#751 |
Postovi: 2,375
Najjača 780ti, GPU na 3.600 MHz: http://www.ebay.com/itm/H-Frequency-...item35d99a7ad0 Što sve neću naći na eBay-u. ![]() c/p opisa: Ultra High Frequency GTX780TI Public Version DDR5 1G Support DirectX 11 Game Graphics Enthusiasts Real 1048M Condition: Brand New,nVIDIA Video Memory Type ![]() Model Number: GTX780TI Cooler Type: Fan DirectX: DirectX 11 Core Clock(Mhz):3600Mhz Chipset Manufacturer: NVIDIA Memory Interface:128 Bit Output Interface Type:VGA,DVI,HDMI Memory Clock(Mhz):800Mhz Video Memory Capacity:1024MB Interface Type:PCI Express Stream Processors:192 Battlefield 4 Sword of Hope 5 files full antialiasing Crysis 3 Game show Perfect run , no Caton !"Battlefield 4" buy support DX11 game ! ! Again : Your attention !This graphics card Real support DX11 games all games. Stop buying cheap DDR3 graphics card, 9800GT or GTS250,Those who only support DX9 and DX10, can not play latest DX11 games! ! GTX780 TI 4 TIMES BETTER THAN GTX780! Solemn promise:We sold merchandise 100% quality assurance,Will be rigorously tested before shipment , 3D MARK software for a long time and some aging pager test! New Overseas GTX780Ti 1G DDR5 UHF perfect to replace the generals licensed version of the black mainstream graphics to New bargains , really value ! Whether a computer installation, computer upgrades enthusiasts are your best choice ! ! Full support XP, 2003, WIN7 WIN8 system ! Withstand any professional online software testing ! True gold fears fire ! Want to buy quickly snapped it ! A rare opportunity, a limited number of 200 sold In stock ! We guarantee new real 1G DDR5, the latest ultra-low power core ! Desktop 250W power supply!! |
#754 |
Datum registracije: Apr 2013
Postovi: 1,336
GTX780 TI 4 TIMES BETTER THAN GTX780 hahahahahahah fu** it..ja mu idem poslat upit ![]() Edit: dobio sam odgovor.. Navodno je kartica jako popularna ![]() ![]() Zadnje izmijenjeno od: hedgehog. 17.07.2014. u 17:59. |
#756 | |
Freelancer
Lokacija: Bilje (Osijek)
Postovi: 5,261
#758 |
Postovi: 1,336
Poslao je činez detalje...ali stvarno mislim da nema ovakve grafe Nvidia GeForce GTX 780 Ti 192 shadera 1024MB GDDR5 Bus Width 128 Bit GPU Clock 783 Memory Clock 902 Mhz Shader 1556 Mhz mail završava rečenicom: "Have to say,it is really good item,really recommend using..." genijalno ![]() posalo je i sliku kutije na kojoj je nacratana neka mačka (!?!) i ime "firme" je STC (!?!) e da, napaja se preko samo jednog 6 pin-a..ovaj novi Nvidia čip je izuzetno efikasan, nema šta ![]() |
#759 |
Freelancer
Postovi: 5,261
#761 | |
Freelancer
Postovi: 5,261
![]() ![]() kad smo vec kod brzini bas neki dan covjek posto ana Octane forum sa pitanjem benchmarkanja jedne Octane (GPU render engine) scene i rezultati su zanimljivi. ------------------------------ ![]() Hello, Here are my test figures: Scene: Octane_benchmark.lws (Lightwave): 1 Titan Black: 66s render time. DL Kernel. 2 Titan Black: 33s render time. DL Kernel. 3 Titan Black: 22s render time. DL Kernel. "Use priority Settings": High Gigabyte Titan Black GHZ (1176MHz) ---------------------------- ![]() 92 sec here with a single GTX 780 3G on mac. card has 901.5 mhz clock. ----------------------------- I onda sam i ja isprobao sa mojom konfom ![]() 22 seconds using 3*Asus STRIX OC 780GTX 6Gb clocked to 1200Mhz ------------------------------- Ispada da sa ovim overclockom sam na brzini Titana Black u renderu, bar u ovim brzim/kracim scenama ![]()
#764 |
Freelancer
Postovi: 5,261
#765 |
Freelancer
Postovi: 5,261
BTW evo jedna zanimljivost od maloprije: Potrosnja struje spojena na UPS - Dual Xeon E5 + 3*780GTX STRIX - 2 * i7 2600K overclock na 4.6GHZ oba - router, NAS, printer, 24 port switch. 2 monitora Render sa sva tri kompa CPU only - Load 1148 W Render sa sva tri kompa CPU + GPU (samo Strixovi) - Load 1702 W Znaci Strixovi povuku 554W dodatnih u odnosu na idle/prikaz slike na monitoru alu i globalu cini se da sva tri Strix ani ne ppovuku 750W zajedno nego nesto ispod 700.
#767 |
Freelancer
Postovi: 5,261
#768 |
Freelancer
Postovi: 5,261
BTW evo danas nesto novo kemijam kako bi ipak ubacio onu 760GTX 4GB u stroj d ane stoji u kutiji bezveze ![]() Za sad testiranje na 660ki i Renderslaveu je proslo odlicno, Kupio PCIE Extender i spojio van kucista karticu i radi, windowsi je vide nema beda ![]() Sad mi pada napmet slozit neki uspravni drzac za karticu i ubaciti je u 900D case okomito pa da bude 4 komada kak je i planirano ![]() https://www.dropbox.com/s/3cj7a2yda2...der_RS_001.jpg https://www.dropbox.com/s/9uwmome8p6...der_RS_002.jpg Ajmo jel ima koji tokar/majstor ovdje na podrucju da sklopi neki drzac za okomitu ugradnju grafe ![]() ![]()
#769 |
Freelancer
Postovi: 5,261
Napokon proradilu u kucistu. Slozio sam custom made Alu nosac za okomitu ugradnju i sa PCI-E Extenderom slozio i 4tu i nakon 2-3 restarta, updejta drivera proradila ![]() https://www.dropbox.com/s/essqlrw35p...n_004.jpg?dl=0 https://www.dropbox.com/s/3ngqbywti5...05.jpg?dl=0&m= https://www.dropbox.com/s/7kjh22750f...06.jpg?dl=0&m=
#771 |
Freelancer
Postovi: 5,261
#772 | |
#773 | |
Freelancer
Postovi: 5,261
#774 |
Split resist itself!
Postovi: 4,037
Vidim da su spojevi Corsair crijeva sad u "suhom" stanju ![]() Ne znam kako si uspija sredit napuknuća, ali bolje da jesi s obzirom na sav taj skupi "lager" u kučištu ![]() https://www.dropbox.com/s/07ml4jd7ad...RS_H80_002.jpg https://www.dropbox.com/s/j8tekfzsm6...RS_H80_003.jpg https://www.dropbox.com/s/ynn631cpq5...RS_H80_004.jpg
![]() Pomelo mi sig -.- |
#775 | |
Džabe si krečio!
Postovi: 5,190
Cudo masinerija ![]() A jebiga, nebi to bas funkcioniralo kako treba kad nisu u SLI-polju. Ali ajde nama za dusu bar 3dmark firestrike, tu ce cak biti zanimljivije pratiti physx score zbog divlje cpu snage... Zadnje izmijenjeno od: Sam Fischer. 25.08.2014. u 09:24. |
#776 | ||
Freelancer
Postovi: 5,261
![]() Citiraj:
#777 | |
N0teb00k n00b
Lokacija: Zagreb/Koprivnica
Postovi: 2,105
#778 | |
Postovi: 7,629
Nije više nekad Corsair koji dizao na kvalitetu. Sada su na čajna kvaliteti. Inače, prava radna stanica ![]()
__________________ |
#779 | |
Freelancer
Postovi: 5,261
![]() Ja sam htio ici na full vodeno za 4 grafe i 2 CPUa ali XSPC nema blokove za moje grafe a EKWB se nije udostojio ni odgovorit na mail a kamo li ponudit (BTW kod XSPC akit za sve bi kostola oko 800 Funti) tako da....
#780 |
Bee-do Bee-do Bee-do, TUP
Datum registracije: Aug 2009
Postovi: 323
Presaugali me... pa stoga krivi post :S
Straight roads are for fast cars, turns are for fast drivers! Zadnje izmijenjeno od: O9g1. 25.08.2014. u 14:30. Razlog: Pucanj u prazno! Mod, briši... Molim! |
