#6151 |
Vozi Miškoooo!!!
Lokacija: Svuda okolo / EU
Postovi: 1,404
Ma tako je i meni sinoc bilo, sad sve sljaka, cak iznenadjujuce dobro. Samo modove dodao, nist drugo nisam mjenjao. A sta znaci probuditi se na vrijeme, M4 se probudio 2 sec prekasno, video, a opet nisam vidio kako kupola leti u zrak, a bas imam zelju. |
#6152 |
Does youer dewg byte?
Postovi: 1,941
http://wotreplays.com/site/782077#sa...3-valentine_at Nemreš pobijediti u ovim low tier borbama, da se na guzicu postavim. Jednostavno nejde.
" Have you tried turning it off and on again ? Are you sure it is plugged in ? " ![]() |
#6156 |
Vozi Miškoooo!!!
Postovi: 1,404
#6157 |
Lokacija: Slav. Brod
Postovi: 491
Za ljubitelj ljute macke http://ftr.wot-news.com/ ![]() Ahh WG never fails EDIT: hihihi it never ends Just a quick announcement first: the “Hellcat” bug where the game randomly crashes is not limited to Hellcat – that piece of information was WG EU’s mistake. It can happen with any tank, really. The original WG EU post was already altered with an edit, explaining that it applies to other vehicles as well.
X:: Maus, E-100, T110E5, T57 Heavy Tank, 113, AMX50B, IS4, E-50M, Leopard 1, M48 Patton, 121, G.W. E 100, T92, Obj. 261, JagdPz E-100, WT auf E100, T110E4, T110E3, IX::IS8 VIII:: Lorr. 155 51, AC Mle 48 PREM:IS6, T34, T26E4, Pz. IV Schmalturm, T-25, Ram II, T14, Matilda BP, 105 leFH18B2, Chi-Nu Kai, T15, T2 LT, T1E6, Tetrarac, LTP, T7 Combat Car, Light MK. VIC, Type 97 Te Ke Zadnje izmijenjeno od: Audi45. 17.04.2014. u 20:10. |
#6158 |
Postovi: 1,941
Evo, pala još jedna masterica u low tieru, čovjek se oteli dok postigne nekaj. Zapravo, u ovih par levela, problem je kaj borbe ne traju duže od 5 minuta, tak da je jako teško taktizirati bilo kaj. http://wotreplays.com/site/782663#pr...n123-marder_ii
#6159 |
Datum registracije: Apr 2003
Lokacija: RI
Postovi: 4,917
Evo jedne s tigrom,kolega iz platoona dobro posluzio mrtav ![]() http://wotreplays.com/site/782851#sa...w_vib_tiger_ii
#6160 | |
Vozi Miškoooo!!!
Postovi: 1,404
Sta netraju 5 minuta ![]() Istrazim zadnji top na IS3 jucer, krenem prije sat vremena da ga vozam malo, nebi pobjedio i na trepavicama da igram, x2 ostavljam za sutra s njim, nemam vise zivaca pokusavati 5000dmg s IS3 i izgubimo, kad me nece onda stvarno nece: video Citiraj:
dobro pa je poginuo, da nije nebi se ti dobro proveo .. ![]() dobar je taj Marder, a i dobra ti ona fora kad si zapucao na svoga dolje kod kuce, tj. pored njega, on se pomako i odma spoto neprijatelja... treba to zapamtiti Zadnje izmijenjeno od: JozicA. 17.04.2014. u 22:38. |
#6161 |
Postovi: 1,941
#6162 |
Datum registracije: Jan 2010
Postovi: 668
Da li netko ima kakav mod pack s nuznim stvarima xvm mini mapa jimbo izvjestaj nakon bitke, probao sam OMC ali ne stima mi dobro |
#6164 | ||
Postovi: 491
evo ti ga na mod pack
X:: Maus, E-100, T110E5, T57 Heavy Tank, 113, AMX50B, IS4, E-50M, Leopard 1, M48 Patton, 121, G.W. E 100, T92, Obj. 261, JagdPz E-100, WT auf E100, T110E4, T110E3, IX::IS8 VIII:: Lorr. 155 51, AC Mle 48 PREM:IS6, T34, T26E4, Pz. IV Schmalturm, T-25, Ram II, T14, Matilda BP, 105 leFH18B2, Chi-Nu Kai, T15, T2 LT, T1E6, Tetrarac, LTP, T7 Combat Car, Light MK. VIC, Type 97 Te Ke |
#6166 |
Postovi: 1,941
S time da zasad u Chr1sovom modu ne radi minimapa u potpunosti, ne postoje statistike nakon borbi, i crashala mi se igra (iako je riješen onaj bug nakon kaj krepaš pa želiš dalje gledati iz nekog drugog tenka). Carousel mod još nije stavljen isto.
#6168 |
Lokacija: RI
Postovi: 4,917
http://adf.ly/k4obg Radi savršeno,ja sam još malo personalizirao aslainov mod,dodao neke sitnice...mogu uploadat svoj res_mods kad se vratim s posla. Za XVM se treba ići tu http://www.modxvm.com/en/ i login,onda activate statistics i to je to...AKO ste to već napravili a i dalje ne radi,a u međuvremenu mjenjali modove,treba ići na http://www.modxvm.com/en/ opet i login,te onda DEACTIVATE stats pa ACTIVATE stats...
#6169 |
al se nekad dobro jelo...
Postovi: 3,312
Pro tip za one koji planiraju zavrsiti misiju za T2 light ovaj mjesec: Kupite ga ovaj vikend u pola cijene (375 golda). Kad ispunite misiju, refundirat ce vam se 750 golda koliko je puna cijena (misiju morate dovrsiti kad nije na popustu, tj. kad zavrsi vikend specijal!). Uzivajte u 375 golda bonusa!
Zenfone 9 | Zephyrus M16 | HP Chromebook X2 | Tesla Model Y LR |
#6170 |
Datum registracije: Jun 2003
Lokacija: Kuća
Postovi: 5,400
Pojedinačno sam sve porihtao. Nišan, minimap, , xvm, zbrajanje nakon bitke, ali neznam kako posložit ono zbrajanje bitaka preko dana da znam da li sam u plusu ili minusu. Šta trebam skinut?
#6172 | |
Lokacija: Daruvar
Postovi: 1,743
http://forum.worldoftanks.eu/index.p...session-stats/ Kvantiteta prije kvalitete.
#6173 |
Postovi: 4,358
Meni igra nakon zadnje zakrpe radi loše. Imam dovoljno FPS-a 30-60 i ping 30-50 ali lag je užasan. Granate kasne, tenkovi se pomiču trzavo, zvuk kasni ili zašteka. Ne koristim nikave modove. Već sam imao jednom sličan problem nakon nadogradnje i trajao je skroz do iduće nadogradnje. Definitivno mi slijedi pauza od ove igre. |
#6174 | |
Lokacija: RI
Postovi: 4,917
#6176 | |
Vozi Miškoooo!!!
Postovi: 1,404
#6177 |
Postovi: 668
prijasnji problem s OMC je bio da nisam cuo zvukove kada me pogadjaju (naravno u rijetkim slucajevima kada bi me netko slucajno pogodio heh) sad sam u njemu stavio neki drugi demage recived i sljaka, ulogirao sam na xvm sajt i sada u igri imam xvm radi. Ne rusi mi se igra sve radi, sad sam odigrao 2 partije s typom59 i zaradio preko 250k novcica, jedna je bila 1. class a druga ace (s njim sam do sada dobio vec 5 ace znacki) ![]() |
#6178 | |
Lokacija: RI
Postovi: 4,917
#6179 |
Postovi: 668
Pardon nije preko 250k nego tocno toliko ![]() ![]() |
#6180 | |
Lokacija: Daruvar
Postovi: 1,743
