Staro 13.05.2014., 09:17   #7561
potemkin.hr
Akutna lijenčina
potemkin.hr's Avatar
Lokacija: Fiume
Postovi: 1,834
Autor ehohr Pregled postova
http://www.diablofans.com/
Taman fino buffaju crusadera da mogu malo s njima pikat.
Ma šta crusadera, pet WDovi sa batsima će nakotiti fetiše dok kažeš keks, sad neće biti uopće problem imati up po 20+ fetiša samo tako, zanimljivi buffovi na svim frontama. Blade će plakat od sreće
* Zombie Handler You can have 1 additional Zombie Dog summoned at one time. The healths of you, your Zombie Dogs and Gargantuan are increased by 20%. (Now also increases player health)
* Fetish Sycophants When you hit enemies with your spells, you have up to a 10% chance to summon a dagger-wielding Fetish to fight by your side for 60 seconds. (No longer requires a physical realm spell, chance up from 5%)
* Fierce Loyalty You can have 1 additional Zombie Dog summoned at one time. While you have a Zombie Dog, Gargantuan, or Fetish following you and not in combat, your movement speed is increased by 30%. (Previously your pets gained 100% of your Life Regen and Thorns)
Svašta bi se dalo s ovim skombinirati
potemkin.hr je offline   Reply With Quote
Staro 13.05.2014., 12:49   #7562
osspaljeni
Silence
osspaljeni's Avatar
Datum registracije: Jul 2011
Postovi: 671
Autor shrek00 Pregled postova
Neloši dropovi
Ovih Magefist ima ko šodera. Lootao sam barem 10 komada sa WDom i nešto sitno s Wizardom koji mi još uvijek stoji na lvl 60
Autor potemkin.hr Pregled postova
Opa, neznam gdje si ovo iskopao ali sviđa mi se
Sa mojim sam buildom znao imati po 16 fetisha zadnji put kad sam uspio prebrojati koliko ih je.
Jedino ova zadnja stvar mi se ne sviđa, ali nešto su morali usrati.
Pošteni trgovac: 1 2
771 to 775 for Dummies
Staro 13.05.2014., 13:38   #7563
shrek00
shrek00's Avatar
Datum registracije: Apr 2008
Postovi: 236
Autor osspaljeni Pregled postova
Vidio sam ih i ja dosta ali ni jedne sa ovakvim rolom
shrek00 je offline   Reply With Quote
Staro 13.05.2014., 15:17   #7564
potemkin.hr
Akutna lijenčina
Lokacija: Fiume
Postovi: 1,834
Na diablofansu su datamineali novi patch i saznali svašta zanimljivo.
Ovo za zadnji pasiv se nikako ne slažem, speed boost realno puno više znači nego da se petovi sami hilaju, pogotovo ako imaš homunculus. Ispada permanentni 30% speed boost na onih maksimalnih 25% (koji se dodatno poveća sa spirit walkom), što je ogromno povećanje brzine koje super dođe npr. kod conduit pylona. Da ne govorim koja bolesnoća ispada ako se ima onaj mojo za permanentni spirit walk
Staro 13.05.2014., 16:30   #7565
osspaljeni
Silence
osspaljeni's Avatar
Postovi: 671
Aha, ma pomiješao sam skill. Ajde nije loše.
Staro 13.05.2014., 18:17   #7566
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,403
Staro 13.05.2014., 19:09   #7567
mamutarka
ODUZIMAM VAM RIJEČ
mamutarka's Avatar
Postovi: 13,403
Staro 14.05.2014., 11:37   #7568
potemkin.hr
Akutna lijenčina
Lokacija: Fiume
Postovi: 1,834
Fala fala.
Nego čitam malo dojmove o patchu novom, i čitam par zanimljivosti vezanih uz WD-ove. Evo recap bitnih stvari:
- Uveli su limit na broj fetiša od 15 komada. Sad ih je puno lakše spawnati u combatu, ali su fetiši od pasiva puno ranjiviji sad jer su im maknuli force armor, kojega imaju samo oni dobiveni od fetish army skilla. Blade će ovo obožavati /s - novo spawnani fetiši pregazuju starije ako se dođe do capa od 15 fetiša. Primjer: Blade spawna na početku combata Fetish army i ima 8 fetiša, s vremenom spawna nove od pasiva, i dođe do limita od 15 fetiša. Svaki sljedeći fetiš će micati najstarijega, znači one od fetish armyja (koji su jači zbog damage buffa na gearu i force armora), te će efektivno pušiti na ukupnom damageu.
- Fixali su kalkulaciju DoT-ova, ali su time (opet) nerfali Jade Harvester WDove koji su pecali critove. Kako su već prije nerfali set da radi samo 30 sekundi trajanja (a ne cijelo trajanje DoT-a), radili smo puno manji ukupni damage na bossovima od pet WD-ova na većim tormentima, ovim su nam srezali damage u korijenu obzirom koji ludi gear requirement build ima (5 komada seta, Quetzalcoatl i Ring of Royal Grandeur kao minimum!). Radio sam možda kojih 350m maksimalni hit na elitima svakih 15 sekundi sa max critom, što prosječno zgirani pet WDovi bez zunimasse naprave u 2 sekunde max sa 15 fetiša, sad me strah vidjeti damage koji će biti dok dođe patch. Tko nema masni cooldown reduction nema šanse da radi sustainable damage koji se može mjeriti sa pet WDima.
Još ću na kraju prijeći natrag na pet WDa kako prikriveno režu JH build radi jednog bursta kak spada unutar 15 sekundi, dok gro klasa radi konstantno marginalno manji damage. Dok se stave brojke na papir i ide se računat ukupni damage se vidi tek koliko je od srezan JH build u stvarnom damageu.
Staro 14.05.2014., 12:46   #7569
burmuz
burmuz's Avatar
Lokacija: Bjelovar
Postovi: 464
Jedno glupo pitanje. Možemo li frend i ja igrati multiplayer ako ja imam ROS a on ne ? ( naravno ne 5. akt). Znam, možemo probati ali smo na poslu do navečer pa ono, ako netko zna
Staro 14.05.2014., 12:54   #7570
osspaljeni
Silence
osspaljeni's Avatar
Postovi: 671
Gdje si našao ove informacije, može li neki link?
Staro 14.05.2014., 13:02   #7571
potemkin.hr
Akutna lijenčina
Lokacija: Fiume
Postovi: 1,834
Evo.
Autor burmuz Pregled postova
Naravno da možete, ali on neće moći igrati adventure mode (bountyji i riftovi) i act 5, te dobivati paragon levele. Starije actove možete u campaign modu bez beda skupa igrati.
Staro 14.05.2014., 13:08   #7572
burmuz
burmuz's Avatar
Lokacija: Bjelovar
Postovi: 464
Hvala. Budemo pičili navečer onda. Ionako sam resetirao questove pa derem ispočetka sve, kupio ROS prije dva dana. Adventure mode ide kad se malo zbildam XD
Staro 14.05.2014., 13:33   #7573
lateralus_eye
lateralus_eye's Avatar
Postovi: 602
Crusader sa Blessed Shield build je OP
lateralus_eye je offline   Reply With Quote
Staro 14.05.2014., 13:51   #7574
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
mozete, ali ako cete igrati ista vece od lvl 62, njemu ce ici jako tesko. isprobano
ali ako on kreira lvl 60 igru, nema problema
Spoiler alert!
Staro 14.05.2014., 15:35   #7575
osspaljeni
Silence
osspaljeni's Avatar
Postovi: 671
Pa ovo je žešće sranje, moj build sad više nema ama baš nikakvog smisla.
Da su stavili cap na 15 i da se ovih 7 komada od FS-a izmjenjuje kako krepaju ili kako krepa koji od FA bilo bi u redu ali ovime su totalno nerfali WDa.
Da ne napominjem da sam znao imati 16+ fetisha koji su s poison dart critali po 3-4mil svaki i da Zuni set gubi bilo kakav smisao ako ću nakon par minuta imati samo fetishe od FS.
Zadnje izmijenjeno od: osspaljeni. 14.05.2014. u 15:59.
Staro 14.05.2014., 15:52   #7576
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,344
Moj wd je prije patcha radio 30 mil na pola sekunde (brojevi se uvijek prikazuje na pola sekunde) a sada u 95% vremena je 10mil na pol sekunde, jednom ili dva puta u pol sata sam uspio dobit 15mil...
KOJI SU TO J*B*NI KRETENI!
žmnpp
Staro 14.05.2014., 16:03   #7577
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Spoiler alert!
Staro 14.05.2014., 16:13   #7578
MAGARAC
MAGARAC's Avatar
Postovi: 5,991
Jer to cura ili decko?
Ja mogu igrat sat vremena max a nakon toga mi dosadi. Nije ni to tak lose za d3.. Nisam nist dobio sto godina niti ne ocekujem da cu ista dobit..
Staro 14.05.2014., 16:58   #7579
BladeRy
BladeRy's Avatar
Datum registracije: Aug 2008
Postovi: 2,000
Opa, novi patch. Sta me ima docekat nakon par dana izbivanja nego nerf do jaja.
Bravo blizz, bravo...
Staro 14.05.2014., 17:30   #7580
potemkin.hr
Akutna lijenčina
Lokacija: Fiume
Postovi: 1,834
Autor buljo Pregled postova
Sad mi lijepo kombinirano DoTovi rade 8m maksimum. Dok opalim soul harvest na elitima radim po 150m damagea max, ide mi na plakanje kako su uništili nekad najjači a i dalje najteži build za skompletirati u igri (7 komada geara minimum).
Da nisu stavili cap na DoT od 30 sekundi ništa ne bi rekao, ali 150m damagea sa cooldownom od 15 sekundi? To loše gearani pet WD napravi ispod sekunde.
Dođe mi da idem igrat Path of Exile i vratim se za 2 mjeseca, ali ne nadam se nešto previše već. Jade Harvester je od najboljeg i najzabavnijeg builda u igri postao sprdačina.
Autor BladeRy Pregled postova
Ajde ajde, pet WDovi su još dobro prošli u odnosu na DoT WDove
Staro 14.05.2014., 17:34   #7581
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
Autor MAGARAC Pregled postova
To je Blizzard.
Nego, čini se meni da su se dečki iz Blizza malo syebali kad su radili osnovu igre, pa im sad za svaku promjenu treba previše vremena + što svakom promjenom stvari odu na gore.
Dobro, dodali su nakon PREVIŠE vremena da konačno dps na oružju dobro računa kod elemental dmg, ali ovo ostalo većinom nije dobro promišljeno.
Meni smeta fist of heavens nerf/buff, koji je za mene više nerf nego buff. Umjesto da je crusader s tim skillom ostao tata mata za range ubijanje monster packova, sad ima manje AoE dpsa, a single target DPS su mu nedovoljno povećali.
Ako su maknuli da proca sa scourge demonic furyem, onda kompletno prelazim na nerfani thorns build.
I tako, bar nam čine život dinamičnijim
Spoiler alert!
Staro 14.05.2014., 17:39   #7582
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,344
Čitam komentare ljudi na us forumu, monka ubili, archon wiza ubili, wda dot ubili, a petove sjebali.
Moram probat malo crusadera ali vrlo vjerojatno da ću napravit isto kaj i ti, opet prestat igrat diablo jer kreteni sustavno uništavaju sve što imalo vrijedi.
I da lag za ulazak u inventory nemoram ni spomenut...
Istina, dinamično tražim novu igru
žmnpp
Staro 14.05.2014., 18:42   #7583
BladeRy
BladeRy's Avatar
Postovi: 2,000
A bas, sve sta je bilo zabavno, nerfaju da bude kao balansirano a usput zabava ode kvragu.
Barem su popravili enchanting.... LINKY
Proklete debilcine dabili debilcine. Kad su napravili 2.0.5 jesu interno sta testirali? Il se sve svelo samo na jel radi installer? Je. Salji vani jebes bugove.
A Buljo, ako trazis igru za igrat, posudim ti ja svoj WoT acc pa mi malo unlockaj tenkova Tu me isto jebu, al im bar nisam platio.
Staro 14.05.2014., 18:49   #7584
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,344
Imam wot i mislim da bum se malo vratio na njega, nisam igrao od rosa. Mogli bi otic tamo i odjebat diablo bar do sljedeceg patcha.
žmnpp
Staro 14.05.2014., 18:57   #7585
BladeRy
BladeRy's Avatar
Postovi: 2,000
Ma znam da imas svoj acc, nego sam hintao da grindas moj
Staro 15.05.2014., 01:53   #7586
osspaljeni
Silence
osspaljeni's Avatar
Postovi: 671
Pa i nije tako strašno, obzirom da imam Carnevil i da su Fetishi uglavnom iza mene...
Nego je li netko naletio do sada na Cow Rift?
10 kratkih nivoa samo krave kao neprijatelji, čak je i Rift Guardian krava
Staro 15.05.2014., 07:34   #7587
ehohr
ehohr's Avatar
Postovi: 348
A jebiga jesam vam lipo reka da nema smisla igrati tog WDa naviknes na OP i onda dode Hammer i objasni kako se balansiraju stvari
Igras sta ti je fun ( ako to uopce vise i postoji ) i skupljas 1% bolji item od onog sta sad imas. Meni je D3 bio najbolji kad sam igro WOTB thrive on chaos build, pucala mi je kifla za iteme bilo mi je bas gust ubijat monstere ali i to je blizzard popravio.
A sto se tice path of exile, cisto sumnjam da ce bit nesto bolje, ako posvetit isto vremena ko za D3 toj igri, sve ce doci na istu kiflu.
Idem malo vidjet sta su napravili s crusaderom i taj buff s legendary dropovima ali tako i tako u zadnje vrijeme sam opet na doti, back to the roots.
ehohr je offline   Reply With Quote
Staro 15.05.2014., 14:20   #7588
Snowrider
Snowrider's Avatar
Lokacija: Lika
Postovi: 864
Legendary Drop Chance Buff radi super, Rift T3 u 5 min palo 7 leg itema,i 3 leg plana. 😄
Snowrider je offline   Reply With Quote
Staro 15.05.2014., 15:02   #7589
fedaykin
Datum registracije: Mar 2012
Lokacija: BJ
Postovi: 57
Autor Daky007 Pregled postova
Ili ne radi 7h odigrano više manje u komadu, 2 seta, blackthorne i wailing host i 3 lega a sve riftovi na t4 i t5 i pokoji bountiji. Long live the.... i još nerfaju/smrdaju pol toga, Ali radije bih da prestane padat al' kad padne da to bude nešto sa stilom jer ovako nula bodova t6 ili nek' pada ko kiša tak da mogu kraftat do iznemoglosti a ne ovako. Šteta što ne streamam, ljudi bi se smilovali pa bi barem netko nešto donirao :P
Ali vidim da ekipa dobiva setove od Kadale, Vyr, Firebird ali Jade i Zuni slabo dolaze ili se ekipa ne hvail baš. Kod mene nakon 2000 shardova ništa, nije neka cifra ali nisam ni farmao lvl 1 t6. 2-3 lega je premalo za toliko shardova.
Nego, jel igra netko monka? I ako da, kak' ide na t5 i t6 ?
fedaykin je offline   Reply With Quote
Staro 15.05.2014., 16:08   #7590
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,856
jucer. imam skrinshotove pa stavim kad doma dodem
Spoiler alert!
