Ultrapiretik
Postovi: 903
Nvidia GeForce 334.89 WHQL Driver
http://www.nvidia.com/download/drive...px/73216/en-us New in GeForce 334.89 WHQL drivers Performance Boost – Increases performance by up to 19% for GeForce 400/500/600/700 series GPUs in several PC games vs. the previous WHQL-certified drivers (332.21). Results will vary depending on your GPU and system configuration. Here are some examples of measured gains: GeForce GTX 770/780/TITAN/780Ti: Up to 19% in F1 2013 Up to 18% in Sleeping Dogs Up to 16% in Hitman Absolution Up to 15% in Company of Heroes 2 Up to 10% in Assassin’s Creed 3 Up to 7% in BioShock Infinite Up to 6% in Sniper Elite V2 Up to 5% in Total War: Rome 2 SLI Technology Assassin’s Creed Liberation HD – created profile Assassin’s Creed: Freedom Cry – created profile Deus Ex: Human Revolution Director’s Cut – created profile The Crew – created profile 3D Vision Shadow Warrior – rating now “Excellent” The Stanley Parable – rated “Excellent” Walking Dead 2 – rated “Good” World Rally Championship 4 – rated “Good” LEGO Marvel Super Heroes – rated “Good” Far Cry 3 Blood Dragon – rated “Fair” |
1
Postovi: 3,604
Jel ko isprobao ? |
1
Postovi: 3,604
Ja instalirao isto gtx470 nemam nikakvih problema mislim u win i programima, igrice baš ne igram, no možda testiram nešto preko vikenda ovisi kakav ću bit sa vremenom. |
Datum registracije: Aug 2008
Lokacija: Split, Croatia
Postovi: 380
Instalirao drivere(imam GTX 560 ti). Digli se frameovi ovako od oka za 10+ u prosjeku, iako napominjem da sam samo na ovim novim mapama na bf4 probao, trebao bi upaliti neke od ovih ranije koje sam igrao sa starim driverima pa da usporedim kako treba.. ali ko ce nac vremena ![]() |
Postovi: 7,697
Na kojoj rezoluciji? Smanjeni detalji? Igrivo za BF4?
__________________ |
Datum registracije: Aug 2011
Lokacija: Sesvete
Postovi: 129
Evo i ja ih danas instalirao i nisam dosad primjetio nikakve probleme. Probao sam po malo: NFS rivals, Rome 2, Wot, Skyrim i malo duže Dragon Age. Zasad sve ide bez problema pa čak i Firefox. |
Lokacija: home
Postovi: 572
ovaj moj nvidia updater očito spava na djelu , nikakvog prozorčića dole desno...vidim da ih ekipa s 560-icama hvali, da se maknem s 314.22 onda? 10-ak frejmova viška nije za odbacit....
iconography fucks with me...you look great in bloodstains... |
#12 | |
Datum registracije: Aug 2010
Lokacija: daleko, daleko iza 9 sela, daleko sam ja...
Postovi: 260
klikneš check for updates, i onda ti kaže ako ima novih updejetova, ako nema ostaju stari. |
Lokacija: Sesvete
Postovi: 129
Meni se monitor ugasi svaki put kad brisem 314.22 i ne pokazuje sliku do restarta. Jesi li brisao stare prije instalacije novih ili samo preko njih instalirao nove. Probaj ih obrisat u safe modu sa DDU. Ja sam tako obrisao sve od starih drivera i nanovo instalirao samo nove drivere i phisx. I evo otad prvi put sa novim driverima komp radi kako treba. |
Lokacija: Vinkovci - Slavonski Brod
Postovi: 139
Meni se sa zadnjih nekoliko drivera nvidijinih javlja screen tearing u svim mogucim okolnostima, citanje teksta (scrolanje misem), u igrama, vecinom igram WoW sada, ali evo is u South parku takodjer, isto se dogadja i na kompu iz profila, i na laptopu, sa istim drverima. Ne znam jel jos itko ima istih problema i da li ih je znao rijesiti, ili bih trebao natrag na neke starije drivere. |
ODUZIMAM VAM RIJEČ
Postovi: 13,503
ja imam tearing isto, u diablo 3, čak sam stavio vsync, i adaptive u driverima i ne pomaže vratio i betu ispred ovih drivera, isto ništa neznam do čega je
