Staro 24.02.2014., 10:28   #1141
junkieee
junkieee's Avatar
Postovi: 986
A nije igra tako kriticna, za kojih 10 mjeseci ce rijesiti sve bug-ove, pa ti bude zao sto si prodao acc
Što se tiče graficke je neki Radeon onda da.. Vise mi nisu nvidije drage, a ove zadnje dvije sto sam od tebe uzeo su vec negdje dalje nasle nekog vlasnika
Ako ti kakav r9 270 uleti to uzimam sigurno .
Staro 24.02.2014., 17:17   #1142
Blue_Fatal1ty
Blue_Fatal1ty's Avatar
Lokacija: Čazma
Postovi: 1,728
Autor junkieee Pregled postova
taj moj harware je ko neka pce k**va
Trenutno sam u fazi rasprodaje, a nabavka će kasnije tokom godine.
Taman će popravit BF4... (vječiti optimist...)
Staro 24.02.2014., 22:02   #1143
Core2Duo22
Mucki provokator
Core2Duo22's Avatar
Postovi: 299
Autor Blue_Fatal1ty Pregled postova
Core2Duo22 je offline   Reply With Quote
Staro 25.02.2014., 20:05   #1144
Neo-ST
Buying Bitcoin
Neo-ST's Avatar
Postovi: 8,226
Skida mi 400mb update, zna li tko šta je ?
Staro 25.02.2014., 20:09   #1145
sinisa1989
Bazinga
sinisa1989's Avatar
Lokacija: Križevci
Postovi: 3,927
Baš sam htio pitati što su sad potrgali.
Idem probati, pa javim.
Možda ima nešto veze s mentlom jer su danas izašli novi driveri.
EDIT:
Ovo je bilo brzo.
http://prntscr.com/2vsim6
Staro 25.02.2014., 20:10   #1146
PointDexter
PointDexter's Avatar
Lokacija: Éire
Postovi: 1,808
alien-smilies-0046.gif von smiliesuche.de
PointDexter je offline   Reply With Quote
Staro 25.02.2014., 21:11   #1147
Dottore
Dottore's Avatar
Postovi: 7,599
Feb 25 PC Game update notes
-Fix for the so called “sound loop crash” issue that caused the game to freeze
-Fix for an issue that sometimes prevented players from shooting while in the gunner position of a vehicle
-Fix for the headshot icon appearing incorrectly at non-headshot deaths, such as suicide or dying of an explosion
-General stability improvements
Mantle
-General stability and performance improvements
-Fix for an issue that caused the sky/fog to be either too bright or too dark when Mantle was used
-Added on-screen video memory utilization statistics with “Render.DrawScreenInfo”
edit.
Ako stvarno popravi sound loop onda sam sretan i hitam u kupnju
HP 845 G8
CPU: AMD Ryzen 7 PRO 5850U
Graphic: AMD Radeon 680M
OS: Windows 11 Pro 24H2
Mice: Logitech MX Master 3S
Lenovo ThinkPad P15v Gen 3
CPU: AMD Ryzen 7 PRO 6850H
RAM: 64GB DDR5
Graphic: AMD Radeon
LCD: 15" IPS @ 3840x2160
Lenovo ThinkPad T14 Gen 3
RAM: 16GB soldered LPDDR4
LCD: 14" IPS @ 1920 x 1200
Mice: Logitech VX Nano
Lenovo X1 Carbon 7th Gen
CPU: Intel Core i7-8665U
RAM: 16GB soldered LPDDR3
Graphic: Intel HD 620
LCD: 14" IPS @ 2560x1440
Lenovo X1 Carbon 10th Gen
CPU: Intel Core i7-1260p
SSD: Sk Hynix 512 GB NVMe M.2
Graphic: Intel Iris Xe
LCD: 14" IPS @ 1920x1200
OS: Windows 11 Pro 23H2
Staro 25.02.2014., 22:00   #1148
PointDexter
Lokacija: Éire
Postovi: 1,808
Soundloopa i crasheva više nema, barem ne na Metrou
Staro 25.02.2014., 23:59   #1149
Rino
[ZA DOM]Rino
Rino's Avatar
Lokacija: Kutina
Postovi: 762
Tako je...imao sam soundloop i crash samo i isključivo na Metro-u, ali sada sve radi OK!
Rino je offline   Reply With Quote
Staro 26.02.2014., 00:22   #1150
Ati freak
aka Striko
Ati freak's Avatar
Lokacija: Krapina - Zagreb
Postovi: 1,735
EDIT: Sry, od svih prozora, napravio reply u krivi
Zadnje izmijenjeno od: Ati freak. 26.02.2014. u 00:43.
Staro 26.02.2014., 14:02   #1151
jurbAs
jurbAs's Avatar
Postovi: 2,582
ja nevjerujem nakon zadnjeg updatea igra ponovo ne radi stop working hahahah pa ovo je smjeh od tima i ekipe koja radi ovu igru. Ajde mi posaljite PM kad dodu novi update da probam
Staro 26.02.2014., 15:24   #1152
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
Autor jurbAs Pregled postova
Obriši u user.cfg-u "UI.DrawEnable 1".
I ako imaš raptr instaliran (amd gaming evolved app), deinstaliraj ga.
Staro 26.02.2014., 22:00   #1153
arnso
arnso's Avatar
Datum registracije: Aug 2011
Postovi: 79
Svake godine izbace novi "polovni" BF i onda 9 mjeseci popravljaju bugove
arnso je offline   Reply With Quote
Staro 26.02.2014., 22:15   #1154
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
Autor arnso Pregled postova
Svake dvije
Staro 28.02.2014., 12:30   #1155
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
http://www.battlefield.com/battlefie...s/naval-strike
Ide spammanje dlc-ima.
Još će na kraju bit točne glasine da novi bf izlazi 11/2014....
Staro 03.03.2014., 11:37   #1156
dejan_08
dejan_08's Avatar
Datum registracije: Jun 2013
Lokacija: Sračinec
Postovi: 24
Evo meni do sad sve super radilo i sad vec par dana ne mogu opce pokrenuti igru.
Prvo mi mi izbaci da trebam 13.12 il novije drivere( ja imam na hd4870 13.9 i do sad nije bilo te poruke) i onda kad opet pokrenem server i kad prođe loading meni se zamrzne slika i u bettelogu mi više ne pokazuje da sam na serveru nego mi piše transitioning.
Obrisao sam onu datoteku--- "UI.DrawEnable 1
Sad ako mi neko može reci u cemu bi mogao biti problem jer da napomene još jednom do sad mi je sve radilo bez problema, a BF3 mogu i dalje normalno pokrenuti?
dejan_08 je offline   Reply With Quote
Staro 03.03.2014., 15:12   #1157
Has
Has's Avatar
Datum registracije: Jan 2014
Lokacija: Austria
Postovi: 99
Pa instaliraj nove drivere i vrati tu obrisanu datoteku. Obrisao si datoteku koja služi za prikaz HUD-a ili user interfacea.
Zadnje izmijenjeno od: Has. 03.03.2014. u 15:17.
Has je offline   Reply With Quote
Staro 03.03.2014., 15:52   #1158
Tvrdi
Sremium
Datum registracije: Oct 2013
Postovi: 2,854
Autor jopis Pregled postova
što bi coca cola rekla, od sada u još manoj boci
Staro 03.03.2014., 18:19   #1159
dejan_08
dejan_08's Avatar
Lokacija: Sračinec
Postovi: 24
O tome se i radi da ne mogu instalirati nove drivere. Kad stavim novije od 13.9
onda imam neke ih 2009 godine ni sam ne znam koja verzija,a za tu datoteku su mi rekli da probam obrisati pa sam i to probal al ništa ne pomaže.
Staro 03.03.2014., 18:31   #1160
jurbAs
jurbAs's Avatar
Postovi: 2,582
fala kolega sada radi uff.
Staro 03.03.2014., 22:45   #1161
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Pa to prakticki vise nije glasina.U pitanju je spin-off na kojem radi Visceral Games.
Mozda u biti samo nosi 'Battlefield' u nazivu, jer se spominje policijska tematika.
Meni to vise vuce na neki hibrid bfa (bf samo zbog naziva)-coda-csa
All you have is your fire and the place you need to reach.
Don't you ever tame your demons, always keep them on a leash.
Alph4Dawg je offline   Reply With Quote
Staro 04.03.2014., 01:28   #1162
Sniper
Community Manager
Sniper's Avatar
Postovi: 312
Jedan dan bilo mi je dosadno i prešao sam single player.
Vidio sam neke detalje na credits
Nakon malo daljnje istrage zapravo njima je jedan kljucan covjek umro, i to 2-3 tjedna pred launch igre, neki developer koji je bio zaduzen za neki segment igre, i sada pokušavaju da to nadoknade zato sto je samo on radio na tome.
Neznam govorim onako kako sam shvatio
Sniper je offline   Reply With Quote
Staro 04.03.2014., 07:55   #1163
Bishop
Postovi: 466
Nemojte me shvatit krivo, smrt kolege je grda stvar, al da umanjivanje radne snage za 1 može na ikakav nacin promjenit nešto, pogotovo služit kao razlog da se opravdaju problemi s bf, e to nije moguce. Jedino da je DICE strukturiran kao firma gdje ima 2 programera i 400 prodajnih zastupnika, onda mozda
Of course he's dead, you can see his brain
Bishop je offline   Reply With Quote
Staro 04.03.2014., 08:19   #1164
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
Autor Sniper Pregled postova
taj je valjda na hitregu radio...
Staro 04.03.2014., 08:22   #1165
Alph4Dawg
Addicted to music.
Alph4Dawg's Avatar
Postovi: 1,782
Ma nije stvar u tome.Pocivao u miru i uvijek je zalosno kada mladi ljudi napuste ovaj svijet, ali ako me sjecanje dobro sluzi; taj covjek je bio zaduzen za singleplayer skriptu ili nesto slicno.
Multiplayer je unistio ostatak DICE studija.
EDIT: Naval Strike je zadnji DLC koji cemo dobiti, a da je izraden od strane DICE-a.DICE se potom prebacuje stopostotno na development Battlefront-a i Mirror's Edge 2, dok ce zadnja dva DLC-a odraditi DICE LA (ex Danger Close), sto bi ujedno znacilo i direktan odgovor DICR-a community-u: Nema podrske za BF4 nakon Naval Strike DLC-a.Sto ste dobili, dobili ste.Sto radi, radi.
Staro 04.03.2014., 08:30   #1166
Blue_Fatal1ty
Lokacija: Čazma
Postovi: 1,728
Autor Alph4Dawg Pregled postova
znači poluproizvod smo dobili i takav će i ostat... Žalosno, a igra fakat ima brdo potencijala...
Staro 04.03.2014., 17:29   #1167
Hellhound
Hellhound's Avatar
Datum registracije: Dec 2010
Lokacija: IRL
Postovi: 264
Na internet slengu : Source or GTFO!!!
Hellhound je offline   Reply With Quote
Staro 04.03.2014., 17:34   #1168
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
Autor Hellhound Pregled postova
http://www.bug.hr/master/vijesti/bf4...ma/130921.aspx
Staro 06.03.2014., 12:03   #1169
jopis
gadget freak
jopis's Avatar
Lokacija: Jasenovac
Postovi: 2,224
Staro 06.03.2014., 12:18   #1170
adaksinjo
adaksinjo's Avatar
Datum registracije: Dec 2011
Lokacija: Virje
Postovi: 590
bitno da su digli max rank
