Staro 06.05.2014., 18:05   #961
_saiko
system kaiser
Postovi: 194
Pa ima ekipa optiku pa nek se netko izjasni
Sumnjam da su politiku mijenjali (a i da jesu onda bi i adsl ista pravila imao).
Ne govorim o statici nego malo humanijem lease timeu odnosno duljem trajanju sesije.
Evo B.Net drzi par dana IP, a njemacki pandan bneta i po par tjedana.
<FLEET>
MBO: Gigabyte GA-X58A-UD7 (rev. 2.0)
CPU: Intel Core i7-950 @ 3.2 GHz
Chipset: Intel X58
RAM: 6 x 4 GB DDR3-1600 (PC3-12800)
VGA: HD4850
HDD(OS): OCZ Vertex3 120GB
HDD(local storage): WD WD2002FAEX 2TB, 2x Seagate 500GB (RAID0@IRST/ICH10R)
ODD: Optiarc (?)
PSU: Silverstone SST-ST60F-P Corsair VX450
Display: Samsung Syncmaster 930BF @ 1280 x 1024
Display2: Panasonic TC-P55VT60 @ 1920x1080
Other: eSata dock
OS: Windows 7 Ultimate x64
Input:
Logitech MX1000 + Logitech UltraX cordless
Model: HP Z420
CPU: Intel Xeon E5-1650 6x core @ 3.2 GHz
Chipset: Intel Sandy Bridge-E
RAM: 4 x 16 GB DDR3-1600 (PC3-12800)
VGA: Nvidia
HDD(OS): Seagate ST500DM002 500GB
HDD(local storage): 2x WD WD5000AAKX (RAID1@C600 SAS/SATA ctrl)
Display: 2x HP LA2205wg 22" @ 1680 x 1050
OS: Windows 7 Enterprise x64
Model: HP Elitebook 8570
CPU: Intel i5 3360M
Chipset: Intel Ivy Bridge
RAM: 2 x 8 GB DDR3-800 (PC3-12800)
VGA: Intel HD4000
HDD: Samsung SSD 850Pro 512GB
ODD: DVD+/-RW
Display: 15.4" (1366 x 768)
Other: Fingerprint reader
Input:
Logitech V500 cordless
MBO: GA-P35-DS3P (rev. 2.0)
CPU: Intel C2Q Q6600 @ 2.4 GHz
RAM: 4 x 2 GB DDR2-800 @ 533 MHz
VGA: ATI Rage 3D @ PCI
HDD(OS): Seagate ST380815AS 80GB / Seagate ST3500418AS 500GB
HDD(storage01): 2x WD RE WD4000FYYZ 4TB (RAID10,f2@mdadm)
HDD(storage02): WDC WD20EARX-00P 2TB
HDD(storage_cctv): Seagate ST3250824AS 250GB
ODD: NEC DVD-RW ND-4551A
PSU: Corsair GS800
Display: -
LAN: Intel 82571EB @2x1Gbps LACP
Controllers: RS232 Oxford Semiconductor Ltd OXuPCI952
OS: Linux x64 (Ubuntu 14.04 LTS)
MBO: HP ProLiant DL120 G7
CPU: Intel Xeon E3-1220 @ 4x 3.10GHz
Chipset: Intel i875P-ICH5
RAM: 4 x 4096 MB DDR3-667 (PC3-10600)
HDD1: 2x MB2000EBUCF HUA723020ALA640 2TB 7200RPM (RAID1@P410)
Display: -
LAN: 82574L @ 1000Mbps FD
OS: Linux x86_64 (Ubuntu 14.04 LTS)
MBO: ASRock 4Core1333-FullHD
CPU: Intel Core 2 Duo E84000 @ 3.0 GHz
Chipset: ATI RS600+SB600
RAM: 1 x 512 MB DDR2-800
VGA: -
HDD: Seagate 500GB
ODD: DVD-RW
PSU: Corsair VX450(?)
Display: Panasonic TH-50PY800
LAN: @1Gbps FD
OS: Windows 8.1 Pro x64
Input:
Logitech Cordless DiNovo Edge
MBO: Intel D201GLY2 (ITX)
CPU: Intel Celeron 220 @ 1.2GHz
Chipset: SiS662
RAM: 1 x 512 MB DDR2-533
VGA: Intel
HDD: Sandisk 1GB CF @ CF2IDE
ODD: -
PSU: miniITX type(?)
Display: -
LAN1-Uplink: @1000Mbps FD
LAN2: @100Mbps FD
OS: Mikrotik OS 6.28
Model: Mikrotik RB2011UAS-2HnD
</FLEET>
cat.7 - where crosstalk is not an issue anymore.
_saiko je offline   Reply With Quote
Staro 06.05.2014., 19:06   #962
domis
Lokacija: Hrvatistan
Postovi: 4,164
kakve to veze ima? to nije statički IP i svakak moraš koristiti dyndns ili sličan servis
Staro 06.05.2014., 19:22   #963
_saiko
system kaiser
Postovi: 194
Pa npr downtime na VPN linkovima mi je ovako do 5 minuta na 24h (DNS TTL ...)
Da forsaju reset u duzim periodima to bi bio puno manji postotak
Posteno bi bilo da lease imas dok god renewas, odnosno dok ti je link ziv.
Ako s tvoje strane pukne link, izgubish lease i bok, to nije statika.
To je nesto o cemu se puno govorilo jos od prvih dana ADSL-a u HR tak da ne bih ulazio dalje ...
<FLEET>
Chipset: Intel X58
VGA: HD4850
ODD: Optiarc (?)
Other: eSata dock
Input:
Model: HP Z420
VGA: Nvidia
CPU: Intel i5 3360M
VGA: Intel HD4000
ODD: DVD+/-RW
Input:
PSU: Corsair GS800
Display: -
Display: -
VGA: -
HDD: Seagate 500GB
ODD: DVD-RW
LAN: @1Gbps FD
Input:
Chipset: SiS662
VGA: Intel
ODD: -
Display: -
LAN2: @100Mbps FD
</FLEET>
Staro 06.05.2014., 19:45   #964
aliquiss
Datum registracije: May 2014
Postovi: 2
Pozdrav,
da, i dalje postoji 24-satni reset.
A evo kak to izgleda
Autor _saiko Pregled postova
aliquiss je offline   Reply With Quote
Staro 07.05.2014., 08:52   #965
Amdejac
Amdejac's Avatar
Datum registracije: Jun 2003
Lokacija: Kuća
Postovi: 5,398
Izdvojio si dodatnih 30 kn.
Asus N750JK (Upgrade)
MBO: Asus N750JK
RAM: 2x8 Gb PC3-12800 DDR3
PSU: Asus Li-ion 69486 mWh
OS: Windows 8.1
Monitor: 17,3 LCD (FHD)
Net: Intel AX210 NGW
Net: TP-Link Archer TX55E
PSU: Xilence, Bronze 550W
Monitor: Samsung
VGA: ATI RX570, 4 Gb
HDD: NVMe 1 Tb, Patriot
PSU: Inter-Tech SP750
Monitor: Samsung
Staro 07.05.2014., 14:25   #966
sandokan111
Datum registracije: Dec 2013
Lokacija: ST
Postovi: 950
Vjerojatno zato sto u cjeniku i dalje ima stavka od 600kn mjesecno za fiksni IP?
Pa da,dulji lease ip-a od 24h i static ip su totalno razlicite stvari. Meni lease na vdslu traje po 10 dana ako hocu.
Ali evo vec je pridonio netko s optikom da i dalje imaju tako mali lease time.
sandokan111 je offline   Reply With Quote
Staro 07.05.2014., 14:28   #967
_saiko
system kaiser
Postovi: 194
VDSL-u... ?
Kod koga to?
<FLEET>
Chipset: Intel X58
VGA: HD4850
ODD: Optiarc (?)
Other: eSata dock
Input:
Model: HP Z420
VGA: Nvidia
CPU: Intel i5 3360M
VGA: Intel HD4000
ODD: DVD+/-RW
Input:
PSU: Corsair GS800
Display: -
Display: -
VGA: -
HDD: Seagate 500GB
ODD: DVD-RW
LAN: @1Gbps FD
Input:
Chipset: SiS662
VGA: Intel
ODD: -
Display: -
LAN2: @100Mbps FD
</FLEET>
Staro 07.05.2014., 15:51   #968
aliquiss
Postovi: 2
Autor Amdejac Pregled postova
A šteta je ne nadodat
Staro 07.05.2014., 21:05   #969
sandokan111
Lokacija: ST
Postovi: 950
VDSL-u... ?
Kod koga to?
H1.
Inace, osobno mi ne odgovara dulji lease, ali eto.
Staro 30.05.2014., 19:16   #970
.Delboy
.Delboy's Avatar
Lokacija: hr
Postovi: 755
Od 1.6 na svim ultra max paketima internet promet je FLAT, a ne 250GB blokovi kao do sada.
Staro 30.05.2014., 19:46   #971
Amdejac
Amdejac's Avatar
Lokacija: Kuća
Postovi: 5,398
Gdje si pročitao tu informaciju?
MBO: Asus N750JK
OS: Windows 8.1
Monitor: Samsung
Monitor: Samsung
Staro 31.05.2014., 11:44   #972
zak75
zak75's Avatar
Postovi: 44
jednostavno covjek ima info iz prve ruke
zak75 je offline   Reply With Quote
Staro 31.05.2014., 13:10   #973
Old Iggy
Old Iggy's Avatar
Postovi: 4,888
Autor zak75 Pregled postova
Dok nema pravog infa to je nepouzdano.
Igor Batinic
Staro 31.05.2014., 13:14   #974
_saiko
system kaiser
Postovi: 194
Ma to je neki aprilili al je zakasnio tocno 2 mjeseca
Bilo kako bilo imamo 24h lol
<FLEET>
Chipset: Intel X58
VGA: HD4850
ODD: Optiarc (?)
Other: eSata dock
Input:
Model: HP Z420
VGA: Nvidia
CPU: Intel i5 3360M
VGA: Intel HD4000
ODD: DVD+/-RW
Input:
PSU: Corsair GS800
Display: -
Display: -
VGA: -
HDD: Seagate 500GB
ODD: DVD-RW
LAN: @1Gbps FD
Input:
Chipset: SiS662
VGA: Intel
ODD: -
Display: -
LAN2: @100Mbps FD
</FLEET>
Staro 31.05.2014., 13:23   #975
snorky_vk
snorky_vk's Avatar
Lokacija: u mraku
Postovi: 846
sto meni vrijedi optika i flat kad nema kablova.... nitko ih ne želi provlačiti jer ih onda mora iznajmiti drugom...
snorky_vk je offline   Reply With Quote
Staro 31.05.2014., 13:32   #976
zak75
zak75's Avatar
Postovi: 44
Na vašoj adresi su dostupne usluge s optičkom vezom.
samo nek bude istina :P
Staro 31.05.2014., 14:00   #977
smash3r
smash3r's Avatar
Datum registracije: Feb 2004
Lokacija: 220 km/h a mozda i malo brze,cekam novi auto
Postovi: 180
Ja dobio free optiku od tcome...inace sada sam na optimi ali ako je istina za 1.6 evo mene natrag na tgnoju
smash3r je offline   Reply With Quote
Staro 31.05.2014., 14:11   #978
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Autor .Delboy Pregled postova
Prelazim!
Znam da sam reko vec 1000 puta al ovo je sad savrsenstvo.
Staro 31.05.2014., 20:38   #979
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,845
kakav je ovaj tablet Vivax 8??jel odključan za tele2??
Najveća brzina od 100/20 Mbit/s uključena je svim novim korisnicima 3 mjeseca bez dodatne naknade.
ako dobro čitam za one koji imaju 40/10 Mbit/s za 10 kn više dobiju 100/20 Mbit/s??umjesto 291 plaćate će 301 kunu.
Za samo 10 kn/mj. uz ugovor na 24 mj. surfajte najvećom dostupnom brzinom u ponudi Hrvatskog Telekoma od 100/20 Mbit/s.
Cijena opcije uz ugovor na 12 mj. je 20 kn/mj., a bez ugovorne obveze je 30 kn/mj
Staro 01.06.2014., 01:16   #980
smash3r
smash3r's Avatar
Postovi: 180
Erm ako uzimas tablet u t-comu normalno da nije otkljucan za tele
Staro 01.06.2014., 16:46   #981
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Pozdrav.
Da nisu slucajno u zadnji cas tutnuli ovaj tretnutni popust od desetak kuna umjesto ukidanja paketa?
Ili da se strpimo još.
EDIT:
Zadnje izmijenjeno od: IcyTexx. 01.06.2014. u 17:31.
Staro 02.06.2014., 09:52   #982
kopija
DIY DILETANT
kopija's Avatar
Lokacija: Čistilište
Postovi: 3,461
Autor IcyTexx Pregled postova
Meni se čini da je ovaj potez dokaz da T nema namjeru krenuti u masovno uvođenje optike.
kopija je online   Reply With Quote
Staro 02.06.2014., 11:08   #983
ThaBigJc
ThaBigJc's Avatar
Lokacija: U kući
Postovi: 53
evo i sluzbeno na stranicama
Ultra MAX2 L
INTERNET
PROMOTIVNA PONUDA: Prva 3 mjeseca uključena brzina 100/20 Mbit/s
Brzina nakon 3 mjeseca 40/10 Mbit/s
FLAT (neograničen) internetski promet
https://www.hrvatskitelekom.hr/paketi/ultra-max
i kao sol na ranu...
OPCIJA POVEĆANJA BRZINE NA 100/20 Mbit/s
Cijena opcije uz ugovor na 12 mj. je 20 kn/mj., a bez ugovorne obveze je 30 kn/mj. Opcija je prva 3 mjeseca promotivno uključena svim novim korisnicima bez naknade.
sjest i plakat sto mi nije dostupno
Any sufficiently advanced technology is indistinguishable from magic.
ThaBigJc je offline   Reply With Quote
Staro 02.06.2014., 15:55   #984
antunhr
antunhr's Avatar
Lokacija: Popovec(Sesvete-Zagreb)
Postovi: 552
Da.. sjesti i plakati.. 100mbita za manje od 300kn mislim da je stvarno fer i korektno
antunhr je offline   Reply With Quote
Staro 02.06.2014., 21:26   #985
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,845
čovjek je bio u pravu svezi/glede fleta,meni je optika povučena prije 1 godine ako se sjećam dobro, mislim pitali ako ćemo rekli da pa nek stoji dok se cjene ne normaliziraju,tj za sada.
što se tiče vivax tableta mislio pitat ako t-com šalje kod za odljučavanje na ostale mreže ko što je slao za samsung galaxy mini.
Staro 02.06.2014., 21:34   #986
_saiko
system kaiser
Postovi: 194
Moze li netko u privatnoj kuci, kome je napravljena instalacija, poslikati splicebox na vanjskom zidu kuce?
Zanima me kakvu kutiju koriste tj dimenzije i dal direkt splajsaju svoj zuti kabel (sa zelenim LC konektorom) il je preko pigtailova islo?
<FLEET>
Chipset: Intel X58
VGA: HD4850
ODD: Optiarc (?)
Other: eSata dock
Input:
Model: HP Z420
VGA: Nvidia
CPU: Intel i5 3360M
VGA: Intel HD4000
ODD: DVD+/-RW
Input:
PSU: Corsair GS800
Display: -
Display: -
VGA: -
HDD: Seagate 500GB
ODD: DVD-RW
LAN: @1Gbps FD
Input:
Chipset: SiS662
VGA: Intel
ODD: -
Display: -
LAN2: @100Mbps FD
</FLEET>
Staro 02.06.2014., 22:57   #987
seriouss
Postovi: 5
Šta stavljaju optiku na privatne kuce?
seriouss je offline   Reply With Quote
Staro 03.06.2014., 00:56   #988
Amdejac
Amdejac's Avatar
Lokacija: Kuća
Postovi: 5,398
Autor seriouss Pregled postova
Da. Ja sam u kući na selu i imam već ohoho optiku.
MBO: Asus N750JK
OS: Windows 8.1
Monitor: Samsung
Monitor: Samsung
Staro 03.06.2014., 09:35   #989
microsoft66
microsoft66's Avatar
Datum registracije: Apr 2008
Lokacija: VK
Postovi: 1,252
šta si ti napravio da su ti to dali?
Staro 03.06.2014., 10:21   #990
trouble
našikan pravim haos
Lokacija: u zabrani
Postovi: 2,707
preselio je u mjesto koje ima optiku...simple as that
