je c25 ili c25 pro a ne samo 4400 jer je taj na cl 3! tnx zed sad cu malo pripazit na to.
@ vas 2...kuciste je piranje ukusa...sto se tice mene sam si jako htio uzet ms-techovo lc401...ono zeleno...to je modersko kuciste al ga nema nigdje u hrvatskoj a kuciste je srot...tj treba se poigrat s njime dosta...dok recimo neki chieftek koji ima 17 kila ili neki cooleramster koji ima nekih 9 su ne 5 nego 20 put bolji od tog kucista...a cijena je 100 kuna +- .... to su se atx kucista i samo ej pitanje upotrijebe materijala, i zavrsna obrana... to sto je dizajn negjde malo losiji ili bolji ne znaci 10°!!! dakle kupujte kucista koja vam se svidaju
blup
Staro 21.08.2005., 22:45   #13
Shinobi1337
Postovi: 25
Ja mislim da je ta AGP...
Staro 21.08.2005., 22:50   #14
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
na asus stranici pise da podrzava le sli...al za to nisam siher...joj u pet sam imao jednu u rukama i nisam gledao znam da sve iznad 6800 ima sli...al za 2.5 mislim da nema nis...tj ako ima u diskontu 24...a to je najvjerojatnije nes tipa xfx ili spart nesto
blup
Staro 21.08.2005., 22:50   #15
Dawar
Dawar's Avatar
Postovi: 1,221
Nije gledao sam na pixelview stranici a i agp ne bi bio baš tak jeftin znaš da su pciex jeftiniji od agp
Staro 21.08.2005., 23:01   #16
Apollo
Cmdr. Lee Adama
Apollo's Avatar
Postovi: 47
Nisi ga onda imao prilike detaljno poslusati. Cim se spustis ispod 1000rpma traktor nadglasa cijeli ostatak venta tako da je po meni los odabir. Ipak ja sam hipersenzitivan sto se toga tice. A Aerocool se meni prije svidjao. Jedino je Jr. model premali. Sr. je bolji. Ali jednostavno je preskup za to sto nudi. Moj AHC me je dosao 140kn a ima 4 + 1 vent. A ovo sto si rekao za moddanje. Well... ne da se bas moddati jer je vec moddano. Bolje onda neki macase big tower pa njega moddaj if U get me...
Staro 21.08.2005., 23:01   #17
MRKONJA
M.U.P.
MRKONJA's Avatar
Datum registracije: Sep 2004
Postovi: 2,277
6800gt su jeftinije u agp verziji.
6800le pci-e košta 1620kn
Abit AX8 VIA k8t890//Venice 3000@2250//1x1gb PQI//POV 7600gs silent//Seagate 7200.10 250gb(16mb//sata)//Hitachi 7k160 120gb@mobile kučište//Seagate 7200.7 200gb
//Samsung SH-w163A//Seasonic S-12 380w//Sharkoon silvation
MRKONJA je offline   Reply With Quote
Staro 21.08.2005., 23:03   #18
Apollo
Cmdr. Lee Adama
Apollo's Avatar
Postovi: 47
Htio si reci Sparkle. Cccc... Sparkle mu se jako isplati uzeti. Fora je u tome sto Sparkle ima VGA koje rade na nesto vecim voltazama (HINT: 6600 Ultra) pa omogucavaju veci OC.
Staro 21.08.2005., 23:19   #19
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
da na njega mislise jer mi diskotn nepregledan i nisam sve popamtio dosad...al uglavnom nikad ju nism imao pa neznam nis o tome pa ti ju nebi preporuci...sam naznacio da postoji
ps mrkonja le kolko ja znam nema sli(makar na stranici pise da ima) i stavio sam ju u prvu konfu
blup
Staro 21.08.2005., 23:31   #20
Apollo
Cmdr. Lee Adama
Apollo's Avatar
Postovi: 47
Tu se slazem. Imaju barem 3 Semprona 2800, a za niti jednoga nisam siguran da je s754. : lol2 :
Staro 21.08.2005., 23:38   #21
Shinobi1337
Postovi: 25
Provjerio sam na njihovoj stranici,imaju i agp i pci verziju te kartice....pa se ja nadam da je pci ova u raju,i uzet cu nju ako je!
Staro 22.08.2005., 00:25   #22
Shinobi1337
Postovi: 25
Decki,jos jedna dilema...
U hgspotu je Intel P4 HT 3.0 2Mb cache 1500 kn...popust...
izmedju athlona 64 3200+ i njega,bolje athlon,jelda?
Staro 22.08.2005., 00:47   #23
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
par puta sala al negjde 10%
blup
Staro 22.08.2005., 00:50   #24
atha
atha's Avatar
Postovi: 9,067
nemoj pitati nas, mi smo previshe subjektivni....i emotivni....
___________
Just atha
x
atha je online   Reply With Quote
Staro 22.08.2005., 01:57   #25
mc_fish
the luda ribetna
mc_fish's Avatar
Postovi: 3,952
mozda ti
govori u svoje ime
ja sam z aono kaj ej bolje
blup
Staro 22.08.2005., 10:05   #26
Dawar
Dawar's Avatar
Postovi: 1,221
Uzmi si rađe ahlona
Staro 22.08.2005., 16:20   #27
E.T.
E.T.'s Avatar
Postovi: 2,458
S obzirom na namjenu konfiguracije od njega bi ti bolji bio i AMD64 3000+...
www.rabbits-clan.com
E.T. je offline   Reply With Quote
Staro 23.08.2005., 20:56   #28
Shinobi1337
Postovi: 25
Konfiguracija mi se svela na ovo...komentirajte molim vas...
MBO DFI LAN PARTY UT nF4 Ultra-D, DDR, zvuk, S-ATA, FW, 2xG-LAN, PCI-E, s. 939
CPU AMD Athlon64 3500+ BOX, socket 939, Venice, 2200MHz, 512kb c., FSB 800MHz
Kućište COOLERMASTER Centurion 5, silver, CAC T05, MIDI, bez PS
VGA PCI-E ATI RADEON X800XT, 256MB DDR3, DVI, VIVO
RAM PC-3200, 1024MB, DDR, Corsair, KIT, Value Select, DDR 400 MHz, 2 x 512MB
HDD 160.0 GB MAXTOR, 8MB cache, Serial ATA, 7200, DiamondMax Plus 9
DVD±RW LG GSA-4163, 16x, black, Dual layer, DVD RAM
Staro 23.08.2005., 21:25   #29
Gemmy
smeghead
Gemmy's Avatar
Postovi: 3,155
Samo izmjeni proc uzmi 3000 venice,svi idu do 2500 ,uštediš dosta
I nemoj maxtora 9,rađe ciljaj na hitachi sata 2 160 Gb,ili seagatea 160 i ja bi uzeo dvd pržu od pioneera 110
Inače sve za 5+
Staro 24.08.2005., 00:43   #30
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,343
uzmi rađe uz dvd rw još jednu optiku...
žmnpp
