#1 | ||
Postovi: 1,606
Catalyst 5.8
Dakle, dan prije nego na službenoj ATI stranici... samo CCC verzija... CP verzija sutra kad i "službeno" budu izašli... ![]() |
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Ili tu: http://files.matrix.is/ Ma ne jebem ih za suhu šljivu, kakav crni CCC. Skidam sutra sa CP-om. Navodno će CP biti dostupan samo još ove godine i onda štanga... Known Issues for Catalyst™ Software Suite 5.8 The following section provides a brief description of known issues associated with the latest version of Catalyst™. These include the following: City of Heroes: Playing the game under Windows XP Media Center Edition may results in display corruption being notice when attempting to task-switch between the game and the desktop. Further details can be found in topic number 737-19792 Doom3: Playing the game under Windows XP Media Center Edition may result in a noticeable performance decrease or corruption of the MCE on-screen display dialog box when lowering or muting the audio during game play. Further details can be found in topic number 737-19791 Grand Theft Auto: San Andreas: Geometry corruption may be noticed when running the mission under Windows XP and using the default setting for the game. Further details can be found in topic number 737-19795 Prince of Persia: Sands of Time: Attempting to launch the game under Windows with an ATI Radeon® X800 XL installed results in an error message being displayed. Further details can be found in topic number 737-19787 Rainbow six3: Athena Sword: Playing the game under Windows 2000 with an ATI Radeon® X700 installed results in the game failing to retain its resolution option of 1600x1200 if you Alt-tab out of the game and then Alt-tab back to the game. Further details can be found in topic number 737-535 Serious Sam: The Second Encounter: Playing the game for approximately 5 to 10 minutes under Windows XP with the game quality set at normal/default, results in display corruption being seen in the menu. Further details can be found in topic number 737-10090 Star Wars Jedi Knight 2: Saving a game and attempting to load the saved game under Windows XP results in the preview window display a blank preview screen. Further details can be found in topic number 737-19786 World of Warcraft: Enabling Full-Screen Glow in the game may result in a blue screen image being displayed when walking under water. This issue is know to occur when using an ATI Radeon® 9100 or 8500 series product. Further details can be found in topic number 737-19075 World of Warcraft: Display corruption is noticed when switching between the game and the Windows desktop, when the desktop is set to 1280x1024 and the graphic preferences is set to Optimal Quality. Further details can be found in topic number 737-19785 The Apply button in the Custom settings of the Advanced mode found under the Catalyst™ Control Center Video standard settings is grayed out when playing a media file. Further details can be found in topic number 737-497 Changing the DPI setting found in the General tab of the display properties to Large size (120 DPI) results in the change not taking effect when launching the Catalyst™ Control Center. Further details can be found in topic number 737-18885 Connecting two display devices using the DVI and CRT connectors on a system containing an ATI Xpress 200 results in the system failing to resume when entering standby state. Further details can be found in topic number 737-19538 The Catalyst™ Control Center may display blank pages when quickly exiting and re-launching the Catalyst™ Control Center while hot-plugging or hot-unplugging a CRT display device. Further details can be found in topic number 737-20070 Catalyst™ Control Center: Customizing the Catalyst™ Control Center may result in the customized logo's for the Catalyst™ Control Center not appearing on the Windows desktop or the system tray. Further details can be found in topic number 737-20071 Installing an All-in-Wonder® into a system containing an ATI Radeon® Xpress 200 series and an ATI Theater 550 Pro may result in loss of signal error message when setting the country region to Sweden. Further details can be found in topic number 737-20073 Connecting an HDTV to an ATI Radeon® X700 series may result in the HDTV being detected as a CRT or TV under the Windows XP operating system. Further details can be found in topic number 737-20074 Attempting to install the integrated WDM driver under Windows XP may result in an error message being displayed indicating that the hardware is not installed because the install Wizard cannot find the necessary software. Further details can be found in topic number 737-20075 Connecting a CRT and a TV may result in the TV not being automatically detected under Windows XP MCE when using an ATI Radeon® 9550/9600/9650 series. Further details can be found in topic number 737-20076 HDTV support may still be displayed within the control panel with ATI products that do not support HDTV. Further details can be found in topic number 737-20077 Having an HDTV connected to an ATI Xpress 200, followed by right-clicking the ATI logo on the Windows taskbar and selecting 640x432 HDTV optimized resolution results in the display mode being the same as 640x480. Further details can be found in topic number 737-20078 Connecting two display devices using the DVI and CRT connectors on a system containing an ATI Xpress 200 results in the system failing to resume when entering standby state. Further details can be found in topic number 737-20079 Catalyst™ Control Center: The Overdrive Automated Clock Configuration Utility may continue running even after the user selects apply or cancel in the utility's confirmation window. Further details can be found in topic number 737-20080 Catalyst™ Control Center: Connecting a TV as the only display device to an ATI Radeon® X300/X600 series may result in the Signal Format found in the Adjustment page of the TV Properties being labeled as Unknown. Further details can be found in topic number 737-20081 ATI Multimedia Center™: Selecting Sweden as the region in the MMC may result in the Teletext displaying incorrect text. Further details can be found in topic number 737-20089 Three of the four ATI entries found in the Add or Remove Programs for Windows XP Japanese version, maybe displayed in English. Further details can be found in topic number 737-2009 |
Postovi: 1,606
a evo i CP verzije (2k/XP): http://www2.ati.com/drivers/5-8_xp-2..._wdm_25203.exe |
#5 | |
Postovi: 1,606
Postovi: 1,606
Od sada (3:00 EST) Catalyste možete skinuti sa službenih stranica... ![]() |
Super Moderators
Postovi: 17,485
Ja ih baš isprobavam (samo drivere, WDM i ATT)-igrao sam sinoć F.E.A.R. demo i ide puno bolje nego sa 5.7 Navodno i BF2 sa novim driverima ide dosta bolje. |
#8 | |
Postovi: 1,625
I koju ti imaš grafičku? (sigurno neku ljudu, jer meni sve sa svim drajverima ide isto.) ![]() tj., ne primjećujem nikakve razlike? Ja ću skinut omege 5.8, kad izađu ofkors
Hejter
Postovi: 6,521
evo cak i ja cu ih skinuti , jer neugodno mi je pomalo da koristim omegu od 4.10 mislim ![]() |
Super Moderators
Postovi: 17,485
Pa i ja sam imao Omegu (5.7), ove sam skunuo samo da vidim da li je istina kaj su pričali po netu da F.E.A.R. ide dosta bolje F.E.A.R. izgleda dosta dobro, samo je demo prekratak. Ima dobrih fora-razvališ ga sačmaricom u vugla, uključiš usporeno vrijeme kao u Max Payne i uživaš gledajući kak krvari ko prasac Dok to gledaš još mu usput odvališ i ruku+nogu čisto da provjeriš kakav je fizikalni model i da li ga svi efekti prate kak treba Grafika je dobra, samo je demo neoptimiziran do bola, sa gigom meme pri prelasku na drugi nivo još i hard počne swapat... |
Super Moderators
Postovi: 17,485
Demo je igran na : 3200+ na 2550 MHz Giga Supertaljenta X800XL 445/550 A valjda bi išlo na 9600 sa skresanim detaljima u 800x600??? Nadam se da će igra ipak biti bolje optimizirana kad izađe. |
Postovi: 1,606
Lokacija: Sisak
Postovi: 1,127
Ma šišaš ti ta poboljšanja i osjetan boost kad se CoD počeo čudno ponašat. kad te ošamuti bomba umjesto motion blura 3D scene samo se izobliče boje kao da se pregrjala kartica. Vratio 5.7 i sve nazad u normali. |
#16 |
Hunter(Den)
Lokacija: Sisak
Postovi: 161
bf2 puno puno bolje radi.... a ovaj mix boja mi je cak i fora u codu |
#18 | |
el_nino
Lokacija: Zagreb-Tresnja
Postovi: 353
f***! a bas COD igram stalno! kakav je u UT2004,ima kakvih problema? :confused: |
#20 | |
ghotic warrior
Lokacija: Jastrebarsko
Postovi: 398
Zato instaliras drivere bez CCC i CP i stavis Ati Tray Tools ![]() |
#21 | |
Super Moderators
Postovi: 17,485
#22 |
Datum registracije: Apr 2004
Postovi: 301
a ko neradi? ![]() neznam, imho ATT je jedan od boljih tweakera koje sam opcenito vidio, u rangu sa nhancerom, a vidio sam da puno ljudi sere po njemo okolo po netu... ![]() ATT>ALL
HARDCORE 4 LIFE athlon xp 2500+ @ 3200+ (11x200) gigabyte ga7n400l ( n force2 ) gigabyte radeon9600pro (@ 510/700 ) 2x256 Samsung ddr400 ŽENE SU KAO RAM, ŠTO VIŠE IMAŠ TO BOLJE |
#23 |
Lokacija: Moscow
Postovi: 1
Wide screen
Kako prilagoditi RADEON 9800 Pro da pokaze nestandardnu rezoluciju wide monitora (u mom slucaju 1680x1050)!?!?!? Pomozite! |
#24 | |
Super Moderators
Postovi: 17,485
Re: Wide screen
#25 | |
Postovi: 1,606
Re: Wide screen
